Linuxcnc Mint 19.3 ISO
- hottabich
- Thank you received: 96
27 Nov 2020 09:45 - 27 Nov 2020 09:58 #190416
by hottabich
Replied by hottabich on topic Linuxcnc Mint 19.3 ISO
Thanks for attention! What do you have in the terminal when you start the designer. I have it as a screenshot from the previous post. I installed like this:
Last edit: 27 Nov 2020 09:58 by hottabich.
The following user(s) said Thank You: Pro_El
- stefan63
- Thank you received: 25
28 Jan 2021 12:21 #196929
by stefan63
Replied by stefan63 on topic Linuxcnc Mint 19.3 ISO
Link is dead
For Mint 19.3 with updated kernel & Official V2.8.0 Linuxcnc:
ISO:
ISO:
- Thank you received: 7501
28 Jan 2021 12:32 #196931
Replied by tommylight on topic Linuxcnc Mint 19.3 ISO
- bevins
- Thank you received: 338
28 Jan 2021 12:58 #196934
by bevins
This works. I just did one yesterday and one this morning.
Replied by bevins on topic Linuxcnc Mint 19.3 ISO
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
- Superuserg
18 Feb 2021 08:43 #199226
by Superuserg
Replied by Superuserg on topic Linuxcnc Mint 19.3 ISO
All the links are DEAD.....Could someone who has a copy of the Linuxcnc Mint 19.3 ISO upload it to google drive and share the link?
- BeagleBrainz
- Visitor
18 Feb 2021 09:01 #199228
by BeagleBrainz
Replied by BeagleBrainz on topic Linuxcnc Mint 19.3 ISO
Not much point in using it, unless you want to compile Linuxcnc every time there is an update.
Best option is to follow Tommy's instructions for Linuxcnc & Mint 19.3, then you can use the official Linuxcnc repos to update.
- Hippy
06 May 2021 17:53 #208140
by Hippy
Replied by Hippy on topic Linuxcnc Mint 19.3 ISO
Ok, just come across this....Sometime ago i installed this ISO ( i think)of Mint 19.2 w/Linuxcnc and plasmac. It currently works good I dont want to break it, so never update anything?
- stefan63
06 May 2021 17:59 #208141
by stefan63
Correct, but it is sometimes hard to resist
If it works as you want only upgrade if you need some new features.
06 May 2021 20:55 #208157
It should be safe to doI do this on all my PC's nearly every day, all use Mint 19.3 as i reverted back from 20.1, it had to much issues with Python 3 and LinuxCNC stuff.
Use at your own risk.
sudo apt-get update
sudo apt-get dist-upgradeUse at your own risk.
- BeagleBrainz
- Visitor
07 May 2021 00:20 #208168
by BeagleBrainz
You’ll have to remove the lines that point to my old repo otherwise apt will have a bitch & moan.
Linuxcnc should be able to be updated from the official repos.
If only my brain chemistry could fixed as easily.
Time to create page: 0.554 seconds
