RPI4 Raspbian 64 bit & LinuxCNC
04 Dec 2020 17:43 #191047
by JackRay
Replied by JackRay on topic RPI4 Raspbian 64 bit & LinuxCNC
The real time is inside ?
thank you
thank you
- snowgoer540
- Thank you received: 746
04 Dec 2020 18:14 #191052
by snowgoer540
Replied by snowgoer540 on topic RPI4 Raspbian 64 bit & LinuxCNC
Yes it’s the preemept-rt kernel. 32 bit though not sure you gain much from 64 bit here.
It’s pretty plug and play I’m running my plasma table on it currently.
04 Dec 2020 19:29 #191059
by JackRay
I install the image, my raspberry starts, but it remains blocked. I have neither access to the mouse nor to the keyboard, nor to the tacrile screen.
Did you have this problem ?
Thank you
Thank you
- snowgoer540
04 Dec 2020 22:46 #191082
by snowgoer540
Nope everything boots and works great right out of the box.
forum.linuxcnc.org/plasmac/40737-plasmac-on-pi4
There’s a video of my table running on a pi
04 Dec 2020 22:58 #191083
Replied by PCW on topic RPI4 Raspbian 64 bit & LinuxCNC
Do you have 8G of RAM? There's a known USB issue with
that version. I think it needs a newer kernel than on the LinuxCNC
image.
image.
05 Dec 2020 06:46 #191108
by JackRay
Hello ,
No I have 2Go of RAM
05 Dec 2020 08:17 #191109
by Mud
Replied by Mud on topic RPI4 Raspbian 64 bit & LinuxCNC
I'm tempted to pick one up - which version do people recommend?
05 Dec 2020 11:15 #191117
by JackRay
I do not know at all .
You think that the difference of "Ram" can have a difference to such an extent that the raspberry remains blocked?
- snowgoer540
05 Dec 2020 11:32 #191118
by snowgoer540
I used the 4gb version
The following user(s) said Thank You: Mud
06 Dec 2020 15:53 - 06 Dec 2020 16:00 #191226
by elovalvo
The boot directory in rt-kernel is probably missing.
run this commands:
mkdir ~/rpi-kernel/rt-kernel
mkdir ~/rpi-kernel/rt-kernel/boot
Replied by elovalvo on topic RPI4 Raspbian 64 bit & LinuxCNC
Hello ,
i built on u amd64 linuxcnc 2.9pre with switch kin branch. It works very well.
Now i want to make it all work on raspberry pi4
I'm trying to install a 64-bit Kernel Preemt-rt on my RaspPi4.
: www.instructables.com/64bit-RT-Kernel-Co...or-Raspberry-Pi-4B-/
works well, until the moment when it no longer happens on a simple file copy.
Can you help me please because I am not very easy in the matter.
thank you so much
run this commands:
Last edit: 06 Dec 2020 16:00 by elovalvo.
Time to create page: 0.230 seconds
