Linuxcnc on Debian Bookworm - a shortcut to master branch
- Topic Author
- Thank you received: 5933
23 Apr 2022 00:43 - 21 Jun 2023 00:56 #240947
This topic is superseeded, use the link below as that is now the best and fastest way to have LinuxCNC up and running.
Thank you.
linuxcnc.org/docs/2.9/html/getting-start...etting-linuxcnc.html
Thank you.
Last edit: 21 Jun 2023 00:56 by tommylight. Reason: edited link
- Topic Author
23 Apr 2022 00:48 - 24 Apr 2022 21:13 #240948
Replied by tommylight on topic Linuxcnc on Debian Bookworm - a shortcut to master branch
--This is the short version of the above:
-Download the Debian non free image from here:-Write image to USB
-Boot from USB
-Installing Debian
-Reboot.
-Open a terminal and type:-reboot
-Just in case you wan to have useful stuff installed:-press Y
-Enjoy.
https://cdimage.debian.org/cdimage/unofficial/non-free/cd-including-firmware/weekly-builds/amd64/iso-dvd/
-Boot from USB
-Installing Debian
-Reboot.
sudo apt update
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev mesaflash
sudo apt install inkscape gimp vlc freecad librecad blender darktable kino kdenlive
-Enjoy.
Last edit: 24 Apr 2022 21:13 by tommylight. Reason: correction
23 Apr 2022 03:42 - 24 Apr 2022 19:26 #240963
Replied by rodw on topic Linuxcnc on Debian Bookworm - a shortcut to master branch
Tommy,
Sorry you are out of date as its now migrated from unstable to testing,
This is on my agenda to test.
You should now use the testing non-free iso which you can download from here so you only have one step.
cdimage.debian.org/cdimage/unofficial/no...weekly-builds/amd64/
On Windows, burn it to a USB stick using rufus
Last time I burnt to a real DVD using imgburn on windows
Then it should be just a matter of doing
sudo apt update
sudo apt install linuxcnc-uspace linuxcnc-uspace mesaflash
One thing I have noticed is that when installing the ISOs sometimes it wants to look on the dvd first.
You can fix that by
sudo apt install nano
sudo nano /etc/apt/sources.list
and then commenting out lines containing cd or dvd by placing a #
Then do sudo apt update again.
To enable auto logon, follow these instructions
www.how2shout.com/linux/enable-or-disabl...-debian-11-bullseye/
Disabling the screen lock can be done from settings/Privacy/Screenlock (click on the region at top right to get to settings)
That sets everything up nicely
Note also that if you do need to get to the latest version of QTplasmac or use some of the very recent features of V 2.9, you still need to build from source. The dependencies are much reduced. I have a screenshare walking through the process here
sudo apt update
You can fix that by
Last edit: 24 Apr 2022 19:26 by rodw.
23 Apr 2022 03:47 #240964
I also forgot to mention is that the debian buildbots a compiling from source so this should be available on about 9 platforms including arm64 which should cover the pi 4 as well.
You can get that here forDebian 12 Testing (Bookworm)
raspi.debian.net/daily-images/
- Topic Author
23 Apr 2022 12:36 #240987
Well, that did not last!
Thank you RodW, i will update the original post.
- Topic Author
23 Apr 2022 12:53 #240989
Rod,
The link you provided has a single image so i added the weekly live builds, there are all the versions there and there is no version number, so no need for updating this guide.
Thank you for everything.
23 Apr 2022 21:15 - 23 Apr 2022 21:17 #241027
Tommy, I think the difference is the live build you used allows you to boot the CD image live without installing on the HDD.
I think the different live versions eg xfce, mate etc refer to the desktop used by the live image.
When you run the installer, you always seem to get an option to choose which desktop to use so I don't think it matters which ISO you start from.
Because the objective is to install linuxcnc, the live image is useless to us.
I may be wrong, but just what I think is going on.
Last edit: 23 Apr 2022 21:17 by rodw.
- Topic Author
23 Apr 2022 22:01 #241031
The default was a trimmed down GNOME DE, for every other choice it will have to download packages making the install much longer and requiring network setup. Also the non graphical and graphical install wizards are hard to use for novices.When you run the installer, you always seem to get an option to choose which desktop to use so I don't think it matters which ISO you start from.
23 Apr 2022 23:54 #241040
Tommy, it would be good if you could amend the title because its no longer considered unstable when it gets to Debian testing aka Bookworm. There are a number of distributions that are based on Debian testing so it can hardly be called "Unstable"!
Should be something like: Linuxcnc on Debian Bookworm - a shortcut to master branch.
- Topic Author
23 Apr 2022 23:58 #241041
Yeah, forgot about that.
Done, thank you.
Done, thank you.
