Linuxcnc on Debian Bookworm - a shortcut to master branch
- my1987toyota
- Thank you received: 271
24 Apr 2022 16:50 #241079
by my1987toyota
Replied by my1987toyota on topic Linuxcnc on Debian Bookworm - a shortcut to master branch
any idea why on my fresh Bullseye install the
sudo apt install linuxcnc-uspace linuxcnc-uspace mesaflash
it keeps coming up with an error of
E: Unable to locate package linuxcnc-uspace
E: Unable to locate package linuxcnc-uspace-dev
E: Unable to locate mesaflash
24 Apr 2022 17:01 #241081
by chris@cnc
Replied by chris@cnc on topic Linuxcnc on Debian Bookworm - a shortcut to master branch
Bullseye is the latest stable Version. But you can switch to testing. Replace in Sources.list bullseye with testing, update and install master. After that you could switch back to bullseye.
- my1987toyota
24 Apr 2022 17:13 - 24 Apr 2022 17:15 #241085
by my1987toyota
Last edit: 24 Apr 2022 17:15 by my1987toyota. Reason: removing an unintended link
- Topic Author
- Thank you received: 5933
24 Apr 2022 17:20 #241088
Replied by tommylight on topic Linuxcnc on Debian Bookworm - a shortcut to master branch
Did you do an update before that?
- my1987toyota
24 Apr 2022 17:28 #241090
by my1987toyota
sudo apt update was the only one I have done so far.
Is their some other update I have missed?
- Topic Author
24 Apr 2022 17:38 #241091
Nope, it should just work ... or Rod has some erroneous information about versions !
I have downloaded the ISO, so i will give it a run later, busy building some 3D printers, and some electronics for the plasma machines.
The following user(s) said Thank You: my1987toyota
- my1987toyota
24 Apr 2022 17:46 #241092
by my1987toyota
have fun.Nope, it should just work ... or Rod has some erroneous information about versions !
- charleyann
- Thank you received: 10
24 Apr 2022 18:13 - 24 Apr 2022 18:15 #241094
by charleyann
Replied by charleyann on topic Linuxcnc on Debian Bookworm - a shortcut to master branch
Deleted
Last edit: 24 Apr 2022 18:15 by charleyann.
- charleyann
24 Apr 2022 18:16 #241095
by charleyann
Looks like the links in the first few posts point to the 11.3 version of Debian
cdimage.debian.org/cdimage/unofficial/no...ds/amd64/iso-hybrid/
cdimage.debian.org/cdimage/unofficial/no...rrent/amd64/iso-dvd/
I went here to get the Bookworm version: cdimage.debian.org/cdimage/unofficial/no...uilds/amd64/iso-dvd/
I found the same thing when following this thread.any idea why on my fresh Bullseye install the
- my1987toyota
24 Apr 2022 18:23 #241096
by my1987toyota
thanks charleyann I will pull a copy of that iso. and give it a try.
Time to create page: 0.148 seconds
