Installing LinuxCNC 2.9 or Master on Linux Mint 21
16 Oct 2022 00:34 #254198
by dberndt
Replied by dberndt on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
Thanks for the help so far Tommy,
I'm a bit lost again. So we've decided the 5.19.0-2-rt-amd64 is the kernel for us and snagged it directly from the debian repo and installed it with gdebi. Wonderful.... But if I need to make/make install something like a wifi driver, I need the kernel source... or something? Which I would get where/how?
Example make error I'm experiencing: make[1]: *** /lib/modules/5.19.0-2-rt-amd64/build: No such file or directory. Stop.
Thanks,
Dave
Thanks,
Dave
- Topic Author
- Thank you received: 5979
16 Oct 2022 01:05 #254199
Replied by tommylight on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
You need the linux header for the same version as linux kernel to be able to compile stuff for the kernel, something like
linux-headers-5.19.0-2-rt-amd64
21 Oct 2022 14:33 #254688
by scotth
Replied by scotth on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
I have been having a problem with a failure to read error, which I thought was a timing problem. I installed all new updates other than Linux kernel 5.15.0-52.58. I have been testing for the last 2 days and NO ERRORS. I don't know which update fixed the issue.
30 Oct 2022 15:43 #255446
by jj80909
Replied by jj80909 on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
Thank you for creating this thread. I have installed Mint21 / LinuxCNC 2.9 successfully and can launch a sim configuration of AXIS or Gmoccapy, but I am having trouble loading any sim configuration using qtvcp. I get the following error when trying to do so:
Debug file information:
Note: Using POSIX realtime
File "/usr/bin/qtvcp", line 12, in <module>
from PyQt5 import QtWidgets, QtCore, QtGui
ModuleNotFoundError: No module named 'PyQt5'
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 153, in apport_excepthook
with os.fdopen(os.open(pr_filename,
FileNotFoundError: [Errno 2] No such file or directory: '/var/crash/_usr_bin_qtvcp.29999.crash'
Original exception was:
link (updating variable file): No such file or directory
2454
2500
Stopping realtime threads
Unloading hal components
I am not fluent in Linux...how do I go about getting the PyQt5 module installed?
Any help is appreciated.
2454
2500
- Topic Author
30 Oct 2022 15:49 #255448
- MarcoGaspar
01 Nov 2022 22:04 #255699
by MarcoGaspar
Replied by MarcoGaspar on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
- Topic Author
02 Nov 2022 00:13 #255718
Links updated.
Heads up, now with version 6.0 of the RT kernel.
- MarcoGaspar
02 Nov 2022 08:00 #255760
by MarcoGaspar
Hello,
I installed the 6.0 rt kernel and when i try to install the linuxcnc deb file it says missing dependencies
- Topic Author
02 Nov 2022 11:48 #255777
Did you do a full upgrade?
- MarcoGaspar
02 Nov 2022 13:41 #255785
by MarcoGaspar
Yes
brand new computer
brand new computer
Time to create page: 0.148 seconds
