Installing LinuxCNC 2.9 or Master on Linux Mint 21
- alangibson
- Thank you received: 23
05 Nov 2023 10:18 - 05 Nov 2023 10:20 #284604
by alangibson
Replied by alangibson on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
Hello all,
I trying to compile the current LinuxCNC 2.9 branch on Linux Mint 21 with non-realtime kernel just to experiment with component development. According to the docs, the following should work. Has anyone encountered this error before?
My system is currently
$ ./autogen.sh
$ ./configure --with-realtime=uspace --disable-gtk2
[snip]
$ make
Makefile:121: *** Makefile.inc must specify RTPREFIX and other variables. Stop.
$ uname -a
Linux oxcart 6.2.0-33-generic #33~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Sep 7 10:33:52 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
$ cat /etc/issue
Linux Mint 21.1 Vera \n \l
Last edit: 05 Nov 2023 10:20 by alangibson.
05 Nov 2023 10:36 #284605
Replied by Aciera on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
Do you actually need the option --disable-gtk2?
05 Nov 2023 11:11 #284608
Replied by rodw on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
I wonder if it is possible to install the new 2.9.1 deb file on Mint from here?
www.linuxcnc.org/dists/bookworm/2.9-rt/
Might be a shortcut
Might be a shortcut
- alangibson
05 Nov 2023 11:37 #284610
by alangibson
Same result without that flag I'm afraid
- alangibson
05 Nov 2023 11:46 #284611
by alangibson
It's pretty close to working actually:
I need to look into how to force it to think those two version or equivalent, or just ignore the dependency.
alangibson@oxcart:~/dev/plasma/linuxcnc$ sudo gdebi linuxcnc_2.9.1_amd64.deb
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
This package is uninstallable
Dependency is not satisfiable: libboost-python1.74.0 (>= 1.74.0+ds1)
alangibson@oxcart:~/dev/plasma/linuxcnc$ sudo apt install libboost-python1.74.0
libboost-python1.74.0 is already the newest version (1.74.0-14ubuntu3).
libboost-python1.74.0 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
- alangibson
05 Nov 2023 12:26 #284614
by alangibson
On second thought, I was being too optimistic. Lack of boost for Python 3.11 will be a problem.
alangibson@oxcart:~/dev/plasma/linuxcnc$ sudo dpkg -i ./linuxcnc_2.9.1_amd64.deb
Selecting previously unselected package linuxcnc.
(Reading database ... 603625 files and directories currently installed.)
Preparing to unpack ./linuxcnc_2.9.1_amd64.deb ...
Unpacking linuxcnc (1:2.9.1) ...
dpkg: dependency problems prevent configuration of linuxcnc:
linuxcnc depends on libboost-python1.74.0 (>= 1.74.0+ds1); however:
Version of libboost-python1.74.0 on system is 1.74.0-14ubuntu3.
linuxcnc depends on libboost-python1.74.0-py311; however:
Package libboost-python1.74.0-py311 is not installed.
linuxcnc depends on libpython3.11 (>= 3.11.0); however:
Package libpython3.11 is not installed.
linuxcnc depends on python3-opengl; however:
Package python3-opengl is not installed.
linuxcnc depends on libgtksourceview-3.0-dev; however:
Package libgtksourceview-3.0-dev is not installed.
linuxcnc depends on tclreadline; however:
Package tclreadline is not installed.
linuxcnc depends on python3-pyqt5.qsci; however:
Package python3-pyqt5.qsci is not installed.
linuxcnc depends on python3-pyqt5.qtopengl; however:
Package python3-pyqt5.qtopengl is not installed.
linuxcnc depends on python3-opencv; however:
Package python3-opencv is not installed.
linuxcnc depends on python3-espeak; however:
Package python3-espeak is not installed.
linuxcnc depends on python3-dbus.mainloop.pyqt5; however:
Package python3-dbus.mainloop.pyqt5 is not installed.
linuxcnc depends on python3-pyqt5.qtwebengine | python3-pyqt5.qtwebkit; however:
Package python3-pyqt5.qtwebengine is not installed.
Package python3-pyqt5.qtwebkit is not installed.
linuxcnc depends on espeak-ng; however:
Package espeak-ng is not installed.
linuxcnc depends on espeak; however:
Package espeak is not installed.
linuxcnc depends on python3-poppler-qt5; however:
Package python3-poppler-qt5 is not installed.
dpkg: error processing package linuxcnc (--install):
- alangibson
05 Nov 2023 13:48 #284620
by alangibson
I settled on just running it in a Docker container for now since all I really need is halcompile for the moment
docker pull debian:bookworm
docker run -it --name=linuxcnc -v $PWD:/linuxcnc debian:bookworm bash
apt update
apt install -y curl
curl -O https://www.linuxcnc.org/dists/bookworm/2.9-uspace/binary-amd64/linuxcnc-uspace_2.9.1_amd64.deb
curl -O https://www.linuxcnc.org/dists/bookworm/2.9-uspace/binary-amd64/linuxcnc-uspace-dev_2.9.1_amd64.deb
curl -O https://www.linuxcnc.org/dists/bookworm/2.9-uspace/binary-amd64/linuxcnc-uspace-dbgsym_2.9.1_amd64.deb
dpkg -i linuxcnc-uspace_2.9.1_amd64.deb linuxcnc-uspace-dev_2.9.1_amd64.deb linuxcnc-uspace-dbgsym_2.9.1_amd64.deb
apt --fix-broken -y install
05 Nov 2023 21:12 #284663
Replied by cmorley on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
I don't think you need --with-realtime.
I'm using mint 21.2 for development - I don't remember doing anything unusual.
Time to create page: 0.216 seconds
