Installing LinuxCNC 2.9 or Master on Linux Mint 21
- Topic Author
- Thank you received: 5983
10 Mar 2023 17:10 #266304
Replied by tommylight on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
Set it and forget it = the official ISO with 2.8.4
For anything else, i still use Mint 21 with 2.9 as i still have the deb.
For the production machines Mint 19.3 with 2.8.4 for PlasmaC
For anyone else on the risky side, use BookWorm with 2.10.
As for stable, i have no issues ever, except with QtPlasmaC still hangs for no reason sometimes, e-stop button does not work ever for quite a while, etc...
The following user(s) said Thank You: bkt, my1987toyota
- my1987toyota
- Thank you received: 279
10 Mar 2023 19:00 - 10 Mar 2023 19:20 #266317
by my1987toyota
Replied by my1987toyota on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
I came across a link for upgrading the python on Mint 21 to 3.11 is that no longer needed for 21.1?
I can't seem to find an answer on line for that one.
www.linuxcapable.com/install-python-3-11-on-linux-mint/
Last edit: 10 Mar 2023 19:20 by my1987toyota.
- Topic Author
10 Mar 2023 19:56 #266327
Already tested with 21.1, does not work.
I did also try every possible way of installing Python on Mint 20, nothing worked. At one point i had 8 versions of python installed. Some issues with paths and linking ...
The link you provided looks quite thorough compared to what i used then, so might just work.
If i get a chance, i will give it a run.
The following user(s) said Thank You: my1987toyota
10 Mar 2023 21:37 #266339
Replied by rodw on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
For ease of use and simple installation, I would go with debian bookworm non free netinstall (CD image)
- my1987toyota
10 Mar 2023 22:21 #266345
by my1987toyota
rod is that the one referenced on JT's site?
11 Mar 2023 00:43 #266362
The non-free firmware is now included in the alpha-2 release and there were warnings telling me not to go to the non-free anymore
cdimage.debian.org/cdimage/bookworm_di_alpha2/amd64/iso-cd/
Debian's hard freeze pending Bookworm becoming the official relaease starts tomorrow so this is pretty solid.
then justpreempt_rt will be installed during this install of 2.9.
Possibly but I just found out this morning its changed on 23 Feb.rod is that the one referenced on JT's site?
then just
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev mesaflash
The following user(s) said Thank You: tommylight, my1987toyota
11 Mar 2023 03:34 #266367
by spumco
Replied by spumco on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
The alpha-2 is what I used in the qtpyvcp-dev VM install - everything just worked. No fuss.
12 Mar 2023 11:20 #266483
Replied by Aciera on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
I have just installed LinuxMint 21.1 'Vera' and compiled the latest 2.10pre (master) on a machine (without a realtime kernel).
After getting errors regarding python when starting linuxcnc i used the link provided by my1987toyota above
(forum.linuxcnc.org/9-installing-linuxcnc...-21?start=140#266317)
to upgrade python from 3.10 to 3.11 using the 'PPA-method' and can confirm that everything seems to be running fine.
I did have to install the openGL module using:
pip install pyopengl
15 Mar 2023 08:21 #266729
by song_gy
Replied by song_gy on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
Hello Aciera, I have tried this method a few times and it still prompts that there is a problem with pyhon. Can you share your specific installation method?
15 Mar 2023 08:41 #266730
Not sure what to say other than that I cloned the git repo for master and installed the missing packages according to the errors using
./configure --with-realtime=uspace --disable-build-documentation-translation --enable-non-distributable
until
make && sudo make setuid
went through with no apparent error but trying to load a config in linuxcnc would fail with errors that seemed so be related to python. Using the linked howto to update python to 3.11 and repeating the build process for linuxcnc gave me a working (simulation) setup.
$sudo update-alternatives --config python
on my machine now reports:
There are 2 choices for the alternative python (providing /usr/bin/python).
Selection Path Priority Status
0 /usr/bin/python3.11 8 auto mode
* 1 /usr/bin/python3.10 7 manual mode
2 /usr/bin/python3.11 8 manual mode
until
Where/ when does this prompt come up?it still prompts that there is a problem with pyhon
Time to create page: 0.343 seconds
