Installing LinuxCNC on Debian 9 - 13
10 Apr 2023 17:32 #268763
by Gubby
Replied by Gubby on topic Installing LinuxCNC on Debian 9 - 13
Do you know if the uspace of 2.9 and 2.10 versions work with Ethernet cards like EC500
10 Apr 2023 18:25 #268771
Support for individual ethernet cards is a matter for the developers of iGh etherlabmaster. I have not had any issues with the cards I have used including on ARM CPU's such as Pi4B and Odroid N2+
Replied by rodw on topic Installing LinuxCNC on Debian 9 - 13
Yes, the linuxcnc-uspace-dev in the bookworm repositories works with ethercat if you follow my sticky in the ethercat sction.Do you know if the uspace of 2.9 and 2.10 versions work with Ethernet cards like EC500
- CtodLinuxcnc
16 Apr 2023 21:29 #269239
by CtodLinuxcnc
Replied by CtodLinuxcnc on topic Installing LinuxCNC on Debian 9 - 13
I had linuc cnc running on deb 11.6 but latency was awful. Could you link more info on the isolcpus? Think that would fix my latency?
Im about to five up and just run it on a pi
16 Apr 2023 21:58 #269242
sudo apt install grub-customizer
sudo grub-customizer
second tab it will have a field that says quiet.
change that to:
2 core PC: quiet isolcpus=1
4 core PC: quiet isolcpus=2,3
Save, exit, reboot
Note if you have an older 2 core machine its well and truly past its useby so you may need to upgrade.
change that to:
Save, exit, reboot
The following user(s) said Thank You: CtodLinuxcnc
- CtodLinuxcnc
16 Apr 2023 22:05 - 16 Apr 2023 22:06 #269243
by CtodLinuxcnc
Thanks a bunch
This is what im using:
Beelink SER5 Mini PC with AMD Ryzen 5 5500U (up to 4.0GHz), 16GB RAM 500GB M.2 Nvme SSD Mini Computer Support 11 pro, Triple Display, WiFi 6, BT5.2, 4K a.co/d/5m7ESmz
I will re-install debian and give that a shot. Hopefully it works, am pretty burnt on installing amd re-installing os heh
Last edit: 16 Apr 2023 22:06 by CtodLinuxcnc.
16 Apr 2023 23:15 #269248
Hmm 6 cores so It will be different and you'll need to experiment
quiet isolcpus=2,3,4,5
quiet isolcpus=3,4,5
quiet isolcpus=4,5
The first one works well on my 6 core ARM PC
I have no Idea about a Ryzen.
quiet isolcpus=4,5
17 Apr 2023 00:50 #269252
Replied by PCW on topic Installing LinuxCNC on Debian 9 - 13
The EC500 is not Ethercat but rather a Mach3 Ethernet board that can work with LinuxCNC
if its stock firmware is replaced with "Remora"
- CtodLinuxcnc
17 Apr 2023 05:38 #269274
by CtodLinuxcnc
I forgot to install the realtime kernel…
After doing that my latency numbers were around 20k nanoseconds! Tried quite 2,3,4,5 and 4,5 but it didn’t seem to have a huge impact so I reverted.
The new kernel did cause freeze issues while shutting down and it ended up being done missing amdgpu drivers. I edited /etc/default/grub with some info i found online for readeon gpus and now I’m around 5k to 10k nanoseconds!
I’m very grateful to you for creating these instructions:
gnipsel.com/linuxcnc/debian-11-emc.html
They were a huge help. Didn’t realize it was you at first. Thanks so much!
17 Apr 2023 07:56 #269282
I've never seen much point in installing on Debian 11 since Linuxcnc found its way into the Debian 12 Repositories. These are my instructions for Debian 12 Bookworm docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
Thats not me. gnipsel is owned by John Thornton (J T on this forum)I’m very grateful to you for creating these instructions:
- CtodLinuxcnc
17 Apr 2023 15:40 #269309
by CtodLinuxcnc
Man. That should be in the announcements (unless i missed it)… spent so much time trying to install 10 and get the firmware for my new machine merged with a bootable iso. I’m new to Linux so it’s been an adventure for me.
Right now 11 is the stable release though right? If I install 12 is that considered the unstable release?
I’m getting used to their release philosophy still… if 12 is bookworm does that mean it will be in the next stable 12 release?
Your linked directions look great. I noticed the bit about skipping root. When i tired adding a root password with 11 it seemed to “forget” what i entered because it did not accept it and i had to reinstall. One because i though it was mean and must have hit a key by accident, twice when i triple checked and made sure I entered what i thought i entered and it still didn’t work. Lol.
Also thanks for the correction, JT you are awesome.
Time to create page: 0.156 seconds
