Compiling LinuxCNC
10 Nov 2022 04:56 #256318
by daiman444
Compiling LinuxCNC was created by daiman444
Hi everyone. attempting to compile 2.9 with any instructions results in an error:
Where can I get this file? it is neither in the download directory nor on the github repository itself
dh_installdocs --doc-main-package=linuxcnc-uspace --package=linuxcnc-doc-de
install -d debian/linuxcnc-doc-de/usr/share/doc/linuxcnc-doc-de
dh_installdocs: error: Cannot find (any matches for) "usr/share/doc/linuxcnc/LinuxCNC_Developer_de.pdf" (tried in ., debian/tmp)
make[1]: *** [debian/rules:108: override_dh_installdocs-indep] Error 255
make[1]: exit directory «/home/ddd/linuxcnc-dev»
make: *** [debian/rules:38: binary] Ошибка 2
dpkg-buildpackage: Error: fakeroot debian/rules binary subprocess returned exit status 2
- Thank you received: 5959
10 Nov 2022 09:01 #256327
Replied by tommylight on topic Compiling LinuxCNC
Try compiling with no docs/documents, it seems the German is missing.
10 Nov 2022 09:09 #256329
by daiman444
Replied by daiman444 on topic Compiling LinuxCNC
thanks for the hint. I had this idea, but I haven't figured out how to do it yet.Try compiling with no docs/documents, it seems the German is missing.
10 Nov 2022 09:27 #256333
Add --nodocs or --no-docs to the end of the build line.
It should be here somewhere
www.google.com/search?q=compile+nodocs+s...org&aqs=heirloom-srp..
Sorry, but on the phone.
The following user(s) said Thank You: daiman444
10 Nov 2022 09:36 #256336
Replied by rodw on topic Compiling LinuxCNC
Building instructions are here
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
Where it shows how to build the debs in the debian folder, do this instead
Tos skip building the dos
./configure uspace no-docs
10 Nov 2022 09:55 #256338
by daiman444
because I'm a noob, I had to work up the courage to get into the configuration script, but it gave me almost no results. your hint worked!Building instructions are here
./configure uspace no-docs Tos skip building the dos
22 Apr 2023 18:19 #269625
I have "un-sticky" this topic as i see no reason for it to have been set as such.
22 Apr 2023 22:34 #269648
Its good you are looking at relevance Tommy. As time goes on, a lot of the installation stickies are becoming obsolete so could be unstickyed to avoid confusion. Its so dynamic now, I've been keeping my latest techniques in Google Drive docs due to this awful forum editorI have "un-sticky" this topic as i see no reason for it to have been set as such.
22 Apr 2023 23:40 #269652
I always do, or better said, i always try to, a lot.Its good you are looking at relevance Tommy.
Time to create page: 0.396 seconds
