- General
- Installing LinuxCNC
- Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
04 Jan 2023 11:18 - 19 Feb 2023 15:44 #260915
by elovalvo
Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi was created by elovalvo
Tested on Raspberry pi 3B+, Pi 4B, Pi400
1) Download from
www.raspberrypi.com/software/operating-s...spberry-pi-os-legacy
a image of stable legacy version of Raspberry Pi OS Buster
and install to an SD card (with Raspberry Pi Imager or similar)
2) Update OS
3) Install the realtime kernel (5.15.65-rt49)
As reported in github.com/kdoren/linux/releases
4) Optimizing kernel (gnipsel.com/linuxcnc/rpi4-11-emc.html)
Add 'isolcpus=1,2,3 idle=poll' to the end of the string then press Ctrl x, y, Enter
Logout and Reboot
5) Install LinuxCNC
Boot the Pi and open a terminal
Add the LinuxCNC Archive Signing Key to your apt keyring
Add the apt repository:
(linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel)
Update the package list from linuxcnc.org
The image is downloadable at this link:
linucnc-2.8.4-buster_armhf_rt.zip
1) Download from
2) Update OS
sudo apt update
sudo apt upgrade
sudo su
cd /tmp
wget https://github.com/kdoren/linux/releases/download/rpi_5.15.65-rt49/linux-image-5.15.65-rt49-v7l+_5.15.65-1_armhf.deb
apt install ./linux-image-5.15.65-rt49-v7l+_5.15.65-1_armhf.deb
KERN=5.15.65-rt49-v7l+
mkdir -p /boot/$KERN/o/
cp -d /usr/lib/linux-image-$KERN/overlays/* /boot/$KERN/o/
cp -dr /usr/lib/linux-image-$KERN/* /boot/$KERN/
[[ -d /usr/lib/linux-image-$KERN/broadcom ]] && cp -d /usr/lib/linux-image-$KERN/broadcom/* /boot/$KERN/
touch /boot/$KERN/o/README
mv /boot/vmlinuz-$KERN /boot/$KERN/
mv /boot/initrd.img-$KERN /boot/$KERN/
mv /boot/System.map-$KERN /boot/$KERN/
cp /boot/config-$KERN /boot/$KERN/
cp /boot/cmdline.txt /boot/$KERN/
cat >> /boot/config.txt << EOF
[all]
kernel=vmlinuz-$KERN
# initramfs initrd.img-$KERN
os_prefix=$KERN/
overlay_prefix=o/$(if [[ "$KERN" =~ 'v8' ]]; then echo -e "\narm_64bit=1"; fi)
[all]
EOF
sudo nano /boot/$KERN/cmdline.txt
Logout and Reboot
5) Install LinuxCNC
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com --recv-key 3cb9fd148f374fef
echo deb http://linuxcnc.org/ buster base 2.8-rtpreempt | sudo tee /etc/apt/sources.list.d/linuxcnc.list
echo deb-src http://linuxcnc.org/ buster base 2.8-rtpreempt | sudo tee -a /etc/apt/sources.list.d/linuxcnc.list
sudo apt-get update
sudo apt-get install linuxcnc-uspace linuxcnc-uspace-dev
Last edit: 19 Feb 2023 15:44 by elovalvo. Reason: The editor of the forum makes bad jokes...
07 Jan 2023 13:44 - 07 Feb 2023 13:23 #261162
by TimGow
Replied by TimGow on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
elovalvo
Thank you for your procedure for installing LinuxCNC for Pi 3B+.
I had to make a small change to make the final 'sudo apt-get update' work:
edited /etc/apt/sources.list.d/linuxcnc.list
changedAll your work here is much appreciated.
Tim
changed
deb linuxcnc.org/ buster base 2.8-rtpreempt
to
Tim
Last edit: 07 Feb 2023 13:23 by JT. Reason: add code tags
The following user(s) said Thank You: elovalvo
07 Jan 2023 13:47 #261163
by TimGow
ah, the formatting here; it was the http:// that I added
05 Feb 2023 18:33 #263764
by 3DPandME
Replied by 3DPandME on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
when I follow these intructions these lines fail and if skipped the pi when getting to the rebooting stage gets stuck at the rainbow screen (new pi4)
-d /usr/lib/linux-image-$KERN/broadcom && cp -d /usr/lib/linux-image-$KERN/broadcom/* /boot/$KERN/
06 Feb 2023 06:56 - 06 Feb 2023 06:57 #263801
by elovalvo
Replied by elovalvo on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
I think you forgot to define the KERN environment variable with the command:
before the command
before the command
Last edit: 06 Feb 2023 06:57 by elovalvo.
07 Feb 2023 12:55 - 07 Feb 2023 13:11 #263924
by JT
Replied by JT on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
Is there something missing from these steps? I get an error invalid option -- 'd'
JT
JT
Last edit: 07 Feb 2023 13:11 by JT.
07 Feb 2023 13:13 - 07 Feb 2023 13:24 #263926
by JT
Also the first part of this line is a link? Ah you need to add code tags...
JT
JT
Last edit: 07 Feb 2023 13:24 by JT.
07 Feb 2023 13:26 #263929
Replied by rodw on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
Have you guys tried these?
raspi.debian.net/daily-images/
If you go bookworm, preempt_rt is packaged and so is linuxcnc.
This is a headless install and leaves you with root access only no pw
so to get a graphical environment you can (no sudo cos you are root)
apt install tasksel
tasksel
select a graphical environment
xfce?
reboot.
Its been a while since i've done this. I know at one stage vtk was missing and I compiled it but I suspect its been added.
There is a good video on youtube with a lady that goes through it step by step on bullseye (not the preempt_rt stuff)
apt install tasksel
tasksel
xfce?
reboot.
07 Feb 2023 13:50 #263932
by JT
Looks like the forum changed your commands because you didn't use code tags
I think this is the correct command.
JT
cp -dr /usr/lib/linux-image-$KERN/* /boot/$KERN/ [[ -d /usr/lib/linux-image-$KERN/broadcom ]]
JT
07 Feb 2023 13:55 #263934
by JT
tasksel seems to do nothing and is already installed... you do have to login as root
JT
JT
- General
Time to create page: 0.374 seconds
