- General
- Installing LinuxCNC
- Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
15 Dec 2023 08:12 #288199
Replied by rodw on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
Have you updated your firmware using the rpi imager?
15 Dec 2023 16:05 #288227
by elovalvo
drive.google.com/file/d/102X3o4uYb6QLkgT...uKe/view?usp=sharing
user: pi
pwd: raspberry
Replied by elovalvo on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
You can try this version, which I've verified works on both the Raspberry Pi4 and the 400no luck with that 2.9.1
It prints a few lines of text in the upper left, then the HDMI signal dies and the monitor goes to sleep. It's not booted and not responsive to keyboard
Both RPI4s I have, burned with RPi imager and "no" to customizations
user: pi
pwd: raspberry
17 Dec 2023 06:11 #288378
by dannym
Replied by dannym on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
OK, I have something else going on, but I can't figure out what.
I've got 2 RPi4B here, 2x new 64GB Sandisks from Amazon, and one older one that put a LinuxCNC image on about a year ago, which booted some text but said "this board requires newer software" and kept repeating that. I'm using HDMI0
The old card still booted to "this board requires newer software".
But I made up a card for the regular RPi OS 64 bit. That did NOT boot either! OK... so...
Power supply? changed to two other power supplies, including my Dell laptop USB-C supply. No diff.
PC? That would make some sense, but I reprogrammed the card on a different PC. No diff.
Bad SDHC card? That we're dealing with 3 different cards acting the same makes that implausible.
There's clearly a problem here if I can't boot a regular image. But as far as I can tell I've ruled out everything but the monitor.
17 Dec 2023 07:15 #288380
by cornholio
Replied by cornholio on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
Did you look into upgrading the RPi firmware\bootloader ?
17 Dec 2023 08:53 #288382
by dannym
Aw crap, it IS the monitor. Well, HDMI cable
- General
Time to create page: 0.257 seconds
