- General
- Installing LinuxCNC
- Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
07 Feb 2023 14:50 #263941
Replied by rodw on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
I followed this a couple of years ago and it workedtasksel seems to do nothing and is already installed... you do have to login as root
JT
07 Feb 2023 14:52 #263942
And what Seb said in the mail list back in september:
This is awesome!
I tried the "2022-08-08" Bookworm image for Raspberry Pi 4. The image
is for the arm64 architecture. Everything seems to work fine on a
Raspberry Pi 4B, including wifi, GUI, and the serial console.
After `apt-get install linuxcnc-uspace linux-image-rt-arm64` and a
little bit of tweaking, I'm now getting latencies around 150 µs, which
is not as good as the Raspbian Buster armhf image at linuxcnc.org (~70
µs latency) but probably acceptable.
It's neat that there are several easy(-ish), usable options for LinuxCNC
on Raspberry Pi now.
This is awesome!
07 Feb 2023 15:58 #263953
by elovalvo
In fact the editor of the forum makes bad jokes...
The commands are those shown here:
github.com/kdoren/linux/wiki/Installatio...ge-(Raspberry-Pi-OS)
Replied by elovalvo on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
Also the first part of this line is a link? Ah you need to add code tags...
-d /usr/lib/linux-image-$KERN/broadcom && cp -d /usr/lib/linux-image-$KERN/broadcom/* /boot/$KERN/
JT
mkdir -p /boot/$KERN/o/
cp -d /usr/lib/linux-image-$KERN/overlays/* /boot/$KERN/o/
cp -dr /usr/lib/linux-image-$KERN/* /boot/$KERN/
[[ -d /usr/lib/linux-image-$KERN/broadcom ]] && cp -d /usr/lib/linux-image-$KERN/broadcom/* /boot/$KERN/
touch /boot/$KERN/o/README
mv /boot/vmlinuz-$KERN /boot/$KERN/
mv /boot/initrd.img-$KERN /boot/$KERN/
mv /boot/System.map-$KERN /boot/$KERN/
cp /boot/config-$KERN /boot/$KERN/
cat >> /boot/config.txt << EOF
[all]
kernel=vmlinuz-$KERN
# initramfs initrd.img-$KERN
os_prefix=$KERN/
overlay_prefix=o/$(if [[ "$KERN" =~ 'v8' ]]; then echo -e "\narm_64bit=1"; fi)
[all]
EOF
12 Feb 2023 10:13 #264349
by elovalvo
If you are interested I have prepared an experimental image that could be useful:
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=170#264143
The link to download it can be found here
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=180#264347
This is awesome!
19 Feb 2023 15:14 #264808
by DrKnow65
Replied by DrKnow65 on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
I think it would be a good idea to edit the first post to displace the isolcpus instruction to the end after installing LinuxCNC and mesaflash.
I was shocked at just how slow the code was compiling on my Rpi3B+ after doing the same thing on my Rpi4. It then came to me that the isolcpus was handicapping the pi before it was necessary.
06 Aug 2023 20:24 - 07 Aug 2023 21:23 #277157
by TOLP2
Replied by TOLP2 on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
EDIT: it works, I managed to create a bug in my HAL-file considering the stepgen. The error given lead to the wrong conclusion that RT was not working.
Last edit: 07 Aug 2023 21:23 by TOLP2. Reason: Problem solved
04 Sep 2023 12:29 #279819
by hus10
Replied by hus10 on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
HI
i have problem when using gmocappy gui
the linuxcnc freeze when i perform touch off
14 Dec 2023 22:53 #288176
by dannym
Replied by dannym on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
I made an SD card with "Raspberry Pi OS (Legacy) with desktop and recommended software" and tried on two different RPi4B, one 4GB one 8GB.
It shows a splash screen, a text changes rapidly in the lower left corner, then it locks up. The HDMI signal is gone, the monitor goes into standby, and it won't respond to keyboard input
Where do I go from here?
15 Dec 2023 00:31 - 15 Dec 2023 00:34 #288179
by cornholio
Replied by cornholio on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
For RPi 4 use this
www.linuxcnc.org/iso/linuxcnc-2.9.1-bookworm-rpi4.img.xz
Unless of course you have a reason to use 2.8.4
I if you use the raspberry pi imager to write the SD card don't "customise" the image.
After booting you can use menu-config to change some settings. Just be aware the structure of this image isn't exactly the same as the Official RPi images but has been tailored for use with Linuxcnc.
Last edit: 15 Dec 2023 00:34 by cornholio.
15 Dec 2023 07:40 - 15 Dec 2023 07:41 #288193
by dannym
no luck with that 2.9.1
It prints a few lines of text in the upper left, then the HDMI signal dies and the monitor goes to sleep. It's not booted and not responsive to keyboard
Both RPI4s I have, burned with RPi imager and "no" to customizations
Last edit: 15 Dec 2023 07:41 by dannym.
- General
Time to create page: 0.370 seconds
