- Thank you received: 123
Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
- elovalvo
- Topic Author
3 years 10 months ago - 3 years 8 months ago #260915
by elovalvo
Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi was created by elovalvo
Tested on Raspberry pi 3B+, Pi 4B, Pi400
1) Download from
www.raspberrypi.com/software/operating-s...spberry-pi-os-legacy
a image of stable legacy version of Raspberry Pi OS Buster
and install to an SD card (with Raspberry Pi Imager or similar)
2) Update OS
3) Install the realtime kernel (5.15.65-rt49)
As reported in github.com/kdoren/linux/releases
4) Optimizing kernel ( gnipsel.com/linuxcnc/rpi4-11-emc.html )
Add 'isolcpus=1,2,3 idle=poll' to the end of the string then press Ctrl x, y, Enter
Logout and Reboot
5) Install LinuxCNC
Boot the Pi and open a terminal
Add the LinuxCNC Archive Signing Key to your apt keyring
Add the apt repository:
( linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel )
Update the package list from linuxcnc.org
The image is downloadable at this link:
linucnc-2.8.4-buster_armhf_rt.zip
1) Download from
2) Update OS
sudo apt update
sudo apt upgrade
sudo su
cd /tmp
wget https://github.com/kdoren/linux/releases/download/rpi_5.15.65-rt49/linux-image-5.15.65-rt49-v7l+_5.15.65-1_armhf.deb
apt install ./linux-image-5.15.65-rt49-v7l+_5.15.65-1_armhf.deb
KERN=5.15.65-rt49-v7l+
mkdir -p /boot/$KERN/o/
cp -d /usr/lib/linux-image-$KERN/overlays/* /boot/$KERN/o/
cp -dr /usr/lib/linux-image-$KERN/* /boot/$KERN/
[[ -d /usr/lib/linux-image-$KERN/broadcom ]] && cp -d /usr/lib/linux-image-$KERN/broadcom/* /boot/$KERN/
touch /boot/$KERN/o/README
mv /boot/vmlinuz-$KERN /boot/$KERN/
mv /boot/initrd.img-$KERN /boot/$KERN/
mv /boot/System.map-$KERN /boot/$KERN/
cp /boot/config-$KERN /boot/$KERN/
cp /boot/cmdline.txt /boot/$KERN/
cat >> /boot/config.txt << EOF
[all]
kernel=vmlinuz-$KERN
# initramfs initrd.img-$KERN
os_prefix=$KERN/
overlay_prefix=o/$(if [[ "$KERN" =~ 'v8' ]]; then echo -e "\narm_64bit=1"; fi)
[all]
EOF
sudo nano /boot/$KERN/cmdline.txt
Logout and Reboot
5) Install LinuxCNC
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com --recv-key 3cb9fd148f374fef
echo deb http://linuxcnc.org/ buster base 2.8-rtpreempt | sudo tee /etc/apt/sources.list.d/linuxcnc.list
echo deb-src http://linuxcnc.org/ buster base 2.8-rtpreempt | sudo tee -a /etc/apt/sources.list.d/linuxcnc.list
sudo apt-get update
sudo apt-get install linuxcnc-uspace linuxcnc-uspace-dev
Last edit: 3 years 8 months ago by elovalvo. Reason: The editor of the forum makes bad jokes...
The following user(s) said Thank You: tommylight, rodw, TimGow, CarterKraft, JT
- TimGow
3 years 10 months ago - 3 years 9 months ago #261162
by TimGow
Replied by TimGow on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
elovalvo
Thank you for your procedure for installing LinuxCNC for Pi 3B+.
I had to make a small change to make the final 'sudo apt-get update' work:
edited /etc/apt/sources.list.d/linuxcnc.list
changed
All your work here is much appreciated.
Tim
changed
deb linuxcnc.org/ buster base 2.8-rtpreempt
to
Tim
Last edit: 3 years 9 months ago by JT. Reason: add code tags
The following user(s) said Thank You: elovalvo
- TimGow
3 years 10 months ago #261163
by TimGow
ah, the formatting here; it was the http:// that I added
- 3DPandME
3 years 9 months ago #263764
by 3DPandME
Replied by 3DPandME on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
when I follow these intructions these lines fail and if skipped the pi when getting to the rebooting stage gets stuck at the rainbow screen (new pi4)
-d /usr/lib/linux-image-$KERN/broadcom && cp -d /usr/lib/linux-image-$KERN/broadcom/* /boot/$KERN/
- elovalvo
- Topic Author
3 years 9 months ago - 3 years 9 months ago #263801
by elovalvo
Replied by elovalvo on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
I think you forgot to define the KERN environment variable with the command:
before the command
before the command
Last edit: 3 years 9 months ago by elovalvo.
- JT
- Thank you received: 517
3 years 9 months ago - 3 years 9 months ago #263924
by JT
Replied by JT on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
Is there something missing from these steps? I get an error invalid option -- 'd'
JT
JT
- JT
3 years 9 months ago - 3 years 9 months ago #263926
by JT
Also the first part of this line is a link? Ah you need to add code tags...
JT
JT
3 years 9 months ago #263929
Replied by rodw on topic Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
Have you guys tried these?
raspi.debian.net/daily-images/
If you go bookworm, preempt_rt is packaged and so is linuxcnc.
This is a headless install and leaves you with root access only no pw
so to get a graphical environment you can (no sudo cos you are root)
apt install tasksel
tasksel
select a graphical environment
xfce?
reboot.
Its been a while since i've done this. I know at one stage vtk was missing and I compiled it but I suspect its been added.
There is a good video on youtube with a lady that goes through it step by step on bullseye (not the preempt_rt stuff)
apt install tasksel
tasksel
xfce?
reboot.
- JT
3 years 9 months ago #263932
by JT
Looks like the forum changed your commands because you didn't use code tags
I think this is the correct command.
JT
cp -dr /usr/lib/linux-image-$KERN/* /boot/$KERN/ [[ -d /usr/lib/linux-image-$KERN/broadcom ]]
JT
- JT
3 years 9 months ago #263934
by JT
tasksel seems to do nothing and is already installed... you do have to login as root
JT
JT
Time to create page: 0.078 seconds
