Locations of LinuxCNC
10 Jan 2023 12:23 - 10 Jan 2023 12:28 #261437
by JT
Replied by JT on topic Locations of LinuxCNC
I just checked the armf 32bit dev and it's also 268kB so I guess the amd is bigger dunno. Anyway they are uploaded now.
JT
JT
Last edit: 10 Jan 2023 12:28 by JT.
The following user(s) said Thank You: elovalvo
10 Jan 2023 15:17 #261450
by elovalvo
In any case you can also check the .deb file using a program like 7-Zip (www.7-zip.org/) with which you can see the content.
Replied by elovalvo on topic Locations of LinuxCNC
JT
- Thank you received: 5942
10 Jan 2023 15:53 #261459
Replied by tommylight on topic Locations of LinuxCNC
No meed for 7zip, the included archive manager can open deb file, right click and choose open with archive manager.
11 Jan 2023 13:26 #261558
by JT
Yep, I use Gdebi to install debs.
JT
JT
12 Jan 2023 10:31 - 12 Jan 2023 11:21 #261677
by elovalvo
A zip file containing all LinuxCNC 2.8.4 .deb files for buster arm64 is available a this link
linuxcnc-uspace_2.8.4_arm64.zip
The ready-made image is available here:
forum.linuxcnc.org/9-installing-linuxcnc...pi-4?start=70#261676
Last edit: 12 Jan 2023 11:21 by elovalvo.
The following user(s) said Thank You: tommylight, JT
19 Feb 2023 08:04 - 23 Feb 2023 08:46 #264796
by elovalvo
The most updated version of LinuxCNC 2.9 for Bookworm for all architectures are also available at this link:
packages.debian.org/search?keywords=linuxcnc-uspace
ftp.debian.org/debian/pool/main/l/linuxcnc/
The locations of LinuxCNC .deb files (deb is an abbreviation for Debian package) can be somewhat hard to find so here are all that I know of.
linuxcnc.org/dists/
buildbot.linuxcnc.org/dista/
buildbot2.highlab.com/
Last edit: 23 Feb 2023 08:46 by elovalvo.
- echristley
- Thank you received: 21
09 May 2023 16:16 #271037
by echristley
Replied by echristley on topic Locations of LinuxCNC
Is there a decoder ring for all of the codenames?
I've got a Rasp Pi Zero. So, 32bit arm. Right? But, I can't find one of the distros that look like an obvious fit.
10 May 2023 07:59 #271087
by elovalvo
LinuxCNC cannot be installed on Rasp Pi Zero
- RobotMatic
03 Dec 2023 22:15 #287146
by RobotMatic
Replied by RobotMatic on topic Locations of LinuxCNC
Hi.
This Links don´t work !!!
i need Install Linuxcnc 2.10 , where I see the .deb File ?
At the moment these links are available:
(tested on Debian Bookworm)
linuxcnc-uspace_2.10.0~pre0_arm64.deb
linuxcnc-uspace-dev_2.10.0~pre0_arm64.deb
04 Dec 2023 00:19 #287151
buildbot.linuxcnc.org/dists/buster/master-rtpreempt/
It might complain about Python versions, though, i have not tested this in quite a while.
The following user(s) said Thank You: RobotMatic
Time to create page: 0.101 seconds
