Locations of LinuxCNC
- JT
- Thank you received: 616
06 Jan 2023 07:08 - 06 Jan 2023 11:27 #261079
by JT
Locations of LinuxCNC was created by JT
The locations of LinuxCNC .deb files (deb is an abbreviation for Debian package) can be somewhat hard to find so here are all that I know of.
linuxcnc.org/dists/
buildbot.linuxcnc.org/dista/
buildbot2.highlab.com/
Debian 12 and up can use apt to install LinuxCNC
JT
linuxcnc.org/dists/
sudo apt install linuxcnc-uspace
sudo apt install linuxcnc-uspace-devJT
Last edit: 06 Jan 2023 11:27 by JT.
The following user(s) said Thank You: tommylight, elovalvo
- Thank you received: 7504
06 Jan 2023 09:17 #261086
Replied by tommylight on topic Locations of LinuxCNC
buildbot.linuxcnc.org/dists/
This is not the same as
linuxcnc.org/dists/
On the latter , there are entries for BookWorm and BullsEye, but on the Buster folder there are no debs for anything above 2.8.
On the first link there are Buster debs for all versions, and there are no BookWorm and BullsEye folders.
To keep this clean, delete this post.
Thank you.
linuxcnc.org/dists/
Thank you.
- JT
06 Jan 2023 11:29 #261105
by JT
Replied by JT on topic Locations of LinuxCNC
On linuxcnc.org/dists/ I've manually uploaded an armf deb for Rpi 4. Gotta work on arm64 deb next both are for Debian 11.
JT
JT
- JT
06 Jan 2023 11:55 #261109
by JT
We could also put LinuxCNC debs for Linux Mint on linuxcnc.org/dists/ if someone wants to build them and make them available to me.
JT
JT
06 Jan 2023 12:00 - 06 Jan 2023 12:01 #261111
Linux Mint 19.n uses debs from our Buster repo.
Linux Mint 21.n used debs from the official Debian BookWorm/BullsEye repo. Or is it SID?
Skip Mint20.n, as far as you possibly can !
Our debs do not work with Mint 21.n, at least till over a month ago.
Last edit: 06 Jan 2023 12:01 by tommylight. Reason: more info
- elovalvo
- Thank you received: 127
06 Jan 2023 12:10 #261113
by elovalvo
If you want the versions for arm64 I can provide them (i. e. 2.8.4 buster, 2.9.0pre bullseye and 2.10.0pre bookworm) tested on Pi3B+, Pi4B and Pi400
Replied by elovalvo on topic Locations of LinuxCNC
JT
- JT
07 Jan 2023 06:20 #261161
by JT
Where can I download them from?
JT
JT
- elovalvo
08 Jan 2023 04:54 #261251
by elovalvo
At the moment these links are available:
(tested on Debian Bookworm)
linuxcnc-uspace_2.10.0~pre0_arm64.deb
linuxcnc-uspace-dev_2.10.0~pre0_arm64.debĀ
(tested on Debian Bullseye)
linuxcnc-uspace_2.9.0~pre0_arm64.deb
linuxcnc-uspace-dev_2.9.0~pre0_arm64.deb
Tomorrow I will upload those for 2.8.4 (tested on buster)
- JT
08 Jan 2023 07:35 #261261
by JT
Both dev debs are only 246kB in size and I expected at least 1MB or more in size so I think something is wrong with them.
Jt
Jt
- elovalvo
09 Jan 2023 10:44 #261365
by elovalvo
Strange, now I check again.
Perhaps it is due to the fact that the compilation does not include the documentation?
The commands I run are:
debian/configure no-docs
dpkg-checkbuilddeps
debuild -uc -us
However, the debs with the various languages are the same for both the armhf and arm64 version
Jt
dpkg-checkbuilddeps
debuild -uc -us
Time to create page: 0.126 seconds
