about:./configure --with-realtime=uspace
- zq17788959338@gmail.com
12 Sep 2023 05:25 #280523
by zq17788959338@gmail.com
Replied by zq17788959338@gmail.com on topic about:./configure --with-realtime=uspace
嗯,这很有趣。
我安装了python3,这是运行检查您失败的行,我添加了python3位,原始行是[/code][/code][/code][/code]if $PYTHON -c "import gi;gi.require_version('Pango', '1.0');from gi.repository import Pango"; then . [code]python3 -c "import gi;gi.require_version('Pango', '1.0');from gi.repository import Pango" was ok [code]python -c "import gi;gi.require_version('Pango', '1.0');from gi.repository import Pango" failed After linking /usr/bin/ptyhon3 to /usr/bin/python [code]python -c "import gi;gi.require_version('Pango', '1.0');from gi.repository import Pango" was ok What does [code]python --version[/return] ? Does Buster have both python3 & python2.x installed ? yes.I have python2.x &python3.x [attachment=55914]20230912132341.png[/attachment]
12 Sep 2023 06:36 #280525
by rmu
Replied by rmu on topic about:./configure --with-realtime=uspace
Try to capture the complete output of the ./configure command. It seems there are a bunch of other python related missing dependencies (libboost_python missing). You can capture the output into a text file with[*], also there should be a config.log that could give hints to what is failing and how. Before trying again run "make distclean".
[*] stackoverflow.com/questions/818255/what-does-21-mean
./configure --with-realtime=uspace 2>&1 >configure.txt
12 Sep 2023 12:05 - 12 Sep 2023 12:08 #280534
by cornholio
Replied by cornholio on topic about:./configure --with-realtime=uspace
What does
I wouldn't go messing around with python too much as it can play havoc with apt. For anyone listening in which was the last version of Linuxcnc to build against python 2.7 ?
python --version return ?
Last edit: 12 Sep 2023 12:08 by cornholio.
12 Sep 2023 12:21 #280535
Replied by rodw on topic about:./configure --with-realtime=uspace
ooops, I forgot to add a link forum.linuxcnc.org/9-installing-linuxcnc...or-linuxcnc-x86-onlyI would recommend you build linuxcnc on a Bookworm installation.
I built an installer which do it all for you.
This will include linuxcnc 2.9 installed as a deb but that is the whole point of the rip-environment command. It will override the 2.9 settings while that window is opened.
If you do build 2.9 debs, I always first uninstall what is there
sudo apt remove linuxcnc-uspace linuxcnc-uspace-dev
Then reinstall the new ones you built (replace the x's with the full deb name with cut and paste)
sudo dpkg -i linuxcnc-uspacexxxxxx
sudo dpkg -i linuxcnc-uspace-devxxxxxx
- Thank you received: 5959
12 Sep 2023 13:06 #280538
Here is a link to ready made debs, try stretch 2.8 or 2.7, or maybe even Jessie also 2.8 or 2.7.
linuxcnc.org/dists/
Replied by tommylight on topic about:./configure --with-realtime=uspace
Early builds of 2.8.For anyone listening in which was the last version of Linuxcnc to build against python 2.7 ?
linuxcnc.org/dists/
12 Sep 2023 15:07 #280557
by cornholio
Thanks Tommy, but I meant which was the last before the changes were made for Python 3. Not pre built packages but source tree.
12 Sep 2023 15:36 #280562
No idea, rarely build it, i force myself to use ready made stuff so i can make it easier for new users.
Now i have become obsolete since LinuxCNC is in Debian repos!
13 Sep 2023 01:05 #280585
Thank you all. I reinstalled the Debian system yesterday. Rebuild. This problem has disappeared.
13 Sep 2023 01:12 #280586
thank you.This problem has been solved.
13 Sep 2023 05:06 #280596
by cornholio
What version of Debian did you sue ?
Just in case someone else has the same issue.
Time to create page: 0.181 seconds
