Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
18 Sep 2023 11:53 - 24 Oct 2023 00:58 #281067
Debian 12 - 2.9.1 image for the Raspberry Pi 4b/400 was created by rodw
This image is built for the Raspberry Pi 64 bit (Pi 4b/400).
It contains the latest build of LInuxcnc (master 2.10 branch) from source as at 18 September 2023
It also contains the latest kernel 6.1.46 Real time patch released on 17 September 2023.
Thi includes the latest gpiod driver for the pi
drive.google.com/file/d/1IhrrdGRNvsdclVi.../view?usp=drive_link
Its been tested pretty well on another thread,
The installer is here if you want to give it a go.
github.com/rodw-au/rpi-img-builder-lcnc/tree/linuxcnc
Once we have an image to download, the mods may wish to sticky this as it sorely needed.
Last edit: 24 Oct 2023 00:58 by rodw.
The following user(s) said Thank You: s.scarcelli, ckuecker
- Thank you received: 5957
18 Sep 2023 14:25 #281079
Replied by tommylight on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
Not there yet, will sticky it later.
Thank you.
Thank you.
18 Sep 2023 20:45 #281104
Replied by rodw on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
Yes, I went to bed. There now.
Also debs and rt kernel are in sub folder
18 Sep 2023 23:20 #281116
Done.
Thank you.
Thank you.
19 Sep 2023 20:50 #281193
I'm uploading a new version. Note the date and time is in the image file name.
Generally pick the newest
25 Sep 2023 19:50 #281611
by meister
Replied by meister on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
Hi rodw,
is spidev working with your image ?
25 Sep 2023 19:55 #281613
I believe SPI has been tested as working but I have no clue about SPI.
Andy's GPIOD driver was backported to V 2.9 last night so I will revert to building 2.9 from here on as the objective is to have an image that can be released if they ever get 2.9 released.
25 Sep 2023 20:16 #281614
by meister
Works out of the box
many thanks !!!!!!!!!!!
28 Sep 2023 09:31 #281776
by zmrdko
Replied by zmrdko on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
raspberry pi 5 coming soon!
29 Sep 2023 09:21 #281850
by cornholio
Replied by cornholio on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
Knowing how much blood, sweat & tears Rod has put into the project, maybe you'd like to donate a RPi5 so Rod might be able to support it quicker.
Time to create page: 0.160 seconds
