Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
30 Sep 2023 08:18 #281911
by mbondaz
Replied by mbondaz on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
Sorry, what's the password ?
30 Sep 2023 11:32 #281922
User: cnc
Password: cnc
Also, when you run it up please type
sudo menu-config
to change locale, time zone. password and a few other settings
Replied by rodw on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
SorrySorry, what's the password ?
User: cnc
Password: cnc
sudo menu-config
The following user(s) said Thank You: mbondaz
01 Oct 2023 09:09 #281972
by mbondaz
Everything works fine for Debian. Thank you!
But when I want to use Linucnc. in the process to configure Linuxcnc, I can't find the the GPIO drivers in the interfaces or everywhere.
What can I do?
Cordially.
What can I do?
Cordially.
01 Oct 2023 10:34 - 01 Oct 2023 12:30 #281975
Don't ask me, I just built the installer
I think you are supposed to use this linuxcnc.org/docs/2.9/html/drivers/hal_gpio.html
Last edit: 01 Oct 2023 12:30 by rodw.
11 Oct 2023 11:51 #282738
by ruffle
Replied by ruffle on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
Been running this on the bench and it's working fine. Thanks.
My only comment is that I can't see any release notes to see what has changed between the versions.
11 Oct 2023 12:50 #282745
Glad you like it. The changes don't really affect the user. Originally, we built Linuxcnc master branch to get the gpio driver. But that was pushed back into 2.9 branch so that is what we build now as that will be released in the very short term.
Then there was an upgrade to the raspberry kernel which we incorporated. That is meaningless to the user.
Hopefully, the next version will be on the linuxcnc downloads page!
11 Oct 2023 21:19 #282773
by phomann
Replied by phomann on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
Hi Rod,
Thanks for creating the image. Last night I installed it and even managed to change the Linux GUI to Cinnamon. It’s easier for me to navigate with.
Over the weekend I’ll have a crack at configuring it for my Taig Mill.
Cheers
Peter
Cheers
Peter
12 Oct 2023 03:47 #282795
Now you've made it to the dark side, how about becoming a Mesa Distributor Down under? The closest one is in NZ which is not terribly convenient.
Thanks Peter, I'll be keen to hear how you get on.Hi Rod,
Cheers
Peter
21 Oct 2023 00:49 #283403
Please download this version of the Rpi image
drive.google.com/file/d/10lxh9Icf07pw9ki.../view?usp=share_link
This should be the final version that goes into the 2.9.1 release of linuxcnc
Because Andy has built the 2.9.1 debs, we use those instead of building from source and the image size has shrunk to 1.2 Gb!
New in this release are repositories for ethercat including the hal driver.
To install ethercat and the hal driver (I hope):Then follow the sticky in the ethercat section to complete installation
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
I'd love to hear feedback on the ethercat installation. I dopn't have a working pin anymore.
I can't include QTPYVCP repositories as they don't publish debs for the Raspberry Pi.
sudo apt install ethercat-master libethercat-dev linuxcnc-ethercat
23 Oct 2023 17:04 #283617
by glsys
Replied by glsys on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
I tried to download, but it says "File is in owner's trash"
Time to create page: 0.468 seconds
