LinuxCNC on Linux Mint Debian Edition 6
06 Oct 2023 07:11 #282425
by onceloved
Replied by onceloved on topic LinuxCNC on Linux Mint Debian Edition 6
What are the configurations of your computers?
- Topic Author
- Thank you received: 5942
06 Oct 2023 15:18 #282445
Replied by tommylight on topic LinuxCNC on Linux Mint Debian Edition 6
Was that question addressed at me or someone else?
If me, here is some of them
-Dell something 980, installed it yesterday, worked all day with a base period of 50000 while doing other stuff on it
-Lenovo M93, works fine
-HP Z220, tested for two days, works fine
Have to try on:
HP 8300 USDT
HP Z420
Acer Switch 5 tablet
Lenovo IdeaPad Y700 with Nvidia graphic
and maybe on Lenovo ThinkBook G3 and some others,
Not sure when i will have the chance, though and i have other PC's with Ryzen 3600 and 3700X and AMD and Nvidia graphics.
On a personal note, i still do not like some of the Cinnamon's stuff, but i managed to get the temps and loads to show on the panel, so i might just stick with it.
Also, for production machines, i will continue to switch to Debian 12 BookWorm, those use Inkscape and LinuxCNC so all is good there.
Have to try on:
HP 8300 USDT
HP Z420
The following user(s) said Thank You: onceloved
06 Oct 2023 19:11 #282458
by scotth
Replied by scotth on topic LinuxCNC on Linux Mint Debian Edition 6
I have one problem. After install, everything loaded and worked fine. I needed to go back and look at a few things on mint 21.2, swapped drives and mint 21.2 ran fine. The problem is I can't get Linux Mint Debian Edition 6 to boot again. No problem with 21.2. I see the same problem with bookworm. LinuxCNC run's no problems there.
This is the problem I see on the HP 8300.
- Topic Author
06 Oct 2023 22:48 #282475
I switch drives daily and often, sometimes several times a day, never had any issue with booting, but that does not help you, so
-were the two hard drives connected at the same time?
-did you update/upgrade Mint while it was on
-do you have "secure boot" enabled? Disable this, now and always.
if all of those are "no", then check the wiring first and foremost, SATA connectors can be inserted backwards, after braking the little tab that does not take much effort.
Then check the BIOS to see if the drive is enabled, on HP press F11 (not sure) at power on to bring the "boot menu" and see if the hdd/ssd is listed there.
07 Oct 2023 00:00 #282480
by scotth
Tommy,
No, I unplug the other drive while building a system.
No, I did the upgrade with no extra drives on the system.
No secure boot, although I tried with it on also, no joy.
The old 21.2 boots no problem though.
I will look tomorrow on F11. The boss has plans for me tonight.
- Topic Author
08 Oct 2023 22:26 #282568
Had the Dell Optiplex 980 wired to Mesa 7i92 for 2 full days running gcode, works fine, no dropped links or latency issues at all.
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Thank you received: 271
10 Oct 2023 22:19 #282707
by my1987toyota
Replied by my1987toyota on topic LinuxCNC on Linux Mint Debian Edition 6
- Topic Author
10 Oct 2023 22:35 #282708
Off topic:
Toyota, how's the recovery going?
- my1987toyota
10 Oct 2023 22:55 #282710
by my1987toyota
recovering well. My back still gets sore really quick, but I am improving a little more every day.
- my1987toyota
10 Oct 2023 23:00 #282711
by my1987toyota
I can't believe it's already been over a year since the accident.Time flys when your busy.
Time to create page: 0.165 seconds
