LinuxCNC on Linux Mint Debian Edition 6
17 Apr 2024 14:54 #298451
by bkt
Replied by bkt on topic LinuxCNC on Linux Mint Debian Edition 6
acually running my drive is:
And the proble is teh same ... but after these command a couple of time:
than again these modprobe command and restart ...
problem seems disappear and after clean my dmesg file .... it stay clean from 1 hour .... now try to reboot and make a latency trest again ....
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 15
serial: 68:1d:ef:38:f0:48
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.051.02-NAPI duplex=full latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:19 ioport:3000(size=256) memory:80404000-80404fff memory:80400000-80403fff
sudo modprobe -r alx && sudo modprobe alx && systemctl restart NetworkManager
sudo modprobe -r r8169 && sudo modprobe r8169 && sudo systemctl restart
18 Apr 2024 15:18 #298562
by bkt
So I try to upgrade LMDE6 to latest rt-preemp release .... so can see r8168 dmks problem at work ..... dmks log:
realtek - tea - best
DKMS make.log for r8168-8.051.02 for kernel 6.6.13+bpo-amd64 (x86_64)
Thu Apr 18 17:14:23 CEST 2024
make: Entering directory '/usr/src/linux-headers-6.6.13+bpo-amd64'
CC [M] /var/lib/dkms/r8168/8.051.02/build/r8168_n.o
CC [M] /var/lib/dkms/r8168/8.051.02/build/r8168_asf.o
CC [M] /var/lib/dkms/r8168/8.051.02/build/rtl_eeprom.o
CC [M] /var/lib/dkms/r8168/8.051.02/build/rtltool.o
/var/lib/dkms/r8168/8.051.02/build/r8168_n.c: In function ‘r8168_csum_workaround’:
/var/lib/dkms/r8168/8.051.02/build/r8168_n.c:29208:24: error: implicit declaration of function ‘skb_gso_segment’; did you mean ‘skb_gso_reset’? [-Werror=implicit-function-declaration]
29208 | segs = skb_gso_segment(skb, features);
| skb_gso_reset
/var/lib/dkms/r8168/8.051.02/build/r8168_n.c:29208:22: warning: assignment to ‘struct sk_buff *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
cc1: some warnings being treated as errors
make[2]: *** [/usr/src/linux-headers-6.6.13+bpo-common/scripts/Makefile.build:248: /var/lib/dkms/r8168/8.051.02/build/r8168_n.o] Error 1
make[1]: *** [/usr/src/linux-headers-6.6.13+bpo-common/Makefile:1938: /var/lib/dkms/r8168/8.051.02/build] Error 2
make: *** [/usr/src/linux-headers-6.6.13+bpo-common/Makefile:246: __sub-make] Error 2
make: Leaving directory '/usr/src/linux-headers-6.6.13+bpo-amd64'
19 Apr 2024 21:46 #298676
Replied by rodw on topic LinuxCNC on Linux Mint Debian Edition 6
change your compiler parameters so warnings are not treated as errors. There should be a environment variable you can set.
20 Apr 2024 08:40 #298701
by bkt
Really after these error realeck begin to not recognise from SO .... so not work at all. These installation is definitely dead.
Time to create page: 0.121 seconds
