Asrock D1800B-ITX Latency Test 200000
- a.o.moiseev
05 Oct 2023 06:31 #282337
by a.o.moiseev
Asrock D1800B-ITX Latency Test 200000 was created by a.o.moiseev
Hi! Can't beat the delay. I tried everything, and Ubuntu 12.04.5 and the subsequent LinuxCNC 2.8.4 Debian 10 Buster RTAI. Can this board even work through the LPT port?
- a.o.moiseev
05 Oct 2023 16:46 #282381
by a.o.moiseev
Replied by a.o.moiseev on topic Asrock D1800B-ITX Latency Test 200000
In this post forum.linuxcnc.org/9-installing-linuxcnc...ages?start=30#149273, everything is as beautiful as in a fairy tale.. Can anyone suggest Linux Mint 19.2 which one is used ? And which one this RTAI?
- Thank you received: 5945
05 Oct 2023 19:46 #282394
Replied by tommylight on topic Asrock D1800B-ITX Latency Test 200000
Hey, that is my fairy tale!
Try this
linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
Linux Mint 19.2 is almost impossible to use as the required dependencies can not be found on the Debian servers.
Try this
- a.o.moiseev
06 Oct 2023 07:13 #282426
by a.o.moiseev
You were born to make a fairy tale come true! And it works, both out of the box and without the Internet! Thank you very much! There was one caveat, after the first launch I turned on the Latency Test was Base max Jitter:15000 . I crawled through the system, connected the network, opened the browser... and Jitter is a billion ! However, it did not work out to repeat this. There were no more than 15351 during the night.
06 Oct 2023 15:01 #282444
Glad it worked for you.
Thank you for reporting back.
Time to create page: 0.179 seconds
