Startup trouble
If so , I have never seen that error
(a "joint following error" is common with setup issues)
And no, you should never ground any Mesa Step/Dir outputs, this
can damage the driver chips
Is this the actual message? Or has it been translated back from a different language on the machine?"Motor 0 positioning error
Position: relative expected"
(also for motor 1 & 2).
The reason I ask is that I can't see that message in the code (I was looking to see what kind of fault causes that message)
- Thank you received: 5944
As PCW already noted, that board doesn't have STEP- or DIR-. Or do you mean I have to ground it on the Mesa card?You have step and dir pins wired to DB25 on the +step and +dir, but there is nothing to -step and -dir, those should be tied to GND.
Edited the post, i missed the small writing on Mesa port so i assumed they are the drives.
Sorry.
No, sorry. The original message is in German:
The reason I ask is that I can't see that message in the code (I was looking to see what kind of fault causes that message)"Motor 0 positioning error
Motor 0 Positionsfehler
Position: relativ erwartet
The error spells "Positionssfehler" but the correct spelling is "Positionsfehler" with only one "s".
Makes it easier to find.
#: src/emc/motion/control.c:830
#, c-format
msgid "joint %d following error"
msgstr "Motor %d Positionssfehler"
Now I need someone to please tell me what causes the error. Or to be more precise: what did I configure wrong, because you cannot have a following error without a position sensor and I don't have one.
commanded position by more than a preset error limit.
In the case of Mesa hardware, it means that the stepgen position
(feed back position from the step generator) does not match the
commanded position.
This can happen with various setup issues and poor latency on the host PC
Can you post your current hal and ini files?
That would help to discover the issue
Sure - thanks!
So something is different on your system.
Can you launch LinuxCNC from the command line
and post the the precise error message(s) that you get?
(Printed in the console)
That is all from the shell.
markus@lcnc:~/linuxcnc/configs/Janus$ linuxcnc -l > log
Note: Using POSIX realtime
note: MAXV max: 33.333 units/sec 2000.000 units/min
note: LJOG max: 33.333 units/sec 2000.000 units/min
note: LJOG default: 16.667 units/sec 1000.000 units/min
note: jog_order='XYZ'
note: jog_invert=set()
Log:
Also, are you sure about the DB25 pinout? there are a lot of TB6560 modules
with different pinouts (many with different enable inputs)
You could also verify the direction signals with a voltmeter when jogging either way
to make sure there is not a hardware error of some kind
