Startup trouble
04 Nov 2023 21:55 #284572
by poesel
Replied by poesel on topic Startup trouble
So electrically I would take 5V from TB1, route it through TB3 14 & 13 (OUT0+/-) to EN+ on the TB6600 and back from EN- to GND on TB1.
How do I get the Mesa card to switch OUT0 when I move an axis?
And is this worth the effort or just something you live with (with those drivers)?
04 Nov 2023 22:55 #284577
Replied by PCW on topic Startup trouble
Yes, you could do it that way, typically you would enable the drives
with something like motion.motion-enabled
05 Nov 2023 21:17 #284664
by poesel
I guess I'll have to read some more docs until I understand what I have to do for the enable.
The step pulse of 40000 is not a problem?
I need about 80 steps per mm and 33 mm/s max speed. That is from the old grbl config so that should already include the microsteps.
80 x 33 = 2640 steps / s => 378 µsec max time per pulse. If the step pulse setting is at 40000 that's 40 µsec so I should be good, right?
05 Nov 2023 23:52 #284672
Yes, that should be fine even with step length and step space = 40000
The following user(s) said Thank You: poesel
Time to create page: 0.308 seconds
