Update error
05 Feb 2024 01:46 #292467
by bob8020
Replied by bob8020 on topic Update error
After installing iso and doing update/upgrade
bob@cnc:~$ cat /etc/debian_version
12.4
Dunno what it was from the iso install as I didn't know to look in /etc/debian_version.
12.4
- Online
- Thank you received: 5945
05 Feb 2024 02:02 #292471
Replied by tommylight on topic Update error
Cr@p, i did try that, this is what i get on an older version with plenty of updates by now:
bookworm/sid
I get the same on Mint 21.2 so that threw me off.
Thanks for the tip, Phill.
bookworm/sid
05 Feb 2024 02:12 #292473
by phillc54
Replied by phillc54 on topic Update error
I really don't know why it wouldn't be reported in lsb_release, another Debian feature I guess.
- Online
05 Feb 2024 02:23 #292476
This is what Mint returns
I wonder the same, so just chalking it to Debian quirks.I really don't know why it wouldn't be reported in lsb_release, another Debian feature I guess.
lsb_release -a
No LSB modules are available.
Distributor ID: Linuxmint
Description: Linux Mint 21.2
Release: 21.2
Codename: victoria
05 Feb 2024 03:14 #292480
by phillc54
That is much more clever...
05 Mar 2024 01:34 #295179
by pgf
Replied by pgf on topic Update error
I can't quite tell from the above conversation whether this is still an open issue, or still needs field data, but I just downloaded LinuxCNC_2.9.2-amd64.hybrid.iso today, and hit this bug on an amd64 system.
/etc/debian_version contains "12.5", which is different than reported above.
05 Mar 2024 05:12 #295193
by cornholio
Replied by cornholio on topic Update error
No bug, that's just the release of the Debian version used.
05 Mar 2024 11:44 - 05 Mar 2024 11:45 #295214
by pgf
I think it's pretty clear that if I download LinuxCNC_2.9.2-amd64.hybrid.iso from official the link at linuxcnc.org/downloads/ , and the installation fails because unnecessary Raspberry Pi firmware is inoperable on my x86 PC, then it's a bug.
Perhaps it's an unavoidable bug, or very inconvenient to fix. But the release is over 2 months old. Plenty of time for there to be a note on the downloads page with a warning, and the (trivial) fix.
paul
paul
Last edit: 05 Mar 2024 11:45 by pgf.
05 Mar 2024 12:07 #295218
by cornholio
If you look at the thread announcing this release the first post gives clear instructions how to fix this.
I gave up on the official iso the other day as it could not load the firmware for my Ethernet card, even tho when booting to a live session it did. I did also mention it.
As to the raspi firmware that is a bug in the installer from Debian. I don’t know why the issue isn’t mentioned on the download page, but the download also mentions the RPi 5 image supports SPI, which it doesn’t.
So to install the latest Debian version and linuxcnc 2.9.2 on my x86 system I used the Debian netinst image, installed the need kernel manually, used the script mentioned in the docs to install linuxcnc, for less frustrating than trying to use the official image.
Now I’m no slouch in this area, I’ve made my own respin of Mint for Linuxcnc, made my own Raspberry Pi images and messed around with Mesa firmware to run on a couple of Xilinx dev boards. This was absolutely the worst experience trying to install linuxcnc on a machine. It amazes me newbies actually get anywhere.
05 Mar 2024 18:54 #295247
Replied by rodw on topic Update error
I think the issue has come back because while we attempt to supress this behaviour in the installer, we are using a live installer so what is actually installed by debian now is different to when the installer was built due to kernel upgrades and security patches.
Its out of our control. We have told you that already. Complaining about this won't fix it.
The following user(s) said Thank You: pgf
Time to create page: 0.312 seconds
