Latest Official LinuxCNC ISO
- Topic Author
- Thank you received: 5942
07 Jan 2024 02:49 - 05 Feb 2024 01:06 #290032
Latest Official LinuxCNC ISO was created by tommylight
LinuxCNC 2.9.2 Debian 12 Bookworm PREEMPT-RT ISO
www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso
Due to unresolved issues with this ISO from Debian 12, after installing open a terminal and do:
sudo dpkg -P raspi-firmware
sudo apt dist-upgrade
Last edit: 05 Feb 2024 01:06 by tommylight. Reason: more info
The following user(s) said Thank You: deanforbes
07 Jan 2024 02:51 #290033
Replied by rodw on topic Latest Official LinuxCNC ISO
Its probably easier to find from the downloads page
linuxcnc.org/downloads/
- Topic Author
07 Jan 2024 02:53 #290034
Replied by tommylight on topic Latest Official LinuxCNC ISO
Yes it is, but that does not change the fact that probably half of our members wander here first as google is pointing them.
13 Jan 2024 19:29 #290576
by daveyr
Replied by daveyr on topic Latest Official LinuxCNC ISO
As a FYI this seems to have brltty installed in it. This causes problems with ShuttleXpress and also the waveshare RS485 USB adapters.
To remove brltty
sudo apt-get remove brltty
This was from the ISO link above and run as a fresh install.
To remove brltty
13 Jan 2024 22:54 #290595
There must be a bug in the Debian Live installer as we tell it to suspress Britty installation so that instruction must be ignored.
- Topic Author
14 Jan 2024 01:02 #290601
Linux (most distros) will install "brltty" whenever they detect a keyboard with added functionality, like extra buttons or fingerprint reader or smart card reader, etc.
It will not install when a plain keyboard is used.
The following user(s) said Thank You: daveyr
14 Jan 2024 10:37 #290629
by daveyr
Thanks for that Tommy i will go and unplug any extra HID devices next time i have to rebuild.
- my1987toyota
- Thank you received: 271
03 Feb 2024 22:38 #292337
by my1987toyota
Replied by my1987toyota on topic Latest Official LinuxCNC ISO
Just for my own information. they don't make a linuxcnc iso that starts with the Debian Mate version with linuxcnc built in.
I would have to install Debian Bookworm with the Mate desktop then download linuxcnc afterwards. Correct?
- Topic Author
03 Feb 2024 22:45 #292338
You can install the official ISO and then install MATE desktop environment, it is pretty much the same minuscule hassle in both cases.
The following user(s) said Thank You: my1987toyota
03 Feb 2024 23:48 #292341
There are 2 ways to do this. The easiest way might be to use tasksel to select what desktop you want.The other way would be to find the mate package via a debian package search
packages.debian.org/index
I think its
sudo apt install mate-desktop-environment
You should be able to select the desktop you want to use from your logon screen with your cursor in the password, a gear appears at bottom right.
I used XFCE because that is what Linuxcnc has used forever. You can use Mate.Just for my own information. they don't make a linuxcnc iso that starts with the Debian Mate version with linuxcnc built in.
sudo apt install tasksel
sudo tasksel
I think its
Time to create page: 0.103 seconds
