Latest Official LinuxCNC ISO
- MarcoGaspar
26 Feb 2024 11:07 #294499
by MarcoGaspar
Replied by MarcoGaspar on topic Latest Official LinuxCNC ISO
Do you know if the Intel Ethernet Network Adapter I225-T1 works well?
Or what card do you recomend?
- MarcoGaspar
27 Feb 2024 10:07 #294590
by MarcoGaspar
Tryed the steps 35/36/37 but its the same.... installed the Linux Mint Debian Edition 6 with the rt kernel and linuxcnc 2.10 and so far no problem.
What intel card do you suggest?
please try
sudo apt install dkms
sudo apt install r8168-dkms
reboot.
Please refer to point 40 and on in my help document
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
27 Feb 2024 11:00 #294595
Replied by rodw on topic Latest Official LinuxCNC ISO
All the computers I have worked with are small and have ethernet builtin. I've always been able to get them going so can't advise on NICs
When I googled that intel card before, it had issues. I don't know if they are any good or not for latency. Isuspect being intel, they are OK.
The following user(s) said Thank You: MarcoGaspar
03 Mar 2024 04:53 #294977
by cornholio
Replied by cornholio on topic Latest Official LinuxCNC ISO
Complete fail with regards ti loading firmware for RTL8168 nic on my Asrock J3355B-ITX board. Tried both on board & PCIe nics, live version has no issue, installer is unable to get IP via dhcp.
Trying the Debian 12.5 Net installer, working fine.
I'm amazed any newbies actually get anywhere, with these nics.
03 Mar 2024 05:48 #294979
by cornholio
Can confirm netinst 12.5 doesn't install the raspi firmware. If this has been mentioned previously I apologise for being a dill.
- Topic Author
- Thank you received: 5942
03 Mar 2024 10:21 #295000
Replied by tommylight on topic Latest Official LinuxCNC ISO
Raspi issue has been fixed since 12.2 for sure, i have tested it multiple times, 12.0 had the issue, 12.2 and 12.4 did not. Did not test 12.3 and 12.1 but from what i read it was on 12.1 also.
03 Mar 2024 11:45 #295012
If the R8168-dkms driver does not install, you must purge it
sudo apt purge R8168-dkms
I have been able to purge it and reboot using another (unbroken) kernel, get the networking sorted again with the R8169 driver and reinstall the dkms driver on the RT kernel.
03 Mar 2024 11:48 - 03 Mar 2024 11:49 #295013
This is right any net install from 12.1 and above got rid of it but it it seems to be hanging around in the Debian Live installer we use with later versions.
Last edit: 03 Mar 2024 11:49 by rodw.
03 Mar 2024 11:57 - 03 Mar 2024 12:00 #295015
by cornholio
Realised that wasn't in response to my issue with firmware not loading.
Last edit: 03 Mar 2024 12:00 by cornholio.
Time to create page: 0.367 seconds
