- General
- Installing LinuxCNC
- Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
- waleed2024
25 Mar 2024 14:56 - 25 Mar 2024 14:57 #296723
by waleed2024
Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media) was created by waleed2024
Hi;
I downloaded the isoo file LinuxCNC_2.9.2-amd64.hybrid.iso and write it to a usb flash. I ran the installer
every time I reach the step (Detect and mount installatin media) it always faild to continue>
the screen of (Faild to copy file from installation media, retry?) appears
I tried to mount it manually, but the same problem exist
I tried many computers and many USB sticks, the same problem
any suggestions??
any suggestions??
Last edit: 25 Mar 2024 14:57 by waleed2024.
25 Mar 2024 15:12 #296726
Replied by rodw on topic Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
Please download the free Balena Etcher program and use it to create your USB boot image.
That is my method of choice these days and how I tested all of the 2.9.x images before release.
- Thank you received: 5942
25 Mar 2024 17:36 - 25 Mar 2024 17:38 #296748
Replied by tommylight on topic Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
When you get that error, try unplugging the USB, wait 5 seconds, plug it back in, wait 15 seconds then hit retry.
If that fails, try what Rod mentioned, and if that also fails, the USB is faulty or a memory module is in really bad condition and has to be changed as it will fail.
Last edit: 25 Mar 2024 17:38 by tommylight. Reason: more info
- waleed2024
17 Apr 2024 14:57 #298452
by waleed2024
Replied by waleed2024 on topic Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
I tried many types of usb flash memory, the same problem
I tried rufus, Balena Etcher and Win32DiskImager, all are the same
I downloaded an image for debian (debian-12.5.0-amd64-DVD.iso) and burn it to same usb flash and install from usb flash, it installed very well with no problem.
is ther any solution to burn linuxcnc and install it directly???
17 Apr 2024 16:04 #298458
If you already have Debian installed, open a terminal and type:
sudo apt update
sudo apt install linuxcnc-uspace
Done.
That installs LinuxCNC and real time kernel.
sudo apt update
Done.
The following user(s) said Thank You: Mecanix
17 Apr 2024 18:19 #298478
by Mecanix
Replied by Mecanix on topic Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
You should make a sticky out of ^this^, along with the official md5 debian release dwload.If you already have Debian installed, open a terminal and type:
sudo apt update
Done.
- waleed2024
17 Apr 2024 21:04 #298492
by waleed2024
17 Apr 2024 21:14 #298494
For you: is the PC connected to the internet?
That was for me.I didn't understand this: "You should make a sticky out of ^this^, along with the official md5 debian release dwload. "
17 Apr 2024 21:15 - 17 Apr 2024 21:29 #298495
by Mecanix
$ sudo nano /etc/apt/sources.list
$ sudo apt update
$ sudo apt install linuxcnc-uspace
deb http://deb.debian.org/debian bookworm main non-free-firmware
deb-src http://deb.debian.org/debian bookworm main non-free-firmware
deb http://deb.debian.org/debian-security/ bookworm-security main non-free-firmware
deb-src http://deb.debian.org/debian-security/ bookworm-security main non-free-firmware
deb http://deb.debian.org/debian bookworm-updates main non-free-firmware
deb-src http://deb.debian.org/debian bookworm-updates main non-free-firmware
$ sudo apt update
Last edit: 17 Apr 2024 21:29 by Mecanix.
- waleed2024
17 Apr 2024 22:12 #298502
by waleed2024
many thanks
all done
all done
- General
Time to create page: 0.241 seconds
