Linux install problem with 2.9.2 iso
26 Mar 2024 00:40 #296789
by dokwine
Linux install problem with 2.9.2 iso was created by dokwine
This was working for me on this system, but now not so much.
I'd installed 2.9.2 with Dragon a few months back - no drama other than migrating from axis to Dragon (was fine
After a few months away, I found the system would not boot "Reboot and Select proper boot device". There had been some power outages and I tend to leave the (linux) system running so after a few attempts I decided the boot SSD was corrupted and I would need to re-install.
I grabbed the 2.9.2 iso, put it on a usb stick and ran the install. Seemed to go fine but when it came time to reboot I got the same message. The BIOS sees the drive and it is 1st priority. I thought maybe disk is toast, but when I boot the live install from USB, I can see the SSD, open it and everything appears fine; just won't boot. FWIW, when I do the install I select options of 1 partition and use whole disk.
The system is a quad core i7 gigabyte itx board with Mesa 5i25. The disk is a 500GB Samsung 860 EVO. Everything is happy, but it doesn't want to boot from that disk. Could use some suggestions on next steps.
26 Mar 2024 01:09 #296790
by cornholio
Replied by cornholio on topic Linux install problem with 2.9.2 iso
Try another boot disk.
- Thank you received: 5942
26 Mar 2024 11:11 #296806
Replied by tommylight on topic Linux install problem with 2.9.2 iso
In BIOS, disable Secure Boot and enable Legacy mode/support.
"Reboot and select proper device" is a BIOS message, not a hdd/ssd issue except when it fails completely.
26 Mar 2024 17:15 #296825
by dokwine
Replied by dokwine on topic Linux install problem with 2.9.2 iso
Thanks for the suggestions gentlemen. I appreciate as always the willingness to help I find here.
Unfortunately, I had already been down both paths (should have said as much, but the post was already long). Summarizing:
- I had already installed and run the 2.9.2 iso on this system before things went pear-shaped. I confirmed Legacy mode and disabled secure boot. I even tried UEFI. No joy.
- I have tried 2 separate disks - both of which had been booting. Same behavior.
- For grins I tried installing a recent copy of Mint I have been using on other systems. Same behavior.
- Interestingly (to me) when installing mint, it saw the copy of bookworm already on the disk. Again confirms (to me) the installs are going ok.
26 Mar 2024 22:06 #296847
by cornholio
I wouldn’t reflash the bios ATM.
Another thing you could try is install linuxcnc on the disk you want to use in a known working machine, then swap the disk to the machine with the issue. Linux is pretty much agnostic in that regard.
There is also the possibility that the disk port you’re trying to use has an issue due to some power event. So you may have to use a alternative port.
27 Mar 2024 02:02 #296857
by dokwine
Thanks. did try swapping disk ports with no change in behavior. There could be something going on, but when I’m running the live image off the USB, I can read the install disk files so it seems to be working.
running out of ideas, I did flash the bios to the latest (circa 2019 I think). No change. Tried to switch everything over to uefi. Reinstall, no change. Everything back to legacy. Reinstall, no change. This makes 0 sense to me. I’ve never had a problem with an install on any of my machines before.
Can’t help but think I’m somehow still crosswise on the legacy vs UEFI install. I’m going to reset the bios to factory and plug in a new out of the box disk and see if that changes anything. I like the idea of installing on another machine, but most of my systems are now of the “NUC” variety w/o open SATA ports. Maybe I can get a mothballed machine back up…
27 Mar 2024 02:33 #296860
Replied by rodw on topic Linux install problem with 2.9.2 iso
It really sounds like a corrupt boot sector.
The 2.92 ISO (And debian 12.x) correctly handles UEFI and on an i7, may be required.
Using a new SSD sounds the way forward
The following user(s) said Thank You: dokwine
27 Mar 2024 02:37 #296861
by cornholio
That would be a corrupt boot sector over multiple installs & different disks & different installs, the OP did try both Mint & Debian.
27 Mar 2024 02:39 #296863
YEs, fault at the hardware level.
27 Mar 2024 05:24 #296871
by dokwine
Thanks guys. I’ll let you know.
Time to create page: 0.195 seconds
