Linux install problem with 2.9.2 iso
- Thank you received: 5942
27 Mar 2024 11:29 #296882
Replied by tommylight on topic Linux install problem with 2.9.2 iso
Before this gets out of hands, Rod, boot sector is on the drives and he used several, so the only common denominator remains the PC/MB, and that is .... well i did not want to say this before but i do have an Acer Switch 5 that did/does the same thing, it was working 24/7 when after reboot stoped working with missing disk error, tried 2 other NVME disks, same error, can be installed without errors on all, but it just wont boot.
Having a sample of 1 is not a reference, so i refrained from mentioning it.
I resorted to using it with a USB-NVME case externally, it is still on 24/7.
Does the PC have more than one NVME slot? Try the other.
Does it have SATA ports? If possible try a SATA SSD or HDD.
If you have anything with Linux already installed, just plug it in and try to boot.
The following user(s) said Thank You: dokwine
28 Mar 2024 18:40 #297019
by dokwine
Replied by dokwine on topic Linux install problem with 2.9.2 iso
So. Waiting for AMZ to show up with a new drive. Decided to try reset CMOS. Checked config and booted. No change. Re-installed and booted. No change.
There was one last SATA port I could reach but hadn't tried. Booted; No change. Re-installed and booted. No change. Time to move on to other things. While rummaging through my cable pile for some line cord a SATA cable turned up. Why not. Plugged it in, Booted, Debian loaded, all is fine. Re-booted multiple times - all is well.
I was ready to accept that I would be going down the USB-NVME route as tommylight suggested (not pretty, but fine). But: bad cable was the culprit. In fairness (to me) this cable had been re-seated on both ends while I was debugging this (multiple times), nothing had moved since the last boot AND the old cable had worked well enough to install a fresh copy of BW/LCNC - multiple times! The image was fine. I started re-storing my config's and everything on the disk (installed via the "bad" cable) was fine.
Of course then I came to my senses and re-installed from the iso with the new cable anyway. (all in UEFI mode, working great Rod).
So thanks for the support from everyone. I wish I could say I understood how what is essentially a serial cable worked well enough for an install, but not well enough to boot. I'm guessing perhaps error correction/re-try was available for read/write on installation but not available for bios on booting. Perhaps you have insights. In anycase I'm back up - THANK YOU!
Ron
Ron
28 Mar 2024 23:06 #297048
I've had multiple time SATA cables causing all kinds of issues, mostly really slow read/writes to HDD/SSD, but i never had one fail completely, so this is new.
Thank you for reporting back.
Time to create page: 0.132 seconds
