Chinese servo drive SG-AS problem with EtherCAT version startup
15 Apr 2023 12:27 #269101
by Stean
Hello,
LinuxCNC is a great project!
I'm trying to start a Chinese servodrive over the EtherCAT bus (previously I've used the analog version with success these drives have been working hard for 3 years with no problems).
After a many days of trying EtherCAT version, I need and ask for some help and suggestions.
My current state before Linux launch:
~$ ethercat master
Master0
Phase: Idle
Active: no
Slaves: 1
Ethernet devices:
Main: b8:ae:ed:b7:47:18 (attached)
Link: UP
Tx frames: 25700
Tx bytes: 2041896
Rx frames: 25699
Rx bytes: 2041836
Tx errors: 0
Tx frame rate [1/s]: 125 125 122
Tx rate [KByte/s]: 7.3 7.4 7.8
Rx frame rate [1/s]: 125 125 122
Rx rate [KByte/s]: 7.3 7.4 7.8
Common:
Tx frames: 25700
Tx bytes: 2041896
Rx frames: 25699
Rx bytes: 2041836
Lost frames: 0
Loss rate [1/s]: 0 0 0
Frame loss [%]: 0.0 0.0 0.0
Distributed clocks:
Reference clock: Slave 0
DC reference time: 0
Application time: 0
2000-01-01 00:00:00.000000000
~$ ethercat slaves
0 0:0 PREOP + SG-AS EtherCAT(COE) Servo Drives Rev1.0
~$ ethercat slaves -v
=== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x00000bf8
Product code: 0x00000001
Revision number: 0x00010008
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 32 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 3144418126 0 0
1 MII down closed no - - - -
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1800/384, TX: 0x1a00/384
Supported protocols: CoE
General:
Group: Drive
Image name: DRIVE
Order number: SG-ASE
Device name: SG-AS EtherCAT(COE) Servo Drives Rev1.0
CoE details:
Enable SDO: yes
Enable SDO Info: yes
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: no
Flags:
Enable SafeOp: yes
Enable notLRW: no
Current consumption: 0 mA
So EtherCAT and Slave is visible.
~$ sudo dmesg
[ 18.499238] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 18.499406] EtherCAT 0: Link state of ecm0 changed to UP.
[ 18.511309] EtherCAT WARNING 0: 1 datagram TIMED OUT!
[ 19.511206] EtherCAT WARNING 0: 124 datagrams TIMED OUT!
[ 20.511312] EtherCAT WARNING 0: 124 datagrams TIMED OUT!
[ 21.515325] EtherCAT WARNING 0: 123 datagrams TIMED OUT!
[ 22.515330] EtherCAT WARNING 0: 121 datagrams TIMED OUT!
[ 23.515201] EtherCAT WARNING 0: 125 datagrams TIMED OUT!
[ 24.523246] EtherCAT WARNING 0: 117 datagrams TIMED OUT!
[ 25.132276] IPv6: ADDRCONF(NETDEV_UP): enp2s0f0: link is not ready
[ 25.133215] RTL8211B Gigabit Ethernet r8169-200:00: attached PHY driver [RTL8211B Gigabit Ethernet] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[ 25.139207] EtherCAT 0: Link state of ecm0 changed to DOWN.
[ 25.232527] IPv6: ADDRCONF(NETDEV_UP): enp2s0f0: link is not ready
[ 25.233386] r8169 0000:02:00.0 enp2s0f0: Link is Down
[ 26.304994] broken atomic modeset userspace detected, disabling atomic
[ 26.823190] r8169 0000:02:00.0 enp2s0f0: Link is Up - 100Mbps/Full - flow control off
[ 26.823202] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0f0: link becomes ready
[ 26.823224] EtherCAT 0: Link state of ecm0 changed to UP.
[ 26.831198] EtherCAT 0: 1 slave(s) responding on main device.
[ 26.831202] EtherCAT 0: Slave states on main device: INIT.
[ 26.831328] EtherCAT 0: Scanning bus.
[ 26.863969] EtherCAT 0: Bus scanning completed in 32 ms.
[ 26.863971] EtherCAT 0: Using slave 0 as DC reference clock.
[ 26.871213] EtherCAT 0: Slave states on main device: PREOP.
[ 30.106146] EtherCAT ERROR 0-0: SDO information error response while fetching SDO 0x0678!
[ 30.106150] EtherCAT ERROR 0-0: SDO abort message 0x06010000: "Unsupported access to an object".
these last errors not looking good but drive no error.
Now LinuxCNC starting ...
~$ ethercat slaves
0 0:0 OP + SG-AS EtherCAT(COE) Servo Drives Rev1.0
OP + looks very good, but now there is a problem with the drive, reports error 40 (bus communication error)
Drive is still in OP mode and I can read the actual position :
~$ ethercat upload -p 0 -t int32 0x6064 0
0x0016336e 1454958
But when the drive has this error I can`t enable and moving.
LinuxCNC does not show actual position and no value with hal commands,
works only ethercat upload ...
Below some more information after LinuxCNC starting, looks bad ...
~$ sudo dmesg
[ 274.670316] EtherCAT: Requesting master 0...
[ 274.670318] EtherCAT: Successfully requested master 0.
[ 274.670443] EtherCAT 0: Domain0: Logical address 0x00000000, 24 byte, expected working counter 3.
[ 274.670444] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 24 byte, type LRW.
[ 274.670451] EtherCAT 0: Master thread exited.
[ 274.670453] EtherCAT 0: Starting EtherCAT-OP thread.
[ 274.670475] EtherCAT WARNING 0: 76 datagrams TIMED OUT!
[ 274.771154] EtherCAT 0: Slave states on main device: OP.
~$ ethercat master
Master0
Phase: Operation
Active: yes
Slaves: 1
Ethernet devices:
Link: UP
Tx frames: 156809
Tx bytes: 12988464
Rx frames: 156808
Rx bytes: 12988380
Tx errors: 0
Tx frame rate [1/s]: 1000 1000 883
Tx rate [KByte/s]: 83.5 83.5 73.4
Rx frame rate [1/s]: 1000 1000 883
Rx rate [KByte/s]: 83.5 83.5 73.4
Common:
Tx frames: 156809
Tx bytes: 12988464
Rx frames: 156808
Rx bytes: 12988380
Lost frames: 0
Distributed clocks:
DC reference time: 734870317937489000
Application time: 734870438688243819
2023-04-15 10:40:38.688243819
tomasz@debian:~$ ethercat pdos
SM0: PhysAddr 0x1800, DefaultSize 384, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1a00, DefaultSize 384, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1000, DefaultSize 10, ControlRegister 0x24, Enable 1
RxPDO 0x1601 ""
PDO entry 0x607a:00, 32 bit, ""
PDO entry 0x60ff:00, 32 bit, ""
PDO entry 0x6040:00, 16 bit, ""
SM3: PhysAddr 0x1100, DefaultSize 10, ControlRegister 0x00, Enable 1
TxPDO 0x1a01 ""
PDO entry 0x6064:00, 32 bit, ""
PDO entry 0x606c:00, 32 bit, ""
PDO entry 0x6041:00, 16 bit, ""
tomasz@debian:~$ halcmd show pin lcec
Component Pins:
Owner Type Dir Value Name
27 s32 OUT 0 lcec.0.0.actual-position ==> 0-drv-act-pos
27 s32 OUT 0 lcec.0.0.actual-torque
27 s32 OUT 0 lcec.0.0.actual-velocity ==> 0-drv-act-velo
27 u32 IN 0x00000004 lcec.0.0.cia-controlword <== 0-controlword
27 u32 OUT 0x00000000 lcec.0.0.cia-statusword ==> 0-statusword
27 s32 IN 0 lcec.0.0.opmode <== 0-modes-of-operation
27 s32 OUT 0 lcec.0.0.opmode-display ==> 0-opmode-display
27 bit OUT FALSE lcec.0.0.slave-online
27 bit OUT FALSE lcec.0.0.slave-oper
27 bit OUT FALSE lcec.0.0.slave-state-init
27 bit OUT FALSE lcec.0.0.slave-state-op
27 bit OUT FALSE lcec.0.0.slave-state-preop
27 bit OUT FALSE lcec.0.0.slave-state-safeop
27 s32 IN 0 lcec.0.0.target-position <== 0-drv-target-pos
27 s32 IN 0 lcec.0.0.target-velocity <== 0-drv-target-velo
27 bit OUT TRUE lcec.0.all-op
27 bit OUT TRUE lcec.0.link-up
27 s32 OUT 0 lcec.0.read.time
27 u32 OUT 0x00000001 lcec.0.slaves-responding
27 bit OUT FALSE lcec.0.state-init
27 bit OUT TRUE lcec.0.state-op
27 bit OUT FALSE lcec.0.state-preop
27 bit OUT FALSE lcec.0.state-safeop
27 s32 OUT 0 lcec.0.write.time
27 bit OUT TRUE lcec.all-op
24 u32 OUT 0x00000001 lcec.conf.master-count
24 u32 OUT 0x00000001 lcec.conf.slave-count
27 bit OUT TRUE lcec.link-up
27 s32 OUT 6356 lcec.read-all.time
27 u32 OUT 0x00000001 lcec.slaves-responding
27 bit OUT FALSE lcec.state-init
27 bit OUT TRUE lcec.state-op
27 bit OUT FALSE lcec.state-preop
27 bit OUT FALSE lcec.state-safeop
27 s32 OUT 13801 lcec.write-all.time
This EtherCAT drive works with other controls e.g. Beckhoff,
maybe I am doing something wrong ?
Regards,
Tom
ps. link to manual
www.dropbox.com/s/f0qcixoivto9b4o/SG-AS%...%20protocol.pdf?dl=0
~$ ethercat master
Master0
Phase: Idle
Active: no
Slaves: 1
Ethernet devices:
Link: UP
Tx frames: 25700
Tx bytes: 2041896
Rx frames: 25699
Rx bytes: 2041836
Tx errors: 0
Common:
Tx frames: 25700
Tx bytes: 2041896
Rx frames: 25699
Rx bytes: 2041836
Lost frames: 0
Distributed clocks:
Application time: 0
~$ ethercat slaves
Device: Main
State: PREOP
Flag: +
Identity:
DL information:
Mailboxes:
General:
Group: Drive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: yes
Enable notLRW: no
~$ sudo dmesg
~$ ethercat slaves
0x0016336e 1454958
~$ sudo dmesg
~$ ethercat master
Master0
Phase: Operation
Active: yes
Slaves: 1
Ethernet devices:
Link: UP
Tx frames: 156809
Tx bytes: 12988464
Rx frames: 156808
Rx bytes: 12988380
Tx errors: 0
Common:
Tx frames: 156809
Tx bytes: 12988464
Rx frames: 156808
Rx bytes: 12988380
Lost frames: 0
Distributed clocks:
RxPDO 0x1601 ""
TxPDO 0x1a01 ""
Component Pins:
Regards,
Tom
ps. link to manual
15 Apr 2023 17:39 #269133
Replied by rodw on topic Chinese servo drive SG-AS problem with EtherCAT version startup
You have not set pid="0x00000001" in your xml file
Value is taken the from the ethercat slaves command
Try that and report back
The following user(s) said Thank You: Stean
15 Apr 2023 18:45 #269144
by Stean
Replied by Stean on topic Chinese servo drive SG-AS problem with EtherCAT version startup
I tried different settings that's why I deleted it, but when I went back it`s same problem.
<slave idx="0" type="generic" vid="00000bf8" pid="0x00000001" configPdos="true">
LinuxCNC starting then on drive ERROR 40 "bus communication error", LinuxCNC not returns any error.
sudo dmesg
[ 318.112664] EtherCAT: Requesting master 0...
[ 318.112667] EtherCAT: Successfully requested master 0.
[ 318.112806] EtherCAT 0: Domain0: Logical address 0x00000000, 24 byte, expected working counter 3.
[ 318.112807] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 24 byte, type LRW.
[ 318.112814] EtherCAT 0: Master thread exited.
[ 318.112816] EtherCAT 0: Starting EtherCAT-OP thread.
[ 318.112837] EtherCAT WARNING 0: 115 datagrams TIMED OUT!
[ 319.185752] EtherCAT 0: Domain 0: Working counter changed to 3/3.
[ 319.191077] EtherCAT 0: Slave states on main device: OP.
sudo dmesg
15 Apr 2023 19:16 #269148
by Stean
maybe Debug will say more ...
[ 2160.964639] EtherCAT 0: Master debug level set to 1.
[ 2187.443029] EtherCAT: Requesting master 0...
[ 2187.443031] EtherCAT DEBUG 0: IDLE -> OPERATION.
[ 2187.443032] EtherCAT: Successfully requested master 0.
[ 2187.443035] EtherCAT DEBUG 0: ecrt_master_create_domain(master = 0x00000000bab03491)
[ 2187.443036] EtherCAT DEBUG 0: Created domain 0.
[ 2187.443038] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443039] EtherCAT DEBUG 0: Creating slave configuration for 0:0, 0x00000BF8/0x00000001.
[ 2187.443040] EtherCAT DEBUG 0 0:0: Attached slave 0.
[ 2187.443098] EtherCAT DEBUG 0 0:0: ecrt_slave_config_dc(sc = 0x0000000012982850, assign_activate = 0x0300, sync0_cycle = 1000000, sync0_shift = 0, sync1_cycle = 0, sync1_shift = 0
[ 2187.443100] EtherCAT DEBUG 0 0:0: ecrt_slave_config_sync_manager(sc = 0x0000000012982850, sync_index = 2, dir = 1, watchdog_mode = 0)
[ 2187.443102] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_assign_clear(sc = 0x0000000012982850, sync_index = 2)
[ 2187.443104] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_assign_add(sc = 0x0000000012982850, sync_index = 2, pdo_index = 0x1600)
[ 2187.443105] EtherCAT DEBUG 0 0:0: Loading default mapping for PDO 0x1600.
[ 2187.443106] EtherCAT DEBUG 0 0:0: No default mapping found.
[ 2187.443108] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_clear(sc = 0x0000000012982850, pdo_index = 0x1600)
[ 2187.443110] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1600, entry_index = 0x6040, entry_subindex = 0x00, entry_bit_length = 16)
[ 2187.443111] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1600, entry_index = 0x6060, entry_subindex = 0x00, entry_bit_length = 8)
[ 2187.443113] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1600, entry_index = 0x607A, entry_subindex = 0x00, entry_bit_length = 32)
[ 2187.443115] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1600, entry_index = 0x60FF, entry_subindex = 0x00, entry_bit_length = 32)
[ 2187.443116] EtherCAT DEBUG 0 0:0: ecrt_slave_config_sync_manager(sc = 0x0000000012982850, sync_index = 3, dir = 2, watchdog_mode = 0)
[ 2187.443118] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_assign_clear(sc = 0x0000000012982850, sync_index = 3)
[ 2187.443119] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_assign_add(sc = 0x0000000012982850, sync_index = 3, pdo_index = 0x1A00)
[ 2187.443120] EtherCAT DEBUG 0 0:0: Loading default mapping for PDO 0x1A00.
[ 2187.443121] EtherCAT DEBUG 0 0:0: No default mapping found.
[ 2187.443122] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_clear(sc = 0x0000000012982850, pdo_index = 0x1A00)
[ 2187.443124] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x6041, entry_subindex = 0x00, entry_bit_length = 16)
[ 2187.443125] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x6061, entry_subindex = 0x00, entry_bit_length = 8)
[ 2187.443127] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x6064, entry_subindex = 0x00, entry_bit_length = 32)
[ 2187.443129] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x606C, entry_subindex = 0x00, entry_bit_length = 32)
[ 2187.443130] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x6077, entry_subindex = 0x00, entry_bit_length = 16)
[ 2187.443160] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443162] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6040, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443163] EtherCAT DEBUG 0: Domain 0: Added 11 bytes, total 11.
[ 2187.443165] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443167] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6060, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443168] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443170] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x607A, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443171] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443173] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x60FF, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443175] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443177] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6041, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443178] EtherCAT DEBUG 0: Domain 0: Added 13 bytes, total 24.
[ 2187.443179] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443181] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6061, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443183] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443184] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6064, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443186] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443187] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x606C, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443189] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443190] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6077, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443209] EtherCAT DEBUG 0: ecrt_domain_external_memory(domain = 0x0000000015413860, mem = 0x0000000016527370)
[ 2187.443210] EtherCAT DEBUG 0: ecrt_master_callbacks(master = 0x00000000bab03491, send_cb = 0x00000000c36257c5, receive_cb = 0x000000002a164c12, cb_data = 0x00000000bab03491)
[ 2187.443211] EtherCAT DEBUG 0: ecrt_master_activate(master = 0x00000000bab03491)
[ 2187.443213] EtherCAT DEBUG 0: Adding datagram pair with expected WC 3.
[ 2187.443214] EtherCAT 0: Domain0: Logical address 0x00000000, 24 byte, expected working counter 3.
[ 2187.443215] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 24 byte, type LRW.
[ 2187.443216] EtherCAT DEBUG 0: Stopping master thread.
[ 2187.443219] EtherCAT DEBUG 0: Master IDLE thread exiting...
[ 2187.443224] EtherCAT 0: Master thread exited.
[ 2187.443225] EtherCAT DEBUG 0: FSM datagram is 00000000cd587c9e.
[ 2187.443226] EtherCAT 0: Starting EtherCAT-OP thread.
[ 2187.443249] EtherCAT DEBUG 0: Operation thread running with fsm interval = 4000 us, max data size=45000
[ 2187.443250] EtherCAT DEBUG 0: mmap()
[ 2187.443252] EtherCAT DEBUG 0: Vma fault, offset = 0, page = 00000000e6b3c905
[ 2187.478992] EtherCAT DEBUG 0: Configuration changed.
[ 2187.478994] EtherCAT DEBUG 0-0: Checking system time offset.
[ 2187.486991] EtherCAT DEBUG 0-0: DC 32 bit system time offset calculation: system_time=1382702644 (corrected with 8000000), app_time=734900849754867809, diff=-1940182483
[ 2187.486993] EtherCAT DEBUG 0-0: Setting time offset to 2354784813 (was 0)
[ 2187.494990] EtherCAT DEBUG 0: Requesting OP...
[ 2187.510990] EtherCAT DEBUG 0-0: Changing state from PREOP to OP.
[ 2187.510993] EtherCAT DEBUG 0-0: Configuring...
[ 2187.513795] EtherCAT DEBUG 0-0: Now in INIT.
[ 2187.513795] EtherCAT DEBUG 0-0: Clearing FMMU configurations...
[ 2187.514794] EtherCAT DEBUG 0-0: Clearing sync manager configurations...
[ 2187.515799] EtherCAT DEBUG 0-0: Clearing DC assignment...
[ 2187.516799] EtherCAT DEBUG 0-0: Configuring mailbox sync managers...
[ 2187.516803] EtherCAT DEBUG 0-0: SM0: Addr 0x1800, Size 384, Ctrl 0x26, En 1
[ 2187.516804] EtherCAT DEBUG 0-0: SM1: Addr 0x1A00, Size 384, Ctrl 0x22, En 1
[ 2187.517796] EtherCAT DEBUG 0-0: Assigning SII access to PDI.
[ 2187.520795] EtherCAT DEBUG 0-0: Now in PREOP.
[ 2187.520796] EtherCAT DEBUG 0-0: Assigning SII access back to EtherCAT.
[ 2187.521799] EtherCAT DEBUG 0-0: Reading mapping of PDO 0x1600.
[ 2187.521800] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:00.
[ 2187.521801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.521802] EtherCAT DEBUG: 00 20 40 00 16 00 00 00 00 00
[ 2187.525795] EtherCAT DEBUG 0-0: Upload response:
[ 2187.525795] EtherCAT DEBUG: 00 30 4F 00 16 00 04 00 00 00
[ 2187.525798] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.525798] EtherCAT DEBUG: 04
[ 2187.525800] EtherCAT DEBUG 0-0: 4 PDO entries mapped.
[ 2187.525801] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:01.
[ 2187.525801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.525802] EtherCAT DEBUG: 00 20 40 00 16 01 00 00 00 00
[ 2187.529796] EtherCAT DEBUG 0-0: Upload response:
[ 2187.529797] EtherCAT DEBUG: 00 30 43 00 16 01 20 00 7A 60
[ 2187.529800] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.529800] EtherCAT DEBUG: 20 00 7A 60
[ 2187.529802] EtherCAT DEBUG 0-0: PDO entry 0x607A:00, 32 bit, "???".
[ 2187.529803] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:02.
[ 2187.529804] EtherCAT DEBUG 0-0: Upload request:
[ 2187.529804] EtherCAT DEBUG: 00 20 40 00 16 02 00 00 00 00
[ 2187.533795] EtherCAT DEBUG 0-0: Upload response:
[ 2187.533795] EtherCAT DEBUG: 00 30 43 00 16 02 20 00 FF 60
[ 2187.533798] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.533798] EtherCAT DEBUG: 20 00 FF 60
[ 2187.533800] EtherCAT DEBUG 0-0: PDO entry 0x60FF:00, 32 bit, "???".
[ 2187.533801] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:03.
[ 2187.533801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.533802] EtherCAT DEBUG: 00 20 40 00 16 03 00 00 00 00
[ 2187.537797] EtherCAT DEBUG 0-0: Upload response:
[ 2187.537799] EtherCAT DEBUG: 00 30 43 00 16 03 10 00 71 60
[ 2187.537802] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.537802] EtherCAT DEBUG: 10 00 71 60
[ 2187.537804] EtherCAT DEBUG 0-0: PDO entry 0x6071:00, 16 bit, "???".
[ 2187.537805] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:04.
[ 2187.537806] EtherCAT DEBUG 0-0: Upload request:
[ 2187.537806] EtherCAT DEBUG: 00 20 40 00 16 04 00 00 00 00
[ 2187.541795] EtherCAT DEBUG 0-0: Upload response:
[ 2187.541795] EtherCAT DEBUG: 00 30 43 00 16 04 10 00 40 60
[ 2187.541798] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.541798] EtherCAT DEBUG: 10 00 40 60
[ 2187.541800] EtherCAT DEBUG 0-0: PDO entry 0x6040:00, 16 bit, "???".
[ 2187.541801] EtherCAT DEBUG 0-0: Changing mapping of PDO 0x1600.
[ 2187.541802] EtherCAT DEBUG 0-0: Currently mapped PDO entries: 0x607A:00/32 0x60FF:00/32 0x6071:00/16 0x6040:00/16. Entries to map: 0x6040:00/16 0x6060:00/8 0x607A:00/32 0x60FF:00/32
[ 2187.541806] EtherCAT DEBUG 0-0: Setting entry count to zero.
[ 2187.541808] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:00.
[ 2187.541808] EtherCAT DEBUG: 00
[ 2187.541809] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.541810] EtherCAT DEBUG: 00 20 2F 00 16 00 00 00 00 00
[ 2187.545795] EtherCAT DEBUG 0-0: Download response:
[ 2187.545796] EtherCAT DEBUG: 00 30 60 00 16 00 00 00 00 00
[ 2187.545799] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6040:00 (16 bit) at position 1.
[ 2187.545800] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:01.
[ 2187.545800] EtherCAT DEBUG: 10 00 40 60
[ 2187.545802] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.545802] EtherCAT DEBUG: 00 20 23 00 16 01 10 00 40 60
[ 2187.549794] EtherCAT DEBUG 0-0: Download response:
[ 2187.549795] EtherCAT DEBUG: 00 30 60 00 16 01 10 00 40 60
[ 2187.549798] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6060:00 (8 bit) at position 2.
[ 2187.549800] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:02.
[ 2187.549800] EtherCAT DEBUG: 08 00 60 60
[ 2187.549802] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.549802] EtherCAT DEBUG: 00 20 23 00 16 02 08 00 60 60
[ 2187.553798] EtherCAT DEBUG 0-0: Download response:
[ 2187.553799] EtherCAT DEBUG: 00 30 60 00 16 02 08 00 60 60
[ 2187.553802] EtherCAT DEBUG 0-0: Mapping PDO entry 0x607A:00 (32 bit) at position 3.
[ 2187.553804] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:03.
[ 2187.553804] EtherCAT DEBUG: 20 00 7A 60
[ 2187.553806] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.553806] EtherCAT DEBUG: 00 20 23 00 16 03 20 00 7A 60
[ 2187.557798] EtherCAT DEBUG 0-0: Download response:
[ 2187.557800] EtherCAT DEBUG: 00 30 60 00 16 03 20 00 7A 60
[ 2187.557803] EtherCAT DEBUG 0-0: Mapping PDO entry 0x60FF:00 (32 bit) at position 4.
[ 2187.557804] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:04.
[ 2187.557804] EtherCAT DEBUG: 20 00 FF 60
[ 2187.557806] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.557806] EtherCAT DEBUG: 00 20 23 00 16 04 20 00 FF 60
[ 2187.561803] EtherCAT DEBUG 0-0: Download response:
[ 2187.561804] EtherCAT DEBUG: 00 30 60 00 16 04 20 00 FF 60
[ 2187.561808] EtherCAT DEBUG 0-0: Setting number of PDO entries to 4.
[ 2187.561810] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:00.
[ 2187.561810] EtherCAT DEBUG: 04
[ 2187.561811] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.561811] EtherCAT DEBUG: 00 20 2F 00 16 00 04 00 00 00
[ 2187.564802] EtherCAT DEBUG 0-0: Download response:
[ 2187.564802] EtherCAT DEBUG: 00 30 60 00 16 00 04 00 00 00
[ 2187.564805] EtherCAT DEBUG 0-0: Successfully configured mapping for PDO 0x1600.
[ 2187.564806] EtherCAT DEBUG 0-0: Setting PDO assignment of SM2:
[ 2187.564807] EtherCAT DEBUG 0-0: Currently assigned PDOs: 0x1601. PDOs to assign: 0x1600
[ 2187.564809] EtherCAT DEBUG 0-0: Setting number of assigned PDOs to zero.
[ 2187.564810] EtherCAT DEBUG 0-0: Downloading SDO 0x1C12:00.
[ 2187.564810] EtherCAT DEBUG: 00
[ 2187.564811] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.564812] EtherCAT DEBUG: 00 20 2F 12 1C 00 00 00 00 00
[ 2187.568797] EtherCAT DEBUG 0-0: Download response:
[ 2187.568798] EtherCAT DEBUG: 00 30 60 12 1C 00 00 00 00 00
[ 2187.568802] EtherCAT DEBUG 0-0: Assigning PDO 0x1600 at position 1.
[ 2187.568803] EtherCAT DEBUG 0-0: Downloading SDO 0x1C12:01.
[ 2187.568804] EtherCAT DEBUG: 00 16
[ 2187.568805] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.568805] EtherCAT DEBUG: 00 20 2B 12 1C 01 00 16 00 00
[ 2187.572794] EtherCAT DEBUG 0-0: Download response:
[ 2187.572795] EtherCAT DEBUG: 00 30 60 12 1C 01 00 16 00 00
[ 2187.572798] EtherCAT DEBUG 0-0: Setting number of assigned PDOs to 1.
[ 2187.572799] EtherCAT DEBUG 0-0: Downloading SDO 0x1C12:00.
[ 2187.572799] EtherCAT DEBUG: 01
[ 2187.572800] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.572801] EtherCAT DEBUG: 00 20 2F 12 1C 00 01 00 00 00
[ 2187.576796] EtherCAT DEBUG 0-0: Download response:
[ 2187.576797] EtherCAT DEBUG: 00 30 60 12 1C 00 01 00 00 00
[ 2187.576802] EtherCAT DEBUG 0-0: Successfully configured PDO assignment of SM2.
[ 2187.576804] EtherCAT DEBUG 0-0: Reading mapping of PDO 0x1A00.
[ 2187.576805] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:00.
[ 2187.576806] EtherCAT DEBUG 0-0: Upload request:
[ 2187.576806] EtherCAT DEBUG: 00 20 40 00 1A 00 00 00 00 00
[ 2187.580794] EtherCAT DEBUG 0-0: Upload response:
[ 2187.580795] EtherCAT DEBUG: 00 30 4F 00 1A 00 04 00 00 00
[ 2187.580798] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.580798] EtherCAT DEBUG: 04
[ 2187.580799] EtherCAT DEBUG 0-0: 4 PDO entries mapped.
[ 2187.580800] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:01.
[ 2187.580801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.580801] EtherCAT DEBUG: 00 20 40 00 1A 01 00 00 00 00
[ 2187.584795] EtherCAT DEBUG 0-0: Upload response:
[ 2187.584797] EtherCAT DEBUG: 00 30 43 00 1A 01 20 00 64 60
[ 2187.584799] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.584800] EtherCAT DEBUG: 20 00 64 60
[ 2187.584802] EtherCAT DEBUG 0-0: PDO entry 0x6064:00, 32 bit, "???".
[ 2187.584803] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:02.
[ 2187.584804] EtherCAT DEBUG 0-0: Upload request:
[ 2187.584804] EtherCAT DEBUG: 00 20 40 00 1A 02 00 00 00 00
[ 2187.588796] EtherCAT DEBUG 0-0: Upload response:
[ 2187.588796] EtherCAT DEBUG: 00 30 43 00 1A 02 20 00 6C 60
[ 2187.588799] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.588799] EtherCAT DEBUG: 20 00 6C 60
[ 2187.588801] EtherCAT DEBUG 0-0: PDO entry 0x606C:00, 32 bit, "???".
[ 2187.588801] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:03.
[ 2187.588802] EtherCAT DEBUG 0-0: Upload request:
[ 2187.588802] EtherCAT DEBUG: 00 20 40 00 1A 03 00 00 00 00
[ 2187.592794] EtherCAT DEBUG 0-0: Upload response:
[ 2187.592795] EtherCAT DEBUG: 00 30 43 00 1A 03 10 00 77 60
[ 2187.592797] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.592798] EtherCAT DEBUG: 10 00 77 60
[ 2187.592800] EtherCAT DEBUG 0-0: PDO entry 0x6077:00, 16 bit, "???".
[ 2187.592800] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:04.
[ 2187.592801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.592801] EtherCAT DEBUG: 00 20 40 00 1A 04 00 00 00 00
[ 2187.596794] EtherCAT DEBUG 0-0: Upload response:
[ 2187.596795] EtherCAT DEBUG: 00 30 43 00 1A 04 10 00 41 60
[ 2187.596797] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.596798] EtherCAT DEBUG: 10 00 41 60
[ 2187.596800] EtherCAT DEBUG 0-0: PDO entry 0x6041:00, 16 bit, "???".
[ 2187.596800] EtherCAT DEBUG 0-0: Changing mapping of PDO 0x1A00.
[ 2187.596801] EtherCAT DEBUG 0-0: Currently mapped PDO entries: 0x6064:00/32 0x606C:00/32 0x6077:00/16 0x6041:00/16. Entries to map: 0x6041:00/16 0x6061:00/8 0x6064:00/32 0x606C:00/32 0x6077:00/16
[ 2187.596806] EtherCAT DEBUG 0-0: Setting entry count to zero.
[ 2187.596807] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:00.
[ 2187.596807] EtherCAT DEBUG: 00
[ 2187.596809] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.596809] EtherCAT DEBUG: 00 20 2F 00 1A 00 00 00 00 00
[ 2187.600800] EtherCAT DEBUG 0-0: Download response:
[ 2187.600801] EtherCAT DEBUG: 00 30 60 00 1A 00 00 00 00 00
[ 2187.600804] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6041:00 (16 bit) at position 1.
[ 2187.600806] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:01.
[ 2187.600806] EtherCAT DEBUG: 10 00 41 60
[ 2187.600808] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.600808] EtherCAT DEBUG: 00 20 23 00 1A 01 10 00 41 60
[ 2187.604800] EtherCAT DEBUG 0-0: Download response:
[ 2187.604801] EtherCAT DEBUG: 00 30 60 00 1A 01 10 00 41 60
[ 2187.604804] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6061:00 (8 bit) at position 2.
[ 2187.604805] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:02.
[ 2187.604805] EtherCAT DEBUG: 08 00 61 60
[ 2187.604807] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.604807] EtherCAT DEBUG: 00 20 23 00 1A 02 08 00 61 60
[ 2187.608796] EtherCAT DEBUG 0-0: Download response:
[ 2187.608796] EtherCAT DEBUG: 00 30 60 00 1A 02 08 00 61 60
[ 2187.608799] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6064:00 (32 bit) at position 3.
[ 2187.608800] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:03.
[ 2187.608800] EtherCAT DEBUG: 20 00 64 60
[ 2187.608802] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.608802] EtherCAT DEBUG: 00 20 23 00 1A 03 20 00 64 60
[ 2187.612794] EtherCAT DEBUG 0-0: Download response:
[ 2187.612795] EtherCAT DEBUG: 00 30 60 00 1A 03 20 00 64 60
[ 2187.612798] EtherCAT DEBUG 0-0: Mapping PDO entry 0x606C:00 (32 bit) at position 4.
[ 2187.612799] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:04.
[ 2187.612799] EtherCAT DEBUG: 20 00 6C 60
[ 2187.612801] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.612801] EtherCAT DEBUG: 00 20 23 00 1A 04 20 00 6C 60
[ 2187.616794] EtherCAT DEBUG 0-0: Download response:
[ 2187.616794] EtherCAT DEBUG: 00 30 60 00 1A 04 20 00 6C 60
[ 2187.616797] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6077:00 (16 bit) at position 5.
[ 2187.616797] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:05.
[ 2187.616798] EtherCAT DEBUG: 10 00 77 60
[ 2187.616799] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.616799] EtherCAT DEBUG: 00 20 23 00 1A 05 10 00 77 60
[ 2187.620795] EtherCAT DEBUG 0-0: Download response:
[ 2187.620795] EtherCAT DEBUG: 00 30 60 00 1A 05 10 00 77 60
[ 2187.620798] EtherCAT DEBUG 0-0: Setting number of PDO entries to 5.
[ 2187.620799] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:00.
[ 2187.620799] EtherCAT DEBUG: 05
[ 2187.620800] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.620800] EtherCAT DEBUG: 00 20 2F 00 1A 00 05 00 00 00
[ 2187.624794] EtherCAT DEBUG 0-0: Download response:
[ 2187.624795] EtherCAT DEBUG: 00 30 60 00 1A 00 05 00 00 00
[ 2187.624797] EtherCAT DEBUG 0-0: Successfully configured mapping for PDO 0x1A00.
[ 2187.624798] EtherCAT DEBUG 0-0: Setting PDO assignment of SM3:
[ 2187.624799] EtherCAT DEBUG 0-0: Currently assigned PDOs: 0x1A01. PDOs to assign: 0x1A00
[ 2187.624800] EtherCAT DEBUG 0-0: Setting number of assigned PDOs to zero.
[ 2187.624801] EtherCAT DEBUG 0-0: Downloading SDO 0x1C13:00.
[ 2187.624801] EtherCAT DEBUG: 00
[ 2187.624802] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.624803] EtherCAT DEBUG: 00 20 2F 13 1C 00 00 00 00 00
[ 2187.628796] EtherCAT DEBUG 0-0: Download response:
[ 2187.628797] EtherCAT DEBUG: 00 30 60 13 1C 00 00 00 00 00
[ 2187.628799] EtherCAT DEBUG 0-0: Assigning PDO 0x1A00 at position 1.
[ 2187.628800] EtherCAT DEBUG 0-0: Downloading SDO 0x1C13:01.
[ 2187.628800] EtherCAT DEBUG: 00 1A
[ 2187.628801] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.628802] EtherCAT DEBUG: 00 20 2B 13 1C 01 00 1A 00 00
[ 2187.631796] EtherCAT DEBUG 0-0: Download response:
[ 2187.631797] EtherCAT DEBUG: 00 30 60 13 1C 01 00 1A 00 00
[ 2187.631799] EtherCAT DEBUG 0-0: Setting number of assigned PDOs to 1.
[ 2187.631800] EtherCAT DEBUG 0-0: Downloading SDO 0x1C13:00.
[ 2187.631801] EtherCAT DEBUG: 01
[ 2187.631801] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.631802] EtherCAT DEBUG: 00 20 2F 13 1C 00 01 00 00 00
[ 2187.635801] EtherCAT DEBUG 0-0: Download response:
[ 2187.635801] EtherCAT DEBUG: 00 30 60 13 1C 00 01 00 00 00
[ 2187.635805] EtherCAT DEBUG 0-0: Successfully configured PDO assignment of SM3.
[ 2187.635808] EtherCAT DEBUG 0-0: SM2: Addr 0x1000, Size 11, Ctrl 0x24, En 1
[ 2187.635809] EtherCAT DEBUG 0-0: SM3: Addr 0x1100, Size 13, Ctrl 0x00, En 1
[ 2187.637800] EtherCAT DEBUG 0 0:0: FMMU: LogAddr 0x00000000, Size 11, PhysAddr 0x1000, SM2, Dir out
[ 2187.637801] EtherCAT DEBUG 0 0:0: FMMU: LogAddr 0x0000000B, Size 13, PhysAddr 0x1100, SM3, Dir in
[ 2187.638798] EtherCAT DEBUG 0-0: Setting DC cycle times to 1000000 / 0.
[ 2187.639800] EtherCAT DEBUG 0-0: Checking for synchrony.
[ 2187.640798] EtherCAT DEBUG 0-0: Sync after 0 ms: 861325 ns
[ 2187.641797] EtherCAT DEBUG 0-0: Sync after 0 ms: 859937 ns
[ 2187.642794] EtherCAT DEBUG 0-0: Sync after 0 ms: 859564 ns
[ 2187.643800] EtherCAT DEBUG 0-0: Sync after 4 ms: 858883 ns
[ 2187.644795] EtherCAT DEBUG 0-0: Sync after 4 ms: 859702 ns
[ 2187.645794] EtherCAT DEBUG 0-0: Sync after 4 ms: 856666 ns
[ 2187.646794] EtherCAT DEBUG 0-0: Sync after 4 ms: 856473 ns
[ 2187.647794] EtherCAT DEBUG 0-0: Sync after 8 ms: 856331 ns
[ 2187.648794] EtherCAT DEBUG 0-0: Sync after 8 ms: 855630 ns
[ 2187.649794] EtherCAT DEBUG 0-0: Sync after 8 ms: 862287 ns
[ 2187.650794] EtherCAT DEBUG 0-0: Sync after 8 ms: 853480 ns
[ 2187.651800] EtherCAT DEBUG 0-0: Sync after 12 ms: 853157 ns
[ 2187.652794] EtherCAT DEBUG 0-0: Sync after 12 ms: 852218 ns
[ 2187.653794] EtherCAT DEBUG 0-0: Sync after 12 ms: 848767 ns
[ 2187.654795] EtherCAT DEBUG 0-0: Sync after 12 ms: 849231 ns
[ 2187.655794] EtherCAT DEBUG 0-0: Sync after 16 ms: 853110 ns
[ 2187.656794] EtherCAT DEBUG 0-0: Sync after 16 ms: 851313 ns
[ 2187.657794] EtherCAT DEBUG 0-0: Sync after 16 ms: 846705 ns
[ 2187.658794] EtherCAT DEBUG 0-0: Sync after 16 ms: 845966 ns
[ 2187.659799] EtherCAT DEBUG 0-0: Sync after 20 ms: 844705 ns
[ 2187.660799] EtherCAT DEBUG 0-0: Sync after 20 ms: 847917 ns
[ 2187.661798] EtherCAT DEBUG 0-0: Sync after 20 ms: 839678 ns
[ 2187.662795] EtherCAT DEBUG 0-0: Sync after 20 ms: 839529 ns
[ 2187.663794] EtherCAT DEBUG 0-0: Sync after 24 ms: 837921 ns
[ 2187.664794] EtherCAT DEBUG 0-0: Sync after 24 ms: 838891 ns
[ 2187.665795] EtherCAT DEBUG 0-0: Sync after 24 ms: 838189 ns
[ 2187.666794] EtherCAT DEBUG 0-0: Sync after 24 ms: 837689 ns
[ 2187.667798] EtherCAT DEBUG 0-0: Sync after 28 ms: 836853 ns
[ 2187.668797] EtherCAT DEBUG 0-0: Sync after 28 ms: 835963 ns
[ 2187.669794] EtherCAT DEBUG 0-0: Sync after 28 ms: 832511 ns
[ 2187.670794] EtherCAT DEBUG 0-0: Sync after 28 ms: 832256 ns
[ 2187.671798] EtherCAT DEBUG 0-0: Sync after 32 ms: 832822 ns
[ 2187.672797] EtherCAT DEBUG 0-0: Sync after 32 ms: 835731 ns
[ 2187.673794] EtherCAT DEBUG 0-0: Sync after 32 ms: 829130 ns
[ 2187.674794] EtherCAT DEBUG 0-0: Sync after 32 ms: 833094 ns
[ 2187.675802] EtherCAT DEBUG 0-0: Sync after 36 ms: 838174 ns
[ 2187.676796] EtherCAT DEBUG 0-0: Sync after 36 ms: 831220 ns
[ 2187.677794] EtherCAT DEBUG 0-0: Sync after 36 ms: 821895 ns
[ 2187.678794] EtherCAT DEBUG 0-0: Sync after 36 ms: 825047 ns
[ 2187.679794] EtherCAT DEBUG 0-0: Sync after 40 ms: 833900 ns
[ 2187.680795] EtherCAT DEBUG 0-0: Sync after 40 ms: 823770 ns
[ 2187.681795] EtherCAT DEBUG 0-0: Sync after 40 ms: 830596 ns
[ 2187.682795] EtherCAT DEBUG 0-0: Sync after 40 ms: 822002 ns
[ 2187.683797] EtherCAT DEBUG 0-0: Sync after 44 ms: 819378 ns
[ 2187.684795] EtherCAT DEBUG 0-0: Sync after 44 ms: 828180 ns
[ 2187.685796] EtherCAT DEBUG 0-0: Sync after 44 ms: 817741 ns
[ 2187.686795] EtherCAT DEBUG 0-0: Sync after 44 ms: 817368 ns
[ 2187.687796] EtherCAT DEBUG 0-0: Sync after 48 ms: 820054 ns
[ 2187.688795] EtherCAT DEBUG 0-0: Sync after 48 ms: 815193 ns
[ 2187.689795] EtherCAT DEBUG 0-0: Sync after 48 ms: 814117 ns
[ 2187.690795] EtherCAT DEBUG 0-0: Sync after 48 ms: 812666 ns
[ 2187.691799] EtherCAT DEBUG 0-0: Sync after 52 ms: 815899 ns
[ 2187.692799] EtherCAT DEBUG 0-0: Sync after 52 ms: 811246 ns
[ 2187.693798] EtherCAT DEBUG 0-0: Sync after 52 ms: 808822 ns
[ 2187.694797] EtherCAT DEBUG 0-0: Sync after 52 ms: 807722 ns
[ 2187.695799] EtherCAT DEBUG 0-0: Sync after 56 ms: 806047 ns
[ 2187.696795] EtherCAT DEBUG 0-0: Sync after 56 ms: 804390 ns
[ 2187.697797] EtherCAT DEBUG 0-0: Sync after 56 ms: 804505 ns
[ 2187.698794] EtherCAT DEBUG 0-0: Sync after 56 ms: 806017 ns
[ 2187.699794] EtherCAT DEBUG 0-0: Sync after 60 ms: 803126 ns
[ 2187.700795] EtherCAT DEBUG 0-0: Sync after 60 ms: 808599 ns
[ 2187.701797] EtherCAT DEBUG 0-0: Sync after 60 ms: 802180 ns
[ 2187.702796] EtherCAT DEBUG 0-0: Sync after 60 ms: 800640 ns
[ 2187.703801] EtherCAT DEBUG 0-0: Sync after 64 ms: 799820 ns
[ 2187.704795] EtherCAT DEBUG 0-0: Sync after 64 ms: 807605 ns
[ 2187.705794] EtherCAT DEBUG 0-0: Sync after 64 ms: 796091 ns
[ 2187.706795] EtherCAT DEBUG 0-0: Sync after 64 ms: 796151 ns
[ 2187.707800] EtherCAT DEBUG 0-0: Sync after 68 ms: 806183 ns
[ 2187.708795] EtherCAT DEBUG 0-0: Sync after 68 ms: 796029 ns
[ 2187.709794] EtherCAT DEBUG 0-0: Sync after 68 ms: 791566 ns
[ 2187.710799] EtherCAT DEBUG 0-0: Sync after 68 ms: 794073 ns
[ 2187.711798] EtherCAT DEBUG 0-0: Sync after 72 ms: 792439 ns
[ 2187.712796] EtherCAT DEBUG 0-0: Sync after 72 ms: 789112 ns
[ 2187.713798] EtherCAT DEBUG 0-0: Sync after 72 ms: 788578 ns
[ 2187.714794] EtherCAT DEBUG 0-0: Sync after 72 ms: 792535 ns
[ 2187.715794] EtherCAT DEBUG 0-0: Sync after 76 ms: 786634 ns
[ 2187.716794] EtherCAT DEBUG 0-0: Sync after 76 ms: 791726 ns
[ 2187.717794] EtherCAT DEBUG 0-0: Sync after 76 ms: 786982 ns
[ 2187.718795] EtherCAT DEBUG 0-0: Sync after 76 ms: 795391 ns
[ 2187.719800] EtherCAT DEBUG 0-0: Sync after 80 ms: 784425 ns
[ 2187.720795] EtherCAT DEBUG 0-0: Sync after 80 ms: 783160 ns
[ 2187.721794] EtherCAT DEBUG 0-0: Sync after 80 ms: 780874 ns
[ 2187.722797] EtherCAT DEBUG 0-0: Sync after 80 ms: 782160 ns
[ 2187.723799] EtherCAT DEBUG 0-0: Sync after 84 ms: 789692 ns
[ 2187.724797] EtherCAT DEBUG 0-0: Sync after 84 ms: 777347 ns
[ 2187.725795] EtherCAT DEBUG 0-0: Sync after 84 ms: 776452 ns
[ 2187.726794] EtherCAT DEBUG 0-0: Sync after 84 ms: 776047 ns
[ 2187.727800] EtherCAT DEBUG 0-0: Sync after 88 ms: 776688 ns
[ 2187.728795] EtherCAT DEBUG 0-0: Sync after 88 ms: 776026 ns
[ 2187.729794] EtherCAT DEBUG 0-0: Sync after 88 ms: 773364 ns
[ 2187.730794] EtherCAT DEBUG 0-0: Sync after 88 ms: 773504 ns
[ 2187.731794] EtherCAT DEBUG 0-0: Sync after 92 ms: 777402 ns
[ 2187.732795] EtherCAT DEBUG 0-0: Sync after 92 ms: 772404 ns
[ 2187.733794] EtherCAT DEBUG 0-0: Sync after 92 ms: 775182 ns
[ 2187.734796] EtherCAT DEBUG 0-0: Sync after 92 ms: 768689 ns
[ 2187.735802] EtherCAT DEBUG 0-0: Sync after 96 ms: 768560 ns
[ 2187.736795] EtherCAT DEBUG 0-0: Sync after 96 ms: 765536 ns
[ 2187.737794] EtherCAT DEBUG 0-0: Sync after 96 ms: 764581 ns
[ 2187.738793] EtherCAT DEBUG 0-0: Sync after 96 ms: 765838 ns
[ 2187.739794] EtherCAT DEBUG 0-0: Sync after 100 ms: 765331 ns
[ 2187.740794] EtherCAT DEBUG 0-0: Sync after 100 ms: 764066 ns
[ 2187.741793] EtherCAT DEBUG 0-0: Sync after 100 ms: 763034 ns
[ 2187.742794] EtherCAT DEBUG 0-0: Sync after 100 ms: 770531 ns
[ 2187.743799] EtherCAT DEBUG 0-0: Sync after 104 ms: 770420 ns
[ 2187.744795] EtherCAT DEBUG 0-0: Sync after 104 ms: 759793 ns
[ 2187.745794] EtherCAT DEBUG 0-0: Sync after 104 ms: 757268 ns
[ 2187.746794] EtherCAT DEBUG 0-0: Sync after 104 ms: 757627 ns
[ 2187.747794] EtherCAT DEBUG 0-0: Sync after 108 ms: 766622 ns
[ 2187.748794] EtherCAT DEBUG 0-0: Sync after 108 ms: 756350 ns
[ 2187.749794] EtherCAT DEBUG 0-0: Sync after 108 ms: 755081 ns
[ 2187.750794] EtherCAT DEBUG 0-0: Sync after 108 ms: 753676 ns
[ 2187.751799] EtherCAT DEBUG 0-0: Sync after 112 ms: 753427 ns
[ 2187.752793] EtherCAT DEBUG 0-0: Sync after 112 ms: 752116 ns
[ 2187.753795] EtherCAT DEBUG 0-0: Sync after 112 ms: 749272 ns
[ 2187.754795] EtherCAT DEBUG 0-0: Sync after 112 ms: 749816 ns
[ 2187.755799] EtherCAT DEBUG 0-0: Sync after 116 ms: 747727 ns
[ 2187.756794] EtherCAT DEBUG 0-0: Sync after 116 ms: 747838 ns
[ 2187.757794] EtherCAT DEBUG 0-0: Sync after 116 ms: 744878 ns
[ 2187.758794] EtherCAT DEBUG 0-0: Sync after 116 ms: 745061 ns
[ 2187.759799] EtherCAT DEBUG 0-0: Sync after 120 ms: 745409 ns
[ 2187.760795] EtherCAT DEBUG 0-0: Sync after 120 ms: 744388 ns
[ 2187.761794] EtherCAT DEBUG 0-0: Sync after 120 ms: 741664 ns
[ 2187.762794] EtherCAT DEBUG 0-0: Sync after 120 ms: 741875 ns
[ 2187.763794] EtherCAT DEBUG 0-0: Sync after 124 ms: 745595 ns
[ 2187.764794] EtherCAT DEBUG 0-0: Sync after 124 ms: 739895 ns
[ 2187.765795] EtherCAT DEBUG 0-0: Sync after 124 ms: 739159 ns
[ 2187.766795] EtherCAT DEBUG 0-0: Sync after 124 ms: 738091 ns
[ 2187.767799] EtherCAT DEBUG 0-0: Sync after 128 ms: 736758 ns
[ 2187.768795] EtherCAT DEBUG 0-0: Sync after 128 ms: 735296 ns
[ 2187.769794] EtherCAT DEBUG 0-0: Sync after 128 ms: 733775 ns
[ 2187.770794] EtherCAT DEBUG 0-0: Sync after 128 ms: 734036 ns
[ 2187.771794] EtherCAT DEBUG 0-0: Sync after 132 ms: 733531 ns
[ 2187.772794] EtherCAT DEBUG 0-0: Sync after 132 ms: 731958 ns
[ 2187.773794] EtherCAT DEBUG 0-0: Sync after 132 ms: 730998 ns
[ 2187.774794] EtherCAT DEBUG 0-0: Sync after 132 ms: 730068 ns
[ 2187.775799] EtherCAT DEBUG 0-0: Sync after 136 ms: 729657 ns
[ 2187.776795] EtherCAT DEBUG 0-0: Sync after 136 ms: 736846 ns
[ 2187.777794] EtherCAT DEBUG 0-0: Sync after 136 ms: 725485 ns
[ 2187.778794] EtherCAT DEBUG 0-0: Sync after 136 ms: 725975 ns
[ 2187.779794] EtherCAT DEBUG 0-0: Sync after 140 ms: 724593 ns
[ 2187.780794] EtherCAT DEBUG 0-0: Sync after 140 ms: 728801 ns
[ 2187.781794] EtherCAT DEBUG 0-0: Sync after 140 ms: 726719 ns
[ 2187.782794] EtherCAT DEBUG 0-0: Sync after 140 ms: 722641 ns
[ 2187.783800] EtherCAT DEBUG 0-0: Sync after 144 ms: 721078 ns
[ 2187.784795] EtherCAT DEBUG 0-0: Sync after 144 ms: 720739 ns
[ 2187.785794] EtherCAT DEBUG 0-0: Sync after 144 ms: 721478 ns
[ 2187.786796] EtherCAT DEBUG 0-0: Sync after 144 ms: 721403 ns
[ 2187.787800] EtherCAT DEBUG 0-0: Sync after 148 ms: 716897 ns
[ 2187.788795] EtherCAT DEBUG 0-0: Sync after 148 ms: 715813 ns
[ 2187.789794] EtherCAT DEBUG 0-0: Sync after 148 ms: 722174 ns
[ 2187.790794] EtherCAT DEBUG 0-0: Sync after 148 ms: 717920 ns
[ 2187.791794] EtherCAT DEBUG 0-0: Sync after 152 ms: 713532 ns
[ 2187.792796] EtherCAT DEBUG 0-0: Sync after 152 ms: 712465 ns
[ 2187.793794] EtherCAT DEBUG 0-0: Sync after 152 ms: 710731 ns
[ 2187.794794] EtherCAT DEBUG 0-0: Sync after 152 ms: 709178 ns
[ 2187.795799] EtherCAT DEBUG 0-0: Sync after 156 ms: 708685 ns
[ 2187.796794] EtherCAT DEBUG 0-0: Sync after 156 ms: 713366 ns
[ 2187.797796] EtherCAT DEBUG 0-0: Sync after 156 ms: 705877 ns
[ 2187.798794] EtherCAT DEBUG 0-0: Sync after 156 ms: 709925 ns
[ 2187.799794] EtherCAT DEBUG 0-0: Sync after 160 ms: 705328 ns
[ 2187.800794] EtherCAT DEBUG 0-0: Sync after 160 ms: 704503 ns
[ 2187.801794] EtherCAT DEBUG 0-0: Sync after 160 ms: 702976 ns
[ 2187.802794] EtherCAT DEBUG 0-0: Sync after 160 ms: 706680 ns
[ 2187.803799] EtherCAT DEBUG 0-0: Sync after 164 ms: 701637 ns
[ 2187.804795] EtherCAT DEBUG 0-0: Sync after 164 ms: 699995 ns
[ 2187.805794] EtherCAT DEBUG 0-0: Sync after 164 ms: 697357 ns
[ 2187.806794] EtherCAT DEBUG 0-0: Sync after 164 ms: 698608 ns
[ 2187.807794] EtherCAT DEBUG 0-0: Sync after 168 ms: 697599 ns
[ 2187.808794] EtherCAT DEBUG 0-0: Sync after 168 ms: 695857 ns
[ 2187.809794] EtherCAT DEBUG 0-0: Sync after 168 ms: 694777 ns
[ 2187.810794] EtherCAT DEBUG 0-0: Sync after 168 ms: 694783 ns
[ 2187.811799] EtherCAT DEBUG 0-0: Sync after 172 ms: 697559 ns
[ 2187.812794] EtherCAT DEBUG 0-0: Sync after 172 ms: 692236 ns
[ 2187.813794] EtherCAT DEBUG 0-0: Sync after 172 ms: 689657 ns
[ 2187.814794] EtherCAT DEBUG 0-0: Sync after 172 ms: 690308 ns
[ 2187.815794] EtherCAT DEBUG 0-0: Sync after 176 ms: 688548 ns
[ 2187.816794] EtherCAT DEBUG 0-0: Sync after 176 ms: 688750 ns
[ 2187.817794] EtherCAT DEBUG 0-0: Sync after 176 ms: 687325 ns
[ 2187.818794] EtherCAT DEBUG 0-0: Sync after 176 ms: 685776 ns
[ 2187.819799] EtherCAT DEBUG 0-0: Sync after 180 ms: 685075 ns
[ 2187.820795] EtherCAT DEBUG 0-0: Sync after 180 ms: 688429 ns
[ 2187.821794] EtherCAT DEBUG 0-0: Sync after 180 ms: 681557 ns
[ 2187.822793] EtherCAT DEBUG 0-0: Sync after 180 ms: 681933 ns
[ 2187.823793] EtherCAT DEBUG 0-0: Sync after 184 ms: 681145 ns
[ 2187.824794] EtherCAT DEBUG 0-0: Sync after 184 ms: 680781 ns
[ 2187.825794] EtherCAT DEBUG 0-0: Sync after 184 ms: 678482 ns
[ 2187.826794] EtherCAT DEBUG 0-0: Sync after 184 ms: 677827 ns
[ 2187.827799] EtherCAT DEBUG 0-0: Sync after 188 ms: 677169 ns
[ 2187.828796] EtherCAT DEBUG 0-0: Sync after 188 ms: 681014 ns
[ 2187.829794] EtherCAT DEBUG 0-0: Sync after 188 ms: 674092 ns
[ 2187.830794] EtherCAT DEBUG 0-0: Sync after 188 ms: 674441 ns
[ 2187.831794] EtherCAT DEBUG 0-0: Sync after 192 ms: 673562 ns
[ 2187.832794] EtherCAT DEBUG 0-0: Sync after 192 ms: 671885 ns
[ 2187.833794] EtherCAT DEBUG 0-0: Sync after 192 ms: 671120 ns
[ 2187.834794] EtherCAT DEBUG 0-0: Sync after 192 ms: 670958 ns
[ 2187.835799] EtherCAT DEBUG 0-0: Sync after 196 ms: 669957 ns
[ 2187.836795] EtherCAT DEBUG 0-0: Sync after 196 ms: 668214 ns
[ 2187.837794] EtherCAT DEBUG 0-0: Sync after 196 ms: 675602 ns
[ 2187.838794] EtherCAT DEBUG 0-0: Sync after 196 ms: 665825 ns
[ 2187.839794] EtherCAT DEBUG 0-0: Sync after 200 ms: 674767 ns
[ 2187.840794] EtherCAT DEBUG 0-0: Sync after 200 ms: 663896 ns
[ 2187.841794] EtherCAT DEBUG 0-0: Sync after 200 ms: 662301 ns
[ 2187.842793] EtherCAT DEBUG 0-0: Sync after 200 ms: 662931 ns
[ 2187.843799] EtherCAT DEBUG 0-0: Sync after 204 ms: 661553 ns
[ 2187.844795] EtherCAT DEBUG 0-0: Sync after 204 ms: 661001 ns
[ 2187.845794] EtherCAT DEBUG 0-0: Sync after 204 ms: 657665 ns
[ 2187.846794] EtherCAT DEBUG 0-0: Sync after 204 ms: 658493 ns
[ 2187.847800] EtherCAT DEBUG 0-0: Sync after 208 ms: 666015 ns
[ 2187.848796] EtherCAT DEBUG 0-0: Sync after 208 ms: 656155 ns
[ 2187.849794] EtherCAT DEBUG 0-0: Sync after 208 ms: 653226 ns
[ 2187.850794] EtherCAT DEBUG 0-0: Sync after 208 ms: 653414 ns
[ 2187.851794] EtherCAT DEBUG 0-0: Sync after 212 ms: 653054 ns
[ 2187.852795] EtherCAT DEBUG 0-0: Sync after 212 ms: 652494 ns
[ 2187.853794] EtherCAT DEBUG 0-0: Sync after 212 ms: 651033 ns
[ 2187.854794] EtherCAT DEBUG 0-0: Sync after 212 ms: 654398 ns
[ 2187.855797] EtherCAT DEBUG 0-0: Sync after 216 ms: 649972 ns
[ 2187.856795] EtherCAT DEBUG 0-0: Sync after 216 ms: 648278 ns
[ 2187.857794] EtherCAT DEBUG 0-0: Sync after 216 ms: 644971 ns
[ 2187.858798] EtherCAT DEBUG 0-0: Sync after 216 ms: 646684 ns
[ 2187.859800] EtherCAT DEBUG 0-0: Sync after 220 ms: 654368 ns
[ 2187.860795] EtherCAT DEBUG 0-0: Sync after 220 ms: 642247 ns
[ 2187.861794] EtherCAT DEBUG 0-0: Sync after 220 ms: 641626 ns
[ 2187.862794] EtherCAT DEBUG 0-0: Sync after 220 ms: 641974 ns
[ 2187.863799] EtherCAT DEBUG 0-0: Sync after 224 ms: 641363 ns
[ 2187.864795] EtherCAT DEBUG 0-0: Sync after 224 ms: 649755 ns
[ 2187.865794] EtherCAT DEBUG 0-0: Sync after 224 ms: 637485 ns
[ 2187.866794] EtherCAT DEBUG 0-0: Sync after 224 ms: 638843 ns
[ 2187.867794] EtherCAT DEBUG 0-0: Sync after 228 ms: 646502 ns
[ 2187.868794] EtherCAT DEBUG 0-0: Sync after 228 ms: 636629 ns
[ 2187.869794] EtherCAT DEBUG 0-0: Sync after 228 ms: 634479 ns
[ 2187.870794] EtherCAT DEBUG 0-0: Sync after 228 ms: 634893 ns
[ 2187.871799] EtherCAT DEBUG 0-0: Sync after 232 ms: 633431 ns
[ 2187.872794] EtherCAT DEBUG 0-0: Sync after 232 ms: 632698 ns
[ 2187.873794] EtherCAT DEBUG 0-0: Sync after 232 ms: 630147 ns
[ 2187.874794] EtherCAT DEBUG 0-0: Sync after 232 ms: 629711 ns
[ 2187.875794] EtherCAT DEBUG 0-0: Sync after 236 ms: 629889 ns
[ 2187.876794] EtherCAT DEBUG 0-0: Sync after 236 ms: 629056 ns
[ 2187.877794] EtherCAT DEBUG 0-0: Sync after 236 ms: 626707 ns
[ 2187.878801] EtherCAT DEBUG 0-0: Sync after 236 ms: 627012 ns
[ 2187.879799] EtherCAT DEBUG 0-0: Sync after 240 ms: 625907 ns
[ 2187.880795] EtherCAT DEBUG 0-0: Sync after 240 ms: 621533 ns
[ 2187.881794] EtherCAT DEBUG 0-0: Sync after 240 ms: 629940 ns
[ 2187.882794] EtherCAT DEBUG 0-0: Sync after 240 ms: 627177 ns
[ 2187.883799] EtherCAT DEBUG 0-0: Sync after 244 ms: 621842 ns
[ 2187.884795] EtherCAT DEBUG 0-0: Sync after 244 ms: 620408 ns
[ 2187.885794] EtherCAT DEBUG 0-0: Sync after 244 ms: 618297 ns
[ 2187.886794] EtherCAT DEBUG 0-0: Sync after 244 ms: 627776 ns
[ 2187.887794] EtherCAT DEBUG 0-0: Sync after 248 ms: 617937 ns
[ 2187.888794] EtherCAT DEBUG 0-0: Sync after 248 ms: 616025 ns
[ 2187.889794] EtherCAT DEBUG 0-0: Sync after 248 ms: 619557 ns
[ 2187.890796] EtherCAT DEBUG 0-0: Sync after 248 ms: 614462 ns
[ 2187.891799] EtherCAT DEBUG 0-0: Sync after 252 ms: 613765 ns
[ 2187.892795] EtherCAT DEBUG 0-0: Sync after 252 ms: 612026 ns
[ 2187.893794] EtherCAT DEBUG 0-0: Sync after 252 ms: 614390 ns
[ 2187.894794] EtherCAT DEBUG 0-0: Sync after 252 ms: 614423 ns
[ 2187.895794] EtherCAT DEBUG 0-0: Sync after 256 ms: 609573 ns
[ 2187.896794] EtherCAT DEBUG 0-0: Sync after 256 ms: 609081 ns
[ 2187.897794] EtherCAT DEBUG 0-0: Sync after 256 ms: 606879 ns
[ 2187.898794] EtherCAT DEBUG 0-0: Sync after 256 ms: 606219 ns
[ 2187.899799] EtherCAT DEBUG 0-0: Sync after 260 ms: 605910 ns
[ 2187.900795] EtherCAT DEBUG 0-0: Sync after 260 ms: 604336 ns
[ 2187.901794] EtherCAT DEBUG 0-0: Sync after 260 ms: 601257 ns
[ 2187.902794] EtherCAT DEBUG 0-0: Sync after 260 ms: 602352 ns
[ 2187.903794] EtherCAT DEBUG 0-0: Sync after 264 ms: 601107 ns
[ 2187.904794] EtherCAT DEBUG 0-0: Sync after 264 ms: 600871 ns
[ 2187.905793] EtherCAT DEBUG 0-0: Sync after 264 ms: 599344 ns
[ 2187.906794] EtherCAT DEBUG 0-0: Sync after 264 ms: 603172 ns
[ 2187.907799] EtherCAT DEBUG 0-0: Sync after 268 ms: 597722 ns
[ 2187.908795] EtherCAT DEBUG 0-0: Sync after 268 ms: 597181 ns
[ 2187.909800] EtherCAT DEBUG 0-0: Sync after 268 ms: 594571 ns
[ 2187.910797] EtherCAT DEBUG 0-0: Sync after 268 ms: 598865 ns
[ 2187.911799] EtherCAT DEBUG 0-0: Sync after 272 ms: 594917 ns
[ 2187.912795] EtherCAT DEBUG 0-0: Sync after 272 ms: 590409 ns
[ 2187.913795] EtherCAT DEBUG 0-0: Sync after 272 ms: 589649 ns
[ 2187.914794] EtherCAT DEBUG 0-0: Sync after 272 ms: 590892 ns
[ 2187.915799] EtherCAT DEBUG 0-0: Sync after 276 ms: 589168 ns
[ 2187.916795] EtherCAT DEBUG 0-0: Sync after 276 ms: 588699 ns
[ 2187.917794] EtherCAT DEBUG 0-0: Sync after 276 ms: 586531 ns
[ 2187.918794] EtherCAT DEBUG 0-0: Sync after 276 ms: 586757 ns
[ 2187.919794] EtherCAT DEBUG 0-0: Sync after 280 ms: 585026 ns
[ 2187.920795] EtherCAT DEBUG 0-0: Sync after 280 ms: 584885 ns
[ 2187.921794] EtherCAT DEBUG 0-0: Sync after 280 ms: 583560 ns
[ 2187.922794] EtherCAT DEBUG 0-0: Sync after 280 ms: 581679 ns
[ 2187.923799] EtherCAT DEBUG 0-0: Sync after 284 ms: 581644 ns
[ 2187.924795] EtherCAT DEBUG 0-0: Sync after 284 ms: 580234 ns
[ 2187.925794] EtherCAT DEBUG 0-0: Sync after 284 ms: 578086 ns
[ 2187.926794] EtherCAT DEBUG 0-0: Sync after 284 ms: 577829 ns
[ 2187.927794] EtherCAT DEBUG 0-0: Sync after 288 ms: 578215 ns
[ 2187.928794] EtherCAT DEBUG 0-0: Sync after 288 ms: 577059 ns
[ 2187.929794] EtherCAT DEBUG 0-0: Sync after 288 ms: 575799 ns
[ 2187.930794] EtherCAT DEBUG 0-0: Sync after 288 ms: 575088 ns
[ 2187.931799] EtherCAT DEBUG 0-0: Sync after 292 ms: 574189 ns
[ 2187.932795] EtherCAT DEBUG 0-0: Sync after 292 ms: 572163 ns
[ 2187.933794] EtherCAT DEBUG 0-0: Sync after 292 ms: 570014 ns
[ 2187.934794] EtherCAT DEBUG 0-0: Sync after 292 ms: 570957 ns
[ 2187.935794] EtherCAT DEBUG 0-0: Sync after 296 ms: 569809 ns
[ 2187.936794] EtherCAT DEBUG 0-0: Sync after 296 ms: 568566 ns
[ 2187.937793] EtherCAT DEBUG 0-0: Sync after 296 ms: 567245 ns
[ 2187.938794] EtherCAT DEBUG 0-0: Sync after 296 ms: 575970 ns
[ 2187.939799] EtherCAT DEBUG 0-0: Sync after 300 ms: 565781 ns
[ 2187.940795] EtherCAT DEBUG 0-0: Sync after 300 ms: 565222 ns
[ 2187.941796] EtherCAT DEBUG 0-0: Sync after 300 ms: 562326 ns
[ 2187.942794] EtherCAT DEBUG 0-0: Sync after 300 ms: 562665 ns
[ 2187.943799] EtherCAT DEBUG 0-0: Sync after 304 ms: 564757 ns
[ 2187.944795] EtherCAT DEBUG 0-0: Sync after 304 ms: 560138 ns
[ 2187.945794] EtherCAT DEBUG 0-0: Sync after 304 ms: 558513 ns
[ 2187.946794] EtherCAT DEBUG 0-0: Sync after 304 ms: 562523 ns
[ 2187.947794] EtherCAT DEBUG 0-0: Sync after 308 ms: 562025 ns
[ 2187.948794] EtherCAT DEBUG 0-0: Sync after 308 ms: 556978 ns
[ 2187.949794] EtherCAT DEBUG 0-0: Sync after 308 ms: 559445 ns
[ 2187.950794] EtherCAT DEBUG 0-0: Sync after 308 ms: 554570 ns
[ 2187.951798] EtherCAT DEBUG 0-0: Sync after 312 ms: 553362 ns
[ 2187.952795] EtherCAT DEBUG 0-0: Sync after 312 ms: 552474 ns
[ 2187.953794] EtherCAT DEBUG 0-0: Sync after 312 ms: 553839 ns
[ 2187.954794] EtherCAT DEBUG 0-0: Sync after 312 ms: 550622 ns
[ 2187.955794] EtherCAT DEBUG 0-0: Sync after 316 ms: 549828 ns
[ 2187.956794] EtherCAT DEBUG 0-0: Sync after 316 ms: 548809 ns
[ 2187.957794] EtherCAT DEBUG 0-0: Sync after 316 ms: 547114 ns
[ 2187.958793] EtherCAT DEBUG 0-0: Sync after 316 ms: 550632 ns
[ 2187.959799] EtherCAT DEBUG 0-0: Sync after 320 ms: 545983 ns
[ 2187.960795] EtherCAT DEBUG 0-0: Sync after 320 ms: 544349 ns
[ 2187.961794] EtherCAT DEBUG 0-0: Sync after 320 ms: 541470 ns
[ 2187.962794] EtherCAT DEBUG 0-0: Sync after 320 ms: 542391 ns
[ 2187.963794] EtherCAT DEBUG 0-0: Sync after 324 ms: 541430 ns
[ 2187.964794] EtherCAT DEBUG 0-0: Sync after 324 ms: 541089 ns
[ 2187.965794] EtherCAT DEBUG 0-0: Sync after 324 ms: 540128 ns
[ 2187.966794] EtherCAT DEBUG 0-0: Sync after 324 ms: 538760 ns
[ 2187.967799] EtherCAT DEBUG 0-0: Sync after 328 ms: 537901 ns
[ 2187.968795] EtherCAT DEBUG 0-0: Sync after 328 ms: 537276 ns
[ 2187.969794] EtherCAT DEBUG 0-0: Sync after 328 ms: 534413 ns
[ 2187.970794] EtherCAT DEBUG 0-0: Sync after 328 ms: 535159 ns
[ 2187.971794] EtherCAT DEBUG 0-0: Sync after 332 ms: 534354 ns
[ 2187.972794] EtherCAT DEBUG 0-0: Sync after 332 ms: 532566 ns
[ 2187.973795] EtherCAT DEBUG 0-0: Sync after 332 ms: 541608 ns
[ 2187.974794] EtherCAT DEBUG 0-0: Sync after 332 ms: 531043 ns
[ 2187.975799] EtherCAT DEBUG 0-0: Sync after 336 ms: 529635 ns
[ 2187.976795] EtherCAT DEBUG 0-0: Sync after 336 ms: 528116 ns
[ 2187.977794] EtherCAT DEBUG 0-0: Sync after 336 ms: 526626 ns
[ 2187.978794] EtherCAT DEBUG 0-0: Sync after 336 ms: 535644 ns
[ 2187.979794] EtherCAT DEBUG 0-0: Sync after 340 ms: 525936 ns
[ 2187.980794] EtherCAT DEBUG 0-0: Sync after 340 ms: 525419 ns
[ 2187.981794] EtherCAT DEBUG 0-0: Sync after 340 ms: 523850 ns
[ 2187.982794] EtherCAT DEBUG 0-0: Sync after 340 ms: 523549 ns
[ 2187.983799] EtherCAT DEBUG 0-0: Sync after 344 ms: 521570 ns
[ 2187.984795] EtherCAT DEBUG 0-0: Sync after 344 ms: 520831 ns
[ 2187.985794] EtherCAT DEBUG 0-0: Sync after 344 ms: 518361 ns
[ 2187.986794] EtherCAT DEBUG 0-0: Sync after 344 ms: 518785 ns
[ 2187.987799] EtherCAT DEBUG 0-0: Sync after 348 ms: 527193 ns
[ 2187.988795] EtherCAT DEBUG 0-0: Sync after 348 ms: 521652 ns
[ 2187.989794] EtherCAT DEBUG 0-0: Sync after 348 ms: 514310 ns
[ 2187.990794] EtherCAT DEBUG 0-0: Sync after 348 ms: 519639 ns
[ 2187.991794] EtherCAT DEBUG 0-0: Sync after 352 ms: 514424 ns
[ 2187.992794] EtherCAT DEBUG 0-0: Sync after 352 ms: 512381 ns
[ 2187.993793] EtherCAT DEBUG 0-0: Sync after 352 ms: 512137 ns
[ 2187.994794] EtherCAT DEBUG 0-0: Sync after 352 ms: 520198 ns
[ 2187.995799] EtherCAT DEBUG 0-0: Sync after 356 ms: 510440 ns
[ 2187.996795] EtherCAT DEBUG 0-0: Sync after 356 ms: 509244 ns
[ 2187.997794] EtherCAT DEBUG 0-0: Sync after 356 ms: 506691 ns
[ 2187.998794] EtherCAT DEBUG 0-0: Sync after 356 ms: 506898 ns
[ 2187.999794] EtherCAT DEBUG 0-0: Sync after 360 ms: 505499 ns
[ 2188.000794] EtherCAT DEBUG 0-0: Sync after 360 ms: 505102 ns
[ 2188.001794] EtherCAT DEBUG 0-0: Sync after 360 ms: 503806 ns
[ 2188.002794] EtherCAT DEBUG 0-0: Sync after 360 ms: 502924 ns
[ 2188.003800] EtherCAT DEBUG 0-0: Sync after 364 ms: 501675 ns
[ 2188.004796] EtherCAT DEBUG 0-0: Sync after 364 ms: 501069 ns
[ 2188.005794] EtherCAT DEBUG 0-0: Sync after 364 ms: 497682 ns
[ 2188.006794] EtherCAT DEBUG 0-0: Sync after 364 ms: 498544 ns
[ 2188.007794] EtherCAT DEBUG 0-0: Sync after 368 ms: 497814 ns
[ 2188.008794] EtherCAT DEBUG 0-0: Sync after 368 ms: 496815 ns
[ 2188.009794] EtherCAT DEBUG 0-0: Sync after 368 ms: 495769 ns
[ 2188.010794] EtherCAT DEBUG 0-0: Sync after 368 ms: 499519 ns
[ 2188.011799] EtherCAT DEBUG 0-0: Sync after 372 ms: 494391 ns
[ 2188.012795] EtherCAT DEBUG 0-0: Sync after 372 ms: 492496 ns
[ 2188.013794] EtherCAT DEBUG 0-0: Sync after 372 ms: 490478 ns
[ 2188.014798] EtherCAT DEBUG 0-0: Sync after 372 ms: 491286 ns
[ 2188.015794] EtherCAT DEBUG 0-0: Sync after 376 ms: 490506 ns
[ 2188.016794] EtherCAT DEBUG 0-0: Sync after 376 ms: 487192 ns
[ 2188.017794] EtherCAT DEBUG 0-0: Sync after 376 ms: 486154 ns
[ 2188.018793] EtherCAT DEBUG 0-0: Sync after 376 ms: 487381 ns
[ 2188.019799] EtherCAT DEBUG 0-0: Sync after 380 ms: 485598 ns
[ 2188.020795] EtherCAT DEBUG 0-0: Sync after 380 ms: 485485 ns
[ 2188.021794] EtherCAT DEBUG 0-0: Sync after 380 ms: 481894 ns
[ 2188.022794] EtherCAT DEBUG 0-0: Sync after 380 ms: 482637 ns
[ 2188.023794] EtherCAT DEBUG 0-0: Sync after 384 ms: 482609 ns
[ 2188.024794] EtherCAT DEBUG 0-0: Sync after 384 ms: 481647 ns
[ 2188.025794] EtherCAT DEBUG 0-0: Sync after 384 ms: 489287 ns
[ 2188.026794] EtherCAT DEBUG 0-0: Sync after 384 ms: 479540 ns
[ 2188.027796] EtherCAT DEBUG 0-0: Sync after 388 ms: 478352 ns
[ 2188.028794] EtherCAT DEBUG 0-0: Sync after 388 ms: 477164 ns
[ 2188.029794] EtherCAT DEBUG 0-0: Sync after 388 ms: 474566 ns
[ 2188.030794] EtherCAT DEBUG 0-0: Sync after 388 ms: 474418 ns
[ 2188.031794] EtherCAT DEBUG 0-0: Sync after 392 ms: 473455 ns
[ 2188.032794] EtherCAT DEBUG 0-0: Sync after 392 ms: 473655 ns
[ 2188.033796] EtherCAT DEBUG 0-0: Sync after 392 ms: 472387 ns
[ 2188.034799] EtherCAT DEBUG 0-0: Sync after 392 ms: 471547 ns
[ 2188.035798] EtherCAT DEBUG 0-0: Sync after 396 ms: 469217 ns
[ 2188.036794] EtherCAT DEBUG 0-0: Sync after 396 ms: 476425 ns
[ 2188.037794] EtherCAT DEBUG 0-0: Sync after 396 ms: 465563 ns
[ 2188.038794] EtherCAT DEBUG 0-0: Sync after 396 ms: 467184 ns
[ 2188.039796] EtherCAT DEBUG 0-0: Sync after 400 ms: 474972 ns
[ 2188.040794] EtherCAT DEBUG 0-0: Sync after 400 ms: 469692 ns
[ 2188.041794] EtherCAT DEBUG 0-0: Sync after 400 ms: 462718 ns
[ 2188.042794] EtherCAT DEBUG 0-0: Sync after 400 ms: 463084 ns
[ 2188.043794] EtherCAT DEBUG 0-0: Sync after 404 ms: 467253 ns
[ 2188.044794] EtherCAT DEBUG 0-0: Sync after 404 ms: 460824 ns
[ 2188.045797] EtherCAT DEBUG 0-0: Sync after 404 ms: 464069 ns
[ 2188.046795] EtherCAT DEBUG 0-0: Sync after 404 ms: 458796 ns
[ 2188.047796] EtherCAT DEBUG 0-0: Sync after 408 ms: 456066 ns
[ 2188.048794] EtherCAT DEBUG 0-0: Sync after 408 ms: 456129 ns
[ 2188.049794] EtherCAT DEBUG 0-0: Sync after 408 ms: 454460 ns
[ 2188.050794] EtherCAT DEBUG 0-0: Sync after 408 ms: 455139 ns
[ 2188.051794] EtherCAT DEBUG 0-0: Sync after 412 ms: 454560 ns
[ 2188.052794] EtherCAT DEBUG 0-0: Sync after 412 ms: 453162 ns
[ 2188.053794] EtherCAT DEBUG 0-0: Sync after 412 ms: 451816 ns
[ 2188.054794] EtherCAT DEBUG 0-0: Sync after 412 ms: 451382 ns
[ 2188.055796] EtherCAT DEBUG 0-0: Sync after 416 ms: 450143 ns
[ 2188.056795] EtherCAT DEBUG 0-0: Sync after 416 ms: 449598 ns
[ 2188.057794] EtherCAT DEBUG 0-0: Sync after 416 ms: 447443 ns
[ 2188.058794] EtherCAT DEBUG 0-0: Sync after 416 ms: 446640 ns
[ 2188.059794] EtherCAT DEBUG 0-0: Sync after 420 ms: 446575 ns
[ 2188.060794] EtherCAT DEBUG 0-0: Sync after 420 ms: 444798 ns
[ 2188.061794] EtherCAT DEBUG 0-0: Sync after 420 ms: 444028 ns
[ 2188.062794] EtherCAT DEBUG 0-0: Sync after 420 ms: 447900 ns
[ 2188.063796] EtherCAT DEBUG 0-0: Sync after 424 ms: 451959 ns
[ 2188.064799] EtherCAT DEBUG 0-0: Sync after 424 ms: 441848 ns
[ 2188.065798] EtherCAT DEBUG 0-0: Sync after 424 ms: 443666 ns
[ 2188.066794] EtherCAT DEBUG 0-0: Sync after 424 ms: 437257 ns
[ 2188.067797] EtherCAT DEBUG 0-0: Sync after 428 ms: 436476 ns
[ 2188.068794] EtherCAT DEBUG 0-0: Sync after 428 ms: 436735 ns
[ 2188.069794] EtherCAT DEBUG 0-0: Sync after 428 ms: 439119 ns
[ 2188.070794] EtherCAT DEBUG 0-0: Sync after 428 ms: 435753 ns
[ 2188.071794] EtherCAT DEBUG 0-0: Sync after 432 ms: 434090 ns
[ 2188.072794] EtherCAT DEBUG 0-0: Sync after 432 ms: 432845 ns
[ 2188.073794] EtherCAT DEBUG 0-0: Sync after 432 ms: 432189 ns
[ 2188.074793] EtherCAT DEBUG 0-0: Sync after 432 ms: 431242 ns
[ 2188.075796] EtherCAT DEBUG 0-0: Sync after 436 ms: 430868 ns
[ 2188.076795] EtherCAT DEBUG 0-0: Sync after 436 ms: 429459 ns
[ 2188.077794] EtherCAT DEBUG 0-0: Sync after 436 ms: 431510 ns
[ 2188.078794] EtherCAT DEBUG 0-0: Sync after 436 ms: 427058 ns
[ 2188.079796] EtherCAT DEBUG 0-0: Sync after 440 ms: 425804 ns
[ 2188.080794] EtherCAT DEBUG 0-0: Sync after 440 ms: 425471 ns
[ 2188.081794] EtherCAT DEBUG 0-0: Sync after 440 ms: 427225 ns
[ 2188.082794] EtherCAT DEBUG 0-0: Sync after 440 ms: 432466 ns
[ 2188.083794] EtherCAT DEBUG 0-0: Sync after 444 ms: 422899 ns
[ 2188.084794] EtherCAT DEBUG 0-0: Sync after 444 ms: 431147 ns
[ 2188.085794] EtherCAT DEBUG 0-0: Sync after 444 ms: 420042 ns
[ 2188.086794] EtherCAT DEBUG 0-0: Sync after 444 ms: 419127 ns
[ 2188.087796] EtherCAT DEBUG 0-0: Sync after 448 ms: 418733 ns
[ 2188.088794] EtherCAT DEBUG 0-0: Sync after 448 ms: 421099 ns
[ 2188.089794] EtherCAT DEBUG 0-0: Sync after 448 ms: 415038 ns
[ 2188.090794] EtherCAT DEBUG 0-0: Sync after 448 ms: 414807 ns
[ 2188.091794] EtherCAT DEBUG 0-0: Sync after 452 ms: 413807 ns
[ 2188.092794] EtherCAT DEBUG 0-0: Sync after 452 ms: 418060 ns
[ 2188.093795] EtherCAT DEBUG 0-0: Sync after 452 ms: 416467 ns
[ 2188.094794] EtherCAT DEBUG 0-0: Sync after 452 ms: 411692 ns
[ 2188.095796] EtherCAT DEBUG 0-0: Sync after 456 ms: 419532 ns
[ 2188.096794] EtherCAT DEBUG 0-0: Sync after 456 ms: 408759 ns
[ 2188.097795] EtherCAT DEBUG 0-0: Sync after 456 ms: 406629 ns
[ 2188.098794] EtherCAT DEBUG 0-0: Sync after 456 ms: 416639 ns
[ 2188.099796] EtherCAT DEBUG 0-0: Sync after 460 ms: 406214 ns
[ 2188.100794] EtherCAT DEBUG 0-0: Sync after 460 ms: 414485 ns
[ 2188.101794] EtherCAT DEBUG 0-0: Sync after 460 ms: 403273 ns
[ 2188.102794] EtherCAT DEBUG 0-0: Sync after 460 ms: 403066 ns
[ 2188.103794] EtherCAT DEBUG 0-0: Sync after 464 ms: 411872 ns
[ 2188.104794] EtherCAT DEBUG 0-0: Sync after 464 ms: 401706 ns
[ 2188.105794] EtherCAT DEBUG 0-0: Sync after 464 ms: 404377 ns
[ 2188.106794] EtherCAT DEBUG 0-0: Sync after 464 ms: 399382 ns
[ 2188.107796] EtherCAT DEBUG 0-0: Sync after 468 ms: 407228 ns
[ 2188.108794] EtherCAT DEBUG 0-0: Sync after 468 ms: 397683 ns
[ 2188.109794] EtherCAT DEBUG 0-0: Sync after 468 ms: 394681 ns
[ 2188.110794] EtherCAT DEBUG 0-0: Sync after 468 ms: 399694 ns
[ 2188.111794] EtherCAT DEBUG 0-0: Sync after 472 ms: 394389 ns
[ 2188.112794] EtherCAT DEBUG 0-0: Sync after 472 ms: 393658 ns
[ 2188.113793] EtherCAT DEBUG 0-0: Sync after 472 ms: 392320 ns
[ 2188.114794] EtherCAT DEBUG 0-0: Sync after 472 ms: 391268 ns
[ 2188.115796] EtherCAT DEBUG 0-0: Sync after 476 ms: 390368 ns
[ 2188.116794] EtherCAT DEBUG 0-0: Sync after 476 ms: 389886 ns
[ 2188.117794] EtherCAT DEBUG 0-0: Sync after 476 ms: 387495 ns
[ 2188.118794] EtherCAT DEBUG 0-0: Sync after 476 ms: 387885 ns
[ 2188.119794] EtherCAT DEBUG 0-0: Sync after 480 ms: 386132 ns
[ 2188.120794] EtherCAT DEBUG 0-0: Sync after 480 ms: 386045 ns
[ 2188.121794] EtherCAT DEBUG 0-0: Sync after 480 ms: 383650 ns
[ 2188.122794] EtherCAT DEBUG 0-0: Sync after 480 ms: 383547 ns
[ 2188.123796] EtherCAT DEBUG 0-0: Sync after 484 ms: 382731 ns
[ 2188.124794] EtherCAT DEBUG 0-0: Sync after 484 ms: 381244 ns
[ 2188.125794] EtherCAT DEBUG 0-0: Sync after 484 ms: 388038 ns
[ 2188.126799] EtherCAT DEBUG 0-0: Sync after 484 ms: 384035 ns
[ 2188.127797] EtherCAT DEBUG 0-0: Sync after 488 ms: 382639 ns
[ 2188.128795] EtherCAT DEBUG 0-0: Sync after 488 ms: 375947 ns
[ 2188.129794] EtherCAT DEBUG 0-0: Sync after 488 ms: 375245 ns
[ 2188.130794] EtherCAT DEBUG 0-0: Sync after 488 ms: 383726 ns
[ 2188.131796] EtherCAT DEBUG 0-0: Sync after 492 ms: 374117 ns
[ 2188.132794] EtherCAT DEBUG 0-0: Sync after 492 ms: 373221 ns
[ 2188.133794] EtherCAT DEBUG 0-0: Sync after 492 ms: 371483 ns
[ 2188.134794] EtherCAT DEBUG 0-0: Sync after 492 ms: 380251 ns
[ 2188.135794] EtherCAT DEBUG 0-0: Sync after 496 ms: 370210 ns
[ 2188.136794] EtherCAT DEBUG 0-0: Sync after 496 ms: 369699 ns
[ 2188.137794] EtherCAT DEBUG 0-0: Sync after 496 ms: 368171 ns
[ 2188.138794] EtherCAT DEBUG 0-0: Sync after 496 ms: 367460 ns
[ 2188.139796] EtherCAT DEBUG 0-0: Sync after 500 ms: 366252 ns
[ 2188.140794] EtherCAT DEBUG 0-0: Sync after 500 ms: 369323 ns
[ 2188.141794] EtherCAT DEBUG 0-0: Sync after 500 ms: 363143 ns
[ 2188.142794] EtherCAT DEBUG 0-0: Sync after 500 ms: 363916 ns
[ 2188.143794] EtherCAT DEBUG 0-0: Sync after 504 ms: 362957 ns
[ 2188.144794] EtherCAT DEBUG 0-0: Sync after 504 ms: 361009 ns
[ 2188.145794] EtherCAT DEBUG 0-0: Sync after 504 ms: 360609 ns
[ 2188.146794] EtherCAT DEBUG 0-0: Sync after 504 ms: 359711 ns
[ 2188.147795] EtherCAT DEBUG 0-0: Sync after 508 ms: 357870 ns
[ 2188.148794] EtherCAT DEBUG 0-0: Sync after 508 ms: 358124 ns
[ 2188.149794] EtherCAT DEBUG 0-0: Sync after 508 ms: 356011 ns
[ 2188.150793] EtherCAT DEBUG 0-0: Sync after 508 ms: 364436 ns
[ 2188.151794] EtherCAT DEBUG 0-0: Sync after 512 ms: 363493 ns
[ 2188.152797] EtherCAT DEBUG 0-0: Sync after 512 ms: 353241 ns
[ 2188.153798] EtherCAT DEBUG 0-0: Sync after 512 ms: 356713 ns
[ 2188.154801] EtherCAT DEBUG 0-0: Sync after 512 ms: 355224 ns
[ 2188.155796] EtherCAT DEBUG 0-0: Sync after 516 ms: 347990 ns
[ 2188.156800] EtherCAT DEBUG 0-0: Sync after 516 ms: 346878 ns
[ 2188.157800] EtherCAT DEBUG 0-0: Sync after 516 ms: 346951 ns
[ 2188.158800] EtherCAT DEBUG 0-0: Sync after 516 ms: 344555 ns
[ 2188.159800] EtherCAT DEBUG 0-0: Sync after 520 ms: 348480 ns
[ 2188.160800] EtherCAT DEBUG 0-0: Sync after 520 ms: 343545 ns
[ 2188.161802] EtherCAT DEBUG 0-0: Sync after 520 ms: 341604 ns
[ 2188.162796] EtherCAT DEBUG 0-0: Sync after 520 ms: 341041 ns
[ 2188.163796] EtherCAT DEBUG 0-0: Sync after 524 ms: 339330 ns
[ 2188.164800] EtherCAT DEBUG 0-0: Sync after 524 ms: 339122 ns
[ 2188.165797] EtherCAT DEBUG 0-0: Sync after 524 ms: 348535 ns
[ 2188.166794] EtherCAT DEBUG 0-0: Sync after 524 ms: 341080 ns
[ 2188.167795] EtherCAT DEBUG 0-0: Sync after 528 ms: 336383 ns
[ 2188.168794] EtherCAT DEBUG 0-0: Sync after 528 ms: 336686 ns
[ 2188.169794] EtherCAT DEBUG 0-0: Sync after 528 ms: 335011 ns
[ 2188.170793] EtherCAT DEBUG 0-0: Sync after 528 ms: 340180 ns
[ 2188.171796] EtherCAT DEBUG 0-0: Sync after 532 ms: 334192 ns
[ 2188.172794] EtherCAT DEBUG 0-0: Sync after 532 ms: 334105 ns
[ 2188.173795] EtherCAT DEBUG 0-0: Sync after 532 ms: 334797 ns
[ 2188.174798] EtherCAT DEBUG 0-0: Sync after 532 ms: 330941 ns
[ 2188.175795] EtherCAT DEBUG 0-0: Sync after 536 ms: 329664 ns
[ 2188.176794] EtherCAT DEBUG 0-0: Sync after 536 ms: 330005 ns
[ 2188.177794] EtherCAT DEBUG 0-0: Sync after 536 ms: 327623 ns
[ 2188.178794] EtherCAT DEBUG 0-0: Sync after 536 ms: 327381 ns
[ 2188.179797] EtherCAT DEBUG 0-0: Sync after 540 ms: 326641 ns
[ 2188.180794] EtherCAT DEBUG 0-0: Sync after 540 ms: 326147 ns
[ 2188.181794] EtherCAT DEBUG 0-0: Sync after 540 ms: 323067 ns
[ 2188.182794] EtherCAT DEBUG 0-0: Sync after 540 ms: 324084 ns
[ 2188.183794] EtherCAT DEBUG 0-0: Sync after 544 ms: 326893 ns
[ 2188.184794] EtherCAT DEBUG 0-0: Sync after 544 ms: 321275 ns
[ 2188.185794] EtherCAT DEBUG 0-0: Sync after 544 ms: 320383 ns
[ 2188.186793] EtherCAT DEBUG 0-0: Sync after 544 ms: 319763 ns
[ 2188.187795] EtherCAT DEBUG 0-0: Sync after 548 ms: 318651 ns
[ 2188.188798] EtherCAT DEBUG 0-0: Sync after 548 ms: 317263 ns
[ 2188.189798] EtherCAT DEBUG 0-0: Sync after 548 ms: 319560 ns
[ 2188.190795] EtherCAT DEBUG 0-0: Sync after 548 ms: 314366 ns
[ 2188.191796] EtherCAT DEBUG 0-0: Sync after 552 ms: 312449 ns
[ 2188.192795] EtherCAT DEBUG 0-0: Sync after 552 ms: 313560 ns
[ 2188.193793] EtherCAT DEBUG 0-0: Sync after 552 ms: 310610 ns
[ 2188.194794] EtherCAT DEBUG 0-0: Sync after 552 ms: 319925 ns
[ 2188.195794] EtherCAT DEBUG 0-0: Sync after 556 ms: 320128 ns
[ 2188.196794] EtherCAT DEBUG 0-0: Sync after 556 ms: 309910 ns
[ 2188.197794] EtherCAT DEBUG 0-0: Sync after 556 ms: 307972 ns
[ 2188.198794] EtherCAT DEBUG 0-0: Sync after 556 ms: 308104 ns
[ 2188.199795] EtherCAT DEBUG 0-0: Sync after 560 ms: 306213 ns
[ 2188.200800] EtherCAT DEBUG 0-0: Sync after 560 ms: 315283 ns
[ 2188.201794] EtherCAT DEBUG 0-0: Sync after 560 ms: 303810 ns
[ 2188.202794] EtherCAT DEBUG 0-0: Sync after 560 ms: 300758 ns
[ 2188.203797] EtherCAT DEBUG 0-0: Sync after 564 ms: 302679 ns
[ 2188.204794] EtherCAT DEBUG 0-0: Sync after 564 ms: 310900 ns
[ 2188.205797] EtherCAT DEBUG 0-0: Sync after 564 ms: 299163 ns
[ 2188.206798] EtherCAT DEBUG 0-0: Sync after 564 ms: 298904 ns
[ 2188.207796] EtherCAT DEBUG 0-0: Sync after 568 ms: 302493 ns
[ 2188.208794] EtherCAT DEBUG 0-0: Sync after 568 ms: 295611 ns
[ 2188.209794] EtherCAT DEBUG 0-0: Sync after 568 ms: 294372 ns
[ 2188.210794] EtherCAT DEBUG 0-0: Sync after 568 ms: 295314 ns
[ 2188.211794] EtherCAT DEBUG 0-0: Sync after 572 ms: 298985 ns
[ 2188.212794] EtherCAT DEBUG 0-0: Sync after 572 ms: 294452 ns
[ 2188.213794] EtherCAT DEBUG 0-0: Sync after 572 ms: 292371 ns
[ 2188.214794] EtherCAT DEBUG 0-0: Sync after 572 ms: 291994 ns
[ 2188.215796] EtherCAT DEBUG 0-0: Sync after 576 ms: 290914 ns
[ 2188.216795] EtherCAT DEBUG 0-0: Sync after 576 ms: 289791 ns
[ 2188.217794] EtherCAT DEBUG 0-0: Sync after 576 ms: 296294 ns
[ 2188.218794] EtherCAT DEBUG 0-0: Sync after 576 ms: 286675 ns
[ 2188.219796] EtherCAT DEBUG 0-0: Sync after 580 ms: 287070 ns
[ 2188.220800] EtherCAT DEBUG 0-0: Sync after 580 ms: 285437 ns
[ 2188.221798] EtherCAT DEBUG 0-0: Sync after 580 ms: 287249 ns
[ 2188.222794] EtherCAT DEBUG 0-0: Sync after 580 ms: 281177 ns
[ 2188.223796] EtherCAT DEBUG 0-0: Sync after 584 ms: 280541 ns
[ 2188.224794] EtherCAT DEBUG 0-0: Sync after 584 ms: 281498 ns
[ 2188.225794] EtherCAT DEBUG 0-0: Sync after 584 ms: 283116 ns
[ 2188.226794] EtherCAT DEBUG 0-0: Sync after 584 ms: 288963 ns
[ 2188.227794] EtherCAT DEBUG 0-0: Sync after 588 ms: 278385 ns
[ 2188.228794] EtherCAT DEBUG 0-0: Sync after 588 ms: 277748 ns
[ 2188.229794] EtherCAT DEBUG 0-0: Sync after 588 ms: 276201 ns
[ 2188.230794] EtherCAT DEBUG 0-0: Sync after 588 ms: 275467 ns
[ 2188.231797] EtherCAT DEBUG 0-0: Sync after 592 ms: 275149 ns
[ 2188.232795] EtherCAT DEBUG 0-0: Sync after 592 ms: 273721 ns
[ 2188.233798] EtherCAT DEBUG 0-0: Sync after 592 ms: 270807 ns
[ 2188.234796] EtherCAT DEBUG 0-0: Sync after 592 ms: 271442 ns
[ 2188.235796] EtherCAT DEBUG 0-0: Sync after 596 ms: 269467 ns
[ 2188.236794] EtherCAT DEBUG 0-0: Sync after 596 ms: 269661 ns
[ 2188.237794] EtherCAT DEBUG 0-0: Sync after 596 ms: 268013 ns
[ 2188.238794] EtherCAT DEBUG 0-0: Sync after 596 ms: 267997 ns
[ 2188.239794] EtherCAT DEBUG 0-0: Sync after 600 ms: 267324 ns
[ 2188.240794] EtherCAT DEBUG 0-0: Sync after 600 ms: 275734 ns
[ 2188.241793] EtherCAT DEBUG 0-0: Sync after 600 ms: 263905 ns
[ 2188.242793] EtherCAT DEBUG 0-0: Sync after 600 ms: 263639 ns
[ 2188.243796] EtherCAT DEBUG 0-0: Sync after 604 ms: 263277 ns
[ 2188.244794] EtherCAT DEBUG 0-0: Sync after 604 ms: 262552 ns
[ 2188.245794] EtherCAT DEBUG 0-0: Sync after 604 ms: 260142 ns
[ 2188.246793] EtherCAT DEBUG 0-0: Sync after 604 ms: 260311 ns
[ 2188.247794] EtherCAT DEBUG 0-0: Sync after 608 ms: 258272 ns
[ 2188.248794] EtherCAT DEBUG 0-0: Sync after 608 ms: 261973 ns
[ 2188.249794] EtherCAT DEBUG 0-0: Sync after 608 ms: 260857 ns
[ 2188.250799] EtherCAT DEBUG 0-0: Sync after 608 ms: 256547 ns
[ 2188.251798] EtherCAT DEBUG 0-0: Sync after 612 ms: 254570 ns
[ 2188.252797] EtherCAT DEBUG 0-0: Sync after 612 ms: 251800 ns
[ 2188.253794] EtherCAT DEBUG 0-0: Sync after 612 ms: 250895 ns
[ 2188.254793] EtherCAT DEBUG 0-0: Sync after 612 ms: 251382 ns
[ 2188.255796] EtherCAT DEBUG 0-0: Sync after 616 ms: 251126 ns
[ 2188.256794] EtherCAT DEBUG 0-0: Sync after 616 ms: 249889 ns
[ 2188.257794] EtherCAT DEBUG 0-0: Sync after 616 ms: 247513 ns
[ 2188.258794] EtherCAT DEBUG 0-0: Sync after 616 ms: 247752 ns
[ 2188.259796] EtherCAT DEBUG 0-0: Sync after 620 ms: 246946 ns
[ 2188.260794] EtherCAT DEBUG 0-0: Sync after 620 ms: 246514 ns
[ 2188.261794] EtherCAT DEBUG 0-0: Sync after 620 ms: 243911 ns
[ 2188.262795] EtherCAT DEBUG 0-0: Sync after 620 ms: 244441 ns
[ 2188.263796] EtherCAT DEBUG 0-0: Sync after 624 ms: 252086 ns
[ 2188.264794] EtherCAT DEBUG 0-0: Sync after 624 ms: 242043 ns
[ 2188.265794] EtherCAT DEBUG 0-0: Sync after 624 ms: 238951 ns
[ 2188.266794] EtherCAT DEBUG 0-0: Sync after 624 ms: 240062 ns
[ 2188.267794] EtherCAT DEBUG 0-0: Sync after 628 ms: 238457 ns
[ 2188.268794] EtherCAT DEBUG 0-0: Sync after 628 ms: 238736 ns
[ 2188.269794] EtherCAT DEBUG 0-0: Sync after 628 ms: 236912 ns
[ 2188.270794] EtherCAT DEBUG 0-0: Sync after 628 ms: 236192 ns
[ 2188.271796] EtherCAT DEBUG 0-0: Sync after 632 ms: 235164 ns
[ 2188.272794] EtherCAT DEBUG 0-0: Sync after 632 ms: 234121 ns
[ 2188.273794] EtherCAT DEBUG 0-0: Sync after 632 ms: 231037 ns
[ 2188.274794] EtherCAT DEBUG 0-0: Sync after 632 ms: 232119 ns
[ 2188.275794] EtherCAT DEBUG 0-0: Sync after 636 ms: 235744 ns
[ 2188.276794] EtherCAT DEBUG 0-0: Sync after 636 ms: 230733 ns
[ 2188.277794] EtherCAT DEBUG 0-0: Sync after 636 ms: 228814 ns
[ 2188.278794] EtherCAT DEBUG 0-0: Sync after 636 ms: 227684 ns
[ 2188.279796] EtherCAT DEBUG 0-0: Sync after 640 ms: 232028 ns
[ 2188.280794] EtherCAT DEBUG 0-0: Sync after 640 ms: 225730 ns
[ 2188.281799] EtherCAT DEBUG 0-0: Sync after 640 ms: 227350 ns
[ 2188.282798] EtherCAT DEBUG 0-0: Sync after 640 ms: 224626 ns
[ 2188.283797] EtherCAT DEBUG 0-0: Sync after 644 ms: 221072 ns
[ 2188.284794] EtherCAT DEBUG 0-0: Sync after 644 ms: 219581 ns
[ 2188.285794] EtherCAT DEBUG 0-0: Sync after 644 ms: 219494 ns
[ 2188.286794] EtherCAT DEBUG 0-0: Sync after 644 ms: 219933 ns
[ 2188.287794] EtherCAT DEBUG 0-0: Sync after 648 ms: 218503 ns
[ 2188.288794] EtherCAT DEBUG 0-0: Sync after 648 ms: 218560 ns
[ 2188.289794] EtherCAT DEBUG 0-0: Sync after 648 ms: 216149 ns
[ 2188.290794] EtherCAT DEBUG 0-0: Sync after 648 ms: 216421 ns
[ 2188.291797] EtherCAT DEBUG 0-0: Sync after 652 ms: 215142 ns
[ 2188.292794] EtherCAT DEBUG 0-0: Sync after 652 ms: 218320 ns
[ 2188.293794] EtherCAT DEBUG 0-0: Sync after 652 ms: 211129 ns
[ 2188.294796] EtherCAT DEBUG 0-0: Sync after 652 ms: 212534 ns
[ 2188.295795] EtherCAT DEBUG 0-0: Sync after 656 ms: 211052 ns
[ 2188.296794] EtherCAT DEBUG 0-0: Sync after 656 ms: 214273 ns
[ 2188.297794] EtherCAT DEBUG 0-0: Sync after 656 ms: 208224 ns
[ 2188.298793] EtherCAT DEBUG 0-0: Sync after 656 ms: 207742 ns
[ 2188.299794] EtherCAT DEBUG 0-0: Sync after 660 ms: 206793 ns
[ 2188.300794] EtherCAT DEBUG 0-0: Sync after 660 ms: 206816 ns
[ 2188.301794] EtherCAT DEBUG 0-0: Sync after 660 ms: 204472 ns
[ 2188.302794] EtherCAT DEBUG 0-0: Sync after 660 ms: 204157 ns
[ 2188.303795] EtherCAT DEBUG 0-0: Sync after 664 ms: 203012 ns
[ 2188.304794] EtherCAT DEBUG 0-0: Sync after 664 ms: 202387 ns
[ 2188.305794] EtherCAT DEBUG 0-0: Sync after 664 ms: 199850 ns
[ 2188.306793] EtherCAT DEBUG 0-0: Sync after 664 ms: 200093 ns
[ 2188.307794] EtherCAT DEBUG 0-0: Sync after 668 ms: 199248 ns
[ 2188.308794] EtherCAT DEBUG 0-0: Sync after 668 ms: 197791 ns
[ 2188.309794] EtherCAT DEBUG 0-0: Sync after 668 ms: 201345 ns
[ 2188.310794] EtherCAT DEBUG 0-0: Sync after 668 ms: 196649 ns
[ 2188.311794] EtherCAT DEBUG 0-0: Sync after 672 ms: 195667 ns
[ 2188.312794] EtherCAT DEBUG 0-0: Sync after 672 ms: 194523 ns
[ 2188.313801] EtherCAT DEBUG 0-0: Sync after 672 ms: 192201 ns
[ 2188.314796] EtherCAT DEBUG 0-0: Sync after 672 ms: 192650 ns
[ 2188.315795] EtherCAT DEBUG 0-0: Sync after 676 ms: 188883 ns
[ 2188.316794] EtherCAT DEBUG 0-0: Sync after 676 ms: 188192 ns
[ 2188.317794] EtherCAT DEBUG 0-0: Sync after 676 ms: 188840 ns
[ 2188.318794] EtherCAT DEBUG 0-0: Sync after 676 ms: 197403 ns
[ 2188.319794] EtherCAT DEBUG 0-0: Sync after 680 ms: 186863 ns
[ 2188.320794] EtherCAT DEBUG 0-0: Sync after 680 ms: 185614 ns
[ 2188.321794] EtherCAT DEBUG 0-0: Sync after 680 ms: 184905 ns
[ 2188.322793] EtherCAT DEBUG 0-0: Sync after 680 ms: 184181 ns
[ 2188.323795] EtherCAT DEBUG 0-0: Sync after 684 ms: 182910 ns
[ 2188.324799] EtherCAT DEBUG 0-0: Sync after 684 ms: 182114 ns
[ 2188.325795] EtherCAT DEBUG 0-0: Sync after 684 ms: 190270 ns
[ 2188.326794] EtherCAT DEBUG 0-0: Sync after 684 ms: 178090 ns
[ 2188.327795] EtherCAT DEBUG 0-0: Sync after 688 ms: 179331 ns
[ 2188.328794] EtherCAT DEBUG 0-0: Sync after 688 ms: 178040 ns
[ 2188.329794] EtherCAT DEBUG 0-0: Sync after 688 ms: 176678 ns
[ 2188.330793] EtherCAT DEBUG 0-0: Sync after 688 ms: 176229 ns
[ 2188.331794] EtherCAT DEBUG 0-0: Sync after 692 ms: 175565 ns
[ 2188.332794] EtherCAT DEBUG 0-0: Sync after 692 ms: 174889 ns
[ 2188.333794] EtherCAT DEBUG 0-0: Sync after 692 ms: 173018 ns
[ 2188.334796] EtherCAT DEBUG 0-0: Sync after 692 ms: 172684 ns
[ 2188.335795] EtherCAT DEBUG 0-0: Sync after 696 ms: 175788 ns
[ 2188.336794] EtherCAT DEBUG 0-0: Sync after 696 ms: 168716 ns
[ 2188.337794] EtherCAT DEBUG 0-0: Sync after 696 ms: 167671 ns
[ 2188.338794] EtherCAT DEBUG 0-0: Sync after 696 ms: 167985 ns
[ 2188.339794] EtherCAT DEBUG 0-0: Sync after 700 ms: 176362 ns
[ 2188.340794] EtherCAT DEBUG 0-0: Sync after 700 ms: 166570 ns
[ 2188.341794] EtherCAT DEBUG 0-0: Sync after 700 ms: 164766 ns
[ 2188.342794] EtherCAT DEBUG 0-0: Sync after 700 ms: 164397 ns
[ 2188.343795] EtherCAT DEBUG 0-0: Sync after 704 ms: 163296 ns
[ 2188.344799] EtherCAT DEBUG 0-0: Sync after 704 ms: 162675 ns
[ 2188.345797] EtherCAT DEBUG 0-0: Sync after 704 ms: 160031 ns
[ 2188.346794] EtherCAT DEBUG 0-0: Sync after 704 ms: 158626 ns
[ 2188.347795] EtherCAT DEBUG 0-0: Sync after 708 ms: 161003 ns
[ 2188.348794] EtherCAT DEBUG 0-0: Sync after 708 ms: 167823 ns
[ 2188.349795] EtherCAT DEBUG 0-0: Sync after 708 ms: 161140 ns
[ 2188.350794] EtherCAT DEBUG 0-0: Sync after 708 ms: 156039 ns
[ 2188.351794] EtherCAT DEBUG 0-0: Sync after 712 ms: 154885 ns
[ 2188.352794] EtherCAT DEBUG 0-0: Sync after 712 ms: 158697 ns
[ 2188.353794] EtherCAT DEBUG 0-0: Sync after 712 ms: 152512 ns
[ 2188.354795] EtherCAT DEBUG 0-0: Sync after 712 ms: 152815 ns
[ 2188.355797] EtherCAT DEBUG 0-0: Sync after 716 ms: 151015 ns
[ 2188.356795] EtherCAT DEBUG 0-0: Sync after 716 ms: 149831 ns
[ 2188.357794] EtherCAT DEBUG 0-0: Sync after 716 ms: 148201 ns
[ 2188.358794] EtherCAT DEBUG 0-0: Sync after 716 ms: 151703 ns
[ 2188.359797] EtherCAT DEBUG 0-0: Sync after 720 ms: 147885 ns
[ 2188.360794] EtherCAT DEBUG 0-0: Sync after 720 ms: 146786 ns
[ 2188.361794] EtherCAT DEBUG 0-0: Sync after 720 ms: 152877 ns
[ 2188.362794] EtherCAT DEBUG 0-0: Sync after 720 ms: 143949 ns
[ 2188.363794] EtherCAT DEBUG 0-0: Sync after 724 ms: 144070 ns
[ 2188.364794] EtherCAT DEBUG 0-0: Sync after 724 ms: 142949 ns
[ 2188.365794] EtherCAT DEBUG 0-0: Sync after 724 ms: 140902 ns
[ 2188.366794] EtherCAT DEBUG 0-0: Sync after 724 ms: 140868 ns
[ 2188.367795] EtherCAT DEBUG 0-0: Sync after 728 ms: 139592 ns
[ 2188.368793] EtherCAT DEBUG 0-0: Sync after 728 ms: 138257 ns
[ 2188.369794] EtherCAT DEBUG 0-0: Sync after 728 ms: 136122 ns
[ 2188.370795] EtherCAT DEBUG 0-0: Sync after 728 ms: 136641 ns
[ 2188.371794] EtherCAT DEBUG 0-0: Sync after 732 ms: 136042 ns
[ 2188.372794] EtherCAT DEBUG 0-0: Sync after 732 ms: 134101 ns
[ 2188.373794] EtherCAT DEBUG 0-0: Sync after 732 ms: 133595 ns
[ 2188.374795] EtherCAT DEBUG 0-0: Sync after 732 ms: 133083 ns
[ 2188.375801] EtherCAT DEBUG 0-0: Sync after 736 ms: 131606 ns
[ 2188.376801] EtherCAT DEBUG 0-0: Sync after 736 ms: 129735 ns
[ 2188.377794] EtherCAT DEBUG 0-0: Sync after 736 ms: 127409 ns
[ 2188.378794] EtherCAT DEBUG 0-0: Sync after 736 ms: 126211 ns
[ 2188.379794] EtherCAT DEBUG 0-0: Sync after 740 ms: 127390 ns
[ 2188.380794] EtherCAT DEBUG 0-0: Sync after 740 ms: 134830 ns
[ 2188.381793] EtherCAT DEBUG 0-0: Sync after 740 ms: 125549 ns
[ 2188.382794] EtherCAT DEBUG 0-0: Sync after 740 ms: 125139 ns
[ 2188.383795] EtherCAT DEBUG 0-0: Sync after 744 ms: 123832 ns
[ 2188.384793] EtherCAT DEBUG 0-0: Sync after 744 ms: 122589 ns
[ 2188.385794] EtherCAT DEBUG 0-0: Sync after 744 ms: 120258 ns
[ 2188.386800] EtherCAT DEBUG 0-0: Sync after 744 ms: 124493 ns
[ 2188.387794] EtherCAT DEBUG 0-0: Sync after 748 ms: 120148 ns
[ 2188.388794] EtherCAT DEBUG 0-0: Sync after 748 ms: 115923 ns
[ 2188.389794] EtherCAT DEBUG 0-0: Sync after 748 ms: 117369 ns
[ 2188.390794] EtherCAT DEBUG 0-0: Sync after 748 ms: 115991 ns
[ 2188.391795] EtherCAT DEBUG 0-0: Sync after 752 ms: 119557 ns
[ 2188.392794] EtherCAT DEBUG 0-0: Sync after 752 ms: 114285 ns
[ 2188.393794] EtherCAT DEBUG 0-0: Sync after 752 ms: 116368 ns
[ 2188.394794] EtherCAT DEBUG 0-0: Sync after 752 ms: 112723 ns
[ 2188.395794] EtherCAT DEBUG 0-0: Sync after 756 ms: 111577 ns
[ 2188.396794] EtherCAT DEBUG 0-0: Sync after 756 ms: 110201 ns
[ 2188.397793] EtherCAT DEBUG 0-0: Sync after 756 ms: 118354 ns
[ 2188.398793] EtherCAT DEBUG 0-0: Sync after 756 ms: 118352 ns
[ 2188.399795] EtherCAT DEBUG 0-0: Sync after 760 ms: 107777 ns
[ 2188.400794] EtherCAT DEBUG 0-0: Sync after 760 ms: 106172 ns
[ 2188.401794] EtherCAT DEBUG 0-0: Sync after 760 ms: 103843 ns
[ 2188.402794] EtherCAT DEBUG 0-0: Sync after 760 ms: 104181 ns
[ 2188.403794] EtherCAT DEBUG 0-0: Sync after 764 ms: 104085 ns
[ 2188.404801] EtherCAT DEBUG 0-0: Sync after 764 ms: 103058 ns
[ 2188.405802] EtherCAT DEBUG 0-0: Sync after 764 ms: 100876 ns
[ 2188.406802] EtherCAT DEBUG 0-0: Sync after 764 ms: 97252 ns
[ 2188.407800] EtherCAT DEBUG 0-0: Sync after 768 ms: 96824 ns
[ 2188.408798] EtherCAT DEBUG 0-0: Sync after 768 ms: 100243 ns
[ 2188.409794] EtherCAT DEBUG 0-0: Sync after 768 ms: 93493 ns
[ 2188.410794] EtherCAT DEBUG 0-0: Sync after 768 ms: 94553 ns
[ 2188.411796] EtherCAT DEBUG 0-0: Sync after 772 ms: 94768 ns
[ 2188.412794] EtherCAT DEBUG 0-0: Sync after 772 ms: 95074 ns
[ 2188.413794] EtherCAT DEBUG 0-0: Sync after 772 ms: 91379 ns
[ 2188.414794] EtherCAT DEBUG 0-0: Sync after 772 ms: 92271 ns
[ 2188.415799] EtherCAT DEBUG 0-0: Sync after 776 ms: 91047 ns
[ 2188.416797] EtherCAT DEBUG 0-0: Sync after 776 ms: 90430 ns
[ 2188.417794] EtherCAT DEBUG 0-0: Sync after 776 ms: 91207 ns
[ 2188.418795] EtherCAT DEBUG 0-0: Sync after 776 ms: 87166 ns
[ 2188.419798] EtherCAT DEBUG 0-0: Sync after 780 ms: 87782 ns
[ 2188.420794] EtherCAT DEBUG 0-0: Sync after 780 ms: 85835 ns
[ 2188.421794] EtherCAT DEBUG 0-0: Sync after 780 ms: 84969 ns
[ 2188.422794] EtherCAT DEBUG 0-0: Sync after 780 ms: 84603 ns
[ 2188.423799] EtherCAT DEBUG 0-0: Sync after 784 ms: 83835 ns
[ 2188.424794] EtherCAT DEBUG 0-0: Sync after 784 ms: 82318 ns
[ 2188.425797] EtherCAT DEBUG 0-0: Sync after 784 ms: 77552 ns
[ 2188.426795] EtherCAT DEBUG 0-0: Sync after 784 ms: 84831 ns
[ 2188.427794] EtherCAT DEBUG 0-0: Sync after 788 ms: 79151 ns
[ 2188.428794] EtherCAT DEBUG 0-0: Sync after 788 ms: 78123 ns
[ 2188.429794] EtherCAT DEBUG 0-0: Sync after 788 ms: 77441 ns
[ 2188.430794] EtherCAT DEBUG 0-0: Sync after 788 ms: 77100 ns
[ 2188.431798] EtherCAT DEBUG 0-0: Sync after 792 ms: 75135 ns
[ 2188.432796] EtherCAT DEBUG 0-0: Sync after 792 ms: 74461 ns
[ 2188.433797] EtherCAT DEBUG 0-0: Sync after 792 ms: 71176 ns
[ 2188.434794] EtherCAT DEBUG 0-0: Sync after 792 ms: 80245 ns
[ 2188.435797] EtherCAT DEBUG 0-0: Sync after 796 ms: 70642 ns
[ 2188.436798] EtherCAT DEBUG 0-0: Sync after 796 ms: 70238 ns
[ 2188.437798] EtherCAT DEBUG 0-0: Sync after 796 ms: 71941 ns
[ 2188.438796] EtherCAT DEBUG 0-0: Sync after 796 ms: 67661 ns
[ 2188.439798] EtherCAT DEBUG 0-0: Sync after 800 ms: 66092 ns
[ 2188.440794] EtherCAT DEBUG 0-0: Sync after 800 ms: 65135 ns
[ 2188.441794] EtherCAT DEBUG 0-0: Sync after 800 ms: 67299 ns
[ 2188.442794] EtherCAT DEBUG 0-0: Sync after 800 ms: 64804 ns
[ 2188.443794] EtherCAT DEBUG 0-0: Sync after 804 ms: 68847 ns
[ 2188.444794] EtherCAT DEBUG 0-0: Sync after 804 ms: 62620 ns
[ 2188.445798] EtherCAT DEBUG 0-0: Sync after 804 ms: 60824 ns
[ 2188.446794] EtherCAT DEBUG 0-0: Sync after 804 ms: 60003 ns
[ 2188.447798] EtherCAT DEBUG 0-0: Sync after 808 ms: 58480 ns
[ 2188.448800] EtherCAT DEBUG 0-0: Sync after 808 ms: 58400 ns
[ 2188.449797] EtherCAT DEBUG 0-0: Sync after 808 ms: 55828 ns
[ 2188.450795] EtherCAT DEBUG 0-0: Sync after 808 ms: 52804 ns
[ 2188.451795] EtherCAT DEBUG 0-0: Sync after 812 ms: 55990 ns
[ 2188.452795] EtherCAT DEBUG 0-0: Sync after 812 ms: 54318 ns
[ 2188.453794] EtherCAT DEBUG 0-0: Sync after 812 ms: 57561 ns
[ 2188.454795] EtherCAT DEBUG 0-0: Sync after 812 ms: 52497 ns
[ 2188.455799] EtherCAT DEBUG 0-0: Sync after 816 ms: 51677 ns
[ 2188.456794] EtherCAT DEBUG 0-0: Sync after 816 ms: 59904 ns
[ 2188.457794] EtherCAT DEBUG 0-0: Sync after 816 ms: 51184 ns
[ 2188.458794] EtherCAT DEBUG 0-0: Sync after 816 ms: 48504 ns
[ 2188.459794] EtherCAT DEBUG 0-0: Sync after 820 ms: 47697 ns
[ 2188.460794] EtherCAT DEBUG 0-0: Sync after 820 ms: 47115 ns
[ 2188.461795] EtherCAT DEBUG 0-0: Sync after 820 ms: 49022 ns
[ 2188.462793] EtherCAT DEBUG 0-0: Sync after 820 ms: 44660 ns
[ 2188.463797] EtherCAT DEBUG 0-0: Sync after 824 ms: 42938 ns
[ 2188.464794] EtherCAT DEBUG 0-0: Sync after 824 ms: 43148 ns
[ 2188.465794] EtherCAT DEBUG 0-0: Sync after 824 ms: 40415 ns
[ 2188.466794] EtherCAT DEBUG 0-0: Sync after 824 ms: 49721 ns
[ 2188.467799] EtherCAT DEBUG 0-0: Sync after 828 ms: 39663 ns
[ 2188.468798] EtherCAT DEBUG 0-0: Sync after 828 ms: 38508 ns
[ 2188.469797] EtherCAT DEBUG 0-0: Sync after 828 ms: 44985 ns
[ 2188.470794] EtherCAT DEBUG 0-0: Sync after 828 ms: 35088 ns
[ 2188.471799] EtherCAT DEBUG 0-0: Sync after 832 ms: 34069 ns
[ 2188.472794] EtherCAT DEBUG 0-0: Sync after 832 ms: 34446 ns
[ 2188.473794] EtherCAT DEBUG 0-0: Sync after 832 ms: 31210 ns
[ 2188.474794] EtherCAT DEBUG 0-0: Sync after 832 ms: 32265 ns
[ 2188.475797] EtherCAT DEBUG 0-0: Sync after 836 ms: 32303 ns
[ 2188.476797] EtherCAT DEBUG 0-0: Sync after 836 ms: 30522 ns
[ 2188.477795] EtherCAT DEBUG 0-0: Sync after 836 ms: 28822 ns
[ 2188.478794] EtherCAT DEBUG 0-0: Sync after 836 ms: 42815 ns
[ 2188.479796] EtherCAT DEBUG 0-0: Sync after 840 ms: 31463 ns
[ 2188.480796] EtherCAT DEBUG 0-0: Sync after 840 ms: 26540 ns
[ 2188.481796] EtherCAT DEBUG 0-0: Sync after 840 ms: 24720 ns
[ 2188.482794] EtherCAT DEBUG 0-0: Sync after 840 ms: 23467 ns
[ 2188.483799] EtherCAT DEBUG 0-0: Sync after 844 ms: 23087 ns
[ 2188.484795] EtherCAT DEBUG 0-0: Sync after 844 ms: 22219 ns
[ 2188.485794] EtherCAT DEBUG 0-0: Sync after 844 ms: 19019 ns
[ 2188.486794] EtherCAT DEBUG 0-0: Sync after 844 ms: 29091 ns
[ 2188.487794] EtherCAT DEBUG 0-0: Sync after 848 ms: 19632 ns
[ 2188.488794] EtherCAT DEBUG 0-0: Sync after 848 ms: 19298 ns
[ 2188.489794] EtherCAT DEBUG 0-0: Sync after 848 ms: 18350 ns
[ 2188.490794] EtherCAT DEBUG 0-0: Sync after 848 ms: 16868 ns
[ 2188.491796] EtherCAT DEBUG 0-0: Sync after 852 ms: 15487 ns
[ 2188.492794] EtherCAT DEBUG 0-0: Sync after 852 ms: 14809 ns
[ 2188.493794] EtherCAT DEBUG 0-0: Sync after 852 ms: 16775 ns
[ 2188.494797] EtherCAT DEBUG 0-0: Sync after 852 ms: 12672 ns
[ 2188.495794] EtherCAT DEBUG 0-0: Sync after 856 ms: 16131 ns
[ 2188.496794] EtherCAT DEBUG 0-0: 8396 ns difference after 856 ms.
[ 2188.496795] EtherCAT DEBUG 0-0: ref_time=734900849711261000
[ 2188.496796] EtherCAT DEBUG 0-0: app_time=734900850763865853
[ 2188.496796] EtherCAT DEBUG 0-0: start_time=734900850863865853
[ 2188.496797] EtherCAT DEBUG 0-0: cycle=1000000
[ 2188.496798] EtherCAT DEBUG 0-0: shift_time=0
[ 2188.496798] EtherCAT DEBUG 0-0: remainder=604853
[ 2188.496799] EtherCAT DEBUG 0-0: start=734900850864261000
[ 2188.496800] EtherCAT DEBUG 0-0: Setting DC cyclic operation start time to 734900850864261000.
[ 2188.498798] EtherCAT DEBUG 0-0: Setting DC AssignActivate to 0x0300.
[ 2188.505794] EtherCAT DEBUG 0-0: Now in SAFEOP.
[ 2188.506795] EtherCAT 0: Domain 0: Working counter changed to 3/3.
[ 2188.507797] EtherCAT DEBUG 0-0: Now in OP. Finished configuration.
[ 2188.514986] EtherCAT 0: Slave states on main device: OP.
Warning: Spoiler!
[ 2160.964639] EtherCAT 0: Master debug level set to 1.
[ 2187.443029] EtherCAT: Requesting master 0...
[ 2187.443031] EtherCAT DEBUG 0: IDLE -> OPERATION.
[ 2187.443032] EtherCAT: Successfully requested master 0.
[ 2187.443035] EtherCAT DEBUG 0: ecrt_master_create_domain(master = 0x00000000bab03491)
[ 2187.443036] EtherCAT DEBUG 0: Created domain 0.
[ 2187.443038] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443039] EtherCAT DEBUG 0: Creating slave configuration for 0:0, 0x00000BF8/0x00000001.
[ 2187.443040] EtherCAT DEBUG 0 0:0: Attached slave 0.
[ 2187.443098] EtherCAT DEBUG 0 0:0: ecrt_slave_config_dc(sc = 0x0000000012982850, assign_activate = 0x0300, sync0_cycle = 1000000, sync0_shift = 0, sync1_cycle = 0, sync1_shift = 0
[ 2187.443100] EtherCAT DEBUG 0 0:0: ecrt_slave_config_sync_manager(sc = 0x0000000012982850, sync_index = 2, dir = 1, watchdog_mode = 0)
[ 2187.443102] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_assign_clear(sc = 0x0000000012982850, sync_index = 2)
[ 2187.443104] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_assign_add(sc = 0x0000000012982850, sync_index = 2, pdo_index = 0x1600)
[ 2187.443105] EtherCAT DEBUG 0 0:0: Loading default mapping for PDO 0x1600.
[ 2187.443106] EtherCAT DEBUG 0 0:0: No default mapping found.
[ 2187.443108] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_clear(sc = 0x0000000012982850, pdo_index = 0x1600)
[ 2187.443110] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1600, entry_index = 0x6040, entry_subindex = 0x00, entry_bit_length = 16)
[ 2187.443111] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1600, entry_index = 0x6060, entry_subindex = 0x00, entry_bit_length = 8)
[ 2187.443113] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1600, entry_index = 0x607A, entry_subindex = 0x00, entry_bit_length = 32)
[ 2187.443115] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1600, entry_index = 0x60FF, entry_subindex = 0x00, entry_bit_length = 32)
[ 2187.443116] EtherCAT DEBUG 0 0:0: ecrt_slave_config_sync_manager(sc = 0x0000000012982850, sync_index = 3, dir = 2, watchdog_mode = 0)
[ 2187.443118] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_assign_clear(sc = 0x0000000012982850, sync_index = 3)
[ 2187.443119] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_assign_add(sc = 0x0000000012982850, sync_index = 3, pdo_index = 0x1A00)
[ 2187.443120] EtherCAT DEBUG 0 0:0: Loading default mapping for PDO 0x1A00.
[ 2187.443121] EtherCAT DEBUG 0 0:0: No default mapping found.
[ 2187.443122] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_clear(sc = 0x0000000012982850, pdo_index = 0x1A00)
[ 2187.443124] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x6041, entry_subindex = 0x00, entry_bit_length = 16)
[ 2187.443125] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x6061, entry_subindex = 0x00, entry_bit_length = 8)
[ 2187.443127] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x6064, entry_subindex = 0x00, entry_bit_length = 32)
[ 2187.443129] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x606C, entry_subindex = 0x00, entry_bit_length = 32)
[ 2187.443130] EtherCAT DEBUG 0 0:0: ecrt_slave_config_pdo_mapping_add(sc = 0x0000000012982850, pdo_index = 0x1A00, entry_index = 0x6077, entry_subindex = 0x00, entry_bit_length = 16)
[ 2187.443160] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443162] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6040, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443163] EtherCAT DEBUG 0: Domain 0: Added 11 bytes, total 11.
[ 2187.443165] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443167] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6060, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443168] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443170] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x607A, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443171] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443173] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x60FF, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443175] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443177] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6041, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443178] EtherCAT DEBUG 0: Domain 0: Added 13 bytes, total 24.
[ 2187.443179] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443181] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6061, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443183] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443184] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6064, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443186] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443187] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x606C, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443189] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x00000000bab03491, alias = 0, position = 0, vendor_id = 0x00000bf8, product_code = 0x00000001)
[ 2187.443190] EtherCAT DEBUG 0 0:0: ecrt_slave_config_reg_pdo_entry(sc = 0x0000000012982850, index = 0x6077, subindex = 0x00, domain = 0x0000000015413860, bit_position = 0x0000000050143884)
[ 2187.443209] EtherCAT DEBUG 0: ecrt_domain_external_memory(domain = 0x0000000015413860, mem = 0x0000000016527370)
[ 2187.443210] EtherCAT DEBUG 0: ecrt_master_callbacks(master = 0x00000000bab03491, send_cb = 0x00000000c36257c5, receive_cb = 0x000000002a164c12, cb_data = 0x00000000bab03491)
[ 2187.443211] EtherCAT DEBUG 0: ecrt_master_activate(master = 0x00000000bab03491)
[ 2187.443213] EtherCAT DEBUG 0: Adding datagram pair with expected WC 3.
[ 2187.443214] EtherCAT 0: Domain0: Logical address 0x00000000, 24 byte, expected working counter 3.
[ 2187.443215] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 24 byte, type LRW.
[ 2187.443216] EtherCAT DEBUG 0: Stopping master thread.
[ 2187.443219] EtherCAT DEBUG 0: Master IDLE thread exiting...
[ 2187.443224] EtherCAT 0: Master thread exited.
[ 2187.443225] EtherCAT DEBUG 0: FSM datagram is 00000000cd587c9e.
[ 2187.443226] EtherCAT 0: Starting EtherCAT-OP thread.
[ 2187.443249] EtherCAT DEBUG 0: Operation thread running with fsm interval = 4000 us, max data size=45000
[ 2187.443250] EtherCAT DEBUG 0: mmap()
[ 2187.443252] EtherCAT DEBUG 0: Vma fault, offset = 0, page = 00000000e6b3c905
[ 2187.478992] EtherCAT DEBUG 0: Configuration changed.
[ 2187.478994] EtherCAT DEBUG 0-0: Checking system time offset.
[ 2187.486991] EtherCAT DEBUG 0-0: DC 32 bit system time offset calculation: system_time=1382702644 (corrected with 8000000), app_time=734900849754867809, diff=-1940182483
[ 2187.486993] EtherCAT DEBUG 0-0: Setting time offset to 2354784813 (was 0)
[ 2187.494990] EtherCAT DEBUG 0: Requesting OP...
[ 2187.510990] EtherCAT DEBUG 0-0: Changing state from PREOP to OP.
[ 2187.510993] EtherCAT DEBUG 0-0: Configuring...
[ 2187.513795] EtherCAT DEBUG 0-0: Now in INIT.
[ 2187.513795] EtherCAT DEBUG 0-0: Clearing FMMU configurations...
[ 2187.514794] EtherCAT DEBUG 0-0: Clearing sync manager configurations...
[ 2187.515799] EtherCAT DEBUG 0-0: Clearing DC assignment...
[ 2187.516799] EtherCAT DEBUG 0-0: Configuring mailbox sync managers...
[ 2187.516803] EtherCAT DEBUG 0-0: SM0: Addr 0x1800, Size 384, Ctrl 0x26, En 1
[ 2187.516804] EtherCAT DEBUG 0-0: SM1: Addr 0x1A00, Size 384, Ctrl 0x22, En 1
[ 2187.517796] EtherCAT DEBUG 0-0: Assigning SII access to PDI.
[ 2187.520795] EtherCAT DEBUG 0-0: Now in PREOP.
[ 2187.520796] EtherCAT DEBUG 0-0: Assigning SII access back to EtherCAT.
[ 2187.521799] EtherCAT DEBUG 0-0: Reading mapping of PDO 0x1600.
[ 2187.521800] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:00.
[ 2187.521801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.521802] EtherCAT DEBUG: 00 20 40 00 16 00 00 00 00 00
[ 2187.525795] EtherCAT DEBUG 0-0: Upload response:
[ 2187.525795] EtherCAT DEBUG: 00 30 4F 00 16 00 04 00 00 00
[ 2187.525798] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.525798] EtherCAT DEBUG: 04
[ 2187.525800] EtherCAT DEBUG 0-0: 4 PDO entries mapped.
[ 2187.525801] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:01.
[ 2187.525801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.525802] EtherCAT DEBUG: 00 20 40 00 16 01 00 00 00 00
[ 2187.529796] EtherCAT DEBUG 0-0: Upload response:
[ 2187.529797] EtherCAT DEBUG: 00 30 43 00 16 01 20 00 7A 60
[ 2187.529800] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.529800] EtherCAT DEBUG: 20 00 7A 60
[ 2187.529802] EtherCAT DEBUG 0-0: PDO entry 0x607A:00, 32 bit, "???".
[ 2187.529803] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:02.
[ 2187.529804] EtherCAT DEBUG 0-0: Upload request:
[ 2187.529804] EtherCAT DEBUG: 00 20 40 00 16 02 00 00 00 00
[ 2187.533795] EtherCAT DEBUG 0-0: Upload response:
[ 2187.533795] EtherCAT DEBUG: 00 30 43 00 16 02 20 00 FF 60
[ 2187.533798] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.533798] EtherCAT DEBUG: 20 00 FF 60
[ 2187.533800] EtherCAT DEBUG 0-0: PDO entry 0x60FF:00, 32 bit, "???".
[ 2187.533801] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:03.
[ 2187.533801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.533802] EtherCAT DEBUG: 00 20 40 00 16 03 00 00 00 00
[ 2187.537797] EtherCAT DEBUG 0-0: Upload response:
[ 2187.537799] EtherCAT DEBUG: 00 30 43 00 16 03 10 00 71 60
[ 2187.537802] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.537802] EtherCAT DEBUG: 10 00 71 60
[ 2187.537804] EtherCAT DEBUG 0-0: PDO entry 0x6071:00, 16 bit, "???".
[ 2187.537805] EtherCAT DEBUG 0-0: Uploading SDO 0x1600:04.
[ 2187.537806] EtherCAT DEBUG 0-0: Upload request:
[ 2187.537806] EtherCAT DEBUG: 00 20 40 00 16 04 00 00 00 00
[ 2187.541795] EtherCAT DEBUG 0-0: Upload response:
[ 2187.541795] EtherCAT DEBUG: 00 30 43 00 16 04 10 00 40 60
[ 2187.541798] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.541798] EtherCAT DEBUG: 10 00 40 60
[ 2187.541800] EtherCAT DEBUG 0-0: PDO entry 0x6040:00, 16 bit, "???".
[ 2187.541801] EtherCAT DEBUG 0-0: Changing mapping of PDO 0x1600.
[ 2187.541802] EtherCAT DEBUG 0-0: Currently mapped PDO entries: 0x607A:00/32 0x60FF:00/32 0x6071:00/16 0x6040:00/16. Entries to map: 0x6040:00/16 0x6060:00/8 0x607A:00/32 0x60FF:00/32
[ 2187.541806] EtherCAT DEBUG 0-0: Setting entry count to zero.
[ 2187.541808] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:00.
[ 2187.541808] EtherCAT DEBUG: 00
[ 2187.541809] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.541810] EtherCAT DEBUG: 00 20 2F 00 16 00 00 00 00 00
[ 2187.545795] EtherCAT DEBUG 0-0: Download response:
[ 2187.545796] EtherCAT DEBUG: 00 30 60 00 16 00 00 00 00 00
[ 2187.545799] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6040:00 (16 bit) at position 1.
[ 2187.545800] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:01.
[ 2187.545800] EtherCAT DEBUG: 10 00 40 60
[ 2187.545802] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.545802] EtherCAT DEBUG: 00 20 23 00 16 01 10 00 40 60
[ 2187.549794] EtherCAT DEBUG 0-0: Download response:
[ 2187.549795] EtherCAT DEBUG: 00 30 60 00 16 01 10 00 40 60
[ 2187.549798] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6060:00 (8 bit) at position 2.
[ 2187.549800] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:02.
[ 2187.549800] EtherCAT DEBUG: 08 00 60 60
[ 2187.549802] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.549802] EtherCAT DEBUG: 00 20 23 00 16 02 08 00 60 60
[ 2187.553798] EtherCAT DEBUG 0-0: Download response:
[ 2187.553799] EtherCAT DEBUG: 00 30 60 00 16 02 08 00 60 60
[ 2187.553802] EtherCAT DEBUG 0-0: Mapping PDO entry 0x607A:00 (32 bit) at position 3.
[ 2187.553804] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:03.
[ 2187.553804] EtherCAT DEBUG: 20 00 7A 60
[ 2187.553806] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.553806] EtherCAT DEBUG: 00 20 23 00 16 03 20 00 7A 60
[ 2187.557798] EtherCAT DEBUG 0-0: Download response:
[ 2187.557800] EtherCAT DEBUG: 00 30 60 00 16 03 20 00 7A 60
[ 2187.557803] EtherCAT DEBUG 0-0: Mapping PDO entry 0x60FF:00 (32 bit) at position 4.
[ 2187.557804] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:04.
[ 2187.557804] EtherCAT DEBUG: 20 00 FF 60
[ 2187.557806] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.557806] EtherCAT DEBUG: 00 20 23 00 16 04 20 00 FF 60
[ 2187.561803] EtherCAT DEBUG 0-0: Download response:
[ 2187.561804] EtherCAT DEBUG: 00 30 60 00 16 04 20 00 FF 60
[ 2187.561808] EtherCAT DEBUG 0-0: Setting number of PDO entries to 4.
[ 2187.561810] EtherCAT DEBUG 0-0: Downloading SDO 0x1600:00.
[ 2187.561810] EtherCAT DEBUG: 04
[ 2187.561811] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.561811] EtherCAT DEBUG: 00 20 2F 00 16 00 04 00 00 00
[ 2187.564802] EtherCAT DEBUG 0-0: Download response:
[ 2187.564802] EtherCAT DEBUG: 00 30 60 00 16 00 04 00 00 00
[ 2187.564805] EtherCAT DEBUG 0-0: Successfully configured mapping for PDO 0x1600.
[ 2187.564806] EtherCAT DEBUG 0-0: Setting PDO assignment of SM2:
[ 2187.564807] EtherCAT DEBUG 0-0: Currently assigned PDOs: 0x1601. PDOs to assign: 0x1600
[ 2187.564809] EtherCAT DEBUG 0-0: Setting number of assigned PDOs to zero.
[ 2187.564810] EtherCAT DEBUG 0-0: Downloading SDO 0x1C12:00.
[ 2187.564810] EtherCAT DEBUG: 00
[ 2187.564811] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.564812] EtherCAT DEBUG: 00 20 2F 12 1C 00 00 00 00 00
[ 2187.568797] EtherCAT DEBUG 0-0: Download response:
[ 2187.568798] EtherCAT DEBUG: 00 30 60 12 1C 00 00 00 00 00
[ 2187.568802] EtherCAT DEBUG 0-0: Assigning PDO 0x1600 at position 1.
[ 2187.568803] EtherCAT DEBUG 0-0: Downloading SDO 0x1C12:01.
[ 2187.568804] EtherCAT DEBUG: 00 16
[ 2187.568805] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.568805] EtherCAT DEBUG: 00 20 2B 12 1C 01 00 16 00 00
[ 2187.572794] EtherCAT DEBUG 0-0: Download response:
[ 2187.572795] EtherCAT DEBUG: 00 30 60 12 1C 01 00 16 00 00
[ 2187.572798] EtherCAT DEBUG 0-0: Setting number of assigned PDOs to 1.
[ 2187.572799] EtherCAT DEBUG 0-0: Downloading SDO 0x1C12:00.
[ 2187.572799] EtherCAT DEBUG: 01
[ 2187.572800] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.572801] EtherCAT DEBUG: 00 20 2F 12 1C 00 01 00 00 00
[ 2187.576796] EtherCAT DEBUG 0-0: Download response:
[ 2187.576797] EtherCAT DEBUG: 00 30 60 12 1C 00 01 00 00 00
[ 2187.576802] EtherCAT DEBUG 0-0: Successfully configured PDO assignment of SM2.
[ 2187.576804] EtherCAT DEBUG 0-0: Reading mapping of PDO 0x1A00.
[ 2187.576805] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:00.
[ 2187.576806] EtherCAT DEBUG 0-0: Upload request:
[ 2187.576806] EtherCAT DEBUG: 00 20 40 00 1A 00 00 00 00 00
[ 2187.580794] EtherCAT DEBUG 0-0: Upload response:
[ 2187.580795] EtherCAT DEBUG: 00 30 4F 00 1A 00 04 00 00 00
[ 2187.580798] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.580798] EtherCAT DEBUG: 04
[ 2187.580799] EtherCAT DEBUG 0-0: 4 PDO entries mapped.
[ 2187.580800] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:01.
[ 2187.580801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.580801] EtherCAT DEBUG: 00 20 40 00 1A 01 00 00 00 00
[ 2187.584795] EtherCAT DEBUG 0-0: Upload response:
[ 2187.584797] EtherCAT DEBUG: 00 30 43 00 1A 01 20 00 64 60
[ 2187.584799] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.584800] EtherCAT DEBUG: 20 00 64 60
[ 2187.584802] EtherCAT DEBUG 0-0: PDO entry 0x6064:00, 32 bit, "???".
[ 2187.584803] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:02.
[ 2187.584804] EtherCAT DEBUG 0-0: Upload request:
[ 2187.584804] EtherCAT DEBUG: 00 20 40 00 1A 02 00 00 00 00
[ 2187.588796] EtherCAT DEBUG 0-0: Upload response:
[ 2187.588796] EtherCAT DEBUG: 00 30 43 00 1A 02 20 00 6C 60
[ 2187.588799] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.588799] EtherCAT DEBUG: 20 00 6C 60
[ 2187.588801] EtherCAT DEBUG 0-0: PDO entry 0x606C:00, 32 bit, "???".
[ 2187.588801] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:03.
[ 2187.588802] EtherCAT DEBUG 0-0: Upload request:
[ 2187.588802] EtherCAT DEBUG: 00 20 40 00 1A 03 00 00 00 00
[ 2187.592794] EtherCAT DEBUG 0-0: Upload response:
[ 2187.592795] EtherCAT DEBUG: 00 30 43 00 1A 03 10 00 77 60
[ 2187.592797] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.592798] EtherCAT DEBUG: 10 00 77 60
[ 2187.592800] EtherCAT DEBUG 0-0: PDO entry 0x6077:00, 16 bit, "???".
[ 2187.592800] EtherCAT DEBUG 0-0: Uploading SDO 0x1A00:04.
[ 2187.592801] EtherCAT DEBUG 0-0: Upload request:
[ 2187.592801] EtherCAT DEBUG: 00 20 40 00 1A 04 00 00 00 00
[ 2187.596794] EtherCAT DEBUG 0-0: Upload response:
[ 2187.596795] EtherCAT DEBUG: 00 30 43 00 1A 04 10 00 41 60
[ 2187.596797] EtherCAT DEBUG 0-0: Uploaded data:
[ 2187.596798] EtherCAT DEBUG: 10 00 41 60
[ 2187.596800] EtherCAT DEBUG 0-0: PDO entry 0x6041:00, 16 bit, "???".
[ 2187.596800] EtherCAT DEBUG 0-0: Changing mapping of PDO 0x1A00.
[ 2187.596801] EtherCAT DEBUG 0-0: Currently mapped PDO entries: 0x6064:00/32 0x606C:00/32 0x6077:00/16 0x6041:00/16. Entries to map: 0x6041:00/16 0x6061:00/8 0x6064:00/32 0x606C:00/32 0x6077:00/16
[ 2187.596806] EtherCAT DEBUG 0-0: Setting entry count to zero.
[ 2187.596807] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:00.
[ 2187.596807] EtherCAT DEBUG: 00
[ 2187.596809] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.596809] EtherCAT DEBUG: 00 20 2F 00 1A 00 00 00 00 00
[ 2187.600800] EtherCAT DEBUG 0-0: Download response:
[ 2187.600801] EtherCAT DEBUG: 00 30 60 00 1A 00 00 00 00 00
[ 2187.600804] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6041:00 (16 bit) at position 1.
[ 2187.600806] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:01.
[ 2187.600806] EtherCAT DEBUG: 10 00 41 60
[ 2187.600808] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.600808] EtherCAT DEBUG: 00 20 23 00 1A 01 10 00 41 60
[ 2187.604800] EtherCAT DEBUG 0-0: Download response:
[ 2187.604801] EtherCAT DEBUG: 00 30 60 00 1A 01 10 00 41 60
[ 2187.604804] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6061:00 (8 bit) at position 2.
[ 2187.604805] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:02.
[ 2187.604805] EtherCAT DEBUG: 08 00 61 60
[ 2187.604807] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.604807] EtherCAT DEBUG: 00 20 23 00 1A 02 08 00 61 60
[ 2187.608796] EtherCAT DEBUG 0-0: Download response:
[ 2187.608796] EtherCAT DEBUG: 00 30 60 00 1A 02 08 00 61 60
[ 2187.608799] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6064:00 (32 bit) at position 3.
[ 2187.608800] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:03.
[ 2187.608800] EtherCAT DEBUG: 20 00 64 60
[ 2187.608802] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.608802] EtherCAT DEBUG: 00 20 23 00 1A 03 20 00 64 60
[ 2187.612794] EtherCAT DEBUG 0-0: Download response:
[ 2187.612795] EtherCAT DEBUG: 00 30 60 00 1A 03 20 00 64 60
[ 2187.612798] EtherCAT DEBUG 0-0: Mapping PDO entry 0x606C:00 (32 bit) at position 4.
[ 2187.612799] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:04.
[ 2187.612799] EtherCAT DEBUG: 20 00 6C 60
[ 2187.612801] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.612801] EtherCAT DEBUG: 00 20 23 00 1A 04 20 00 6C 60
[ 2187.616794] EtherCAT DEBUG 0-0: Download response:
[ 2187.616794] EtherCAT DEBUG: 00 30 60 00 1A 04 20 00 6C 60
[ 2187.616797] EtherCAT DEBUG 0-0: Mapping PDO entry 0x6077:00 (16 bit) at position 5.
[ 2187.616797] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:05.
[ 2187.616798] EtherCAT DEBUG: 10 00 77 60
[ 2187.616799] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.616799] EtherCAT DEBUG: 00 20 23 00 1A 05 10 00 77 60
[ 2187.620795] EtherCAT DEBUG 0-0: Download response:
[ 2187.620795] EtherCAT DEBUG: 00 30 60 00 1A 05 10 00 77 60
[ 2187.620798] EtherCAT DEBUG 0-0: Setting number of PDO entries to 5.
[ 2187.620799] EtherCAT DEBUG 0-0: Downloading SDO 0x1A00:00.
[ 2187.620799] EtherCAT DEBUG: 05
[ 2187.620800] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.620800] EtherCAT DEBUG: 00 20 2F 00 1A 00 05 00 00 00
[ 2187.624794] EtherCAT DEBUG 0-0: Download response:
[ 2187.624795] EtherCAT DEBUG: 00 30 60 00 1A 00 05 00 00 00
[ 2187.624797] EtherCAT DEBUG 0-0: Successfully configured mapping for PDO 0x1A00.
[ 2187.624798] EtherCAT DEBUG 0-0: Setting PDO assignment of SM3:
[ 2187.624799] EtherCAT DEBUG 0-0: Currently assigned PDOs: 0x1A01. PDOs to assign: 0x1A00
[ 2187.624800] EtherCAT DEBUG 0-0: Setting number of assigned PDOs to zero.
[ 2187.624801] EtherCAT DEBUG 0-0: Downloading SDO 0x1C13:00.
[ 2187.624801] EtherCAT DEBUG: 00
[ 2187.624802] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.624803] EtherCAT DEBUG: 00 20 2F 13 1C 00 00 00 00 00
[ 2187.628796] EtherCAT DEBUG 0-0: Download response:
[ 2187.628797] EtherCAT DEBUG: 00 30 60 13 1C 00 00 00 00 00
[ 2187.628799] EtherCAT DEBUG 0-0: Assigning PDO 0x1A00 at position 1.
[ 2187.628800] EtherCAT DEBUG 0-0: Downloading SDO 0x1C13:01.
[ 2187.628800] EtherCAT DEBUG: 00 1A
[ 2187.628801] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.628802] EtherCAT DEBUG: 00 20 2B 13 1C 01 00 1A 00 00
[ 2187.631796] EtherCAT DEBUG 0-0: Download response:
[ 2187.631797] EtherCAT DEBUG: 00 30 60 13 1C 01 00 1A 00 00
[ 2187.631799] EtherCAT DEBUG 0-0: Setting number of assigned PDOs to 1.
[ 2187.631800] EtherCAT DEBUG 0-0: Downloading SDO 0x1C13:00.
[ 2187.631801] EtherCAT DEBUG: 01
[ 2187.631801] EtherCAT DEBUG 0-0: Expedited download request:
[ 2187.631802] EtherCAT DEBUG: 00 20 2F 13 1C 00 01 00 00 00
[ 2187.635801] EtherCAT DEBUG 0-0: Download response:
[ 2187.635801] EtherCAT DEBUG: 00 30 60 13 1C 00 01 00 00 00
[ 2187.635805] EtherCAT DEBUG 0-0: Successfully configured PDO assignment of SM3.
[ 2187.635808] EtherCAT DEBUG 0-0: SM2: Addr 0x1000, Size 11, Ctrl 0x24, En 1
[ 2187.635809] EtherCAT DEBUG 0-0: SM3: Addr 0x1100, Size 13, Ctrl 0x00, En 1
[ 2187.637800] EtherCAT DEBUG 0 0:0: FMMU: LogAddr 0x00000000, Size 11, PhysAddr 0x1000, SM2, Dir out
[ 2187.637801] EtherCAT DEBUG 0 0:0: FMMU: LogAddr 0x0000000B, Size 13, PhysAddr 0x1100, SM3, Dir in
[ 2187.638798] EtherCAT DEBUG 0-0: Setting DC cycle times to 1000000 / 0.
[ 2187.639800] EtherCAT DEBUG 0-0: Checking for synchrony.
[ 2187.640798] EtherCAT DEBUG 0-0: Sync after 0 ms: 861325 ns
[ 2187.641797] EtherCAT DEBUG 0-0: Sync after 0 ms: 859937 ns
[ 2187.642794] EtherCAT DEBUG 0-0: Sync after 0 ms: 859564 ns
[ 2187.643800] EtherCAT DEBUG 0-0: Sync after 4 ms: 858883 ns
[ 2187.644795] EtherCAT DEBUG 0-0: Sync after 4 ms: 859702 ns
[ 2187.645794] EtherCAT DEBUG 0-0: Sync after 4 ms: 856666 ns
[ 2187.646794] EtherCAT DEBUG 0-0: Sync after 4 ms: 856473 ns
[ 2187.647794] EtherCAT DEBUG 0-0: Sync after 8 ms: 856331 ns
[ 2187.648794] EtherCAT DEBUG 0-0: Sync after 8 ms: 855630 ns
[ 2187.649794] EtherCAT DEBUG 0-0: Sync after 8 ms: 862287 ns
[ 2187.650794] EtherCAT DEBUG 0-0: Sync after 8 ms: 853480 ns
[ 2187.651800] EtherCAT DEBUG 0-0: Sync after 12 ms: 853157 ns
[ 2187.652794] EtherCAT DEBUG 0-0: Sync after 12 ms: 852218 ns
[ 2187.653794] EtherCAT DEBUG 0-0: Sync after 12 ms: 848767 ns
[ 2187.654795] EtherCAT DEBUG 0-0: Sync after 12 ms: 849231 ns
[ 2187.655794] EtherCAT DEBUG 0-0: Sync after 16 ms: 853110 ns
[ 2187.656794] EtherCAT DEBUG 0-0: Sync after 16 ms: 851313 ns
[ 2187.657794] EtherCAT DEBUG 0-0: Sync after 16 ms: 846705 ns
[ 2187.658794] EtherCAT DEBUG 0-0: Sync after 16 ms: 845966 ns
[ 2187.659799] EtherCAT DEBUG 0-0: Sync after 20 ms: 844705 ns
[ 2187.660799] EtherCAT DEBUG 0-0: Sync after 20 ms: 847917 ns
[ 2187.661798] EtherCAT DEBUG 0-0: Sync after 20 ms: 839678 ns
[ 2187.662795] EtherCAT DEBUG 0-0: Sync after 20 ms: 839529 ns
[ 2187.663794] EtherCAT DEBUG 0-0: Sync after 24 ms: 837921 ns
[ 2187.664794] EtherCAT DEBUG 0-0: Sync after 24 ms: 838891 ns
[ 2187.665795] EtherCAT DEBUG 0-0: Sync after 24 ms: 838189 ns
[ 2187.666794] EtherCAT DEBUG 0-0: Sync after 24 ms: 837689 ns
[ 2187.667798] EtherCAT DEBUG 0-0: Sync after 28 ms: 836853 ns
[ 2187.668797] EtherCAT DEBUG 0-0: Sync after 28 ms: 835963 ns
[ 2187.669794] EtherCAT DEBUG 0-0: Sync after 28 ms: 832511 ns
[ 2187.670794] EtherCAT DEBUG 0-0: Sync after 28 ms: 832256 ns
[ 2187.671798] EtherCAT DEBUG 0-0: Sync after 32 ms: 832822 ns
[ 2187.672797] EtherCAT DEBUG 0-0: Sync after 32 ms: 835731 ns
[ 2187.673794] EtherCAT DEBUG 0-0: Sync after 32 ms: 829130 ns
[ 2187.674794] EtherCAT DEBUG 0-0: Sync after 32 ms: 833094 ns
[ 2187.675802] EtherCAT DEBUG 0-0: Sync after 36 ms: 838174 ns
[ 2187.676796] EtherCAT DEBUG 0-0: Sync after 36 ms: 831220 ns
[ 2187.677794] EtherCAT DEBUG 0-0: Sync after 36 ms: 821895 ns
[ 2187.678794] EtherCAT DEBUG 0-0: Sync after 36 ms: 825047 ns
[ 2187.679794] EtherCAT DEBUG 0-0: Sync after 40 ms: 833900 ns
[ 2187.680795] EtherCAT DEBUG 0-0: Sync after 40 ms: 823770 ns
[ 2187.681795] EtherCAT DEBUG 0-0: Sync after 40 ms: 830596 ns
[ 2187.682795] EtherCAT DEBUG 0-0: Sync after 40 ms: 822002 ns
[ 2187.683797] EtherCAT DEBUG 0-0: Sync after 44 ms: 819378 ns
[ 2187.684795] EtherCAT DEBUG 0-0: Sync after 44 ms: 828180 ns
[ 2187.685796] EtherCAT DEBUG 0-0: Sync after 44 ms: 817741 ns
[ 2187.686795] EtherCAT DEBUG 0-0: Sync after 44 ms: 817368 ns
[ 2187.687796] EtherCAT DEBUG 0-0: Sync after 48 ms: 820054 ns
[ 2187.688795] EtherCAT DEBUG 0-0: Sync after 48 ms: 815193 ns
[ 2187.689795] EtherCAT DEBUG 0-0: Sync after 48 ms: 814117 ns
[ 2187.690795] EtherCAT DEBUG 0-0: Sync after 48 ms: 812666 ns
[ 2187.691799] EtherCAT DEBUG 0-0: Sync after 52 ms: 815899 ns
[ 2187.692799] EtherCAT DEBUG 0-0: Sync after 52 ms: 811246 ns
[ 2187.693798] EtherCAT DEBUG 0-0: Sync after 52 ms: 808822 ns
[ 2187.694797] EtherCAT DEBUG 0-0: Sync after 52 ms: 807722 ns
[ 2187.695799] EtherCAT DEBUG 0-0: Sync after 56 ms: 806047 ns
[ 2187.696795] EtherCAT DEBUG 0-0: Sync after 56 ms: 804390 ns
[ 2187.697797] EtherCAT DEBUG 0-0: Sync after 56 ms: 804505 ns
[ 2187.698794] EtherCAT DEBUG 0-0: Sync after 56 ms: 806017 ns
[ 2187.699794] EtherCAT DEBUG 0-0: Sync after 60 ms: 803126 ns
[ 2187.700795] EtherCAT DEBUG 0-0: Sync after 60 ms: 808599 ns
[ 2187.701797] EtherCAT DEBUG 0-0: Sync after 60 ms: 802180 ns
[ 2187.702796] EtherCAT DEBUG 0-0: Sync after 60 ms: 800640 ns
[ 2187.703801] EtherCAT DEBUG 0-0: Sync after 64 ms: 799820 ns
[ 2187.704795] EtherCAT DEBUG 0-0: Sync after 64 ms: 807605 ns
[ 2187.705794] EtherCAT DEBUG 0-0: Sync after 64 ms: 796091 ns
[ 2187.706795] EtherCAT DEBUG 0-0: Sync after 64 ms: 796151 ns
[ 2187.707800] EtherCAT DEBUG 0-0: Sync after 68 ms: 806183 ns
[ 2187.708795] EtherCAT DEBUG 0-0: Sync after 68 ms: 796029 ns
[ 2187.709794] EtherCAT DEBUG 0-0: Sync after 68 ms: 791566 ns
[ 2187.710799] EtherCAT DEBUG 0-0: Sync after 68 ms: 794073 ns
[ 2187.711798] EtherCAT DEBUG 0-0: Sync after 72 ms: 792439 ns
[ 2187.712796] EtherCAT DEBUG 0-0: Sync after 72 ms: 789112 ns
[ 2187.713798] EtherCAT DEBUG 0-0: Sync after 72 ms: 788578 ns
[ 2187.714794] EtherCAT DEBUG 0-0: Sync after 72 ms: 792535 ns
[ 2187.715794] EtherCAT DEBUG 0-0: Sync after 76 ms: 786634 ns
[ 2187.716794] EtherCAT DEBUG 0-0: Sync after 76 ms: 791726 ns
[ 2187.717794] EtherCAT DEBUG 0-0: Sync after 76 ms: 786982 ns
[ 2187.718795] EtherCAT DEBUG 0-0: Sync after 76 ms: 795391 ns
[ 2187.719800] EtherCAT DEBUG 0-0: Sync after 80 ms: 784425 ns
[ 2187.720795] EtherCAT DEBUG 0-0: Sync after 80 ms: 783160 ns
[ 2187.721794] EtherCAT DEBUG 0-0: Sync after 80 ms: 780874 ns
[ 2187.722797] EtherCAT DEBUG 0-0: Sync after 80 ms: 782160 ns
[ 2187.723799] EtherCAT DEBUG 0-0: Sync after 84 ms: 789692 ns
[ 2187.724797] EtherCAT DEBUG 0-0: Sync after 84 ms: 777347 ns
[ 2187.725795] EtherCAT DEBUG 0-0: Sync after 84 ms: 776452 ns
[ 2187.726794] EtherCAT DEBUG 0-0: Sync after 84 ms: 776047 ns
[ 2187.727800] EtherCAT DEBUG 0-0: Sync after 88 ms: 776688 ns
[ 2187.728795] EtherCAT DEBUG 0-0: Sync after 88 ms: 776026 ns
[ 2187.729794] EtherCAT DEBUG 0-0: Sync after 88 ms: 773364 ns
[ 2187.730794] EtherCAT DEBUG 0-0: Sync after 88 ms: 773504 ns
[ 2187.731794] EtherCAT DEBUG 0-0: Sync after 92 ms: 777402 ns
[ 2187.732795] EtherCAT DEBUG 0-0: Sync after 92 ms: 772404 ns
[ 2187.733794] EtherCAT DEBUG 0-0: Sync after 92 ms: 775182 ns
[ 2187.734796] EtherCAT DEBUG 0-0: Sync after 92 ms: 768689 ns
[ 2187.735802] EtherCAT DEBUG 0-0: Sync after 96 ms: 768560 ns
[ 2187.736795] EtherCAT DEBUG 0-0: Sync after 96 ms: 765536 ns
[ 2187.737794] EtherCAT DEBUG 0-0: Sync after 96 ms: 764581 ns
[ 2187.738793] EtherCAT DEBUG 0-0: Sync after 96 ms: 765838 ns
[ 2187.739794] EtherCAT DEBUG 0-0: Sync after 100 ms: 765331 ns
[ 2187.740794] EtherCAT DEBUG 0-0: Sync after 100 ms: 764066 ns
[ 2187.741793] EtherCAT DEBUG 0-0: Sync after 100 ms: 763034 ns
[ 2187.742794] EtherCAT DEBUG 0-0: Sync after 100 ms: 770531 ns
[ 2187.743799] EtherCAT DEBUG 0-0: Sync after 104 ms: 770420 ns
[ 2187.744795] EtherCAT DEBUG 0-0: Sync after 104 ms: 759793 ns
[ 2187.745794] EtherCAT DEBUG 0-0: Sync after 104 ms: 757268 ns
[ 2187.746794] EtherCAT DEBUG 0-0: Sync after 104 ms: 757627 ns
[ 2187.747794] EtherCAT DEBUG 0-0: Sync after 108 ms: 766622 ns
[ 2187.748794] EtherCAT DEBUG 0-0: Sync after 108 ms: 756350 ns
[ 2187.749794] EtherCAT DEBUG 0-0: Sync after 108 ms: 755081 ns
[ 2187.750794] EtherCAT DEBUG 0-0: Sync after 108 ms: 753676 ns
[ 2187.751799] EtherCAT DEBUG 0-0: Sync after 112 ms: 753427 ns
[ 2187.752793] EtherCAT DEBUG 0-0: Sync after 112 ms: 752116 ns
[ 2187.753795] EtherCAT DEBUG 0-0: Sync after 112 ms: 749272 ns
[ 2187.754795] EtherCAT DEBUG 0-0: Sync after 112 ms: 749816 ns
[ 2187.755799] EtherCAT DEBUG 0-0: Sync after 116 ms: 747727 ns
[ 2187.756794] EtherCAT DEBUG 0-0: Sync after 116 ms: 747838 ns
[ 2187.757794] EtherCAT DEBUG 0-0: Sync after 116 ms: 744878 ns
[ 2187.758794] EtherCAT DEBUG 0-0: Sync after 116 ms: 745061 ns
[ 2187.759799] EtherCAT DEBUG 0-0: Sync after 120 ms: 745409 ns
[ 2187.760795] EtherCAT DEBUG 0-0: Sync after 120 ms: 744388 ns
[ 2187.761794] EtherCAT DEBUG 0-0: Sync after 120 ms: 741664 ns
[ 2187.762794] EtherCAT DEBUG 0-0: Sync after 120 ms: 741875 ns
[ 2187.763794] EtherCAT DEBUG 0-0: Sync after 124 ms: 745595 ns
[ 2187.764794] EtherCAT DEBUG 0-0: Sync after 124 ms: 739895 ns
[ 2187.765795] EtherCAT DEBUG 0-0: Sync after 124 ms: 739159 ns
[ 2187.766795] EtherCAT DEBUG 0-0: Sync after 124 ms: 738091 ns
[ 2187.767799] EtherCAT DEBUG 0-0: Sync after 128 ms: 736758 ns
[ 2187.768795] EtherCAT DEBUG 0-0: Sync after 128 ms: 735296 ns
[ 2187.769794] EtherCAT DEBUG 0-0: Sync after 128 ms: 733775 ns
[ 2187.770794] EtherCAT DEBUG 0-0: Sync after 128 ms: 734036 ns
[ 2187.771794] EtherCAT DEBUG 0-0: Sync after 132 ms: 733531 ns
[ 2187.772794] EtherCAT DEBUG 0-0: Sync after 132 ms: 731958 ns
[ 2187.773794] EtherCAT DEBUG 0-0: Sync after 132 ms: 730998 ns
[ 2187.774794] EtherCAT DEBUG 0-0: Sync after 132 ms: 730068 ns
[ 2187.775799] EtherCAT DEBUG 0-0: Sync after 136 ms: 729657 ns
[ 2187.776795] EtherCAT DEBUG 0-0: Sync after 136 ms: 736846 ns
[ 2187.777794] EtherCAT DEBUG 0-0: Sync after 136 ms: 725485 ns
[ 2187.778794] EtherCAT DEBUG 0-0: Sync after 136 ms: 725975 ns
[ 2187.779794] EtherCAT DEBUG 0-0: Sync after 140 ms: 724593 ns
[ 2187.780794] EtherCAT DEBUG 0-0: Sync after 140 ms: 728801 ns
[ 2187.781794] EtherCAT DEBUG 0-0: Sync after 140 ms: 726719 ns
[ 2187.782794] EtherCAT DEBUG 0-0: Sync after 140 ms: 722641 ns
[ 2187.783800] EtherCAT DEBUG 0-0: Sync after 144 ms: 721078 ns
[ 2187.784795] EtherCAT DEBUG 0-0: Sync after 144 ms: 720739 ns
[ 2187.785794] EtherCAT DEBUG 0-0: Sync after 144 ms: 721478 ns
[ 2187.786796] EtherCAT DEBUG 0-0: Sync after 144 ms: 721403 ns
[ 2187.787800] EtherCAT DEBUG 0-0: Sync after 148 ms: 716897 ns
[ 2187.788795] EtherCAT DEBUG 0-0: Sync after 148 ms: 715813 ns
[ 2187.789794] EtherCAT DEBUG 0-0: Sync after 148 ms: 722174 ns
[ 2187.790794] EtherCAT DEBUG 0-0: Sync after 148 ms: 717920 ns
[ 2187.791794] EtherCAT DEBUG 0-0: Sync after 152 ms: 713532 ns
[ 2187.792796] EtherCAT DEBUG 0-0: Sync after 152 ms: 712465 ns
[ 2187.793794] EtherCAT DEBUG 0-0: Sync after 152 ms: 710731 ns
[ 2187.794794] EtherCAT DEBUG 0-0: Sync after 152 ms: 709178 ns
[ 2187.795799] EtherCAT DEBUG 0-0: Sync after 156 ms: 708685 ns
[ 2187.796794] EtherCAT DEBUG 0-0: Sync after 156 ms: 713366 ns
[ 2187.797796] EtherCAT DEBUG 0-0: Sync after 156 ms: 705877 ns
[ 2187.798794] EtherCAT DEBUG 0-0: Sync after 156 ms: 709925 ns
[ 2187.799794] EtherCAT DEBUG 0-0: Sync after 160 ms: 705328 ns
[ 2187.800794] EtherCAT DEBUG 0-0: Sync after 160 ms: 704503 ns
[ 2187.801794] EtherCAT DEBUG 0-0: Sync after 160 ms: 702976 ns
[ 2187.802794] EtherCAT DEBUG 0-0: Sync after 160 ms: 706680 ns
[ 2187.803799] EtherCAT DEBUG 0-0: Sync after 164 ms: 701637 ns
[ 2187.804795] EtherCAT DEBUG 0-0: Sync after 164 ms: 699995 ns
[ 2187.805794] EtherCAT DEBUG 0-0: Sync after 164 ms: 697357 ns
[ 2187.806794] EtherCAT DEBUG 0-0: Sync after 164 ms: 698608 ns
[ 2187.807794] EtherCAT DEBUG 0-0: Sync after 168 ms: 697599 ns
[ 2187.808794] EtherCAT DEBUG 0-0: Sync after 168 ms: 695857 ns
[ 2187.809794] EtherCAT DEBUG 0-0: Sync after 168 ms: 694777 ns
[ 2187.810794] EtherCAT DEBUG 0-0: Sync after 168 ms: 694783 ns
[ 2187.811799] EtherCAT DEBUG 0-0: Sync after 172 ms: 697559 ns
[ 2187.812794] EtherCAT DEBUG 0-0: Sync after 172 ms: 692236 ns
[ 2187.813794] EtherCAT DEBUG 0-0: Sync after 172 ms: 689657 ns
[ 2187.814794] EtherCAT DEBUG 0-0: Sync after 172 ms: 690308 ns
[ 2187.815794] EtherCAT DEBUG 0-0: Sync after 176 ms: 688548 ns
[ 2187.816794] EtherCAT DEBUG 0-0: Sync after 176 ms: 688750 ns
[ 2187.817794] EtherCAT DEBUG 0-0: Sync after 176 ms: 687325 ns
[ 2187.818794] EtherCAT DEBUG 0-0: Sync after 176 ms: 685776 ns
[ 2187.819799] EtherCAT DEBUG 0-0: Sync after 180 ms: 685075 ns
[ 2187.820795] EtherCAT DEBUG 0-0: Sync after 180 ms: 688429 ns
[ 2187.821794] EtherCAT DEBUG 0-0: Sync after 180 ms: 681557 ns
[ 2187.822793] EtherCAT DEBUG 0-0: Sync after 180 ms: 681933 ns
[ 2187.823793] EtherCAT DEBUG 0-0: Sync after 184 ms: 681145 ns
[ 2187.824794] EtherCAT DEBUG 0-0: Sync after 184 ms: 680781 ns
[ 2187.825794] EtherCAT DEBUG 0-0: Sync after 184 ms: 678482 ns
[ 2187.826794] EtherCAT DEBUG 0-0: Sync after 184 ms: 677827 ns
[ 2187.827799] EtherCAT DEBUG 0-0: Sync after 188 ms: 677169 ns
[ 2187.828796] EtherCAT DEBUG 0-0: Sync after 188 ms: 681014 ns
[ 2187.829794] EtherCAT DEBUG 0-0: Sync after 188 ms: 674092 ns
[ 2187.830794] EtherCAT DEBUG 0-0: Sync after 188 ms: 674441 ns
[ 2187.831794] EtherCAT DEBUG 0-0: Sync after 192 ms: 673562 ns
[ 2187.832794] EtherCAT DEBUG 0-0: Sync after 192 ms: 671885 ns
[ 2187.833794] EtherCAT DEBUG 0-0: Sync after 192 ms: 671120 ns
[ 2187.834794] EtherCAT DEBUG 0-0: Sync after 192 ms: 670958 ns
[ 2187.835799] EtherCAT DEBUG 0-0: Sync after 196 ms: 669957 ns
[ 2187.836795] EtherCAT DEBUG 0-0: Sync after 196 ms: 668214 ns
[ 2187.837794] EtherCAT DEBUG 0-0: Sync after 196 ms: 675602 ns
[ 2187.838794] EtherCAT DEBUG 0-0: Sync after 196 ms: 665825 ns
[ 2187.839794] EtherCAT DEBUG 0-0: Sync after 200 ms: 674767 ns
[ 2187.840794] EtherCAT DEBUG 0-0: Sync after 200 ms: 663896 ns
[ 2187.841794] EtherCAT DEBUG 0-0: Sync after 200 ms: 662301 ns
[ 2187.842793] EtherCAT DEBUG 0-0: Sync after 200 ms: 662931 ns
[ 2187.843799] EtherCAT DEBUG 0-0: Sync after 204 ms: 661553 ns
[ 2187.844795] EtherCAT DEBUG 0-0: Sync after 204 ms: 661001 ns
[ 2187.845794] EtherCAT DEBUG 0-0: Sync after 204 ms: 657665 ns
[ 2187.846794] EtherCAT DEBUG 0-0: Sync after 204 ms: 658493 ns
[ 2187.847800] EtherCAT DEBUG 0-0: Sync after 208 ms: 666015 ns
[ 2187.848796] EtherCAT DEBUG 0-0: Sync after 208 ms: 656155 ns
[ 2187.849794] EtherCAT DEBUG 0-0: Sync after 208 ms: 653226 ns
[ 2187.850794] EtherCAT DEBUG 0-0: Sync after 208 ms: 653414 ns
[ 2187.851794] EtherCAT DEBUG 0-0: Sync after 212 ms: 653054 ns
[ 2187.852795] EtherCAT DEBUG 0-0: Sync after 212 ms: 652494 ns
[ 2187.853794] EtherCAT DEBUG 0-0: Sync after 212 ms: 651033 ns
[ 2187.854794] EtherCAT DEBUG 0-0: Sync after 212 ms: 654398 ns
[ 2187.855797] EtherCAT DEBUG 0-0: Sync after 216 ms: 649972 ns
[ 2187.856795] EtherCAT DEBUG 0-0: Sync after 216 ms: 648278 ns
[ 2187.857794] EtherCAT DEBUG 0-0: Sync after 216 ms: 644971 ns
[ 2187.858798] EtherCAT DEBUG 0-0: Sync after 216 ms: 646684 ns
[ 2187.859800] EtherCAT DEBUG 0-0: Sync after 220 ms: 654368 ns
[ 2187.860795] EtherCAT DEBUG 0-0: Sync after 220 ms: 642247 ns
[ 2187.861794] EtherCAT DEBUG 0-0: Sync after 220 ms: 641626 ns
[ 2187.862794] EtherCAT DEBUG 0-0: Sync after 220 ms: 641974 ns
[ 2187.863799] EtherCAT DEBUG 0-0: Sync after 224 ms: 641363 ns
[ 2187.864795] EtherCAT DEBUG 0-0: Sync after 224 ms: 649755 ns
[ 2187.865794] EtherCAT DEBUG 0-0: Sync after 224 ms: 637485 ns
[ 2187.866794] EtherCAT DEBUG 0-0: Sync after 224 ms: 638843 ns
[ 2187.867794] EtherCAT DEBUG 0-0: Sync after 228 ms: 646502 ns
[ 2187.868794] EtherCAT DEBUG 0-0: Sync after 228 ms: 636629 ns
[ 2187.869794] EtherCAT DEBUG 0-0: Sync after 228 ms: 634479 ns
[ 2187.870794] EtherCAT DEBUG 0-0: Sync after 228 ms: 634893 ns
[ 2187.871799] EtherCAT DEBUG 0-0: Sync after 232 ms: 633431 ns
[ 2187.872794] EtherCAT DEBUG 0-0: Sync after 232 ms: 632698 ns
[ 2187.873794] EtherCAT DEBUG 0-0: Sync after 232 ms: 630147 ns
[ 2187.874794] EtherCAT DEBUG 0-0: Sync after 232 ms: 629711 ns
[ 2187.875794] EtherCAT DEBUG 0-0: Sync after 236 ms: 629889 ns
[ 2187.876794] EtherCAT DEBUG 0-0: Sync after 236 ms: 629056 ns
[ 2187.877794] EtherCAT DEBUG 0-0: Sync after 236 ms: 626707 ns
[ 2187.878801] EtherCAT DEBUG 0-0: Sync after 236 ms: 627012 ns
[ 2187.879799] EtherCAT DEBUG 0-0: Sync after 240 ms: 625907 ns
[ 2187.880795] EtherCAT DEBUG 0-0: Sync after 240 ms: 621533 ns
[ 2187.881794] EtherCAT DEBUG 0-0: Sync after 240 ms: 629940 ns
[ 2187.882794] EtherCAT DEBUG 0-0: Sync after 240 ms: 627177 ns
[ 2187.883799] EtherCAT DEBUG 0-0: Sync after 244 ms: 621842 ns
[ 2187.884795] EtherCAT DEBUG 0-0: Sync after 244 ms: 620408 ns
[ 2187.885794] EtherCAT DEBUG 0-0: Sync after 244 ms: 618297 ns
[ 2187.886794] EtherCAT DEBUG 0-0: Sync after 244 ms: 627776 ns
[ 2187.887794] EtherCAT DEBUG 0-0: Sync after 248 ms: 617937 ns
[ 2187.888794] EtherCAT DEBUG 0-0: Sync after 248 ms: 616025 ns
[ 2187.889794] EtherCAT DEBUG 0-0: Sync after 248 ms: 619557 ns
[ 2187.890796] EtherCAT DEBUG 0-0: Sync after 248 ms: 614462 ns
[ 2187.891799] EtherCAT DEBUG 0-0: Sync after 252 ms: 613765 ns
[ 2187.892795] EtherCAT DEBUG 0-0: Sync after 252 ms: 612026 ns
[ 2187.893794] EtherCAT DEBUG 0-0: Sync after 252 ms: 614390 ns
[ 2187.894794] EtherCAT DEBUG 0-0: Sync after 252 ms: 614423 ns
[ 2187.895794] EtherCAT DEBUG 0-0: Sync after 256 ms: 609573 ns
[ 2187.896794] EtherCAT DEBUG 0-0: Sync after 256 ms: 609081 ns
[ 2187.897794] EtherCAT DEBUG 0-0: Sync after 256 ms: 606879 ns
[ 2187.898794] EtherCAT DEBUG 0-0: Sync after 256 ms: 606219 ns
[ 2187.899799] EtherCAT DEBUG 0-0: Sync after 260 ms: 605910 ns
[ 2187.900795] EtherCAT DEBUG 0-0: Sync after 260 ms: 604336 ns
[ 2187.901794] EtherCAT DEBUG 0-0: Sync after 260 ms: 601257 ns
[ 2187.902794] EtherCAT DEBUG 0-0: Sync after 260 ms: 602352 ns
[ 2187.903794] EtherCAT DEBUG 0-0: Sync after 264 ms: 601107 ns
[ 2187.904794] EtherCAT DEBUG 0-0: Sync after 264 ms: 600871 ns
[ 2187.905793] EtherCAT DEBUG 0-0: Sync after 264 ms: 599344 ns
[ 2187.906794] EtherCAT DEBUG 0-0: Sync after 264 ms: 603172 ns
[ 2187.907799] EtherCAT DEBUG 0-0: Sync after 268 ms: 597722 ns
[ 2187.908795] EtherCAT DEBUG 0-0: Sync after 268 ms: 597181 ns
[ 2187.909800] EtherCAT DEBUG 0-0: Sync after 268 ms: 594571 ns
[ 2187.910797] EtherCAT DEBUG 0-0: Sync after 268 ms: 598865 ns
[ 2187.911799] EtherCAT DEBUG 0-0: Sync after 272 ms: 594917 ns
[ 2187.912795] EtherCAT DEBUG 0-0: Sync after 272 ms: 590409 ns
[ 2187.913795] EtherCAT DEBUG 0-0: Sync after 272 ms: 589649 ns
[ 2187.914794] EtherCAT DEBUG 0-0: Sync after 272 ms: 590892 ns
[ 2187.915799] EtherCAT DEBUG 0-0: Sync after 276 ms: 589168 ns
[ 2187.916795] EtherCAT DEBUG 0-0: Sync after 276 ms: 588699 ns
[ 2187.917794] EtherCAT DEBUG 0-0: Sync after 276 ms: 586531 ns
[ 2187.918794] EtherCAT DEBUG 0-0: Sync after 276 ms: 586757 ns
[ 2187.919794] EtherCAT DEBUG 0-0: Sync after 280 ms: 585026 ns
[ 2187.920795] EtherCAT DEBUG 0-0: Sync after 280 ms: 584885 ns
[ 2187.921794] EtherCAT DEBUG 0-0: Sync after 280 ms: 583560 ns
[ 2187.922794] EtherCAT DEBUG 0-0: Sync after 280 ms: 581679 ns
[ 2187.923799] EtherCAT DEBUG 0-0: Sync after 284 ms: 581644 ns
[ 2187.924795] EtherCAT DEBUG 0-0: Sync after 284 ms: 580234 ns
[ 2187.925794] EtherCAT DEBUG 0-0: Sync after 284 ms: 578086 ns
[ 2187.926794] EtherCAT DEBUG 0-0: Sync after 284 ms: 577829 ns
[ 2187.927794] EtherCAT DEBUG 0-0: Sync after 288 ms: 578215 ns
[ 2187.928794] EtherCAT DEBUG 0-0: Sync after 288 ms: 577059 ns
[ 2187.929794] EtherCAT DEBUG 0-0: Sync after 288 ms: 575799 ns
[ 2187.930794] EtherCAT DEBUG 0-0: Sync after 288 ms: 575088 ns
[ 2187.931799] EtherCAT DEBUG 0-0: Sync after 292 ms: 574189 ns
[ 2187.932795] EtherCAT DEBUG 0-0: Sync after 292 ms: 572163 ns
[ 2187.933794] EtherCAT DEBUG 0-0: Sync after 292 ms: 570014 ns
[ 2187.934794] EtherCAT DEBUG 0-0: Sync after 292 ms: 570957 ns
[ 2187.935794] EtherCAT DEBUG 0-0: Sync after 296 ms: 569809 ns
[ 2187.936794] EtherCAT DEBUG 0-0: Sync after 296 ms: 568566 ns
[ 2187.937793] EtherCAT DEBUG 0-0: Sync after 296 ms: 567245 ns
[ 2187.938794] EtherCAT DEBUG 0-0: Sync after 296 ms: 575970 ns
[ 2187.939799] EtherCAT DEBUG 0-0: Sync after 300 ms: 565781 ns
[ 2187.940795] EtherCAT DEBUG 0-0: Sync after 300 ms: 565222 ns
[ 2187.941796] EtherCAT DEBUG 0-0: Sync after 300 ms: 562326 ns
[ 2187.942794] EtherCAT DEBUG 0-0: Sync after 300 ms: 562665 ns
[ 2187.943799] EtherCAT DEBUG 0-0: Sync after 304 ms: 564757 ns
[ 2187.944795] EtherCAT DEBUG 0-0: Sync after 304 ms: 560138 ns
[ 2187.945794] EtherCAT DEBUG 0-0: Sync after 304 ms: 558513 ns
[ 2187.946794] EtherCAT DEBUG 0-0: Sync after 304 ms: 562523 ns
[ 2187.947794] EtherCAT DEBUG 0-0: Sync after 308 ms: 562025 ns
[ 2187.948794] EtherCAT DEBUG 0-0: Sync after 308 ms: 556978 ns
[ 2187.949794] EtherCAT DEBUG 0-0: Sync after 308 ms: 559445 ns
[ 2187.950794] EtherCAT DEBUG 0-0: Sync after 308 ms: 554570 ns
[ 2187.951798] EtherCAT DEBUG 0-0: Sync after 312 ms: 553362 ns
[ 2187.952795] EtherCAT DEBUG 0-0: Sync after 312 ms: 552474 ns
[ 2187.953794] EtherCAT DEBUG 0-0: Sync after 312 ms: 553839 ns
[ 2187.954794] EtherCAT DEBUG 0-0: Sync after 312 ms: 550622 ns
[ 2187.955794] EtherCAT DEBUG 0-0: Sync after 316 ms: 549828 ns
[ 2187.956794] EtherCAT DEBUG 0-0: Sync after 316 ms: 548809 ns
[ 2187.957794] EtherCAT DEBUG 0-0: Sync after 316 ms: 547114 ns
[ 2187.958793] EtherCAT DEBUG 0-0: Sync after 316 ms: 550632 ns
[ 2187.959799] EtherCAT DEBUG 0-0: Sync after 320 ms: 545983 ns
[ 2187.960795] EtherCAT DEBUG 0-0: Sync after 320 ms: 544349 ns
[ 2187.961794] EtherCAT DEBUG 0-0: Sync after 320 ms: 541470 ns
[ 2187.962794] EtherCAT DEBUG 0-0: Sync after 320 ms: 542391 ns
[ 2187.963794] EtherCAT DEBUG 0-0: Sync after 324 ms: 541430 ns
[ 2187.964794] EtherCAT DEBUG 0-0: Sync after 324 ms: 541089 ns
[ 2187.965794] EtherCAT DEBUG 0-0: Sync after 324 ms: 540128 ns
[ 2187.966794] EtherCAT DEBUG 0-0: Sync after 324 ms: 538760 ns
[ 2187.967799] EtherCAT DEBUG 0-0: Sync after 328 ms: 537901 ns
[ 2187.968795] EtherCAT DEBUG 0-0: Sync after 328 ms: 537276 ns
[ 2187.969794] EtherCAT DEBUG 0-0: Sync after 328 ms: 534413 ns
[ 2187.970794] EtherCAT DEBUG 0-0: Sync after 328 ms: 535159 ns
[ 2187.971794] EtherCAT DEBUG 0-0: Sync after 332 ms: 534354 ns
[ 2187.972794] EtherCAT DEBUG 0-0: Sync after 332 ms: 532566 ns
[ 2187.973795] EtherCAT DEBUG 0-0: Sync after 332 ms: 541608 ns
[ 2187.974794] EtherCAT DEBUG 0-0: Sync after 332 ms: 531043 ns
[ 2187.975799] EtherCAT DEBUG 0-0: Sync after 336 ms: 529635 ns
[ 2187.976795] EtherCAT DEBUG 0-0: Sync after 336 ms: 528116 ns
[ 2187.977794] EtherCAT DEBUG 0-0: Sync after 336 ms: 526626 ns
[ 2187.978794] EtherCAT DEBUG 0-0: Sync after 336 ms: 535644 ns
[ 2187.979794] EtherCAT DEBUG 0-0: Sync after 340 ms: 525936 ns
[ 2187.980794] EtherCAT DEBUG 0-0: Sync after 340 ms: 525419 ns
[ 2187.981794] EtherCAT DEBUG 0-0: Sync after 340 ms: 523850 ns
[ 2187.982794] EtherCAT DEBUG 0-0: Sync after 340 ms: 523549 ns
[ 2187.983799] EtherCAT DEBUG 0-0: Sync after 344 ms: 521570 ns
[ 2187.984795] EtherCAT DEBUG 0-0: Sync after 344 ms: 520831 ns
[ 2187.985794] EtherCAT DEBUG 0-0: Sync after 344 ms: 518361 ns
[ 2187.986794] EtherCAT DEBUG 0-0: Sync after 344 ms: 518785 ns
[ 2187.987799] EtherCAT DEBUG 0-0: Sync after 348 ms: 527193 ns
[ 2187.988795] EtherCAT DEBUG 0-0: Sync after 348 ms: 521652 ns
[ 2187.989794] EtherCAT DEBUG 0-0: Sync after 348 ms: 514310 ns
[ 2187.990794] EtherCAT DEBUG 0-0: Sync after 348 ms: 519639 ns
[ 2187.991794] EtherCAT DEBUG 0-0: Sync after 352 ms: 514424 ns
[ 2187.992794] EtherCAT DEBUG 0-0: Sync after 352 ms: 512381 ns
[ 2187.993793] EtherCAT DEBUG 0-0: Sync after 352 ms: 512137 ns
[ 2187.994794] EtherCAT DEBUG 0-0: Sync after 352 ms: 520198 ns
[ 2187.995799] EtherCAT DEBUG 0-0: Sync after 356 ms: 510440 ns
[ 2187.996795] EtherCAT DEBUG 0-0: Sync after 356 ms: 509244 ns
[ 2187.997794] EtherCAT DEBUG 0-0: Sync after 356 ms: 506691 ns
[ 2187.998794] EtherCAT DEBUG 0-0: Sync after 356 ms: 506898 ns
[ 2187.999794] EtherCAT DEBUG 0-0: Sync after 360 ms: 505499 ns
[ 2188.000794] EtherCAT DEBUG 0-0: Sync after 360 ms: 505102 ns
[ 2188.001794] EtherCAT DEBUG 0-0: Sync after 360 ms: 503806 ns
[ 2188.002794] EtherCAT DEBUG 0-0: Sync after 360 ms: 502924 ns
[ 2188.003800] EtherCAT DEBUG 0-0: Sync after 364 ms: 501675 ns
[ 2188.004796] EtherCAT DEBUG 0-0: Sync after 364 ms: 501069 ns
[ 2188.005794] EtherCAT DEBUG 0-0: Sync after 364 ms: 497682 ns
[ 2188.006794] EtherCAT DEBUG 0-0: Sync after 364 ms: 498544 ns
[ 2188.007794] EtherCAT DEBUG 0-0: Sync after 368 ms: 497814 ns
[ 2188.008794] EtherCAT DEBUG 0-0: Sync after 368 ms: 496815 ns
[ 2188.009794] EtherCAT DEBUG 0-0: Sync after 368 ms: 495769 ns
[ 2188.010794] EtherCAT DEBUG 0-0: Sync after 368 ms: 499519 ns
[ 2188.011799] EtherCAT DEBUG 0-0: Sync after 372 ms: 494391 ns
[ 2188.012795] EtherCAT DEBUG 0-0: Sync after 372 ms: 492496 ns
[ 2188.013794] EtherCAT DEBUG 0-0: Sync after 372 ms: 490478 ns
[ 2188.014798] EtherCAT DEBUG 0-0: Sync after 372 ms: 491286 ns
[ 2188.015794] EtherCAT DEBUG 0-0: Sync after 376 ms: 490506 ns
[ 2188.016794] EtherCAT DEBUG 0-0: Sync after 376 ms: 487192 ns
[ 2188.017794] EtherCAT DEBUG 0-0: Sync after 376 ms: 486154 ns
[ 2188.018793] EtherCAT DEBUG 0-0: Sync after 376 ms: 487381 ns
[ 2188.019799] EtherCAT DEBUG 0-0: Sync after 380 ms: 485598 ns
[ 2188.020795] EtherCAT DEBUG 0-0: Sync after 380 ms: 485485 ns
[ 2188.021794] EtherCAT DEBUG 0-0: Sync after 380 ms: 481894 ns
[ 2188.022794] EtherCAT DEBUG 0-0: Sync after 380 ms: 482637 ns
[ 2188.023794] EtherCAT DEBUG 0-0: Sync after 384 ms: 482609 ns
[ 2188.024794] EtherCAT DEBUG 0-0: Sync after 384 ms: 481647 ns
[ 2188.025794] EtherCAT DEBUG 0-0: Sync after 384 ms: 489287 ns
[ 2188.026794] EtherCAT DEBUG 0-0: Sync after 384 ms: 479540 ns
[ 2188.027796] EtherCAT DEBUG 0-0: Sync after 388 ms: 478352 ns
[ 2188.028794] EtherCAT DEBUG 0-0: Sync after 388 ms: 477164 ns
[ 2188.029794] EtherCAT DEBUG 0-0: Sync after 388 ms: 474566 ns
[ 2188.030794] EtherCAT DEBUG 0-0: Sync after 388 ms: 474418 ns
[ 2188.031794] EtherCAT DEBUG 0-0: Sync after 392 ms: 473455 ns
[ 2188.032794] EtherCAT DEBUG 0-0: Sync after 392 ms: 473655 ns
[ 2188.033796] EtherCAT DEBUG 0-0: Sync after 392 ms: 472387 ns
[ 2188.034799] EtherCAT DEBUG 0-0: Sync after 392 ms: 471547 ns
[ 2188.035798] EtherCAT DEBUG 0-0: Sync after 396 ms: 469217 ns
[ 2188.036794] EtherCAT DEBUG 0-0: Sync after 396 ms: 476425 ns
[ 2188.037794] EtherCAT DEBUG 0-0: Sync after 396 ms: 465563 ns
[ 2188.038794] EtherCAT DEBUG 0-0: Sync after 396 ms: 467184 ns
[ 2188.039796] EtherCAT DEBUG 0-0: Sync after 400 ms: 474972 ns
[ 2188.040794] EtherCAT DEBUG 0-0: Sync after 400 ms: 469692 ns
[ 2188.041794] EtherCAT DEBUG 0-0: Sync after 400 ms: 462718 ns
[ 2188.042794] EtherCAT DEBUG 0-0: Sync after 400 ms: 463084 ns
[ 2188.043794] EtherCAT DEBUG 0-0: Sync after 404 ms: 467253 ns
[ 2188.044794] EtherCAT DEBUG 0-0: Sync after 404 ms: 460824 ns
[ 2188.045797] EtherCAT DEBUG 0-0: Sync after 404 ms: 464069 ns
[ 2188.046795] EtherCAT DEBUG 0-0: Sync after 404 ms: 458796 ns
[ 2188.047796] EtherCAT DEBUG 0-0: Sync after 408 ms: 456066 ns
[ 2188.048794] EtherCAT DEBUG 0-0: Sync after 408 ms: 456129 ns
[ 2188.049794] EtherCAT DEBUG 0-0: Sync after 408 ms: 454460 ns
[ 2188.050794] EtherCAT DEBUG 0-0: Sync after 408 ms: 455139 ns
[ 2188.051794] EtherCAT DEBUG 0-0: Sync after 412 ms: 454560 ns
[ 2188.052794] EtherCAT DEBUG 0-0: Sync after 412 ms: 453162 ns
[ 2188.053794] EtherCAT DEBUG 0-0: Sync after 412 ms: 451816 ns
[ 2188.054794] EtherCAT DEBUG 0-0: Sync after 412 ms: 451382 ns
[ 2188.055796] EtherCAT DEBUG 0-0: Sync after 416 ms: 450143 ns
[ 2188.056795] EtherCAT DEBUG 0-0: Sync after 416 ms: 449598 ns
[ 2188.057794] EtherCAT DEBUG 0-0: Sync after 416 ms: 447443 ns
[ 2188.058794] EtherCAT DEBUG 0-0: Sync after 416 ms: 446640 ns
[ 2188.059794] EtherCAT DEBUG 0-0: Sync after 420 ms: 446575 ns
[ 2188.060794] EtherCAT DEBUG 0-0: Sync after 420 ms: 444798 ns
[ 2188.061794] EtherCAT DEBUG 0-0: Sync after 420 ms: 444028 ns
[ 2188.062794] EtherCAT DEBUG 0-0: Sync after 420 ms: 447900 ns
[ 2188.063796] EtherCAT DEBUG 0-0: Sync after 424 ms: 451959 ns
[ 2188.064799] EtherCAT DEBUG 0-0: Sync after 424 ms: 441848 ns
[ 2188.065798] EtherCAT DEBUG 0-0: Sync after 424 ms: 443666 ns
[ 2188.066794] EtherCAT DEBUG 0-0: Sync after 424 ms: 437257 ns
[ 2188.067797] EtherCAT DEBUG 0-0: Sync after 428 ms: 436476 ns
[ 2188.068794] EtherCAT DEBUG 0-0: Sync after 428 ms: 436735 ns
[ 2188.069794] EtherCAT DEBUG 0-0: Sync after 428 ms: 439119 ns
[ 2188.070794] EtherCAT DEBUG 0-0: Sync after 428 ms: 435753 ns
[ 2188.071794] EtherCAT DEBUG 0-0: Sync after 432 ms: 434090 ns
[ 2188.072794] EtherCAT DEBUG 0-0: Sync after 432 ms: 432845 ns
[ 2188.073794] EtherCAT DEBUG 0-0: Sync after 432 ms: 432189 ns
[ 2188.074793] EtherCAT DEBUG 0-0: Sync after 432 ms: 431242 ns
[ 2188.075796] EtherCAT DEBUG 0-0: Sync after 436 ms: 430868 ns
[ 2188.076795] EtherCAT DEBUG 0-0: Sync after 436 ms: 429459 ns
[ 2188.077794] EtherCAT DEBUG 0-0: Sync after 436 ms: 431510 ns
[ 2188.078794] EtherCAT DEBUG 0-0: Sync after 436 ms: 427058 ns
[ 2188.079796] EtherCAT DEBUG 0-0: Sync after 440 ms: 425804 ns
[ 2188.080794] EtherCAT DEBUG 0-0: Sync after 440 ms: 425471 ns
[ 2188.081794] EtherCAT DEBUG 0-0: Sync after 440 ms: 427225 ns
[ 2188.082794] EtherCAT DEBUG 0-0: Sync after 440 ms: 432466 ns
[ 2188.083794] EtherCAT DEBUG 0-0: Sync after 444 ms: 422899 ns
[ 2188.084794] EtherCAT DEBUG 0-0: Sync after 444 ms: 431147 ns
[ 2188.085794] EtherCAT DEBUG 0-0: Sync after 444 ms: 420042 ns
[ 2188.086794] EtherCAT DEBUG 0-0: Sync after 444 ms: 419127 ns
[ 2188.087796] EtherCAT DEBUG 0-0: Sync after 448 ms: 418733 ns
[ 2188.088794] EtherCAT DEBUG 0-0: Sync after 448 ms: 421099 ns
[ 2188.089794] EtherCAT DEBUG 0-0: Sync after 448 ms: 415038 ns
[ 2188.090794] EtherCAT DEBUG 0-0: Sync after 448 ms: 414807 ns
[ 2188.091794] EtherCAT DEBUG 0-0: Sync after 452 ms: 413807 ns
[ 2188.092794] EtherCAT DEBUG 0-0: Sync after 452 ms: 418060 ns
[ 2188.093795] EtherCAT DEBUG 0-0: Sync after 452 ms: 416467 ns
[ 2188.094794] EtherCAT DEBUG 0-0: Sync after 452 ms: 411692 ns
[ 2188.095796] EtherCAT DEBUG 0-0: Sync after 456 ms: 419532 ns
[ 2188.096794] EtherCAT DEBUG 0-0: Sync after 456 ms: 408759 ns
[ 2188.097795] EtherCAT DEBUG 0-0: Sync after 456 ms: 406629 ns
[ 2188.098794] EtherCAT DEBUG 0-0: Sync after 456 ms: 416639 ns
[ 2188.099796] EtherCAT DEBUG 0-0: Sync after 460 ms: 406214 ns
[ 2188.100794] EtherCAT DEBUG 0-0: Sync after 460 ms: 414485 ns
[ 2188.101794] EtherCAT DEBUG 0-0: Sync after 460 ms: 403273 ns
[ 2188.102794] EtherCAT DEBUG 0-0: Sync after 460 ms: 403066 ns
[ 2188.103794] EtherCAT DEBUG 0-0: Sync after 464 ms: 411872 ns
[ 2188.104794] EtherCAT DEBUG 0-0: Sync after 464 ms: 401706 ns
[ 2188.105794] EtherCAT DEBUG 0-0: Sync after 464 ms: 404377 ns
[ 2188.106794] EtherCAT DEBUG 0-0: Sync after 464 ms: 399382 ns
[ 2188.107796] EtherCAT DEBUG 0-0: Sync after 468 ms: 407228 ns
[ 2188.108794] EtherCAT DEBUG 0-0: Sync after 468 ms: 397683 ns
[ 2188.109794] EtherCAT DEBUG 0-0: Sync after 468 ms: 394681 ns
[ 2188.110794] EtherCAT DEBUG 0-0: Sync after 468 ms: 399694 ns
[ 2188.111794] EtherCAT DEBUG 0-0: Sync after 472 ms: 394389 ns
[ 2188.112794] EtherCAT DEBUG 0-0: Sync after 472 ms: 393658 ns
[ 2188.113793] EtherCAT DEBUG 0-0: Sync after 472 ms: 392320 ns
[ 2188.114794] EtherCAT DEBUG 0-0: Sync after 472 ms: 391268 ns
[ 2188.115796] EtherCAT DEBUG 0-0: Sync after 476 ms: 390368 ns
[ 2188.116794] EtherCAT DEBUG 0-0: Sync after 476 ms: 389886 ns
[ 2188.117794] EtherCAT DEBUG 0-0: Sync after 476 ms: 387495 ns
[ 2188.118794] EtherCAT DEBUG 0-0: Sync after 476 ms: 387885 ns
[ 2188.119794] EtherCAT DEBUG 0-0: Sync after 480 ms: 386132 ns
[ 2188.120794] EtherCAT DEBUG 0-0: Sync after 480 ms: 386045 ns
[ 2188.121794] EtherCAT DEBUG 0-0: Sync after 480 ms: 383650 ns
[ 2188.122794] EtherCAT DEBUG 0-0: Sync after 480 ms: 383547 ns
[ 2188.123796] EtherCAT DEBUG 0-0: Sync after 484 ms: 382731 ns
[ 2188.124794] EtherCAT DEBUG 0-0: Sync after 484 ms: 381244 ns
[ 2188.125794] EtherCAT DEBUG 0-0: Sync after 484 ms: 388038 ns
[ 2188.126799] EtherCAT DEBUG 0-0: Sync after 484 ms: 384035 ns
[ 2188.127797] EtherCAT DEBUG 0-0: Sync after 488 ms: 382639 ns
[ 2188.128795] EtherCAT DEBUG 0-0: Sync after 488 ms: 375947 ns
[ 2188.129794] EtherCAT DEBUG 0-0: Sync after 488 ms: 375245 ns
[ 2188.130794] EtherCAT DEBUG 0-0: Sync after 488 ms: 383726 ns
[ 2188.131796] EtherCAT DEBUG 0-0: Sync after 492 ms: 374117 ns
[ 2188.132794] EtherCAT DEBUG 0-0: Sync after 492 ms: 373221 ns
[ 2188.133794] EtherCAT DEBUG 0-0: Sync after 492 ms: 371483 ns
[ 2188.134794] EtherCAT DEBUG 0-0: Sync after 492 ms: 380251 ns
[ 2188.135794] EtherCAT DEBUG 0-0: Sync after 496 ms: 370210 ns
[ 2188.136794] EtherCAT DEBUG 0-0: Sync after 496 ms: 369699 ns
[ 2188.137794] EtherCAT DEBUG 0-0: Sync after 496 ms: 368171 ns
[ 2188.138794] EtherCAT DEBUG 0-0: Sync after 496 ms: 367460 ns
[ 2188.139796] EtherCAT DEBUG 0-0: Sync after 500 ms: 366252 ns
[ 2188.140794] EtherCAT DEBUG 0-0: Sync after 500 ms: 369323 ns
[ 2188.141794] EtherCAT DEBUG 0-0: Sync after 500 ms: 363143 ns
[ 2188.142794] EtherCAT DEBUG 0-0: Sync after 500 ms: 363916 ns
[ 2188.143794] EtherCAT DEBUG 0-0: Sync after 504 ms: 362957 ns
[ 2188.144794] EtherCAT DEBUG 0-0: Sync after 504 ms: 361009 ns
[ 2188.145794] EtherCAT DEBUG 0-0: Sync after 504 ms: 360609 ns
[ 2188.146794] EtherCAT DEBUG 0-0: Sync after 504 ms: 359711 ns
[ 2188.147795] EtherCAT DEBUG 0-0: Sync after 508 ms: 357870 ns
[ 2188.148794] EtherCAT DEBUG 0-0: Sync after 508 ms: 358124 ns
[ 2188.149794] EtherCAT DEBUG 0-0: Sync after 508 ms: 356011 ns
[ 2188.150793] EtherCAT DEBUG 0-0: Sync after 508 ms: 364436 ns
[ 2188.151794] EtherCAT DEBUG 0-0: Sync after 512 ms: 363493 ns
[ 2188.152797] EtherCAT DEBUG 0-0: Sync after 512 ms: 353241 ns
[ 2188.153798] EtherCAT DEBUG 0-0: Sync after 512 ms: 356713 ns
[ 2188.154801] EtherCAT DEBUG 0-0: Sync after 512 ms: 355224 ns
[ 2188.155796] EtherCAT DEBUG 0-0: Sync after 516 ms: 347990 ns
[ 2188.156800] EtherCAT DEBUG 0-0: Sync after 516 ms: 346878 ns
[ 2188.157800] EtherCAT DEBUG 0-0: Sync after 516 ms: 346951 ns
[ 2188.158800] EtherCAT DEBUG 0-0: Sync after 516 ms: 344555 ns
[ 2188.159800] EtherCAT DEBUG 0-0: Sync after 520 ms: 348480 ns
[ 2188.160800] EtherCAT DEBUG 0-0: Sync after 520 ms: 343545 ns
[ 2188.161802] EtherCAT DEBUG 0-0: Sync after 520 ms: 341604 ns
[ 2188.162796] EtherCAT DEBUG 0-0: Sync after 520 ms: 341041 ns
[ 2188.163796] EtherCAT DEBUG 0-0: Sync after 524 ms: 339330 ns
[ 2188.164800] EtherCAT DEBUG 0-0: Sync after 524 ms: 339122 ns
[ 2188.165797] EtherCAT DEBUG 0-0: Sync after 524 ms: 348535 ns
[ 2188.166794] EtherCAT DEBUG 0-0: Sync after 524 ms: 341080 ns
[ 2188.167795] EtherCAT DEBUG 0-0: Sync after 528 ms: 336383 ns
[ 2188.168794] EtherCAT DEBUG 0-0: Sync after 528 ms: 336686 ns
[ 2188.169794] EtherCAT DEBUG 0-0: Sync after 528 ms: 335011 ns
[ 2188.170793] EtherCAT DEBUG 0-0: Sync after 528 ms: 340180 ns
[ 2188.171796] EtherCAT DEBUG 0-0: Sync after 532 ms: 334192 ns
[ 2188.172794] EtherCAT DEBUG 0-0: Sync after 532 ms: 334105 ns
[ 2188.173795] EtherCAT DEBUG 0-0: Sync after 532 ms: 334797 ns
[ 2188.174798] EtherCAT DEBUG 0-0: Sync after 532 ms: 330941 ns
[ 2188.175795] EtherCAT DEBUG 0-0: Sync after 536 ms: 329664 ns
[ 2188.176794] EtherCAT DEBUG 0-0: Sync after 536 ms: 330005 ns
[ 2188.177794] EtherCAT DEBUG 0-0: Sync after 536 ms: 327623 ns
[ 2188.178794] EtherCAT DEBUG 0-0: Sync after 536 ms: 327381 ns
[ 2188.179797] EtherCAT DEBUG 0-0: Sync after 540 ms: 326641 ns
[ 2188.180794] EtherCAT DEBUG 0-0: Sync after 540 ms: 326147 ns
[ 2188.181794] EtherCAT DEBUG 0-0: Sync after 540 ms: 323067 ns
[ 2188.182794] EtherCAT DEBUG 0-0: Sync after 540 ms: 324084 ns
[ 2188.183794] EtherCAT DEBUG 0-0: Sync after 544 ms: 326893 ns
[ 2188.184794] EtherCAT DEBUG 0-0: Sync after 544 ms: 321275 ns
[ 2188.185794] EtherCAT DEBUG 0-0: Sync after 544 ms: 320383 ns
[ 2188.186793] EtherCAT DEBUG 0-0: Sync after 544 ms: 319763 ns
[ 2188.187795] EtherCAT DEBUG 0-0: Sync after 548 ms: 318651 ns
[ 2188.188798] EtherCAT DEBUG 0-0: Sync after 548 ms: 317263 ns
[ 2188.189798] EtherCAT DEBUG 0-0: Sync after 548 ms: 319560 ns
[ 2188.190795] EtherCAT DEBUG 0-0: Sync after 548 ms: 314366 ns
[ 2188.191796] EtherCAT DEBUG 0-0: Sync after 552 ms: 312449 ns
[ 2188.192795] EtherCAT DEBUG 0-0: Sync after 552 ms: 313560 ns
[ 2188.193793] EtherCAT DEBUG 0-0: Sync after 552 ms: 310610 ns
[ 2188.194794] EtherCAT DEBUG 0-0: Sync after 552 ms: 319925 ns
[ 2188.195794] EtherCAT DEBUG 0-0: Sync after 556 ms: 320128 ns
[ 2188.196794] EtherCAT DEBUG 0-0: Sync after 556 ms: 309910 ns
[ 2188.197794] EtherCAT DEBUG 0-0: Sync after 556 ms: 307972 ns
[ 2188.198794] EtherCAT DEBUG 0-0: Sync after 556 ms: 308104 ns
[ 2188.199795] EtherCAT DEBUG 0-0: Sync after 560 ms: 306213 ns
[ 2188.200800] EtherCAT DEBUG 0-0: Sync after 560 ms: 315283 ns
[ 2188.201794] EtherCAT DEBUG 0-0: Sync after 560 ms: 303810 ns
[ 2188.202794] EtherCAT DEBUG 0-0: Sync after 560 ms: 300758 ns
[ 2188.203797] EtherCAT DEBUG 0-0: Sync after 564 ms: 302679 ns
[ 2188.204794] EtherCAT DEBUG 0-0: Sync after 564 ms: 310900 ns
[ 2188.205797] EtherCAT DEBUG 0-0: Sync after 564 ms: 299163 ns
[ 2188.206798] EtherCAT DEBUG 0-0: Sync after 564 ms: 298904 ns
[ 2188.207796] EtherCAT DEBUG 0-0: Sync after 568 ms: 302493 ns
[ 2188.208794] EtherCAT DEBUG 0-0: Sync after 568 ms: 295611 ns
[ 2188.209794] EtherCAT DEBUG 0-0: Sync after 568 ms: 294372 ns
[ 2188.210794] EtherCAT DEBUG 0-0: Sync after 568 ms: 295314 ns
[ 2188.211794] EtherCAT DEBUG 0-0: Sync after 572 ms: 298985 ns
[ 2188.212794] EtherCAT DEBUG 0-0: Sync after 572 ms: 294452 ns
[ 2188.213794] EtherCAT DEBUG 0-0: Sync after 572 ms: 292371 ns
[ 2188.214794] EtherCAT DEBUG 0-0: Sync after 572 ms: 291994 ns
[ 2188.215796] EtherCAT DEBUG 0-0: Sync after 576 ms: 290914 ns
[ 2188.216795] EtherCAT DEBUG 0-0: Sync after 576 ms: 289791 ns
[ 2188.217794] EtherCAT DEBUG 0-0: Sync after 576 ms: 296294 ns
[ 2188.218794] EtherCAT DEBUG 0-0: Sync after 576 ms: 286675 ns
[ 2188.219796] EtherCAT DEBUG 0-0: Sync after 580 ms: 287070 ns
[ 2188.220800] EtherCAT DEBUG 0-0: Sync after 580 ms: 285437 ns
[ 2188.221798] EtherCAT DEBUG 0-0: Sync after 580 ms: 287249 ns
[ 2188.222794] EtherCAT DEBUG 0-0: Sync after 580 ms: 281177 ns
[ 2188.223796] EtherCAT DEBUG 0-0: Sync after 584 ms: 280541 ns
[ 2188.224794] EtherCAT DEBUG 0-0: Sync after 584 ms: 281498 ns
[ 2188.225794] EtherCAT DEBUG 0-0: Sync after 584 ms: 283116 ns
[ 2188.226794] EtherCAT DEBUG 0-0: Sync after 584 ms: 288963 ns
[ 2188.227794] EtherCAT DEBUG 0-0: Sync after 588 ms: 278385 ns
[ 2188.228794] EtherCAT DEBUG 0-0: Sync after 588 ms: 277748 ns
[ 2188.229794] EtherCAT DEBUG 0-0: Sync after 588 ms: 276201 ns
[ 2188.230794] EtherCAT DEBUG 0-0: Sync after 588 ms: 275467 ns
[ 2188.231797] EtherCAT DEBUG 0-0: Sync after 592 ms: 275149 ns
[ 2188.232795] EtherCAT DEBUG 0-0: Sync after 592 ms: 273721 ns
[ 2188.233798] EtherCAT DEBUG 0-0: Sync after 592 ms: 270807 ns
[ 2188.234796] EtherCAT DEBUG 0-0: Sync after 592 ms: 271442 ns
[ 2188.235796] EtherCAT DEBUG 0-0: Sync after 596 ms: 269467 ns
[ 2188.236794] EtherCAT DEBUG 0-0: Sync after 596 ms: 269661 ns
[ 2188.237794] EtherCAT DEBUG 0-0: Sync after 596 ms: 268013 ns
[ 2188.238794] EtherCAT DEBUG 0-0: Sync after 596 ms: 267997 ns
[ 2188.239794] EtherCAT DEBUG 0-0: Sync after 600 ms: 267324 ns
[ 2188.240794] EtherCAT DEBUG 0-0: Sync after 600 ms: 275734 ns
[ 2188.241793] EtherCAT DEBUG 0-0: Sync after 600 ms: 263905 ns
[ 2188.242793] EtherCAT DEBUG 0-0: Sync after 600 ms: 263639 ns
[ 2188.243796] EtherCAT DEBUG 0-0: Sync after 604 ms: 263277 ns
[ 2188.244794] EtherCAT DEBUG 0-0: Sync after 604 ms: 262552 ns
[ 2188.245794] EtherCAT DEBUG 0-0: Sync after 604 ms: 260142 ns
[ 2188.246793] EtherCAT DEBUG 0-0: Sync after 604 ms: 260311 ns
[ 2188.247794] EtherCAT DEBUG 0-0: Sync after 608 ms: 258272 ns
[ 2188.248794] EtherCAT DEBUG 0-0: Sync after 608 ms: 261973 ns
[ 2188.249794] EtherCAT DEBUG 0-0: Sync after 608 ms: 260857 ns
[ 2188.250799] EtherCAT DEBUG 0-0: Sync after 608 ms: 256547 ns
[ 2188.251798] EtherCAT DEBUG 0-0: Sync after 612 ms: 254570 ns
[ 2188.252797] EtherCAT DEBUG 0-0: Sync after 612 ms: 251800 ns
[ 2188.253794] EtherCAT DEBUG 0-0: Sync after 612 ms: 250895 ns
[ 2188.254793] EtherCAT DEBUG 0-0: Sync after 612 ms: 251382 ns
[ 2188.255796] EtherCAT DEBUG 0-0: Sync after 616 ms: 251126 ns
[ 2188.256794] EtherCAT DEBUG 0-0: Sync after 616 ms: 249889 ns
[ 2188.257794] EtherCAT DEBUG 0-0: Sync after 616 ms: 247513 ns
[ 2188.258794] EtherCAT DEBUG 0-0: Sync after 616 ms: 247752 ns
[ 2188.259796] EtherCAT DEBUG 0-0: Sync after 620 ms: 246946 ns
[ 2188.260794] EtherCAT DEBUG 0-0: Sync after 620 ms: 246514 ns
[ 2188.261794] EtherCAT DEBUG 0-0: Sync after 620 ms: 243911 ns
[ 2188.262795] EtherCAT DEBUG 0-0: Sync after 620 ms: 244441 ns
[ 2188.263796] EtherCAT DEBUG 0-0: Sync after 624 ms: 252086 ns
[ 2188.264794] EtherCAT DEBUG 0-0: Sync after 624 ms: 242043 ns
[ 2188.265794] EtherCAT DEBUG 0-0: Sync after 624 ms: 238951 ns
[ 2188.266794] EtherCAT DEBUG 0-0: Sync after 624 ms: 240062 ns
[ 2188.267794] EtherCAT DEBUG 0-0: Sync after 628 ms: 238457 ns
[ 2188.268794] EtherCAT DEBUG 0-0: Sync after 628 ms: 238736 ns
[ 2188.269794] EtherCAT DEBUG 0-0: Sync after 628 ms: 236912 ns
[ 2188.270794] EtherCAT DEBUG 0-0: Sync after 628 ms: 236192 ns
[ 2188.271796] EtherCAT DEBUG 0-0: Sync after 632 ms: 235164 ns
[ 2188.272794] EtherCAT DEBUG 0-0: Sync after 632 ms: 234121 ns
[ 2188.273794] EtherCAT DEBUG 0-0: Sync after 632 ms: 231037 ns
[ 2188.274794] EtherCAT DEBUG 0-0: Sync after 632 ms: 232119 ns
[ 2188.275794] EtherCAT DEBUG 0-0: Sync after 636 ms: 235744 ns
[ 2188.276794] EtherCAT DEBUG 0-0: Sync after 636 ms: 230733 ns
[ 2188.277794] EtherCAT DEBUG 0-0: Sync after 636 ms: 228814 ns
[ 2188.278794] EtherCAT DEBUG 0-0: Sync after 636 ms: 227684 ns
[ 2188.279796] EtherCAT DEBUG 0-0: Sync after 640 ms: 232028 ns
[ 2188.280794] EtherCAT DEBUG 0-0: Sync after 640 ms: 225730 ns
[ 2188.281799] EtherCAT DEBUG 0-0: Sync after 640 ms: 227350 ns
[ 2188.282798] EtherCAT DEBUG 0-0: Sync after 640 ms: 224626 ns
[ 2188.283797] EtherCAT DEBUG 0-0: Sync after 644 ms: 221072 ns
[ 2188.284794] EtherCAT DEBUG 0-0: Sync after 644 ms: 219581 ns
[ 2188.285794] EtherCAT DEBUG 0-0: Sync after 644 ms: 219494 ns
[ 2188.286794] EtherCAT DEBUG 0-0: Sync after 644 ms: 219933 ns
[ 2188.287794] EtherCAT DEBUG 0-0: Sync after 648 ms: 218503 ns
[ 2188.288794] EtherCAT DEBUG 0-0: Sync after 648 ms: 218560 ns
[ 2188.289794] EtherCAT DEBUG 0-0: Sync after 648 ms: 216149 ns
[ 2188.290794] EtherCAT DEBUG 0-0: Sync after 648 ms: 216421 ns
[ 2188.291797] EtherCAT DEBUG 0-0: Sync after 652 ms: 215142 ns
[ 2188.292794] EtherCAT DEBUG 0-0: Sync after 652 ms: 218320 ns
[ 2188.293794] EtherCAT DEBUG 0-0: Sync after 652 ms: 211129 ns
[ 2188.294796] EtherCAT DEBUG 0-0: Sync after 652 ms: 212534 ns
[ 2188.295795] EtherCAT DEBUG 0-0: Sync after 656 ms: 211052 ns
[ 2188.296794] EtherCAT DEBUG 0-0: Sync after 656 ms: 214273 ns
[ 2188.297794] EtherCAT DEBUG 0-0: Sync after 656 ms: 208224 ns
[ 2188.298793] EtherCAT DEBUG 0-0: Sync after 656 ms: 207742 ns
[ 2188.299794] EtherCAT DEBUG 0-0: Sync after 660 ms: 206793 ns
[ 2188.300794] EtherCAT DEBUG 0-0: Sync after 660 ms: 206816 ns
[ 2188.301794] EtherCAT DEBUG 0-0: Sync after 660 ms: 204472 ns
[ 2188.302794] EtherCAT DEBUG 0-0: Sync after 660 ms: 204157 ns
[ 2188.303795] EtherCAT DEBUG 0-0: Sync after 664 ms: 203012 ns
[ 2188.304794] EtherCAT DEBUG 0-0: Sync after 664 ms: 202387 ns
[ 2188.305794] EtherCAT DEBUG 0-0: Sync after 664 ms: 199850 ns
[ 2188.306793] EtherCAT DEBUG 0-0: Sync after 664 ms: 200093 ns
[ 2188.307794] EtherCAT DEBUG 0-0: Sync after 668 ms: 199248 ns
[ 2188.308794] EtherCAT DEBUG 0-0: Sync after 668 ms: 197791 ns
[ 2188.309794] EtherCAT DEBUG 0-0: Sync after 668 ms: 201345 ns
[ 2188.310794] EtherCAT DEBUG 0-0: Sync after 668 ms: 196649 ns
[ 2188.311794] EtherCAT DEBUG 0-0: Sync after 672 ms: 195667 ns
[ 2188.312794] EtherCAT DEBUG 0-0: Sync after 672 ms: 194523 ns
[ 2188.313801] EtherCAT DEBUG 0-0: Sync after 672 ms: 192201 ns
[ 2188.314796] EtherCAT DEBUG 0-0: Sync after 672 ms: 192650 ns
[ 2188.315795] EtherCAT DEBUG 0-0: Sync after 676 ms: 188883 ns
[ 2188.316794] EtherCAT DEBUG 0-0: Sync after 676 ms: 188192 ns
[ 2188.317794] EtherCAT DEBUG 0-0: Sync after 676 ms: 188840 ns
[ 2188.318794] EtherCAT DEBUG 0-0: Sync after 676 ms: 197403 ns
[ 2188.319794] EtherCAT DEBUG 0-0: Sync after 680 ms: 186863 ns
[ 2188.320794] EtherCAT DEBUG 0-0: Sync after 680 ms: 185614 ns
[ 2188.321794] EtherCAT DEBUG 0-0: Sync after 680 ms: 184905 ns
[ 2188.322793] EtherCAT DEBUG 0-0: Sync after 680 ms: 184181 ns
[ 2188.323795] EtherCAT DEBUG 0-0: Sync after 684 ms: 182910 ns
[ 2188.324799] EtherCAT DEBUG 0-0: Sync after 684 ms: 182114 ns
[ 2188.325795] EtherCAT DEBUG 0-0: Sync after 684 ms: 190270 ns
[ 2188.326794] EtherCAT DEBUG 0-0: Sync after 684 ms: 178090 ns
[ 2188.327795] EtherCAT DEBUG 0-0: Sync after 688 ms: 179331 ns
[ 2188.328794] EtherCAT DEBUG 0-0: Sync after 688 ms: 178040 ns
[ 2188.329794] EtherCAT DEBUG 0-0: Sync after 688 ms: 176678 ns
[ 2188.330793] EtherCAT DEBUG 0-0: Sync after 688 ms: 176229 ns
[ 2188.331794] EtherCAT DEBUG 0-0: Sync after 692 ms: 175565 ns
[ 2188.332794] EtherCAT DEBUG 0-0: Sync after 692 ms: 174889 ns
[ 2188.333794] EtherCAT DEBUG 0-0: Sync after 692 ms: 173018 ns
[ 2188.334796] EtherCAT DEBUG 0-0: Sync after 692 ms: 172684 ns
[ 2188.335795] EtherCAT DEBUG 0-0: Sync after 696 ms: 175788 ns
[ 2188.336794] EtherCAT DEBUG 0-0: Sync after 696 ms: 168716 ns
[ 2188.337794] EtherCAT DEBUG 0-0: Sync after 696 ms: 167671 ns
[ 2188.338794] EtherCAT DEBUG 0-0: Sync after 696 ms: 167985 ns
[ 2188.339794] EtherCAT DEBUG 0-0: Sync after 700 ms: 176362 ns
[ 2188.340794] EtherCAT DEBUG 0-0: Sync after 700 ms: 166570 ns
[ 2188.341794] EtherCAT DEBUG 0-0: Sync after 700 ms: 164766 ns
[ 2188.342794] EtherCAT DEBUG 0-0: Sync after 700 ms: 164397 ns
[ 2188.343795] EtherCAT DEBUG 0-0: Sync after 704 ms: 163296 ns
[ 2188.344799] EtherCAT DEBUG 0-0: Sync after 704 ms: 162675 ns
[ 2188.345797] EtherCAT DEBUG 0-0: Sync after 704 ms: 160031 ns
[ 2188.346794] EtherCAT DEBUG 0-0: Sync after 704 ms: 158626 ns
[ 2188.347795] EtherCAT DEBUG 0-0: Sync after 708 ms: 161003 ns
[ 2188.348794] EtherCAT DEBUG 0-0: Sync after 708 ms: 167823 ns
[ 2188.349795] EtherCAT DEBUG 0-0: Sync after 708 ms: 161140 ns
[ 2188.350794] EtherCAT DEBUG 0-0: Sync after 708 ms: 156039 ns
[ 2188.351794] EtherCAT DEBUG 0-0: Sync after 712 ms: 154885 ns
[ 2188.352794] EtherCAT DEBUG 0-0: Sync after 712 ms: 158697 ns
[ 2188.353794] EtherCAT DEBUG 0-0: Sync after 712 ms: 152512 ns
[ 2188.354795] EtherCAT DEBUG 0-0: Sync after 712 ms: 152815 ns
[ 2188.355797] EtherCAT DEBUG 0-0: Sync after 716 ms: 151015 ns
[ 2188.356795] EtherCAT DEBUG 0-0: Sync after 716 ms: 149831 ns
[ 2188.357794] EtherCAT DEBUG 0-0: Sync after 716 ms: 148201 ns
[ 2188.358794] EtherCAT DEBUG 0-0: Sync after 716 ms: 151703 ns
[ 2188.359797] EtherCAT DEBUG 0-0: Sync after 720 ms: 147885 ns
[ 2188.360794] EtherCAT DEBUG 0-0: Sync after 720 ms: 146786 ns
[ 2188.361794] EtherCAT DEBUG 0-0: Sync after 720 ms: 152877 ns
[ 2188.362794] EtherCAT DEBUG 0-0: Sync after 720 ms: 143949 ns
[ 2188.363794] EtherCAT DEBUG 0-0: Sync after 724 ms: 144070 ns
[ 2188.364794] EtherCAT DEBUG 0-0: Sync after 724 ms: 142949 ns
[ 2188.365794] EtherCAT DEBUG 0-0: Sync after 724 ms: 140902 ns
[ 2188.366794] EtherCAT DEBUG 0-0: Sync after 724 ms: 140868 ns
[ 2188.367795] EtherCAT DEBUG 0-0: Sync after 728 ms: 139592 ns
[ 2188.368793] EtherCAT DEBUG 0-0: Sync after 728 ms: 138257 ns
[ 2188.369794] EtherCAT DEBUG 0-0: Sync after 728 ms: 136122 ns
[ 2188.370795] EtherCAT DEBUG 0-0: Sync after 728 ms: 136641 ns
[ 2188.371794] EtherCAT DEBUG 0-0: Sync after 732 ms: 136042 ns
[ 2188.372794] EtherCAT DEBUG 0-0: Sync after 732 ms: 134101 ns
[ 2188.373794] EtherCAT DEBUG 0-0: Sync after 732 ms: 133595 ns
[ 2188.374795] EtherCAT DEBUG 0-0: Sync after 732 ms: 133083 ns
[ 2188.375801] EtherCAT DEBUG 0-0: Sync after 736 ms: 131606 ns
[ 2188.376801] EtherCAT DEBUG 0-0: Sync after 736 ms: 129735 ns
[ 2188.377794] EtherCAT DEBUG 0-0: Sync after 736 ms: 127409 ns
[ 2188.378794] EtherCAT DEBUG 0-0: Sync after 736 ms: 126211 ns
[ 2188.379794] EtherCAT DEBUG 0-0: Sync after 740 ms: 127390 ns
[ 2188.380794] EtherCAT DEBUG 0-0: Sync after 740 ms: 134830 ns
[ 2188.381793] EtherCAT DEBUG 0-0: Sync after 740 ms: 125549 ns
[ 2188.382794] EtherCAT DEBUG 0-0: Sync after 740 ms: 125139 ns
[ 2188.383795] EtherCAT DEBUG 0-0: Sync after 744 ms: 123832 ns
[ 2188.384793] EtherCAT DEBUG 0-0: Sync after 744 ms: 122589 ns
[ 2188.385794] EtherCAT DEBUG 0-0: Sync after 744 ms: 120258 ns
[ 2188.386800] EtherCAT DEBUG 0-0: Sync after 744 ms: 124493 ns
[ 2188.387794] EtherCAT DEBUG 0-0: Sync after 748 ms: 120148 ns
[ 2188.388794] EtherCAT DEBUG 0-0: Sync after 748 ms: 115923 ns
[ 2188.389794] EtherCAT DEBUG 0-0: Sync after 748 ms: 117369 ns
[ 2188.390794] EtherCAT DEBUG 0-0: Sync after 748 ms: 115991 ns
[ 2188.391795] EtherCAT DEBUG 0-0: Sync after 752 ms: 119557 ns
[ 2188.392794] EtherCAT DEBUG 0-0: Sync after 752 ms: 114285 ns
[ 2188.393794] EtherCAT DEBUG 0-0: Sync after 752 ms: 116368 ns
[ 2188.394794] EtherCAT DEBUG 0-0: Sync after 752 ms: 112723 ns
[ 2188.395794] EtherCAT DEBUG 0-0: Sync after 756 ms: 111577 ns
[ 2188.396794] EtherCAT DEBUG 0-0: Sync after 756 ms: 110201 ns
[ 2188.397793] EtherCAT DEBUG 0-0: Sync after 756 ms: 118354 ns
[ 2188.398793] EtherCAT DEBUG 0-0: Sync after 756 ms: 118352 ns
[ 2188.399795] EtherCAT DEBUG 0-0: Sync after 760 ms: 107777 ns
[ 2188.400794] EtherCAT DEBUG 0-0: Sync after 760 ms: 106172 ns
[ 2188.401794] EtherCAT DEBUG 0-0: Sync after 760 ms: 103843 ns
[ 2188.402794] EtherCAT DEBUG 0-0: Sync after 760 ms: 104181 ns
[ 2188.403794] EtherCAT DEBUG 0-0: Sync after 764 ms: 104085 ns
[ 2188.404801] EtherCAT DEBUG 0-0: Sync after 764 ms: 103058 ns
[ 2188.405802] EtherCAT DEBUG 0-0: Sync after 764 ms: 100876 ns
[ 2188.406802] EtherCAT DEBUG 0-0: Sync after 764 ms: 97252 ns
[ 2188.407800] EtherCAT DEBUG 0-0: Sync after 768 ms: 96824 ns
[ 2188.408798] EtherCAT DEBUG 0-0: Sync after 768 ms: 100243 ns
[ 2188.409794] EtherCAT DEBUG 0-0: Sync after 768 ms: 93493 ns
[ 2188.410794] EtherCAT DEBUG 0-0: Sync after 768 ms: 94553 ns
[ 2188.411796] EtherCAT DEBUG 0-0: Sync after 772 ms: 94768 ns
[ 2188.412794] EtherCAT DEBUG 0-0: Sync after 772 ms: 95074 ns
[ 2188.413794] EtherCAT DEBUG 0-0: Sync after 772 ms: 91379 ns
[ 2188.414794] EtherCAT DEBUG 0-0: Sync after 772 ms: 92271 ns
[ 2188.415799] EtherCAT DEBUG 0-0: Sync after 776 ms: 91047 ns
[ 2188.416797] EtherCAT DEBUG 0-0: Sync after 776 ms: 90430 ns
[ 2188.417794] EtherCAT DEBUG 0-0: Sync after 776 ms: 91207 ns
[ 2188.418795] EtherCAT DEBUG 0-0: Sync after 776 ms: 87166 ns
[ 2188.419798] EtherCAT DEBUG 0-0: Sync after 780 ms: 87782 ns
[ 2188.420794] EtherCAT DEBUG 0-0: Sync after 780 ms: 85835 ns
[ 2188.421794] EtherCAT DEBUG 0-0: Sync after 780 ms: 84969 ns
[ 2188.422794] EtherCAT DEBUG 0-0: Sync after 780 ms: 84603 ns
[ 2188.423799] EtherCAT DEBUG 0-0: Sync after 784 ms: 83835 ns
[ 2188.424794] EtherCAT DEBUG 0-0: Sync after 784 ms: 82318 ns
[ 2188.425797] EtherCAT DEBUG 0-0: Sync after 784 ms: 77552 ns
[ 2188.426795] EtherCAT DEBUG 0-0: Sync after 784 ms: 84831 ns
[ 2188.427794] EtherCAT DEBUG 0-0: Sync after 788 ms: 79151 ns
[ 2188.428794] EtherCAT DEBUG 0-0: Sync after 788 ms: 78123 ns
[ 2188.429794] EtherCAT DEBUG 0-0: Sync after 788 ms: 77441 ns
[ 2188.430794] EtherCAT DEBUG 0-0: Sync after 788 ms: 77100 ns
[ 2188.431798] EtherCAT DEBUG 0-0: Sync after 792 ms: 75135 ns
[ 2188.432796] EtherCAT DEBUG 0-0: Sync after 792 ms: 74461 ns
[ 2188.433797] EtherCAT DEBUG 0-0: Sync after 792 ms: 71176 ns
[ 2188.434794] EtherCAT DEBUG 0-0: Sync after 792 ms: 80245 ns
[ 2188.435797] EtherCAT DEBUG 0-0: Sync after 796 ms: 70642 ns
[ 2188.436798] EtherCAT DEBUG 0-0: Sync after 796 ms: 70238 ns
[ 2188.437798] EtherCAT DEBUG 0-0: Sync after 796 ms: 71941 ns
[ 2188.438796] EtherCAT DEBUG 0-0: Sync after 796 ms: 67661 ns
[ 2188.439798] EtherCAT DEBUG 0-0: Sync after 800 ms: 66092 ns
[ 2188.440794] EtherCAT DEBUG 0-0: Sync after 800 ms: 65135 ns
[ 2188.441794] EtherCAT DEBUG 0-0: Sync after 800 ms: 67299 ns
[ 2188.442794] EtherCAT DEBUG 0-0: Sync after 800 ms: 64804 ns
[ 2188.443794] EtherCAT DEBUG 0-0: Sync after 804 ms: 68847 ns
[ 2188.444794] EtherCAT DEBUG 0-0: Sync after 804 ms: 62620 ns
[ 2188.445798] EtherCAT DEBUG 0-0: Sync after 804 ms: 60824 ns
[ 2188.446794] EtherCAT DEBUG 0-0: Sync after 804 ms: 60003 ns
[ 2188.447798] EtherCAT DEBUG 0-0: Sync after 808 ms: 58480 ns
[ 2188.448800] EtherCAT DEBUG 0-0: Sync after 808 ms: 58400 ns
[ 2188.449797] EtherCAT DEBUG 0-0: Sync after 808 ms: 55828 ns
[ 2188.450795] EtherCAT DEBUG 0-0: Sync after 808 ms: 52804 ns
[ 2188.451795] EtherCAT DEBUG 0-0: Sync after 812 ms: 55990 ns
[ 2188.452795] EtherCAT DEBUG 0-0: Sync after 812 ms: 54318 ns
[ 2188.453794] EtherCAT DEBUG 0-0: Sync after 812 ms: 57561 ns
[ 2188.454795] EtherCAT DEBUG 0-0: Sync after 812 ms: 52497 ns
[ 2188.455799] EtherCAT DEBUG 0-0: Sync after 816 ms: 51677 ns
[ 2188.456794] EtherCAT DEBUG 0-0: Sync after 816 ms: 59904 ns
[ 2188.457794] EtherCAT DEBUG 0-0: Sync after 816 ms: 51184 ns
[ 2188.458794] EtherCAT DEBUG 0-0: Sync after 816 ms: 48504 ns
[ 2188.459794] EtherCAT DEBUG 0-0: Sync after 820 ms: 47697 ns
[ 2188.460794] EtherCAT DEBUG 0-0: Sync after 820 ms: 47115 ns
[ 2188.461795] EtherCAT DEBUG 0-0: Sync after 820 ms: 49022 ns
[ 2188.462793] EtherCAT DEBUG 0-0: Sync after 820 ms: 44660 ns
[ 2188.463797] EtherCAT DEBUG 0-0: Sync after 824 ms: 42938 ns
[ 2188.464794] EtherCAT DEBUG 0-0: Sync after 824 ms: 43148 ns
[ 2188.465794] EtherCAT DEBUG 0-0: Sync after 824 ms: 40415 ns
[ 2188.466794] EtherCAT DEBUG 0-0: Sync after 824 ms: 49721 ns
[ 2188.467799] EtherCAT DEBUG 0-0: Sync after 828 ms: 39663 ns
[ 2188.468798] EtherCAT DEBUG 0-0: Sync after 828 ms: 38508 ns
[ 2188.469797] EtherCAT DEBUG 0-0: Sync after 828 ms: 44985 ns
[ 2188.470794] EtherCAT DEBUG 0-0: Sync after 828 ms: 35088 ns
[ 2188.471799] EtherCAT DEBUG 0-0: Sync after 832 ms: 34069 ns
[ 2188.472794] EtherCAT DEBUG 0-0: Sync after 832 ms: 34446 ns
[ 2188.473794] EtherCAT DEBUG 0-0: Sync after 832 ms: 31210 ns
[ 2188.474794] EtherCAT DEBUG 0-0: Sync after 832 ms: 32265 ns
[ 2188.475797] EtherCAT DEBUG 0-0: Sync after 836 ms: 32303 ns
[ 2188.476797] EtherCAT DEBUG 0-0: Sync after 836 ms: 30522 ns
[ 2188.477795] EtherCAT DEBUG 0-0: Sync after 836 ms: 28822 ns
[ 2188.478794] EtherCAT DEBUG 0-0: Sync after 836 ms: 42815 ns
[ 2188.479796] EtherCAT DEBUG 0-0: Sync after 840 ms: 31463 ns
[ 2188.480796] EtherCAT DEBUG 0-0: Sync after 840 ms: 26540 ns
[ 2188.481796] EtherCAT DEBUG 0-0: Sync after 840 ms: 24720 ns
[ 2188.482794] EtherCAT DEBUG 0-0: Sync after 840 ms: 23467 ns
[ 2188.483799] EtherCAT DEBUG 0-0: Sync after 844 ms: 23087 ns
[ 2188.484795] EtherCAT DEBUG 0-0: Sync after 844 ms: 22219 ns
[ 2188.485794] EtherCAT DEBUG 0-0: Sync after 844 ms: 19019 ns
[ 2188.486794] EtherCAT DEBUG 0-0: Sync after 844 ms: 29091 ns
[ 2188.487794] EtherCAT DEBUG 0-0: Sync after 848 ms: 19632 ns
[ 2188.488794] EtherCAT DEBUG 0-0: Sync after 848 ms: 19298 ns
[ 2188.489794] EtherCAT DEBUG 0-0: Sync after 848 ms: 18350 ns
[ 2188.490794] EtherCAT DEBUG 0-0: Sync after 848 ms: 16868 ns
[ 2188.491796] EtherCAT DEBUG 0-0: Sync after 852 ms: 15487 ns
[ 2188.492794] EtherCAT DEBUG 0-0: Sync after 852 ms: 14809 ns
[ 2188.493794] EtherCAT DEBUG 0-0: Sync after 852 ms: 16775 ns
[ 2188.494797] EtherCAT DEBUG 0-0: Sync after 852 ms: 12672 ns
[ 2188.495794] EtherCAT DEBUG 0-0: Sync after 856 ms: 16131 ns
[ 2188.496794] EtherCAT DEBUG 0-0: 8396 ns difference after 856 ms.
[ 2188.496795] EtherCAT DEBUG 0-0: ref_time=734900849711261000
[ 2188.496796] EtherCAT DEBUG 0-0: app_time=734900850763865853
[ 2188.496796] EtherCAT DEBUG 0-0: start_time=734900850863865853
[ 2188.496797] EtherCAT DEBUG 0-0: cycle=1000000
[ 2188.496798] EtherCAT DEBUG 0-0: shift_time=0
[ 2188.496798] EtherCAT DEBUG 0-0: remainder=604853
[ 2188.496799] EtherCAT DEBUG 0-0: start=734900850864261000
[ 2188.496800] EtherCAT DEBUG 0-0: Setting DC cyclic operation start time to 734900850864261000.
[ 2188.498798] EtherCAT DEBUG 0-0: Setting DC AssignActivate to 0x0300.
[ 2188.505794] EtherCAT DEBUG 0-0: Now in SAFEOP.
[ 2188.506795] EtherCAT 0: Domain 0: Working counter changed to 3/3.
[ 2188.507797] EtherCAT DEBUG 0-0: Now in OP. Finished configuration.
[ 2188.514986] EtherCAT 0: Slave states on main device: OP.
15 Apr 2023 19:36 #269151
by Stean
Replied by Stean on topic Chinese servo drive SG-AS problem with EtherCAT version startup
I have noticed that when I reset the servodrive without shutting down LinuxCNC, then the drive becomes visible in the DRO and shows the actual position, the drive has no error and it`s in working order "bb".
15 Apr 2023 19:44 #269152
by Stean
.. also when I switch machine power on, then drive switched to "run" and working in JOG mode !
The problem to be solved, why the error 40 occurs. m
Maybe someone had a similar problem (?)
Thank you RodW.
Thank you RodW.
15 Apr 2023 20:39 #269155
by Stean
... and you're right with an empty pid="" it doesn't work, that's why I lost a lot of time.
I observed that if I set Control Word to RESET (128) before starting LinuxCNC and before Power ON, then no error on drive.
thank you Rod
thank you Rod
- pheanoukma
18 Apr 2024 05:36 #298531
by pheanoukma
Replied by pheanoukma on topic Chinese servo drive SG-AS problem with EtherCAT version startup
Hi man, I have the same error as yours, can u tell me on how u fix ur sg as drives from showing up the error 40 communication lost error and THESE abort msg
Time to create page: 0.205 seconds
