Limits override on start up.
05 Oct 2020 15:31 #184978 by Clive S
Hi guys, thank you all indeed! :)
[AXIS_X]
MAX_VELOCITY = 15.0
MAX_ACCELERATION = 30.0
MIN_LIMIT = 0
MAX_LIMIT = 200.0
[JOINT_0]
TYPE = LINEAR
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 15.0
MIN_LIMIT = 0
MAX_LIMIT = 200.0
HOME_IGNORE_LIMITS = NO
HOME_USE_INDEX = NO
HOME_OFFSET = -1.0
HOME = 3.0
HOME_SEARCH_VEL = 30.0
HOME_LATCH_VEL = -10.0
HOME_SEQUENCE = 0
I don't know what to ask. Sorry.
Thank you all!!! :)
HOME_IGNORE_LIMITS = NO (Try setting this to Yes)
HOME_USE_INDEX = NO
HOME_OFFSET = -1.0 Set this to 0 to start with
HOME = 3.0
HOME_LATCH_VEL = -10.0 Are you aware that the sign changes the direction of travel
HOME_SEQUENCE = 0
05 Oct 2020 15:54 #184979 by ajsinfotech
Hi Aciera,
Thanks for your replay.
do you mean you try to home the axis in gmoccapy?
Yes, I mean home my x axis in gmoccapy
File Name: gmoccapy-test02.hal
File Size:14 KB
File Name: gmoccapy-test02.ini
File Size:6 KB
05 Oct 2020 16:00 - 05 Oct 2020 16:04 #184981 by ajsinfotech
Hi Clive S
Thanks for reply.
Yes, I tried all of this in several combinations. Maybe not the right one I guess. :unsure:
Last edit: 05 Oct 2020 16:04 by ajsinfotech.
05 Oct 2020 16:42 - 05 Oct 2020 16:48 #184984 by Aciera
Replied by Aciera on topic Limits override on start up.
Do I understand you correctly that the machine does not move when you try to home the axis but instead comes up with the error that the home switch is already activated?
[edit]
Ok, one thing you need to fix is that you called the limit-switch signals of all three axis the same "all-limit-home".
Those need to be separate like "all-limit-home-x", "all-limit-home-y", "all-limit-home-z".
Last edit: 05 Oct 2020 16:48 by Aciera.
05 Oct 2020 21:52 #185011 by ajsinfotech
Thanks Clive, it seems you point me in the right direction :)
Trying to demux the signal into 3 new ones resulted to be a bit tricky:
- First get errors like signal was already asigned... etc
- Then, the signal does not exist... etc
Anyway I can figure out how to demux the signal all-limits-home into limit-home-x, limit-home-y and limit-home-z and started to run inconsistently.
Now I get:
- Home switch inactive before start of latch move j=0 (when I hit the switch)
or
- Hit limit in home state 14 (when I hold the switch pressed)
:sick:
06 Oct 2020 05:22 #185035 by newbynobi
Do you home using linuxcnc, or just pressing the switches?
The latch error is caused due to inconsistency Motor Mobe and your finger
Please make a short video, press home_x button in gmoccapy and post exact error output from terminal
Please start LinuxCNC from console to see all errors
Norbert
06 Oct 2020 12:54 - 06 Oct 2020 13:00 #185059 by ajsinfotech
Many thanks newbynobi! :)
I really really don't like this kind of erratic behaviors. And from the beginning is what I get. It is so diverse, you never know what comes next.
I think it is time to research a little more over another interface, I mean gscreen or another one. Does anyone have any suggestion?
Maybe doing a fresh start could solve all this problems.
Sorry but, I don't like to bother all of you with things when I am absolutely lost.
I will start from ground zero and track step by step. I don't like chasing phantoms.:woohoo:
Many thanks to all of you!!! :)
Last edit: 06 Oct 2020 13:00 by ajsinfotech.
06 Oct 2020 13:24 #185066 by Aciera
I'm sorry but you're all over the place.
We try to help. But you need to provide clear information.
If your setup in the hal and ini is incorrect you will not get the machine to behave the way you want, no matter which user interface you try.
The procedure to get efficient help includes answering the questions, reposting your ini and hal files after you made changes and describing the behavior you get when using linuxcnc with these ini and hal files.
If you can't post a video you need to make it clear which button you press where and how the machine moves.
06 Oct 2020 14:35 #185076 by ajsinfotech
Maybe you are right, but there is no clear information on how to setup the whole thing in a general and easy way. I think this is truly possible.
At the same time I've been doing a lot of customization (Spindle PID, RPi3, Mesa 7c81, etc) all of this with not clear or direct info. It is overwhelming.
I prefer to do a deepest analysis of the process background and setting up from ground zero in a manual way step by step. Setting up a CNC this way does not give me any confidence. Sorry.
I'll be in touch :)
Many thanks!
07 Oct 2020 10:55 #185231 by Mike_Eitel
So if you decide to proceed logical. That is good.
1. Are your switches independend or dasy chained?
2. Can you confirm that each switch shows his value reliable in hal?
3. Do all of them react the same way, means signal gets f.x. true when triggered?
4. Is your hal written to accept the signals non inverted.?
5. Are your switches ate the end of your movement, or can your machine be outside?
Only then:
Have you read and looked and understood the drawings of
linuxcnc.org/docs/2.8/html/config/ini-homing.html
Mike
Moderators: newbynobiHansU
Time to create page: 0.351 seconds
