Limits override on start up.
- Thank you received: 7481
Yes.Does the limit-switches work in gmoccapy the same way as in axis?
By adding them in hal and ini files.How do I instruct gmoccapy to see the limit-switches?
From limit switches to parallel port or Mesa card, then in hal file and uses the values set in the ini file.Where is the limit switch signal come from?
linuxcnc.org/docs/2.8/html/config/ini-homing.html
- ajsinfotech
Yes I finally figure that. Besides, I check the limits switches and work ok.
The problem is the "auto-home" mode. I don't know how to do it automatically in gmoccapy (maybe I can do some macro).
I really like the way axis handle that. Its auto-home mode fetching all the limit switches and setting up all the zeroes is simple and "visually" confident. You have a really feedback on how the machine is homing up.
Is there a way to do the same in gmoccapy? I mean, finding the limit switches and zeroing, not only nice simulations in the gremlin box.
- Mike_Eitel
- Thank you received: 183
linuxcnc.org/docs/2.8/html/gui/gmoccapy.html
And watched the proposed youtubes?
For homing you have a buttons menue (lower menues bar) and there another for setting values.
Mike
- ajsinfotech
Several times, forward and backward
Anyway gmoccapy does not behave like axis no matter how you set up your limit switches (at least my tests). I mean, finding the probe is ok going back and forth like the docs. But homing it's not the same like axis.
I insist with gmoccapy because of tool measurement.
It drives me nuts... maybe I have to leave it for a while...
Tool measurement can be done in any of the modern LinuxCNC GUI's, Axis included.I insist with gmoccapy because of tool measurement.
- phillc54
- Thank you received: 2100
- newbynobi
- Thank you received: 394
Can you make a short video of what axis is doing different?
I am not able to see your problem:( But I would like to help.
Norbert
- ajsinfotech
Sorry but, why a simple limit switch setting is so complicated? It is a simple switch you know?
I read this link lots of times:
linuxcnc.org/docs/devel/html/config/ini-homing.html
The drawings seem to be pretty clear but to my understanding, what says in point 4. Shared Limit/Home Switch Example Layout does not fit what says in point 5. Homing Sequence. Not even fit the numerical examples (I mean magnitude signs).
What I want: To home my machine using shared home/limit switches to automatically find my hardware limits.
But whatever configuration I tried I always get these 2 messages when I attempt to set the x axis limit:
- joint 2 on limit switch error
- joint 1 on limit switch error
It seems when the limit switch trips it drives the machine to a full stop (send the above messages) and not further actions can be done beyond this. What explains in point 5. Homing Sequence never ever happens.
I am not sure how gmoccapy works. Can I find my hardware limits automatically with my shared home/limit switches? I think this kind of limit switch homing can't be done with gmoccapy.
I remember long time ago I tested this with axis and it works fine. Now I am using gmoccapy with a RPi3 and a Mesa 7c81 so migrate to axis just to test this is a lot of work and I think I will mess all this up.
I show you one of my testings (just what I think is the important thing). I tested any kind of sign combinations, distances and speeds:
[AXIS_X]
MAX_VELOCITY = 15.0
MAX_ACCELERATION = 30.0
MIN_LIMIT = 0
MAX_LIMIT = 200.0
[JOINT_0]
TYPE = LINEAR
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 15.0
MIN_LIMIT = 0
MAX_LIMIT = 200.0
HOME_IGNORE_LIMITS = NO
HOME_USE_INDEX = NO
HOME_OFFSET = -1.0
HOME = 3.0
HOME_SEARCH_VEL = 30.0
HOME_LATCH_VEL = -10.0
HOME_SEQUENCE = 0I don't know what to ask. Sorry.
Thank you all!!!
- ajsinfotech
- Thank you received: 2176
do you mean you try to home the axis in gmoccapy?when I attempt to set the x axis limit:
Can you attach your INI and HAL?
