Limits override on start up.
- ajsinfotech
Daisy chained. Limit/home shared.1. Are your switches independend or dasy chained?
I can confirm the switch is working ok in halshow.2. Can you confirm that each switch shows his value reliable in hal?
I have just one switch connected to test right now. I have 3 axis (x-y-z) and I will use just 3 limit/home shared switchs daisy chained (series connection).3. Do all of them react the same way, means signal gets f.x. true when triggered?
When limit switch trips, led halshow lit.
I didn't need to use any inverted signal in the HAL at all. I always try to avoid this kind of inverted signals whenever is possible.4. Is your hal written to accept the signals non inverted.?
I am testing the whole electronic box separately. It is not installed in the machine yet. I simply press the limit switch by hand to test.5. Are your switches ate the end of your movement, or can your machine be outside?
linuxcnc.org/docs/2.8/html/config/ini-homing.html
I am using scheme 4. Shared Limit/Home Switch Example Layout
I try to discriminate the all-limit-home signals by axis as Aciera recommends:
Those need to be separate like "all-limit-home-x", "all-limit-home-y", "all-limit-home-z".
In my last try I even discriminate just home signals this way:
# Digital IO's
# IO Pin 003 (P1-04): IOPort
net all-limit-home <= hm2_7c81.0.gpio.003.in
# Setup home/limit switch signals
net all-limit-home => and2.0.in0
net homing0-x1 => and2.0.in1 <= joint.0.homing
net limit-home-x <= and2.0.out
net limit-home-x => joint.0.home-sw-in
net limit-home-x => joint.0.pos-lim-sw-inAnd it works as I expected (tested in halshow), but I don't know if it is the way the linuxcnc expect.
My tests:
Test 1:
- Limit switch not pressed.
- Click home-x button
- Axis x starts to run from left to right (to the center of the machine, not to the origin).
- When I press the limit switch the tool comes back to the origin and sits about 10mm right from zero and I get: Home switch inactive before start of latch move j=0.
Test 2:
- Limit switch pressed before I click home-x button.
- The axis does not move at all.
- When I hit the switch I get: Hit limit in home state 5
Test 3:
- I did the same as Test 1 but changing speed signs in HOME_SEARCH_VEL and HOME_LATCH_VEL parameters:
#HOME_IGNORE_LIMITS = NO
#HOME_USE_INDEX = NO
#HOME_OFFSET = -1.0
#HOME = 3.0
#HOME_SEARCH_VEL = 30.0
#HOME_LATCH_VEL = -10.0
#HOME_SEQUENCE = 0
HOME_USE_INDEX = NO
HOME_OFFSET = -1.0
HOME = 3.0
HOME_SEARCH_VEL = -30.0
HOME_LATCH_VEL = 10.0
HOME_SEQUENCE = 0- Same behavior and error like Test 1, just opposite direction movement.
I tried to post some photos/video but I have some technical issues.
If you need any other test just tell me.
- Thank you received: 2164
I did not realize you had your home/limit switches daisy chained, I am sorry.I try to discriminate the all-limit-home signals by axis as Aciera recommends:
I don't have much time right now but here is an old thread about homing with shared homing/limit switches:
forum.linuxcnc.org/38-general-linuxcnc-q...it-switches?start=20
- ajsinfotech
I also comment this line and test it as case Test 1:
#net limit-home-x => joint.0.pos-lim-sw-inExactly same behavior like Test 1.
- Mike_Eitel
- Thank you received: 183
I would use very low speeds as you are slower than a machine driven switch
If your construction foresees the switch go true when reached: You must invert home_search_vel direction by changing sign. When you ask for homing, an axis must move towards switch.Test 1 shows your error, test 2 is the proof.
When you jog the axis, does it move correct direction. Means when commanding positive x it is usual that x axis table moves to the left. I'm old fashioned and personaly run in positive scale values as i dislike double - thinking. If it runs wrong i change two wires of the motor, or if that is not so easy i invert the dir signal of the driver.
So adapt and redo with test 1. If it moves right, d3cide wisched behavior according figure 3
- newbynobi
- Thank you received: 394
Try following:
PRESS HOME X
While the motor is moving, press the limit switch,
As soon as the motor change direction leave the limit switch free, so stop pressing it.
Is the axis now homed?
Norbert
- ajsinfotech
Sorry I'm late but I was doing my last mechanical tunes.
Aciera
Yes, maybe the tricky part are all the signals that motion module handle and sample at the same time.See my edit above. Also be aware that trying to simulate the home/limit button by hand my be tricky handle
Mike_Eitel
It is to discriminate limit/home switches just to home when homing.I do not understand your and2 constrution
Yes, you are right. But in this case does not matter. To test is the same.If your construction foresees the switch go true when reached: You must invert home_search_vel direction by changing sign.
newbynobi
Well... IMHO it is not a "race condition" I think. But one can easily get confused with that.As I mentioned in a previous post, pressing the button by hand may result in race conditions between machine and human reactions.
The tricky part is that motion module appears to be sampling/driving signals at the same time (probably multi-threading). And the problem is when motion detects the home switch tripped, at the same time is checking the limit switches (and it is still pressed, no matter if you do it by hand or not). Remember I am sharing all the limits/homes. That's why I was trying to use the and2 construction, just to discriminate the home event from the limit switch event.
Another thing that can add lots of confusion is a slower CPU. Events get delayed are almost impossible to follow.
I was a bit wandering around but finally I made it
Now my script:
net logic-out <= logic.0.or => not.0.in
net no-homing <= not.0.out
net homing-0 => and2.0.in1 <= joint.0.homing
net home-x <= and2.0.out
net home-x => joint.0.home-sw-in
net homing-0 => logic.0.in-00
net all-limit-home => and2.3.in0
net no-homing => and2.3.in1
net limit-x <= and2.3.out
net limit-x => joint.0.pos-lim-sw-in
net all-limit-home => and2.1.in0
net homing-1 => and2.1.in1 <= joint.1.homing
net home-y <= and2.1.out
net home-y => joint.1.home-sw-in
net homing-1 => logic.0.in-01
net all-limit-home => and2.4.in0
net no-homing => and2.4.in1
net limit-y <= and2.4.out
net limit-y => joint.1.pos-lim-sw-in
net all-limit-home => and2.2.in0
net homing-2 => and2.2.in1 <= joint.2.homing
net home-z <= and2.2.out
net home-z => joint.2.home-sw-in
net homing-2 => logic.0.in-02
net all-limit-home => and2.5.in0
net no-homing => and2.5.in1
net limit-z <= and2.5.out
net limit-z => joint.2.pos-lim-sw-in
And it perfectly works for me
Thanks to all of you for your support and patience!!!
- ajsinfotech
It's me, again...
I was doing some housekeeping trying to get a clean environment but unfortunately I break something.
Everything works fine but when gmoccapy starts gave me this 2 annoying messages at startup:
- can't open None
- Unable to open file <None>
Here is my log:
**** arrange JOG button
less than 6 axis
/home/pi/linuxcnc/bin/gmoccapy:325: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
emc/task/emctask.cc 395: interp_error: Unable to open file <None>
can't open None
**** GMOCCAPY INFO ****
**** Invalid embedded tab configuration ****
**** No tabs will be added! ****
**** no audio available! ****
**** PYGST libray not installed? ****
**** is python-gstX.XX installed? ****
- newbynobi
Norbert
- ajsinfotech
I always set this option to None. I set it with a new file and then set it to None again to force a recycle but no luck.
I create a brand new gmoccapy configuration and then apply my scripts over it and runs like a charm!
Maybe I missed something while I had been doing the housekeeping, I don't know, but it is great you could do a fresh start, then copy the new files and the app starts ok.
Thanks Norbert
