Back or front tool
02 Oct 2021 09:34 #222001
by john11668
Replied by john11668 on topic Back or front tool
Machine sets itself up in back tool mode as that is called up in ini file .
For RH thread I could use threading tool reversed in back tool and reverse the spindle but it is then prone to saddle lift,
Hence this question. Will maybe get a chance to try G10 and R180 over the weekend . Sounds like we are in for grotty weather.
02 Oct 2021 17:11 #222034
by john11668
Right so called up G10 L2 P06 R180 and it tells me " invalid parameters in linear command"
And "linear move on line 13 would exceed Y's positive limit " And I dont have a Y axis ???????
Line 13 calls up G0 X10 Z10 both within limits.
Help please ??
Help please ??
05 Oct 2021 05:22 #222247
by newbynobi
Replied by newbynobi on topic Back or front tool
just a curious question.
Did you try to enter a negative pitch while in back tool lathe mode?
By the way, this is not a gmoccapy behavior, it seems to be a trajectory planer issue.
Norbert
Norbert
The following user(s) said Thank You: anfänger
07 Oct 2021 10:08 #222438
by john11668
Hi Norbert
I did not try a negative pitch .
I thought that would just alter the z motion and I can do that by specifying a negative start and and cutting toward z positive ..
Will give it a try though and report back.
Will also try setting a negative thread depth and if that does not work maybe a negative regression. Must look at the code for internal threads canned cycle to see if any clues there.
07 Oct 2021 15:09 #222462
Replied by Aciera on topic Back or front tool
As a last resort you could also setup two switchable kinematics.
07 Oct 2021 20:54 #222487
Replied by andypugh on topic Back or front tool
Diameter stuff shouldn't care, as smaller-X = smaller-dia regardless of front or back tool.Will also try setting a negative thread depth and if that does not work maybe a negative regression. Must look at the code for internal threads canned cycle to see if any clues there.
10 Oct 2021 17:28 #222776
by john11668
There is a difference though
To reduce diameter with back tool x minus requires the saddle to move downwards where as this has to be reversed for front tool.
12 Oct 2021 22:32 #222980
That's a config thing if there is only one toolpost. If there are both front and back toolposts, then, yes, it's complicated.There is a difference though
12 Oct 2021 23:14 #222986
by john11668
Compicated ? or impossible ?
If complicated then a few pointers might be nice
14 Oct 2021 00:03 #223053
Do you actually have both front and back toolposts?
One workaround is to program one toolpost in negative X. it's a bit of a kludge.
Time to create page: 0.198 seconds
