resizing virtual keyboard
23 May 2023 18:32 #272043
by pistrix
Replied by pistrix on topic resizing virtual keyboard
Wonderful. Thank you very much for your kindness and help.
23 May 2023 18:38 #272044
by HansU
Replied by HansU on topic resizing virtual keyboard
The following user(s) said Thank You: pistrix
26 Nov 2023 18:23 #286564
by pistrix
I have just updated to LinuxCNC 2.91 and Gmoccapy 3.4.6. and the keyboard is again full width. I guess I cannot use the glade file you wrote for me but I need a new one compatible with Gmoccapy 3.4.6.
Could you please make a new glade for me with the keyboard width of 870 pixels?
12 Dec 2023 21:49 #287980
by HansU
Maybe I'll add a setting to set the width of the keyboard...
30 Dec 2023 14:07 #289380
by HansU
I implemented the Setting for LinuxCNC 2.9.2, see here: github.com/LinuxCNC/linuxcnc/pull/2813
It will be available soon in the 2.9 branch, but you can also copy the two modified files.
31 Dec 2023 05:59 #289413
Replied by rodw on topic resizing virtual keyboard
2.9.2 has been released (se the downloads page) so I think you may have missed the boat.
31 Dec 2023 10:03 #289423
by HansU
Maybe my post was a bit misleading. I wanted to say that I added it on top of the current version (2.9.2), so it is not included in the 2.9.2 release.
31 Dec 2023 10:57 #289424
I'm not sure what the answer is.
This is where the lack of integration between the buildbot and linuxcnc.org/dists is an issue. There is no easy way to swap between the 2.9.2 release and the buildbot versions. The user will need to overwrite files in /etc/apt/sources.list.dMaybe my post was a bit misleading. I wanted to say that I added it on top of the current version (2.9.2), so it is not included in the 2.9.2 release.
31 Dec 2023 11:49 #289426
by HansU
The user could download the .deb manually and install it.
The following user(s) said Thank You: tommylight, zz912
