Some tips for better gmoccapy
13 Aug 2023 18:27 #277853
by MichalHK
Some tips for better gmoccapy was created by MichalHK
Hello,
at last two years Im installing gmoccapy at about 3 machines and every time I must doing same "upgrade/changes".
1) F4 shortcut for AUTO mode.
Default gmoccapy for switching mode is F3 = rapid F5 = MDI
Please add F4 for AUTO mode. Its logical. Im doing this at every machine they Im installing.
Its few simple rows of code.
2) Cyclus timer - every industrial cnc machine controller like Fanuc, Seimens, Heidenhain atc.... have cyclus timer.
If I first run gmoccapy I cant believe that timer missing. Solution is here forum.linuxcnc.org/gmoccapy/40709-gmocappy-clock
So why its not included in 2.9.0PRE for example?
3)Spindle load - same as point 2. Nice spindle load bar exists there forum.linuxcnc.org/gmoccapy/45856-spindl...-in-gmoccapy?start=0 So why is not defaultly installed?
I can help, no problem, I can push configurations into github.
Thanks MichalHK
Thanks MichalHK
The following user(s) said Thank You: zz912
- Thank you received: 5948
13 Aug 2023 19:00 #277857
Replied by tommylight on topic Some tips for better gmoccapy
1. I have no idea, i use Axis mostly.
2. It is nice to have.
3. Most do not have any feedback for load to show there, so having a bar that does nothing is just clutter.
But it would be nice to be able to configure in Settings, whoever needs it would enable it.
14 Aug 2023 04:59 - 14 Aug 2023 07:38 #277910
by zz912
Replied by zz912 on topic Some tips for better gmoccapy
3. I use it. A lot of drivers (Spindle + axis) have Modbus RS485. I would like to have "load feedback" for axis as well.
4. I think it would help a lot if at least the manual mentioned how to add "Load feedback" and "Cyclus timer" to Gmoccapy, so that everyone doesn't have to develop it from scratch.
Last edit: 14 Aug 2023 07:38 by zz912.
Time to create page: 0.319 seconds
