NativeCAM is Features renamed
22 Nov 2016 22:25 - 22 Nov 2016 23:07 #83147
by gmouer
Replied by gmouer on topic NativeCAM is Features renamed
Hi Fern,
I am having some problems getting NativeCAM embedded. I was successful cloning it and getting it to run standalone from the command line. I then ran sudo python setup.py per the instructions and copy/pasted the command line for mill.ini. I get a error, terminal screen info is as follows:
bridgeport@Bridgeport:~$ ls
catalogs Downloads linuxcnc_print.txt Pictures Templates
Desktop linuxcnc Music Public Videos
Documents linuxcnc_debug.txt NativeCAM support
bridgeport@Bridgeport:~$ cd NativeCAM
bridgeport@Bridgeport:~/NativeCAM$ linuxcnc configs/sim/axis/ncam_demo/mill.iniLINUXCNC - 2.8.0-pre1-2761-g2b678aa
Machine configuration directory is '/home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo'
Machine configuration file is 'mill.ini'
Starting LinuxCNC...
Found file(REL): ./core_sim.hal
./core_sim.hal:28: Pin 'axis.0.motor-pos-cmd' does not exist
LinuxCNC terminated with an error. You can find more information in the log:
/home/bridgeport/linuxcnc_debug.txt
and
/home/bridgeport/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Any suggestions on where I am going wrong? (I am running master under Debian Wheezy) I have seen others with a axis.0.motor-pos-cmd error like this.
and
Last edit: 22 Nov 2016 23:07 by gmouer.
23 Nov 2016 00:01 #83150
by FernV
Replied by FernV on topic NativeCAM is Features renamed
This line tells you that in the file 'core_sim.hal' (this is a config file for lcnc) it is looking for a pin 'axis.0.motor-pos-cmd'
that does not exists.
Just comment the line with a '#' and any other lines that may tell you this kind of message.
After all you are learning with the simulator, isn't it ?
Regards
Fern
Regards
Fern
23 Nov 2016 00:09 - 23 Nov 2016 00:16 #83151
by gmouer
I am confused why I am getting that when so many others are running the same sim file you provide and apparently not getting that error. In the file, the comments say it loops the motor command back to the motion module for simulation purposes. I would suspect the simulator would not function without it.
I fully plan on implementing it on the Bridgeport mill configs next anyways. I am very excited about using Ncam on a very regular basis on that machine. (just finished the retrofit today)
One other question: I plan on using a Pyvcp side panel with axis with some checkboxes and led's for such things as selecting hi and low range in the hal files config. Many use Pyvcp side panels for such purposes. How will that work with NativeCam implemented? Will the Pyvcp panel be adjacent to the axis/NativeCam window? I am a bit worried about how this will work out.
Last edit: 23 Nov 2016 00:16 by gmouer.
23 Nov 2016 00:45 #83152
Replied by PCW on topic NativeCAM is Features renamed
I really know nothing about this but is that just a symptom of running NativeCAM on master
(which is JA-XX based so doesn't have axis.0.motor-pos-cmd anymore but just the joint
equivalent)
equivalent)
23 Nov 2016 00:46 #83153
by gmouer
Playing further I may see part of the problem. I cloned the repo into my linuxcnc directory, it created a folder in the linuxcnc folder named NativeCAM. When launching either the embedded sim or my own machine config I get errors referencing files that are not found, always referenced in a folder "ncam", there is no such folder.
Looking over the sim mill ini file, it also references a ncam directory, which does not exist.
Apparently the directory names and locations are not matching up.
Did the software change perhaps and this was not updated?
23 Nov 2016 00:48 #83154
by gmouer
Makes perfect sense. I am surprised however, Fern is using Master I believe, I wonder why he does not have this issue?
Apparently the sim file is not compatible with the latest releases of master.
equivalent)
23 Nov 2016 17:24 #83183
by FernV
I do not know if you cloned after your previous post but here is what I see in it :
For your info, other users had that problem before
forum.linuxcnc.org/40-subroutines-and-ng...named?start=20#81411
Including the printed message will help me pointing the problem and the solution
Regards
Fern
- You seem to be running 'LINUXCNC - 2.8.0-pre1-2761-g2b678aa' which may be part of the problem
- Machine configuration directory is '/home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo' not under linuxcnc directory as you state
Regards
Fern
23 Nov 2016 17:56 - 23 Nov 2016 17:56 #83184
by gmouer
I just checked your files directly on the github, core_sim.hal is included in your files.
I found this info on joints/axes and the changes in Master related to it.
linuxcnc.org/2016/06/27/Joints-Axes-merged/
The core_sim hal file in github for Nativecam has references to axis.0. Core_sim.hal in the sims that come with master refer to joint 1 per the new standard. What is interesting is that according to the doc I linked to, Master should automatically update the hal file to the new standard using joints, apparently that does not happen for some reason and the error message results. I had a near identical error in the homing hal file for similar reasons.
The other errors, referring to a "ncam" directory are still a mystery. There is no ncam directory doing a standard setup.
Hope this helps a bit.
Last edit: 23 Nov 2016 17:56 by gmouer.
23 Nov 2016 18:37 - 23 Nov 2016 18:43 #83185
by FernV
I want you to do this :
fernand@debian:~/NativeCAM$ ./ncam.py
NativeCAM info:
inifile = NA
SYS_DIR = /home/fernand/NativeCAM
NCAM_DIR = /home/fernand/NativeCAM
program = ./ncam.py
real path = /home/fernand/NativeCAM/ncam.py
Using standard menu.xml, no menu-custom.xml found
Can not find file quick_access.lst
Previous work not saved as current work
No default template saved
Now type or copy : ./ncam.py -iconfigs/sim/axis/ncam_demo/mill.ini
You should have a result similar to this :
fernand@debian:~/NativeCAM$ ./ncam.py -iconfigs/sim/axis/ncam_demo/mill.ini
NativeCAM info:
inifile = /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/mill.ini
NCAM_DIR = /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam
program = ./ncam.py
Created 3 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/catalogs
Created 69 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/cfg
Created 69 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib
Created 151 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/graphics
Created 5 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/xml
[RS274NGC]SUBROUTINE_PATH = ncam/lib/mill:ncam/lib/utilities
SUBROUTINE_PATH[0] (realpath) = /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib/mill
SUBROUTINE_PATH[1] (realpath) = /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib/utilities
Now type or copy : sudo python setup.py c
Add a c (clear) at the end
You should have a result similar to this if you already executed it :
fernand@debian:~/NativeCAM$ sudo python setup.py c
[sudo] password for fernand:
wait, processing...
removed link to ncam.py from /usr/lib/pymodules/python2.7/gladevcp
"from ncam import NCam" removed from /usr/share/pyshared/gladevcp/hal_pythonplugin.py
removed link to ncam.py from /usr/share/pyshared/gladevcp
glade-widget-class named NCam removed from /usr/share/glade3/catalogs/hal_python.xml
glade-widget-class-ref name NCam removed from /usr/share/glade3/catalogs/hal_python.xml
/usr/share/glade3/catalogs/hal_python.xml saved
WITHOUT a c at the end
wait, processing...
created link to ncam.py in /usr/lib/pymodules/python2.7/gladevcp
"from ncam import NCam" added to /usr/share/pyshared/gladevcp/hal_pythonplugin.py
created link to ncam.py in /usr/share/pyshared/gladevcp
glade-widget-class named NCam added to /usr/share/glade3/catalogs/hal_python.xml
glade-widget-class-ref named NCam added to /usr/share/glade3/catalogs/hal_python.xml
Now type or copy : linuxcnc configs/sim/axis/ncam_demo/mill.ini
fernand@debian:~/NativeCAM$ linuxcnc configs/sim/axis/ncam_demo/mill.ini
LINUXCNC - 2.7.8
Machine configuration directory is '/home/fernand/NativeCAM/configs/sim/axis/ncam_demo'
Found file(REL): ./sim_spindle_encoder.hal
Found file(REL): ./axis_manualtoolchange.hal
Found file(REL): ./simulated_home.hal
task: main loop took 0.014381 seconds
task: main loop took 0.014113 seconds
NativeCAM info:
program = /usr/lib/pymodules/python2.7/gladevcp/ncam.py
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/catalogs
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/cfg
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/graphics
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/xml
task: main loop took 0.016372 seconds
task: main loop took 0.013368 seconds
Xlib.protocol.request.QueryExtension
task: main loop took 0.013335 seconds
All this has been done on Debian Wheezy with a fresh cloning of NativeCAM
Replace all *.hal files with the one from your working config directory
If you do not have this kind of result, show me the result you have. I can NOT help you without it
Regards
Fern
- Open a terminal in NativeCAM directory
- type : ./ncam.py
NativeCAM info:
inifile = NA
program = ./ncam.py
NativeCAM info:
program = ./ncam.py
wait, processing...
wait, processing...
LINUXCNC - 2.7.8
NativeCAM info:
Regards
Fern
Last edit: 23 Nov 2016 18:43 by FernV.
24 Nov 2016 01:22 #83205
by gmouer
Hi Fern,
I will do a individual post for each section of your instructions along with my results to avoid confusion. I started by clearing out my old NativeCAM install and starting with a fresh clone from github.
Results of first instruction:
bridgeport@Bridgeport:~/NativeCAM$ ./ncam.py
NativeCAM info:
inifile = NA
SYS_DIR = /home/bridgeport/NativeCAM
NCAM_DIR = /home/bridgeport/NativeCAM
program = ./ncam.py
real path = /home/bridgeport/NativeCAM/ncam.py
This appears to be the same as what you posted. I should also note that the NativeCAM standalone program launched and came up in a window.
Next instruction/results to follow.
George
- type : ./ncam.py
NativeCAM info:
inifile = NA
program = ./ncam.py
Regards
Fern
Hi Fern,
NativeCAM info:
inifile = NA
program = ./ncam.py
George
Time to create page: 0.271 seconds
