NativeCAM is Features renamed
06 Nov 2016 22:31 #82522
by grijalvap
Replied by grijalvap on topic NativeCAM is Features renamed
Hi
I have installed and tested the plasma version of nCAM, it looks good.
I have a Comment.
The torch should start outside of the cutting path, in the scrap piece, this is named "Lead In",
thanks for the great work.
I have a Comment.
07 Nov 2016 20:55 #82567
by FernV
Replied by FernV on topic NativeCAM is Features renamed
Hi Floris,
Have you tried with the latest version on github ? If it does not work, I have another solution to try
Fern
Fern
07 Nov 2016 21:04 #82568
by FernV
Very interesting, I will have another look at it. Have you tried the options in the shape you want : Cut inside or outside ? But as I see in the drawing this is not what you are talking about.
I have heard of "Lead in" and "Lead out" but was not aware of the meaning
Regards
Fern
Regards
Fern
- eFalegname
- Thank you received: 30
07 Nov 2016 23:06 - 07 Nov 2016 23:08 #82573
by eFalegname
Replied by eFalegname on topic NativeCAM is Features renamed
Hi Fern, yes I tried it unfortunately , this is the latest version...
Last edit: 07 Nov 2016 23:08 by eFalegname.
07 Nov 2016 23:24 #82574
For what its worth, if you download the demo version of Sheetcam, and load a DXF file, it will show a couple of different leadin methods, show them on the screen and generate the Gcode. The demo version has a limit to the number of lines of code generated but it will be enough for demonstration purposes. Most leadins I see are an arc rather than a straight line so you don't get problems on the corners.
Replied by rodw on topic NativeCAM is Features renamed
Regards
Fern
07 Nov 2016 23:33 #82575
by gmouer
Replied by gmouer on topic NativeCAM is Features renamed
It might be worth mentioning that lead-in and lead-out is also used for milling, its not just a plasma thing.
11 Nov 2016 22:11 - 11 Nov 2016 22:11 #82708
by FernV
If the latest update does not solve the issue, we will have to hard-code the sub-directories
Run setup first then lcnc with ncam embedded
Regards
Fern
Regards
Fern
Last edit: 11 Nov 2016 22:11 by FernV.
- eFalegname
12 Nov 2016 13:30 - 12 Nov 2016 13:35 #82712
by eFalegname
Hi Fern, I begin to worry, it is not resolved in any way...
Cheers,
Floris
Regards
Fern
Cheers,
Floris
Last edit: 12 Nov 2016 13:35 by eFalegname.
14 Nov 2016 15:17 - 14 Nov 2016 22:50 #82784
by FernV
Hi Floris
I see the problem is not what I expected (I was unable to view your video until this morning)
I also see that even with the previous version it 'works' except it does not refresh automatically. I started to have this problem last week and the message on my pc is :
"target application died or uses a Tk version before 4.0"
I will see what needs to be updated. Your file does not show that message.
However, if you use lcnc menu file->open, you should be able to load you project ngc file
Regards
Fern
PS
I just tried gmoccapy and it works perfectly for me, what about you ? Maybe the issue is with axis-remote.
I also note that you were not able to edit preferences. Retry with the latest ncam version I just pushedand you may notice some preference values not loaded. Don't give up
Regards
Fern
PS
Last edit: 14 Nov 2016 22:50 by FernV. Reason: Added some remarks
15 Nov 2016 00:33 #82818
by FernV
Hi Floris,
I just upgraded to lcnc 2.7.8 and changes are reflected immediately in lcnc simulator, no more "target application died or uses a Tk version before 4.0" message. Really do not know why your's do not work properly
Fern
Fern
Time to create page: 0.181 seconds
