NativeCAM is Features renamed
04 Nov 2017 16:16 #101310 by vmihalca
Hi Fern,
I have managed to display the spindle direction field. Thanks for your help! :)
In the image above, at Tool number, in the picture there is 0 - None. In the dropdown I see also tool 1 and tool 2.
From where does the native cam loads these tools? It doesn't seem to be from the linuxcnc's tool table. There I have three tools, here I can see only two, and the offsets of those tools are ignored.
I'm I missing something?
04 Nov 2017 21:52 #101336 by FernV
Replied by FernV on topic NativeCAM is Features renamed
NativeCAM loads the tool table specified if your ini file i.e : [EMCIO] TOOL_TABLE = *.tbl
Fern
06 Nov 2017 19:32 - 06 Nov 2017 19:34 #101456 by vmihalca
File Name: ncam_2017-11-06-2.ngc
File Size:3 KB
Hi Fern,
I have managed to load the native cam in a tab, now I have more space. Thanks! :)
I have noticed a few issues that you may want to correct.
1. If I make visible the hidden fields as you suggested, they don't remain visible at the next relaunch even if I click "Save values as defaults". Also the values I'm saving are not kept on the next relaunch.
2. Under the tool change tab, I can't change the cut depth, the minimum value it takes is 2.54. If I enter, anything smaller than 2.54 it converts it to 2.54. In my lathe units, 2.54mm its a DOC that cannot be used for most materials.
3. Even if the tool table is set correct and the the tool 1 moves at the correct position if I issue an G0 Z0 X0, when I start the program the tool 30-40mm behind the actual part.
I will post the generated code below for a simple facing operation, perhaps it helps you debugging the cause.
Last edit: 06 Nov 2017 19:34 by vmihalca.
07 Nov 2017 03:59 #101481 by FernV
File Size:3 KB
Hi Fern,
Please be patient
Those problems have been solved with many others...
Fern
13 Nov 2017 15:55 #101729 by vmihalca
Hi Fern,
I saw that you committed some new files in gitgub and there's a 0.1.11 tag.
I have not managed to get to the shop yet..have you published the update so that its avaibalble in Synaptics Package Manager ?
Does this include the fixes to the issues I've mentioned above?
13 Nov 2017 16:25 #101730 by FernV
Unless you want to do translation or add/edit icons, you should not clone or download files from github
...have you published the update so that its avaibalble in Synaptics Package Manager ?
Yes
Lot more
Fern
13 Nov 2017 17:43 - 13 Nov 2017 18:03 #101733 by vmihalca
Hi Fern,
I've just updated, and although in the about dialog it says 0.1.11, I see the old buttons, where a thread represents each operation.
While I had previous version, I tried to change some routines so that I can fix some bugs, so in the ncam/catalogs/lathe I have created a menu-custom.xml. Right now it seems is taking the values from this one.
Now if I delete that file, it's being recreated with the previous values each time I start linuxcnc.
I've ended up copying the values inside menu.xml into custom-menu.xml and now I can see your updates in the UI.
Any idea how can I get rid of that custom-menu.xml? :)
Last edit: 13 Nov 2017 18:03 by vmihalca.
13 Nov 2017 18:07 #101734 by FernV
... although in the about dialog it says 0.1.11, I see the old buttons, where a thread represents each operation. Do I have to uninstall/cleanup something?
Are you using a menu-custom.xml ? If so delete it to use the standard menu.
For testing, I recommend you use the lcnc wizard and make a new copy of the files like 2.7.axis-1
This way you will be able to use the new default_template and the new tool table. Loading lcnc with the wizard and axis had some issues on my pc, I recommend you load in a terminal like $ linuxcnc lathe-mm.ini
gmoccapy did not have this problem nor gscreen
Fern
13 Nov 2017 18:11 #101735 by FernV
...Any idea how can I get rid of that custom-menu.xml?
Is your my-stuff sub-directory empty ?
Fern
13 Nov 2017 18:39 #101736 by vmihalca
I have only a readme file
Time to create page: 0.146 seconds
