NativeCam raspberry Pi 4
12 Jan 2018 16:16 #104339
by FernV
Hi Daniel
Those subroutines have not been updated for a long time and are not compatible with current ones. They will be in a next release
Regards
Fern
Replied by FernV on topic Use NativeCAM as a deb package now
... i see in some videos a tool probing routine like tool diameter probing. How can i activate this functions
Hi Daniel
Regards
Fern
20 Jan 2018 16:43 #104746
by Vig
Replied by Vig on topic Use NativeCAM as a deb package now
Hi Fern !
Sorry, I do not know English
/etc/apt/sources.list.d :
deb packagecloud.io/FernV/NativeCAM/linuxmint/ sylvia main
deb-src packagecloud.io/FernV/NativeCAM/linuxmint/ sylvia main
Synaptic :
«packagecloud.io/FernV/NativeCAM/linuxmint sylvia Release» not file Release.
Synaptic :
22 Jan 2018 13:28 #104840
by FernV
Retry now
Fern
Fern
22 Jan 2018 18:45 #104860
by Vig
Hi
Fern !
OK !!!!
Fern !
OK !!!!
05 Feb 2018 12:55 #105434
by BigDo
Replied by BigDo on topic Use NativeCAM as a deb package now
Hi Fern,
today i tried to perform an update and get a message: Failed to pick up from packagecloud.io/FernV/NativeCAM/ubuntu/d.../main/source/Sources
and if i try to open
in a browser i get the message
'Bandwidth or Storage Limit Exceeded'
Regards
Niko
Regards
Niko
- eFalegname
- Thank you received: 30
05 Feb 2018 13:31 #105435
by eFalegname
Replied by eFalegname on topic Use NativeCAM as a deb package now
I got the same error as you. The packages are available here: packagecloud.io/FernV/NativeCAM
Floris
Floris
05 Feb 2018 15:25 #105439
by Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <geneslinuxbox.net:6309/gene>
Replied by Gene1934 on topic Use NativeCAM as a deb package now
i noticed my apt/sources..list.d/NativeCam
deb line in a jessie install fails too, is this change of address permanent?
05 Feb 2018 15:33 - 05 Feb 2018 15:37 #105441
by FernV
I am trying to setup another server so I do not have to pay from my own pocket anymore for every install/update you do.
Expect an answer this week.
Fern
P.S. Like any deb packages, update should be automatic when I upload a new version. You do not have to do it manually.
Fern
Last edit: 05 Feb 2018 15:37 by FernV.
05 Feb 2018 17:14 #105447
by Gene1934
That's not working, and hasn't for a week or more.
And I wasn't aware you were being charged by the byte, that majorly sucks.
05 Feb 2018 17:27 #105448
by FernV
You should not worry now because a new version is not due for a month or two, maybe more. I am working on major changes making it much simpler to use while adding many options and much improved gcode files. But still much testing and fixing to do.
The situation only affects new install. If you have version 0.1.14b no need to update now.
Regards
Fern
Regards
Fern
The following user(s) said Thank You: tommylight, cncnoob1979
Time to create page: 0.133 seconds
