NativeCam raspberry Pi 4
10 Sep 2019 13:52 #144700
by Dimitrios
Replied by Dimitrios on topic Use NativeCAM as a deb package now
Fern, first of all, many, many thanks for your great effort. Hope not to bother you with noob questions but:
Being fairly ignorant in Linux, for some years i am using LinuxCNC with good results. yesterday I downloaded and installed version 2.7.14, and, for the first time, tried to install NativeCAM, following the procedures on the first page of this thread. all I get is:
'Detected operating system as debian/wheezy.
Checking for curl...
Installing curl...
Reading package lists...
Building dependency tree...
Reading state information...
Package curl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'curl' has no installation candidate
Running apt-get update... done.
Installing debian-archive-keyring which is needed for installing
apt-transport-https on many Debian systems.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...ncam_debsetup.txt: line 115: curl: command not found
Unable to run:
curl packagecloud.io/install/repositories/Fer...wheezy&source=script
Double check your curl installation and try again.
I am lost. Synaptic ignore any reference to curl itself, only shows libcurl. i downloaded the curl package, but can't manage to synaptic use it. What I am missing here?
I really appreciate some guidance.
BR
Dimitrios
Installing curl...
Unable to run:
BR
Dimitrios
10 Sep 2019 17:25 #144720
by Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <geneslinuxbox.net:6309/gene>
Replied by Gene1934 on topic Use NativeCAM as a deb package now
I've had similar. Go ahead and install libcurl, ISTR it works somehow
The following user(s) said Thank You: Dimitrios
10 Sep 2019 17:34 #144721
by Dimitrios
Thanks Gene1934! I'll try it and report back.
Regards,
Dimitrios
Regards,
Dimitrios
10 Sep 2019 17:41 #144722
by Dimitrios
Well, sinaptic informs me that I have libcurl3-gnutls installed, version 7.26.0-1+wheezy25+deb7u1 which is the latest version.
what now? My ignorance in Linux is troubling me. Do I have to somehow force a new install, using apt-get?
You can point me to some docs, do not want to be a lazy guy!
thanks again, and regards.
Dimitrios
Dimitrios
10 Sep 2019 17:58 #144727
by Gene1934
Maybe some else, even Fern can help. wget does essentially the same thing but probably needs different cli options. So the scripts that use curl might be editable to use wget.
I think I read someplace quite a while back that curl was using an out of date security library, Its dirt I haven't kicked around much, and the oldtimers memory fades too fast, it will be 85 years old next month. Sorry I can't be more specific.
Gene1934
Gene1934
10 Sep 2019 18:21 #144728
by Dimitrios
Thank you, Gene!
I am searching around, and, if I find a solution, i will post it here.
My mom is 84, and still work as a translator and consultant for language and literature works. She has a PhD in that area.
You are perfectly fine, believe me. Still go a long stretch!
Best regards
Dimitrios
Best regards
Dimitrios
10 Sep 2019 20:36 #144740
by okiejim
Replied by okiejim on topic Use NativeCAM as a deb package now
That curl error was exactly what was happening to me with unbutu lucid. I finally gave up and got the latest debian 9 live dvd and was able to load up NativeCam. I really love NativeCam and will continue to us it as my new go to for CAM.
10 Sep 2019 21:02 #144743
by BigDo
Replied by BigDo on topic Use NativeCAM as a deb package now
try
sudo apt-get install curl
11 Sep 2019 12:56 #144816
by Dimitrios
okiejim, you installed debian 9 and native cam, but not linux cnc?
BigDo, I tryed apt-get today and go the same. No curl librarie to install.
It is only me, or there are other people with this problem?
I will search more today, but I am lost.
Regards,
Dimitrios
Regards,
Dimitrios
- Project_Hopeless
- Thank you received: 9
12 Apr 2020 17:40 #163795
by Project_Hopeless
Replied by Project_Hopeless on topic Use NativeCAM as a deb package now
I downloaded the Non-Deb, unzip'd and can run directly from the ncam.py file
However If I try to install like so... it says package can't be found. What am i doing wrong?
ant@LinuxPC:~$ curl -s https://packagecloud.io/install/repositories/FernV/NativeCAM/script.deb.sh | sudo bash
[sudo] password for ant:
Detected operating system as LinuxMint/tina.
Detected curl...
Checking for gpg...
Detected gpg...
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...done.
Importing packagecloud gpg key... done.
The repository is setup! You can now install packages.
ant@LinuxPC:~$ sudo apt-get install nativecam
Reading package lists... Done
Reading state information... Done
E: Unable to locate package nativecam
ant@LinuxPC:~$ ^C
ant@LinuxPC:~$ ^C
ant@LinuxPC:~$
Time to create page: 0.168 seconds
