NativeCam raspberry Pi 4
21 Apr 2021 21:49 #206716
by itanc
Replied by itanc on topic Use NativeCAM as a deb package now
Hi Tommy and thanks so much again but...
open synaptics package manager
click settings
click repositories to reveal some tabs but no option for partner repositories.
there is a source code radio button but it is locked and checked
am i looking in the wrong place?
cheers
tanc
click settings
cheers
tanc
- Thank you received: 5959
21 Apr 2021 22:01 #206721
Replied by tommylight on topic Use NativeCAM as a deb package now
Is there something like "unstable packages" ?
Sorry, long time since i used Debian.
21 Apr 2021 22:39 #206727
by itanc
no cant find that either. feeling like a bit of a twerp now
22 Apr 2021 00:12 #206743
by itanc
hi tommy
i have now installed the latest debian i can find (back to buster) and run the deb package and this happens
tanc@debian6:~/Desktop$ sudo bash ncam_debsetup.txt
Detected operating system as debian/buster.
Checking for curl...
Installing curl...
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
libcurl4
The following NEW packages will be installed:
curl libcurl4
0 upgraded, 2 newly installed, 0 to remove and 96 not upgraded.
Need to get 597 kB of archives.
After this operation, 1,125 kB of additional disk space will be used.
Get:1 security.debian.org/debian-security buster/updates/main amd64 libcurl4 amd64 7.64.0-4+deb10u2 [332 kB]
Get:2 security.debian.org/debian-security buster/updates/main amd64 curl amd64 7.64.0-4+deb10u2 [265 kB]
Fetched 597 kB in 0s (4,020 kB/s)
Selecting previously unselected package libcurl4:amd64.
(Reading database ... 85073 files and directories currently installed.)
Preparing to unpack .../libcurl4_7.64.0-4+deb10u2_amd64.deb ...
Unpacking libcurl4:amd64 (7.64.0-4+deb10u2) ...
Selecting previously unselected package curl.
Preparing to unpack .../curl_7.64.0-4+deb10u2_amd64.deb ...
Unpacking curl (7.64.0-4+deb10u2) ...
Setting up libcurl4:amd64 (7.64.0-4+deb10u2) ...
Setting up curl (7.64.0-4+deb10u2) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10) ...
Running apt-get update... done.
Installing debian-archive-keyring which is needed for installing
apt-transport-https on many Debian systems.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...done.
Importing packagecloud gpg key... done.
The repository is setup! Installing NativeCAM... done.
tanc@debian6:~/Desktop$ ncam -h
bash: ncam: command not found
this was where i was a few weeks ago when it seemed so close.
if you can shed any light i would be so very happy to get back to making parts!!
cheers
tanc
Installing curl...
libcurl4
curl libcurl4
cheers
tanc
22 Apr 2021 02:20 #206758
by pdxalz
Replied by pdxalz on topic Use NativeCAM as a deb package now
Take a look at this thread: forum.linuxcnc.org/nativecam/39068-nativ...ge-for-buster-please
The third message from russtuff has a solution that worked for me.
Alan
Alan
24 Apr 2021 18:15 #206962
by itanc
Wow, Thank you for the tip, I had already tried this and failed but in the intervening few weeks i have obviously learned enough about linux that this time it worked! i now have 10 hard drives in the drawer all with blank installs and working Ncam.
thanks do much again, it really make a difference.
cheers
tanc
cheers
tanc
- twoflowers
- User is blocked
- Thank you received: 32
31 May 2021 12:07 #210791
by twoflowers
Replied by twoflowers on topic Use NativeCAM as a deb package now
Does anybody know if there's a way to run nativecam with python3 on debian 11/devuan4?
- Coordinates
12 Dec 2021 15:19 #228929
by Coordinates
Replied by Coordinates on topic Use NativeCAM as a deb package now
when i click on (ncam_debsetup.text)my browser open up window that show me text and not download it
can plz tell how to download it or just copy the all text in notepad and copy it in linuxcnc and then run sudo bash ncam_debsetup.text .
15 Jul 2022 17:08 #247406
by COFHAL
Replied by COFHAL on topic NativeCam raspberry Pi 4
Is it possible to install nativecam on a raspberry PI 4 with raspbian buster?
16 Jul 2022 20:15 #247498
Replied by andypugh on topic NativeCam raspberry Pi 4
Maybe, if the deb package does not contain any compiled code.Is it possible to install nativecam on a raspberry PI 4 with raspbian buster?
Time to create page: 0.234 seconds
