NativeCAM deb package for BUSTER, please
12 May 2020 03:18 - 12 May 2020 03:19 #167453
by Roguish
NativeCAM deb package for BUSTER, please was created by Roguish
Fern,
could you prepare a deb package for debian buster, please?
and at least master branch.
also, the install instructions need a bit of TLC.
Thanks.
Thanks.
Last edit: 12 May 2020 03:19 by Roguish.
12 Sep 2020 23:16 #181945
by pdxalz
Replied by pdxalz on topic NativeCAM deb package for BUSTER, please
I just installed NativeCAM on Buster using the Synaptics Manager.
After installing ncam -h worked.
I had tried using using the install instructions in this forum that use ncam_debsetup.txt listed in other messages in this forum, but it did not work. I was making it too difficult as usual.
20 Sep 2020 18:14 #182941
by russtuff
Replied by russtuff on topic NativeCAM deb package for BUSTER, please
It looks like Stretch is the latest release at: packagecloud.io/FernV/NativeCAM
I'm not an expert, but if Buster doesn't show up on that list (make sure to check it), you should be able to install it using these steps (they worked for me):
1. Open a terminal and run this:2. Then this:3. Now run:4. Open Applications > System > Synaptic Package Manager
5. Navigate to Settings > Repositories
6. Click on the one for packagecloud.io/FernV/NativeCAM/debian/
7. Change the name from buster to stretch in the Distribution field
8. Click OK (Reload when prompted)
9. Close Synaptic Package Manager (if you don't, you probably can't run the next command)
10. Back at your terminal, run this:11. Then this:12. You should see a prompt to create a new directory, and if Axis is open it will ask to restart it.
13. You should answer yes to both.
14. NativeCAM should open in a separate window.
sudo apt update -y
sudo apt upgrade -y
curl -s https://packagecloud.io/install/repositories/FernV/NativeCAM/script.deb.sh | sudo bash
sudo apt install nativecam
ncam
17 Nov 2020 22:45 #189631
by aleksamc
Replied by aleksamc on topic NativeCAM deb package for BUSTER, please
Thenks, for your help topic, russtuff.
I've loose few hours to unsuccesfully install nativecam, but with your help I made it in 2 minutes.
I want to add some clarification.
You need to repeat steps 1 and 2 after step 10.
The following user(s) said Thank You: itanc
Time to create page: 0.127 seconds
