Linuxcnc and NativeCAM, how install all correctly?
02 Sep 2023 17:43 #279669
by Taichi
Linuxcnc and NativeCAM, how install all correctly? was created by Taichi
Hello, please tell me which version of LinuxCNC is better to install so that NativeCAM works correctly? Yesterday I tried to install it on the latest version of linuxcnc. Although it installed and worked, I cannot attach it to the system. Only work in stand alone mode. Therefore, I want to download an older version of linuxcnc that worked correctly. The information on the forum about NativeCAM is not systematized, and there is no possibility to download an older version on the site at all.
Maybe there is a version of linuxcnc with the NativeCAM package already installed?
Thx for help
Thx for help
03 Sep 2023 07:13 #279698
Replied by Aciera on topic Linuxcnc and NativeCAM, how install all correctly?
NativeCAM is Python2 as far as I know so it can only be used up to linuxcnc version 2.8.x. I don't know of any ISO with NativeCam already installed.
I used to have NativeCam as a tab in gmoccapy and, if I remember correctly, I used these instructions:
github.com/FernV/NativeCAM
05 Sep 2023 12:42 #279959
by Taichi
Replied by Taichi on topic Linuxcnc and NativeCAM, how install all correctly?
Well, I tried reinstalling linuxcnc again. Now "sudo bash ncam_debsetup.txt" does not install the plugin. packagecloud.io only hosts a package for Debian 9, so it is not installed using this method.
Then I tried the hint on github
cannot replace files in the menu. The script executes with an error
I will also try to install Debian 9 and update Linuxcnc via apt-get
I will try and let you know if it worked for me
This method installed the plugin, but it always does not work correctly."The repository has not been updated for Debian Buster version
As a workaround one can do this:
Download package from packagecloud.io/FernV/NativeCAM/packages...all.deb/download.deb
Install manually: sudo dpkg -i nativecam_0.1.14b_all.deb
Install any missing dependencies: sudo apt --fix-broken install"
sudo ncam -i linuxcnc.ini -c mill
05 Sep 2023 12:49 #279962
I think I may have linked the wrong page, as I was actually trying to point you to the package install:
forum.linuxcnc.org/nativecam/39068-nativ...buster-please#182941
05 Sep 2023 13:00 #279964
by Taichi
I also tried this option before reinstalling linuxcnc. The error when executing the script was the same. This forced me to reinstall the system again
Time to create page: 0.155 seconds
