Daughterboard inputs not recognized in HALMETER
01 Nov 2017 20:25 #101153
Replied by andypugh on topic Daughterboard inputs not recognized in HALMETER
Yes, but surely with a 7i76 you will be using the dedicated step-dir outputs on the board anyway?
You don't get to define where those are, the firmware sets them up to match the 7i76.
01 Nov 2017 20:50 #101156
by Dubmfg
Replied by Dubmfg on topic Daughterboard inputs not recognized in HALMETER
Yeeeeees.... sorry Im a bit confused. So the erratic motion I'm seeing in my Z axis is a result of wiring then, not that pin 10 was being used already? I ask because I disabled the pin in the Z axis settings of my .hal, so you're saying theyre not related?
01 Nov 2017 21:02 #101157
The post
here
shows which pins are step/dir (though you don't need to know normally)
Look in the 7i76 manual to see which terminals on the board are step-dir. (if you want you can also see the mapping from 5i25 pins to 7i76 pins there. Or infer it at least, it isn't explicitly stated.
But, make sure that the HAL hasn't set any of those pins to "input" or "inverted" at the 5i25 level.
01 Nov 2017 23:28 #101166
by Dubmfg
Thanks Andy. Just having trouble with the limit switches not stopping the homing movement in X and Y now. Z works and homes the cycle just fine, X and Y home in the correct direction but do not stop when the switch is triggered :/. Ill keep messing around I guess, unless you have some insight.
02 Nov 2017 00:15 #101167
Sounds like maybe they are connected as limits, but not as homes.
Typically the switch output pin needs to be connected to three axis.N... pins (max lim, min lim, home)
02 Nov 2017 00:22 - 02 Nov 2017 00:25 #101169
by Dubmfg
With the limit settings below I get a funtional Z home, XY do not stop when switch triggered. The setting is the same for Z as it is for the others so it doesnt make sense to me. I redacted lines from both below to make it easier to view.
The home switches all should trip when the table reaches -Xlimit/home, -Ylimit/home, and +Zlimit/home
HAL BELOW
# home switches
# must noise debounce inputs - otherwise coolant on/off can cause estops
net home-limit-x-raw <= hm2_5i25.0.7i76.0.0.input-01-not => debounce.0.1.in
net home-limit-y-raw <= hm2_5i25.0.7i76.0.0.input-02-not => debounce.0.2.in
net home-limit-z-raw <= hm2_5i25.0.7i76.0.0.input-03-not => debounce.0.3.in
INI BELOW
[AXIS_0]
MIN_LIMIT = -0.000001
MAX_LIMIT = 16.65
HOME_OFFSET = -0.010
HOME_SEARCH_VEL = -0.750
HOME_LATCH_VEL = 0.050
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
[AXIS_1]
MAX_LIMIT = 8.65
HOME_SEQUENCE = 1
[AXIS_2]
MIN_LIMIT = -13
MAX_LIMIT = 0.000001
HOME_OFFSET = 0.010
HOME_SEARCH_VEL = 0.750
HOME_LATCH_VEL = -0.050
HOME_SEQUENCE = 0
HAL BELOW
# home switches
INI BELOW
[AXIS_0]
MAX_LIMIT = 16.65
HOME_SEQUENCE = 1
[AXIS_1]
MAX_LIMIT = 8.65
HOME_SEQUENCE = 1
[AXIS_2]
MIN_LIMIT = -13
HOME_OFFSET = 0.010
HOME_SEQUENCE = 0
Last edit: 02 Nov 2017 00:25 by Dubmfg.
02 Nov 2017 01:16 #101170
You need a lot more HAL. Where do the debounce.out pins go to?
02 Nov 2017 02:43 - 02 Nov 2017 03:32 #101175
by Dubmfg
The full HAL is a few posts back on this thread.
The debounce goes from:
#onwards to
net and-home-x debounce.0.1.out enable-limit-x.in1 door-limit-x-lut.in-0 door-limit-in.in1
net and-home-y debounce.0.2.out enable-limit-y.in1 door-limit-x-lut.in-1 door-limit-y-lut.in-0
net and-home-z debounce.0.3.out enable-limit-z.in1
Could the logic above that links the X and Y to the (nonexistant) door switches be causing issue?
The truth table:
# door/
# limit-sw-enable x-homing door-sw-configured - Y in - X in -- out axis.0.*-lim-sw-in -- lut5 weight
# 0 X X X X | 0
# 1 0 0 0 0 | 0
# 1 0 0 0 1 | 1 0x00020000
# 1 0 0 1 0 | 0
# 1 0 0 1 1 | 1 0x00080000
# 1 1 0 0 0 | 0
# 1 1 0 0 1 | 1 0x02000000
# 1 1 0 1 0 | 0
# 1 1 0 1 1 | 1 0x08000000
# 1 1 1 0 0 | 0
# 1 1 1 0 1 | 0
# 1 1 1 1 0 | 1 0x40000000
# 1 1 1 1 1 | 1 0x80000000
# 0xCA0A0000
setp door-limit-x-lut.function 0xCA0A0000
# connect X and Y to axis.0.*-lim-sw-in via lut5-based mux configured as above
net x-lim-out door-limit-x-lut.out axis.0.home-sw-in axis.0.neg-lim-sw-in axis.0.pos-lim-sw-in
# limit-sw-enable x-homing door-sw-configured - Y in -- out axis.1.*-lim-sw-in -- lut5 weight
# 0 X X X | 0
# 1 0 0 0 | 0
# 1 0 0 1 | 1 0x00000200
# 1 0 1 0 | 0
# 1 0 1 1 | 1 0x00000800
# 1 1 0 0 | 0
# 1 1 0 1 | 1 0x00002000
# 1 1 1 0 | 0
# 1 1 1 1 | 0
# 0x00002A00
setp door-limit-y-lut.function 0x00002A00
net y-lim-out door-limit-y-lut.out axis.1.home-sw-in axis.1.neg-lim-sw-in axis.1.pos-lim-sw-in
net x-is-homing axis.0.homing door-limit-x-lut.in-3 door-limit-y-lut.in-2
# door switch to spindle comp is former x-axis limit input ANDed with NOT door-sw-configured from UI
# if door-sw-configured is TRUE then the spindle comp input follows the X limit input
# if door-sw-configured is FALSE the the spindle comp input is always FALSE
# inverter NOT gate
net enc-door-switch-configured door-limit-x-lut.in-2 door-limit-y-lut.in-1 door-limit-in.in0 tormachspindle.enc-door-switch-configured
# connect X limit inputs to axis.2.*-sw-*
net z-lim-out enable-limit-z.out axis.2.home-sw-in axis.2.neg-lim-sw-in axis.2.pos-lim-sw-in
# UI can display this
net enc-door-switch-status door-limit-in.out tormachspindle.enc-door-switch-status
#onwards to
The truth table:
# door/
# 0 X X X X | 0
# 1 0 0 0 0 | 0
# 1 0 0 1 0 | 0
# 1 1 0 0 0 | 0
# 1 1 0 1 0 | 0
# 1 1 1 0 0 | 0
# 1 1 1 0 1 | 0
# 0xCA0A0000
# 0 X X X | 0
# 1 0 0 0 | 0
# 1 0 1 0 | 0
# 1 1 0 0 | 0
# 1 1 1 0 | 0
# 1 1 1 1 | 0
# 0x00002A00
# inverter NOT gate
Last edit: 02 Nov 2017 03:32 by Dubmfg.
02 Nov 2017 10:00 #101181
If you don't have a door then I would certainly remove all that door interlock logic.
But not before making a note of where all the door interlock logic goes to. You probably need to make sure that those inputs are satisfied by simpler routes.
Keep the debounce too, phantom limit triggers from electrical noise can be very annoying.
02 Nov 2017 18:00 #101200
by Dubmfg
So I've been playing with removal of the door logic, and I managed to make the Z axis which was working for homing not work. I'm comparing the files now to see what it could have been that broke it, hoping that its what is wrong with the X and Y axis. Not having much luck so far.
Moderators: cncbasher
Time to create page: 0.265 seconds
