DIY Arduino ATC Pathpilot....
09 Mar 2021 16:18 #201559 by Dorro1971
Hi all,
I have visited this site often and I have always taken without giving !
Well now it may be time for me to pay back
Here is a you tube link for my quick and dirty Pathpilot atc test.
The green led on the arduino simulates a drawbar solenoid and the red one stimulates an air last, the left hand stepper it the tray in-tray out and the carousel is obvious.
The code is not quite finished but it does work, so if there is enough interest I will post it when complete.
Please let me know what you think...
Cheers I.
The following user(s) said Thank You: Clive S, snowgoer540, Steve303
09 Mar 2021 17:43 #201571 by Clive S
Dorro1971 wrote The code is not quite finished but it does work, so if there is enough interest I will post it when complete.
Looking good, how are you connecting it to PP,
09 Mar 2021 18:05 #201577 by Dorro1971
USB same as the original,
there are no pathpilot modifications expect a rule in rules.d for the arduino device id....
09 Mar 2021 19:14 #201585 by belli
Replied by belli on topic DIY Arduino ATC Pathpilot....
Been waiting for this! The last part I need for a tool changer and I am too dum to figure it out on my own...
Please post code so that I can give it a whirl.
09 Mar 2021 19:25 #201586 by snowgoer540
I am definitely interested as well! This is great, good work!
10 Mar 2021 16:04 #201660 by Vmax549
I would also be interested.
(;-) TP
18 Mar 2021 00:56 #202688 by Vmax549
I have an Mega and opto isolation boards to go with it. Can it run on an Mega. I do have a complicated single arm ATC that I can test with.
(;-) TP
29 Mar 2021 14:56 #204047 by snowgoer540
Hi all,
Cheers I.
I was just thinking about this today, and thought I'd check to see how it's going. Any good progress?
02 Apr 2021 03:47 #204458 by tunnelmaynia
It would be amazing if you could share the code and your instructions. I already designed my atc but I have never learned the electronics end of machining. Also what hobbies had another $5k to throw down after they already had to buy the machine. If anything tormach should make it a learning exorsise for their customers and allow them to build their own atc and help them the programming side instead of writing the rules to block arduino. I was looking and saw rules in the etc/udev/rules.d/ that blacklisted arduino brands and certain USB serial adapters. Has anyone else noticed this? It's something like 77-usbdeviceblacklist in the rules.d folder. Again I'm not a code writer but to me I think it had an ignore command in it.
06 Apr 2021 13:11 #205103 by Vmax549
Has there been any progress on the ATC code ??? I have time to work on it here.
(;-) TP
Moderators: cncbasher
Time to create page: 0.233 seconds
