DIY Arduino ATC Pathpilot....
- snowgoer540
- Thank you received: 753
24 Jan 2022 12:15 - 24 Jan 2022 12:30 #232951
by snowgoer540
Replied by snowgoer540 on topic DIY Arduino ATC Pathpilot....
You need to put a rules file for the arduino in the rules folder. If you haven’t done that then it won’t recognize it.
somewhere out here there’s an example of how to do that for the usbio clones. I’m at work currently so I can’t be more helpful than that at the moment…
edit: I see the rules file was part of my post, perhaps the contexts of the rules file needs to change to match your specific arduino board…?
Last edit: 24 Jan 2022 12:30 by snowgoer540.
24 Jan 2022 15:06 #232970
by Vmax549
Replied by Vmax549 on topic DIY Arduino ATC Pathpilot....
I did add the new rules file and changed the IDs to match my device. The error message I get said that PP could not open the com port. I have looked but not really found any reference to which port it is trying to open yet ( Still looking through the code.
( TP
( TP
24 Jan 2022 22:38 #233022
by Vmax549
Here is the error I get when PP looks for teh Arduino.
2022-01-24 16:20:49.138303 CST (+0:00:04.008069) | ATC: i/o error Traceback (most recent call last):
File "python/hal_zbotatc.py", line 1018, in connect_to_device_thread
self.atc_s_cmd = serial.Serial("/dev/zbot_atc", baudrate=57600, timeout=0)
File "/usr/local/lib/python2.7/dist-packages/serial/serialutil.py", line 236, in __init__
self.open()
File "/usr/local/lib/python2.7/dist-packages/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
SerialException: [Errno 2] could not open port /dev/zbot_atc: [Errno 2] No such file or directory: '/dev/zbot_atc'
[python/hal_zbotatc.py:1255]
2022-01-24 16:20:49.145704 CST (+0:00:00.007401) | ATC: device not found [python/hal_zbotatc.py:1069]
2022-01-24 16:21:03.145798 CST (+0:00:14.673367) | Check ATC USB cabling, or fuses. Switching mill to manual toolchange. Repair problem. To re-enable, click ATC in Settings tab. [tormach_mill_ui.py:8194]
2022-01-24 16:21:03.154095 CST (+0:00:00.008297) | Tool change type changed to Manual [/home/operator/v2.8.3/python/ui_settings_mill.py:136]
self.open()
- snowgoer540
24 Jan 2022 22:48 #233025
by snowgoer540
Without trying to muddle through it at the machine, it's hard for me to say.
But perhaps there is something here that will help: xoomspeed.com/CNC/usbio/installation.htm
25 Jan 2022 00:06 #233027
by Vmax549
Tried that and get the same error. PP is looking for something it cannot find.
( TP
( TP
25 Jan 2022 00:07 #233028
by Vmax549
Remember this is a NON Tormach machine and it does NOT have the atc card and it appears to be looking for it but cannot find it.
( TP
( TP
- snowgoer540
25 Jan 2022 12:41 #233057
by snowgoer540
Oh, I'm not sure I knew that. Unfortunately, I'm not sure I can be much help in that case, hopefully someone who has gotten it to work chimes in.
25 Jan 2022 16:42 #233084
by Vmax549
Update minor progress. I worked on the rules a bit and got PP to ping the Arduino and the Arduino signals back but PP does not like what it says so it shuts the ATC mode back down. Not having any idea what PP is looking for when it pings the Arduino make it tuff to figure this out.
The Arduino is working as I can talk to it with the Arduino IDE serial monitor. I can ping it with VE and get the responce.info back.
So now to figure out what PP did not like when looking for the ATC.
( TP
( TP
25 Jan 2022 20:48 #233103
by Vmax549
Snow do you know IF any of teh pins on the Arduino need to be jumpered to emulate the ATC is ready to run. I see in the PP atc code IF anything is not reporting as correct then PP shuts down the ATC function all together. Things like PDB or VFD not responding. ONCE I get PP talking to the Arduino then I can figure out the rest maybe (. At this point I am not sure if it is a comm issue or a setup issue with hardware.
Perhaps you could check with your friend who wrote all the code. He seemed to make it work.
( TP
( TP
- snowgoer540
26 Jan 2022 01:48 #233138
by snowgoer540
I fired off an email, will report back if he replies
Moderators: cncbasher
Time to create page: 0.388 seconds
