Disabling keyboard arrows moving the machine.
- nick.smith
- Thank you received: 4
03 Jun 2023 13:18 #272818
by nick.smith
Disabling keyboard arrows moving the machine. was created by nick.smith
The arrow keys move the machine.
I want to disable this.
I know how you can remap keys with xmodmap, but if I change the behavior of the arrows, I also lose desirable behavior in other apps.
Importantly, I want to disable Up / Down arrows from moving in Y, but on the MDI line, I use up / down to scroll MDI history.
Does default LinuxCNC have this behavior?
Any ideas how to get rid of this "feature"?
Also, please note the question is how to remove this and not a discussion on why I want it removed. This is not a feature to me. It's a bug.
03 Jun 2023 18:17 #272826
by JPL
Replied by JPL on topic Disabling keyboard arrows moving the machine.
This should work: forum.linuxcnc.org/38-general-linuxcnc-q...gging?start=20#62231
Then to solve the issue about shift+arrow keys go down 3 posts and add the lines from dgarrett post
03 Jun 2023 18:23 #272827
by JPL
arghh ... Originally missed that... Not so sure that the solution I've proposed will work for that.... Importantly, I want to disable Up / Down arrows from moving in Y, but on the MDI line, I use up / down to scroll MDI history. ...
- nick.smith
03 Jun 2023 18:24 #272828
by nick.smith
Replied by nick.smith on topic Disabling keyboard arrows moving the machine.
I'll give it a shot and report back. There has to be a way to do it.
- nick.smith
03 Jun 2023 22:22 #272842
by nick.smith
I've updated
\tmc\configs\tormach_mill\tormach_1100M.ini
with the required line and made unbind.py
No change. Is that the correct .ini file?
04 Jun 2023 15:01 #272882
by gerritv
Replied by gerritv on topic Disabling keyboard arrows moving the machine.
At the top of that file you should see a warning that the file is replaced everytime that you run PP. Instead edit one of the .ini files listed at the top.
- nick.smith
04 Jun 2023 15:30 #272883
by nick.smith
I did both. And saw the entry was maintained after reboot. But still didn't disable the keys.
Moderators: cncbasher
Time to create page: 0.347 seconds
