Computer total freezes only during jogging
- jtc
- Thank you received: 13
08 Sep 2015 14:50 #62231
by jtc
Thanks!
it works when press this keys, but if I do a fast jog, with the "Shift"+"arrow" key the machine will respond, and it will not stop when released it
Tried to add "<KeyRelease-Shift>" and "<KeyPress-Shift>" in unbind.py file but without success (i didnt know if KeyPress-Shift and KeyRelease-Shift are the correct names)
how can it be solved?
João
Replied by jtc on topic Computer total freezes only during jogging
Edit the inifile to add this line to the [DISPLAY] stanza:
USER_COMMAND_FILE = unbind.py
Create a new file named unbind.py in the same directory as the
inifile with the following contents:root_window.tk.call("bind",".","<KeyPress-Left>","") # Left arrow root_window.tk.call("bind",".","<KeyPress-Right>","") # Right arrow root_window.tk.call("bind",".","<KeyPress-Up>","") # Up arrow root_window.tk.call("bind",".","<KeyPress-Down>","") # Down arrow root_window.tk.call("bind",".","<KeyPress-Prior>","") # PgUp root_window.tk.call("bind",".","<KeyPress-Next>","") # PgDn root_window.tk.call("bind",".","<KeyRelease-Left>","") # Left arrow root_window.tk.call("bind",".","<KeyRelease-Right>","") # Right arrow root_window.tk.call("bind",".","<KeyRelease-Up>","") # Up arrow root_window.tk.call("bind",".","<KeyRelease-Down>","") # Down arrow root_window.tk.call("bind",".","<KeyRelease-Prior>","") # PgUp root_window.tk.call("bind",".","<KeyRelease-Next>","") # PgDn
You can do this in a ~/.axisrc file as well (for each user); using [DISPLAY]USER_COMMAND_FILE applys to any use of the modified inifile
Thanks!
João
- Thank you received: 5015
08 Sep 2015 16:13 #62232
What exactly did you do? I tested it before posting it, and it worked for me.
Where did you put the .axisrc file, and what did you call the .axisrc file?
Replied by andypugh on topic Computer total freezes only during jogging
I tried to implement this way and it didn't work.
- jtc
08 Sep 2015 19:08 #62251
by jtc
Hi.
The .axisrc file was created on the home directory. I didn't call the .axisrc file, it was needed on the ini file? so probably it's the reason why it didin't work.
João
Hi.
João
- dgarrett
- Thank you received: 325
08 Sep 2015 19:26 #62254
by dgarrett
Replied by dgarrett on topic Computer total freezes only during jogging
try adding;Tried to add "<KeyRelease-Shift>" and "<KeyPress-Shift>" in unbind.py file but without success (i didnt know if KeyPress-Shift and KeyRelease-Shift are the correct names)
root_window.tk.call("bind",".","<Shift-Key-Left>","")
root_window.tk.call("bind",".","<Shift-Key-Right>","")
root_window.tk.call("bind",".","<Shift-Key-Up>","")
root_window.tk.call("bind",".","<Shift-Key-Down>","")
root_window.tk.call("bind",".","<Shift-Key-Prior>","")
root_window.tk.call("bind",".","<Shift-Key-Next>","")
08 Sep 2015 19:45 #62262
the .axisrc should be loaded automatically by the Axis GUI. There shouldn't be any need to call it from the INI.
Dewey is showing more advanced and flexible use-cases.
- jtc
08 Sep 2015 20:06 #62265
by jtc
It's now correctly working!
regarding the .axisrc, I still don't know why it didn't work. but I prefer this "new" method.
João
João
Time to create page: 0.126 seconds
