choice of controller for a plasma build
03 Feb 2022 21:00 #233911
by carlos515
choice of controller for a plasma build was created by carlos515
I am looking to switch from Mach4 to Linuxcnc for my plasma build. I was looking at the 7i92 with a 7i85s. I have a promo 150 thc. Would these cards work together with the 4 stepper drivers DM542 ? I have a 3 motor 1 slave setup.
I am just starting to learn abouth linux , so this is a big jump for me.
Thanks,
Carlos
Thanks,
Carlos
03 Feb 2022 22:43 #233920
Replied by rodw on topic choice of controller for a plasma build
Have a look at
7i92 and 7i76
7i76e which does above with one card
or 7i96
Your Proma will work with QTplasmac but for USD $69 you might like to also look at THCAD-10 when ordering your Mesa cards.
Even the Proma Diehards (like Tommylight) have long since converted to the THCAD .... Then Linuxcnc is the THC.
7i92 and 7i76
or 7i96
03 Feb 2022 23:16 #233926
by carlos515
Replied by carlos515 on topic choice of controller for a plasma build
Thanks, The 7i76e is all out of stock and they are having a hard time getting parts.That is why i am looking at alternatives.
I was also wondering about my ohmic set up. Would I be able to use my Robot3T ohmic sensor with the THCAD and Linuxcnc?
03 Feb 2022 23:36 #233927
Replied by PCW on topic choice of controller for a plasma build
A 7I76+7I92M is a pretty close substitute for a 7I76E
The following user(s) said Thank You: carlos515
05 Feb 2022 08:10 #234014
by carlos515
I lucked in and ended up with a 7i76e......Now the I have an Everlast 82i . If I interpret the specs , 80A/112v would this work out to 2.24v at 1/50 and 7v at 1/16 divider?
Would I be able to use a 0-5v board on the 1/16 divider setting?
05 Feb 2022 11:01 - 05 Feb 2022 11:02 #234017
For more info, refer to this thread I raised on plasma spider
plasmaspider.com/viewtopic.php?f=111&t=23700
From my experience with the everlast 50i, the resistors in the voltage divider get counted as belonging to the thcad so 16:1 is actually 24:1. This gives you 240 v full scale on a THCAD-10 which is so close to perfect.I lucked in and ended up with a 7i76e......Now the I have an Everlast 82i . If I interpret the specs , 80A/112v would this work out to 2.24v at 1/50 and 7v at 1/16 divider?
Last edit: 05 Feb 2022 11:02 by rodw.
05 Feb 2022 16:01 #234029
by carlos515
Thank You
Carlos
Carlos
05 Feb 2022 20:00 #234048
Iforgot to mention the Everlast cnc connector is made by Weipu. Try one of these.
www.aliexpress.com/item/32702181628.html
05 Feb 2022 20:38 #234052
by carlos515
Thanks, I have one already......I just ordered a THCAD-10. Had to order it from Germany. The shortage of electronics is getting scarry .
Carlos
Carlos
Time to create page: 0.144 seconds
